[U-Boot] [PATCH v2] Add NanoBone board support
NanoBone Specification: ----------------------- CPU: TI AM335x
Memory: 256MB DDR3 64MB NOR flash 256MB NAND flash 128KB FRAM
Ethernet: 2 x 10/100 connected to SMSC LAN8710 PHY
USB: 1 x USB2.0 Type A
I2C: 2Kbit EEPROM (Microchip 24AA02) RTC (Maxim DS1338) GPIO Expander (Microchip MCP23017)
Expansion connector: 6 x UART 1 x MMC/SD 1 x USB2.0
Signed-off-by: Mark Jackson mpfj@newflow.co.uk --- Changes in v2: - Tweaked after comments from Tom Rini
MAINTAINERS | 4 + board/newflow/nanobone/Makefile | 46 ++++++ board/newflow/nanobone/board.c | 304 +++++++++++++++++++++++++++++++++++++++ board/newflow/nanobone/board.h | 24 ++++ board/newflow/nanobone/mux.c | 203 ++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/nanobone.h | 285 ++++++++++++++++++++++++++++++++++++ 7 files changed, 867 insertions(+) create mode 100644 board/newflow/nanobone/Makefile create mode 100644 board/newflow/nanobone/board.c create mode 100644 board/newflow/nanobone/board.h create mode 100644 board/newflow/nanobone/mux.c create mode 100644 include/configs/nanobone.h
diff --git a/MAINTAINERS b/MAINTAINERS index bbab5fe..3724e21 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -711,6 +711,10 @@ Ilko Iliev iliev@ronetix.at PM9263 AT91SAM9263 PM9G45 ARM926EJS (AT91SAM9G45 SoC) +Mark Jackson mpfj@newflow.co.uk + + NANOBONE ARM ARMV7 (AM33xx Soc) + Michael Jones michael.jones@matrix-vision.de omap3_mvblx ARM ARMV7 (OMAP3xx SoC) diff --git a/board/newflow/nanobone/Makefile b/board/newflow/nanobone/Makefile new file mode 100644 index 0000000..67a87a1 --- /dev/null +++ b/board/newflow/nanobone/Makefile @@ -0,0 +1,46 @@ +# +# Makefile +# +# Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/ +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed "as is" WITHOUT ANY WARRANTY of any +# kind, whether express or implied; without even the implied warranty +# of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +ifdef CONFIG_SPL_BUILD +COBJS := mux.o +endif + +COBJS += board.o +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/newflow/nanobone/board.c b/board/newflow/nanobone/board.c new file mode 100644 index 0000000..d0af256 --- /dev/null +++ b/board/newflow/nanobone/board.c @@ -0,0 +1,304 @@ +/* + * board.c + * + * Board functions for Newflow NanoBone board + * + * Copyright (C) 2013, Newflow Ltd - http://www.newflow.co.uk/ + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR /PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <errno.h> +#include <asm/arch/clock.h> +#include <asm/arch/cpu.h> +#include <asm/arch/ddr_defs.h> +#include <asm/arch/gpio.h> +#include <asm/arch/hardware.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/mem.h> +#include <asm/arch/mmc_host_def.h> +#include <asm/arch/omap.h> +#include <asm/emif.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <cpsw.h> +#include <i2c.h> +#include <miiphy.h> +#include <spl.h> +#include "board.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* FRAM config */ +#define FRAM_CS 1 +#define FRAM_BASE 0x1c000000 +#define FRAM_SIZE GPMC_SIZE_16M +static u32 gpmc_fram_config[GPMC_MAX_REG] = { + 0x00001200, + 0x00101000, + 0x00020201, + 0x0f030f03, + 0x010d1010, + 0x000301c0, + 0 +}; + +/* NOR Flash config */ +#define NOR_CS 3 +#define NOR_BASE 0x18000000 +#define NOR_SIZE GPMC_SIZE_64M +static u32 gpmc_nor_config[GPMC_MAX_REG] = { + 0x00001200, + 0x00101004, + 0x00020201, + 0x10041004, + 0x010f1010, + 0x000601c0, + 0 +}; + +static struct wd_timer *wdtimer = (struct wd_timer *)WDT_BASE; +#ifdef CONFIG_SPL_BUILD +static struct uart_sys *uart_base = (struct uart_sys *)DEFAULT_UART_BASE; +#endif + +/* MII mode defines */ +#define PORT1_MII_MODE_ENABLE 0x0 +#define PORT2_MII_MODE_ENABLE 0x0 + +static struct ctrl_dev *cdev = (struct ctrl_dev *)CTRL_DEVICE_BASE; + +/* UART Defines */ +#ifdef CONFIG_SPL_BUILD +#define UART_RESET (0x1 << 1) +#define UART_CLK_RUNNING_MASK 0x1 +#define UART_SMART_IDLE_EN (0x1 << 0x3) + +static void rtc32k_enable(void) +{ + struct rtc_regs *rtc = (struct rtc_regs *)RTC_BASE; + + /* + * Unlock the RTC's registers. For more details please see the + * RTC_SS section of the TRM. In order to unlock we need to + * write these specific values (keys) in this order. + */ + writel(0x83e70b13, &rtc->kick0r); + writel(0x95a4f1e0, &rtc->kick1r); + + /* Enable the RTC 32K OSC by setting bits 3 and 6. */ + writel((1 << 3) | (1 << 6), &rtc->osc); +} + +static const struct ddr_data ddr3_data = { + .datardsratio0 = MT41J128MJT125_RD_DQS, + .datawdsratio0 = MT41J128MJT125_WR_DQS, + .datafwsratio0 = MT41J128MJT125_PHY_FIFO_WE, + .datawrsratio0 = MT41J128MJT125_PHY_WR_DATA, + .datadldiff0 = PHY_DLL_LOCK_DIFF, +}; + +static const struct cmd_control ddr3_cmd_ctrl_data = { + .cmd0csratio = MT41J128MJT125_RATIO, + .cmd0dldiff = MT41J128MJT125_DLL_LOCK_DIFF, + .cmd0iclkout = MT41J128MJT125_INVERT_CLKOUT, + + .cmd1csratio = MT41J128MJT125_RATIO, + .cmd1dldiff = MT41J128MJT125_DLL_LOCK_DIFF, + .cmd1iclkout = MT41J128MJT125_INVERT_CLKOUT, + + .cmd2csratio = MT41J128MJT125_RATIO, + .cmd2dldiff = MT41J128MJT125_DLL_LOCK_DIFF, + .cmd2iclkout = MT41J128MJT125_INVERT_CLKOUT, +}; + +static struct emif_regs ddr3_emif_reg_data = { + .sdram_config = MT41J128MJT125_EMIF_SDCFG, + .ref_ctrl = MT41J128MJT125_EMIF_SDREF, + .sdram_tim1 = MT41J128MJT125_EMIF_TIM1, + .sdram_tim2 = MT41J128MJT125_EMIF_TIM2, + .sdram_tim3 = MT41J128MJT125_EMIF_TIM3, + .zq_config = MT41J128MJT125_ZQ_CFG, + .emif_ddr_phy_ctlr_1 = MT41J128MJT125_EMIF_READ_LATENCY | + PHY_EN_DYN_PWRDN, +}; +#endif /* CONFIG_SPL_BUILD */ + +/* + * early system init of muxing and clocks. + */ +void s_init(void) +{ + /* WDT1 is already running when the bootloader gets control + * Disable it to avoid "random" resets + */ + writel(0xAAAA, &wdtimer->wdtwspr); + while (readl(&wdtimer->wdtwwps) != 0x0) + ; + writel(0x5555, &wdtimer->wdtwspr); + while (readl(&wdtimer->wdtwwps) != 0x0) + ; + +#ifdef CONFIG_SPL_BUILD + /* Setup the PLLs and the clocks for the peripherals */ + pll_init(); + + /* Enable RTC32K clock */ + rtc32k_enable(); + + /* UART softreset */ + u32 regVal; + regVal = readl(&uart_base->uartsyscfg); + regVal |= UART_RESET; + writel(regVal, &uart_base->uartsyscfg); + while ((readl(&uart_base->uartsyssts) & + UART_CLK_RUNNING_MASK) != UART_CLK_RUNNING_MASK) + ; + + /* Disable smart idle */ + regVal = readl(&uart_base->uartsyscfg); + regVal |= UART_SMART_IDLE_EN; + writel(regVal, &uart_base->uartsyscfg); + + config_ddr(303, MT41J128MJT125_IOCTRL_VALUE, &ddr3_data, + &ddr3_cmd_ctrl_data, &ddr3_emif_reg_data, 0); + + gd = &gdata; + + enable_board_pin_mux(); + + preloader_console_init(); + + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); +#endif /* CONFIG_SPL_BUILD */ +} + +/* + * Basic board specific setup. Pinmux has been handled already. + */ +int board_init(void) +{ + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); + + gd->bd->bi_boot_params = PHYS_DRAM_1 + 0x100; + + gpmc_init(); + + /* enable FRAM chip select */ + enable_gpmc_cs_config(gpmc_fram_config, &gpmc_cfg->cs[FRAM_CS], + FRAM_BASE, FRAM_SIZE); + /* enable NOR flash chip select */ + enable_gpmc_cs_config(gpmc_nor_config, &gpmc_cfg->cs[NOR_CS], + NOR_BASE, NOR_SIZE); + + return 0; +} + +int board_late_init(void) +{ + setenv("board_name", "nanobone"); + setenv("board_rev", "0001"); + + /* we always use BCH8 ECC mode */ + omap_nand_switch_ecc(1, 8); + + return 0; +} + +static void cpsw_control(int enabled) +{ + /* VTP can be added here */ + + return; +} + +static struct cpsw_slave_data cpsw_slaves[] = { + { + .slave_reg_ofs = 0x208, + .sliver_reg_ofs = 0xd80, + .phy_id = 0, + .phy_if = PHY_INTERFACE_MODE_MII, + }, + { + .slave_reg_ofs = 0x308, + .sliver_reg_ofs = 0xdc0, + .phy_id = 1, + .phy_if = PHY_INTERFACE_MODE_MII, + }, +}; + +static struct cpsw_platform_data cpsw_data = { + .mdio_base = CPSW_MDIO_BASE, + .cpsw_base = CPSW_BASE, + .mdio_div = 0xff, + .channels = 8, + .cpdma_reg_ofs = 0x800, + .slaves = 2, + .slave_data = cpsw_slaves, + .ale_reg_ofs = 0xd00, + .ale_entries = 1024, + .host_port_reg_ofs = 0x108, + .hw_stats_reg_ofs = 0x900, + .mac_control = (1 << 5), + .control = cpsw_control, + .host_port_num = 0, + .version = CPSW_CTRL_VERSION_2, +}; + +int board_eth_init(bd_t *bis) +{ + int rv, n = 0; + uint8_t mac_addr[6]; + uint32_t mac_hi, mac_lo; + + if (!getenv("ethaddr")) { + printf("<ethaddr> not set. Reading from E-fuse\n"); + /* try reading mac address from efuse */ + mac_lo = readl(&cdev->macid0l); + mac_hi = readl(&cdev->macid0h); + mac_addr[0] = mac_hi & 0xff; + mac_addr[1] = (mac_hi & 0xff00) >> 8; + mac_addr[2] = (mac_hi & 0xff0000) >> 16; + mac_addr[3] = (mac_hi & 0xff000000) >> 24; + mac_addr[4] = mac_lo & 0xff; + mac_addr[5] = (mac_lo & 0xff00) >> 8; + + if (is_valid_ether_addr(mac_addr)) + eth_setenv_enetaddr("ethaddr", mac_addr); + } + + if (!getenv("eth1addr")) { + printf("<eth1addr> not set. Reading from E-fuse\n"); + /* try reading mac address from efuse */ + mac_lo = readl(&cdev->macid1l); + mac_hi = readl(&cdev->macid1h); + mac_addr[0] = mac_hi & 0xff; + mac_addr[1] = (mac_hi & 0xff00) >> 8; + mac_addr[2] = (mac_hi & 0xff0000) >> 16; + mac_addr[3] = (mac_hi & 0xff000000) >> 24; + mac_addr[4] = mac_lo & 0xff; + mac_addr[5] = (mac_lo & 0xff00) >> 8; + + if (is_valid_ether_addr(mac_addr)) + eth_setenv_enetaddr("eth1addr", mac_addr); + } + + writel(PORT1_MII_MODE_ENABLE | PORT2_MII_MODE_ENABLE, &cdev->miisel); + + rv = cpsw_register(&cpsw_data); + if (rv < 0) + printf("Error %d registering CPSW switch\n", rv); + else + n += rv; + + return n; +} diff --git a/board/newflow/nanobone/board.h b/board/newflow/nanobone/board.h new file mode 100644 index 0000000..9f5075b --- /dev/null +++ b/board/newflow/nanobone/board.h @@ -0,0 +1,24 @@ +/* + * board.h + * + * TI AM335x boards information header + * + * Copyright (C) 2011, Texas Instruments, Incorporated - http://www.ti.com/ + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR /PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef _BOARD_H_ +#define _BOARD_H_ + +void enable_board_pin_mux(void); + +#endif diff --git a/board/newflow/nanobone/mux.c b/board/newflow/nanobone/mux.c new file mode 100644 index 0000000..bf9c999 --- /dev/null +++ b/board/newflow/nanobone/mux.c @@ -0,0 +1,203 @@ +/* + * mux.c + * + * Copyright (C) 2013, Newflow Ltd - http://www.newflow.co.uk/ + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation version 2. + * + * This program is distributed "as is" WITHOUT ANY WARRANTY of any + * kind, whether express or implied; without even the implied warranty + * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/hardware.h> +#include <asm/arch/mux.h> +#include <asm/io.h> +#include <i2c.h> +#include "board.h" + +static struct module_pin_mux gpmc_pin_mux[] = { + {OFFSET(gpmc_ad0), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD0 */ + {OFFSET(gpmc_ad1), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD1 */ + {OFFSET(gpmc_ad2), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD2 */ + {OFFSET(gpmc_ad3), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD3 */ + {OFFSET(gpmc_ad4), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD4 */ + {OFFSET(gpmc_ad5), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD5 */ + {OFFSET(gpmc_ad6), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD6 */ + {OFFSET(gpmc_ad7), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD7 */ + {OFFSET(gpmc_ad8), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD8 */ + {OFFSET(gpmc_ad9), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD9 */ + {OFFSET(gpmc_ad10), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD10 */ + {OFFSET(gpmc_ad11), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD11 */ + {OFFSET(gpmc_ad12), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD12 */ + {OFFSET(gpmc_ad13), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD13 */ + {OFFSET(gpmc_ad14), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD14 */ + {OFFSET(gpmc_ad15), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* GPMC AD15 */ + {OFFSET(gpmc_csn0), (MODE(0) | PULLUDEN)}, /* GPMC_CSN0 */ + {OFFSET(gpmc_csn1), (MODE(0) | PULLUDEN)}, /* GPMC_CSN1 */ + {OFFSET(gpmc_csn2), (MODE(0) | PULLUDEN)}, /* GPMC_CSN2 */ + {OFFSET(gpmc_csn3), (MODE(0) | PULLUDEN)}, /* GPMC_CSN3 */ + {OFFSET(gpmc_advn_ale), (MODE(0) | PULLUDEN)}, /* GPMC_ADV_ALE */ + {OFFSET(gpmc_oen_ren), (MODE(0) | PULLUDEN)}, /* GPMC_OE */ + {OFFSET(gpmc_wen), (MODE(0) | PULLUDEN)}, /* GPMC_WEN */ + {OFFSET(gpmc_be0n_cle), (MODE(0) | PULLUDEN)}, /* GPMC_BE_CLE */ + {OFFSET(gpmc_wait0), (MODE(0) | RXACTIVE)}, /* NAND WAIT */ + {OFFSET(lcd_data1), (MODE(1) | PULLUDDIS)}, /* GPMC A17 */ + {OFFSET(lcd_data2), (MODE(1) | PULLUDDIS)}, /* GPMC A18 */ + {OFFSET(lcd_data3), (MODE(1) | PULLUDDIS)}, /* GPMC A19 */ + {OFFSET(lcd_data4), (MODE(1) | PULLUDDIS)}, /* GPMC A20 */ + {OFFSET(lcd_data5), (MODE(1) | PULLUDDIS)}, /* GPMC A21 */ + {OFFSET(lcd_data6), (MODE(1) | PULLUDDIS)}, /* GPMC A22 */ + {OFFSET(lcd_data7), (MODE(1) | PULLUDDIS)}, /* GPMC A23 */ + {OFFSET(lcd_data8), (MODE(1) | PULLUDDIS)}, /* GPMC A24 */ + {OFFSET(lcd_data9), (MODE(1) | PULLUDDIS)}, /* GPMC A25 */ + {OFFSET(lcd_data10), (MODE(1) | PULLUDDIS)}, /* GPMC A26 */ + {-1}, +}; + +static struct module_pin_mux i2c0_pin_mux[] = { + {OFFSET(i2c0_sda), (MODE(0) | RXACTIVE | + PULLUDEN | SLEWCTRL)}, /* I2C_DATA */ + {OFFSET(i2c0_scl), (MODE(0) | RXACTIVE | + PULLUDEN | SLEWCTRL)}, /* I2C_SCLK */ + {-1}, +}; + +static struct module_pin_mux mii1_pin_mux[] = { + {OFFSET(mii1_col), MODE(0) | RXACTIVE}, /* MII1_COL */ + {OFFSET(mii1_crs), MODE(0) | RXACTIVE}, /* MII1_CRS */ + {OFFSET(mii1_rxerr), MODE(0) | RXACTIVE}, /* MII1_RXERR */ + {OFFSET(mii1_txen), MODE(0)}, /* MII1_TXEN */ + {OFFSET(mii1_rxdv), MODE(0) | RXACTIVE}, /* MII1_RXDV */ + {OFFSET(mii1_txd3), MODE(0)}, /* MII1_TXD3 */ + {OFFSET(mii1_txd2), MODE(0)}, /* MII1_TXD2 */ + {OFFSET(mii1_txd1), MODE(0)}, /* MII1_TXD1 */ + {OFFSET(mii1_txd0), MODE(0)}, /* MII1_TXD0 */ + {OFFSET(mii1_txclk), MODE(0) | RXACTIVE}, /* MII1_TXCLK */ + {OFFSET(mii1_rxclk), MODE(0) | RXACTIVE}, /* MII1_RXCLK */ + {OFFSET(mii1_rxd3), MODE(0) | RXACTIVE}, /* MII1_RXD3 */ + {OFFSET(mii1_rxd2), MODE(0) | RXACTIVE}, /* MII1_RXD2 */ + {OFFSET(mii1_rxd1), MODE(0) | RXACTIVE}, /* MII1_RXD1 */ + {OFFSET(mii1_rxd0), MODE(0) | RXACTIVE}, /* MII1_RXD0 */ + {OFFSET(mdio_data), MODE(0) | RXACTIVE | PULLUP_EN}, /* MDIO_DATA */ + {OFFSET(mdio_clk), MODE(0) | PULLUP_EN}, /* MDIO_CLK */ + {-1}, +}; + +static struct module_pin_mux mii2_pin_mux[] = { + {OFFSET(gpmc_a0), MODE(1)}, /* MII2_TXEN */ + {OFFSET(gpmc_a1), MODE(1) | RXACTIVE}, /* MII2_RXDV */ + {OFFSET(gpmc_a2), MODE(1)}, /* MII2_TXD3 */ + {OFFSET(gpmc_a3), MODE(1)}, /* MII2_TXD2 */ + {OFFSET(gpmc_a4), MODE(1)}, /* MII2_TXD1 */ + {OFFSET(gpmc_a5), MODE(1)}, /* MII2_TXD0 */ + {OFFSET(gpmc_a6), MODE(1) | RXACTIVE}, /* MII2_TXCLK */ + {OFFSET(gpmc_a7), MODE(1) | RXACTIVE}, /* MII2_RXCLK */ + {OFFSET(gpmc_a8), MODE(1) | RXACTIVE}, /* MII2_RXD3 */ + {OFFSET(gpmc_a9), MODE(1) | RXACTIVE}, /* MII2_RXD2 */ + {OFFSET(gpmc_a10), MODE(1) | RXACTIVE}, /* MII2_RXD1 */ + {OFFSET(gpmc_a11), MODE(1) | RXACTIVE}, /* MII2_RXD0 */ + {OFFSET(gpmc_wpn), MODE(1) | RXACTIVE}, /* MII2_RXERR */ + {OFFSET(gpmc_be1n), MODE(1) | RXACTIVE}, /* MII2_COL */ + {OFFSET(mdio_data), MODE(0) | RXACTIVE | PULLUP_EN}, /* MDIO_DATA */ + {OFFSET(mdio_clk), MODE(0) | PULLUP_EN}, /* MDIO_CLK */ + {-1}, +}; + +static struct module_pin_mux mmc0_no_cd_pin_mux[] = { + {OFFSET(mmc0_dat3), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT3 */ + {OFFSET(mmc0_dat2), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT2 */ + {OFFSET(mmc0_dat1), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT1 */ + {OFFSET(mmc0_dat0), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT0 */ + {OFFSET(mmc0_clk), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_CLK */ + {OFFSET(mmc0_cmd), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_CMD */ + {OFFSET(mcasp0_aclkr), (MODE(4) | RXACTIVE)}, /* MMC0_WP */ + {OFFSET(emu1), (MODE(7) | RXACTIVE)}, /* MMC0_CD */ + {-1}, +}; + +static struct module_pin_mux uart0_pin_mux[] = { + {OFFSET(uart0_rxd), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* UART0_RXD */ + {OFFSET(uart0_txd), (MODE(0) | PULLUDEN)}, /* UART0_TXD */ + {-1}, +}; + +static struct module_pin_mux uart1_pin_mux[] = { + {OFFSET(uart1_ctsn), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* UART1_CTSN */ + {OFFSET(uart1_rtsn), (MODE(0) | PULLUDEN)}, /* UART1_RTSN */ + {OFFSET(uart1_rxd), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* UART1_RXD */ + {OFFSET(uart1_txd), (MODE(0) | PULLUDEN)}, /* UART1_TXD */ + {-1}, +}; + +static struct module_pin_mux uart2_pin_mux[] = { + {OFFSET(lcd_data8), (MODE(6) | PULLUP_EN | RXACTIVE)}, /* UART2_CTSN */ + {OFFSET(lcd_data9), (MODE(6) | PULLUDEN)}, /* UART2_RTSN */ + {OFFSET(spi0_sclk), (MODE(1) | PULLUP_EN | RXACTIVE)}, /* UART2_RXD */ + {OFFSET(spi0_d0), (MODE(1) | PULLUDEN)}, /* UART2_TXD */ + {-1}, +}; + +static struct module_pin_mux uart3_pin_mux[] = { + {OFFSET(lcd_data10), (MODE(6) | PULLUP_EN | RXACTIVE)}, /* UART3_CTSN */ + {OFFSET(lcd_data11), (MODE(6) | PULLUDEN)}, /* UART3_RTSN */ + {OFFSET(spi0_cs1), (MODE(1) | PULLUP_EN | RXACTIVE)}, /* UART3_RXD */ + {OFFSET(ecap0_in_pwm0_out), (MODE(1) | PULLUDEN)}, /* UART3_TXD */ + {-1}, +}; + +static struct module_pin_mux uart4_pin_mux[] = { + {OFFSET(lcd_data12), (MODE(6) | PULLUP_EN | RXACTIVE)}, /* UART4_CTSN */ + {OFFSET(lcd_data13), (MODE(6) | PULLUDEN)}, /* UART4_RTSN */ + {OFFSET(uart0_ctsn), (MODE(1) | PULLUP_EN | RXACTIVE)}, /* UART4_RXD */ + {OFFSET(uart0_rtsn), (MODE(1) | PULLUDEN)}, /* UART4_TXD */ + {-1}, +}; + +static struct module_pin_mux uart5_pin_mux[] = { + {OFFSET(lcd_data14), (MODE(4) | PULLUP_EN | RXACTIVE)}, /* UART5_RXD */ + {OFFSET(rmii1_refclk), (MODE(3) | PULLUDEN)}, /* UART5_TXD */ + {-1}, +}; + +static struct module_pin_mux usb0_pin_mux[] = { + {OFFSET(usb0_dm), (MODE(0) | RXACTIVE)}, /* USB0_DM */ + {OFFSET(usb0_dp), (MODE(0) | RXACTIVE)}, /* USB0_DP */ + {OFFSET(usb0_ce), (MODE(0) | RXACTIVE)}, /* USB0_CE */ + {OFFSET(usb0_id), (MODE(0) | RXACTIVE)}, /* USB0_ID */ + {OFFSET(usb0_vbus), (MODE(0) | RXACTIVE)}, /* USB0_VBUS */ + {OFFSET(usb0_drvvbus), (MODE(0) | PULLUDEN)}, /* USB0_DRVVBUS */ + {-1}, +}; + +static struct module_pin_mux usb1_pin_mux[] = { + {OFFSET(usb1_dm), (MODE(0) | RXACTIVE)}, /* USB1_DM */ + {OFFSET(usb1_dp), (MODE(0) | RXACTIVE)}, /* USB1_DP */ + {OFFSET(usb1_ce), (MODE(0) | RXACTIVE)}, /* USB1_CE */ + {OFFSET(usb1_id), (MODE(0) | RXACTIVE)}, /* USB1_ID */ + {OFFSET(usb1_vbus), (MODE(0) | RXACTIVE)}, /* USB1_VBUS */ + {OFFSET(usb1_drvvbus), (MODE(0) | PULLUDEN)}, /* USB1_DRVVBUS */ + {-1}, +}; + +void enable_board_pin_mux() +{ + configure_module_pin_mux(gpmc_pin_mux); + configure_module_pin_mux(i2c0_pin_mux); + configure_module_pin_mux(mii1_pin_mux); + configure_module_pin_mux(mii2_pin_mux); + configure_module_pin_mux(mmc0_no_cd_pin_mux); + configure_module_pin_mux(uart0_pin_mux); + configure_module_pin_mux(uart1_pin_mux); + configure_module_pin_mux(uart2_pin_mux); + configure_module_pin_mux(uart3_pin_mux); + configure_module_pin_mux(uart4_pin_mux); + configure_module_pin_mux(uart5_pin_mux); + configure_module_pin_mux(usb0_pin_mux); + configure_module_pin_mux(usb1_pin_mux); +} diff --git a/boards.cfg b/boards.cfg index f785da8..34de63b 100644 --- a/boards.cfg +++ b/boards.cfg @@ -243,6 +243,7 @@ am335x_evm_uart3 arm armv7 am335x ti am335x_evm_uart4 arm armv7 am335x ti am33xx am335x_evm:SERIAL5,CONS_INDEX=5 am335x_evm_uart5 arm armv7 am335x ti am33xx am335x_evm:SERIAL6,CONS_INDEX=6 am335x_evm_usbspl arm armv7 am335x ti am33xx am335x_evm:SERIAL1,CONS_INDEX=1,SPL_USBETH_SUPPORT +nanobone arm armv7 nanobone newflow am33xx ti814x_evm arm armv7 ti814x ti am33xx pcm051 arm armv7 pcm051 phytec am33xx pcm051 highbank arm armv7 highbank - highbank diff --git a/include/configs/nanobone.h b/include/configs/nanobone.h new file mode 100644 index 0000000..80e28bb --- /dev/null +++ b/include/configs/nanobone.h @@ -0,0 +1,285 @@ +/* + * nanobone.h + * + * Copyright (C) 2013 Newflow Ltd - http://www.newflow.co.uk/ + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation version 2. + * + * This program is distributed "as is" WITHOUT ANY WARRANTY of any + * kind, whether express or implied; without even the implied warranty + * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef __CONFIG_NANOBONE_H +#define __CONFIG_NANOBONE_H + +#define CONFIG_AM33XX + +#include <asm/arch/omap.h> + +#define CONFIG_DMA_COHERENT +#define CONFIG_DMA_COHERENT_SIZE (1 << 20) + +#define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ +#define CONFIG_SYS_MALLOC_LEN (1024 << 10) +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT "U-Boot# " +#define CONFIG_BOARD_LATE_INIT +#define MACH_TYPE_NANOBONE 4483 +#define CONFIG_MACH_TYPE MACH_TYPE_NANOBONE + +/* + * We do have NOR on the board but it doesn't contain any "user + * accessible" data. We use it as long-term storage using a + * custom layout, so there's no point in exposing it to uboot. + */ +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_OF_LIBFDT +#define CONFIG_CMD_BOOTZ +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG + +/* commands to include */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_VERSION_VARIABLE + +/* set to negative value for no autoboot */ +#define CONFIG_BOOTDELAY 0 +#define CONFIG_ZERO_BOOTDELAY_CHECK +#define CONFIG_ENV_VARS_UBOOT_CONFIG +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG +#ifndef CONFIG_SPL_BUILD +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=0x80200000\0" \ + "fdtaddr=0x80f80000\0" \ + "fdt_high=0xffffffff\0" \ + "console=ttyO0,115200n8\0" \ + +#endif /* CONFIG_SPL_BUILD */ + +#define CONFIG_BOOTCOMMAND "mtdparts default; " \ + "nand read $loadaddr kernel; bootm" +#define CONFIG_BOOTARGS "console=ttyO0,115200n8 noinitrd ip=off " \ + "mem=256M rootwait=1 ubi.mtd=7,2048 " \ + "rootfstype=ubifs root=ubi0:rootfs" + +/* Clock Defines */ +#define V_OSCK 26000000 /* Clock output from T2 */ +#define V_SCLK (V_OSCK) +#define CONFIG_SYS_MPUCLK 720 + +#define CONFIG_CMD_ECHO + +/* max number of command args */ +#define CONFIG_SYS_MAXARGS 16 + +/* Console I/O Buffer Size */ +#define CONFIG_SYS_CBSIZE 512 + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE \ + + sizeof(CONFIG_SYS_PROMPT) + 16) + +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#undef CONFIG_CMD_MEMTEST + +#define CONFIG_SYS_LOAD_ADDR 0x81000000 /* Default load address */ + +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_OMAP_HSMMC +#define CONFIG_CMD_MMC +#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_EXT4 +#define CONFIG_CMD_FS_GENERIC + + /* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ +#define PHYS_DRAM_1 0x80000000 /* DRAM Bank #1 */ +#define CONFIG_MAX_RAM_BANK_SIZE (1024 << 20) /* 1GB */ + +#define CONFIG_SYS_SDRAM_BASE PHYS_DRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (NON_SECURE_SRAM_END - \ + GENERATED_GBL_DATA_SIZE) + /* Platform/Board specific defs */ +#define CONFIG_SYS_TIMERBASE 0x48040000 /* Use Timer2 */ +#define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ +#define CONFIG_SYS_HZ 1000 /* 1ms clock */ + +/* NS16550 Configuration */ +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK (48000000) +#define CONFIG_SYS_NS16550_COM1 0x44e09000 /* UART0 */ +#define CONFIG_SYS_NS16550_COM2 0x48022000 /* UART1 */ +#define CONFIG_SYS_NS16550_COM3 0x48024000 /* UART2 */ +#define CONFIG_SYS_NS16550_COM4 0x481a6000 /* UART3 */ +#define CONFIG_SYS_NS16550_COM5 0x481a8000 /* UART4 */ +#define CONFIG_SYS_NS16550_COM6 0x481aa000 /* UART5 */ +#define CONFIG_CONS_INDEX 1 + +/* I2C Configuration */ +#define CONFIG_I2C +#define CONFIG_CMD_I2C +#define CONFIG_HARD_I2C +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 1 +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_DRIVER_OMAP24XX_I2C +#define CONFIG_CMD_EEPROM +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* Main EEPROM */ +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 +#define CONFIG_SYS_I2C_MULTI_EEPROMS + +#define CONFIG_OMAP_GPIO + +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_SYS_CONSOLE_INFO_QUIET + +/* Defines for SPL */ +#define CONFIG_SPL +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_TEXT_BASE 0x402F0400 +#define CONFIG_SPL_MAX_SIZE (101 * 1024) +#define CONFIG_SPL_STACK CONFIG_SYS_INIT_SP_ADDR + +#define CONFIG_SPL_BSS_START_ADDR 0x80000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ + +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /* address 0x60000 */ +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x200 /* 256 KB */ +#define CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION 1 +#define CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME "u-boot.img" +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SPL_FAT_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT + +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBDISK_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_GPIO_SUPPORT +#define CONFIG_SPL_YMODEM_SUPPORT +#define CONFIG_SPL_NET_SUPPORT +#define CONFIG_SPL_NET_VCI_STRING "AM335x U-Boot SPL" +#define CONFIG_SPL_ETH_SUPPORT +#define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/omap-common/u-boot-spl.lds" + +#define CONFIG_SPL_BOARD_INIT +#define CONFIG_SPL_NAND_AM33XX_BCH +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_NAND_BASE +#define CONFIG_SPL_NAND_DRIVERS +#define CONFIG_SPL_NAND_ECC +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ + CONFIG_SYS_NAND_PAGE_SIZE) +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) +#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS +#define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ + 10, 11, 12, 13, 14, 15, 16, 17, \ + 18, 19, 20, 21, 22, 23, 24, 25, \ + 26, 27, 28, 29, 30, 31, 32, 33, \ + 34, 35, 36, 37, 38, 39, 40, 41, \ + 42, 43, 44, 45, 46, 47, 48, 49, \ + 50, 51, 52, 53, 54, 55, 56, 57, } + +#define CONFIG_SYS_NAND_ECCSIZE 512 +#define CONFIG_SYS_NAND_ECCBYTES 14 + +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE + +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 + +/* + * 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM + * 64 bytes before this address should be set aside for u-boot.img's + * header. That is 0x800FFFC0--0x80100000 should not be used for any + * other needs. + */ +#define CONFIG_SYS_TEXT_BASE 0x80800000 +#define CONFIG_SYS_SPL_MALLOC_START 0x80208000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 + +/* Since SPL did pll and ddr initialization for us, + * we don't need to do it twice. + */ +#ifndef CONFIG_SPL_BUILD +#define CONFIG_SKIP_LOWLEVEL_INIT +#endif /* CONFIG_SPL_BUILD */ + +/* Unsupported features */ +#undef CONFIG_USE_IRQ + +#define CONFIG_CMD_NET +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING +#define CONFIG_DRIVER_TI_CPSW +#define CONFIG_MII +#define CONFIG_BOOTP_DEFAULT +#define CONFIG_BOOTP_DNS +#define CONFIG_BOOTP_DNS2 +#define CONFIG_BOOTP_SEND_HOSTNAME +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_SUBNETMASK +#define CONFIG_NET_RETRY_COUNT 10 +#define CONFIG_NET_MULTI +#define CONFIG_PHY_GIGE +#define CONFIG_PHYLIB +#define CONFIG_PHY_ADDR 1 +#define CONFIG_PHY_SMSC + + +/* UBIFS support */ +#define CONFIG_CMD_UBI +#define CONFIG_CMD_UBIFS +#define CONFIG_RBTREE +#define CONFIG_LZO + +/* NAND support */ +#define CONFIG_NAND +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NAND_TRIMFFS + +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS +#define CONFIG_CMD_MTDPARTS +#define MTDIDS_DEFAULT "nand0=nand" +#define MTDPARTS_DEFAULT "mtdparts=nand:" \ + "128k(spl1)," \ + "128k(spl2)," \ + "128k(spl3)," \ + "128k(spl4)," \ + "1792k(boot)," \ + "128k(env)," \ + "4m(kernel)," \ + "64m(rootfs)," \ + "-(data)" + +#define CONFIG_NAND_OMAP_GPMC +#define GPMC_NAND_ECC_LP_x8_LAYOUT 1 +#define CONFIG_SYS_NAND_BASE (0x08000000) /* physical address */ + /* to access nand at */ + /* CS0 */ +#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET 0x1e0000 /* environment starts here */ +#define CONFIG_SYS_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ + +#endif /* ! __CONFIG_NANOBONE_H */
CPU: TI AM335x
Changes in v2:
This appears to be whitespace corrupted, please re-send.
CPU: TI AM335x
Changes in v2:
Any chance this board can be added ?
Regards Mark J.
CPU: TI AM335x
Changes in v2:
I guess the email asking for you to re-send got lost, the copy in patchwork appears to be whitespace corrupted. Since you need to re-send anyhow (sorry) please update to use the SPDX tags now, thanks.
CPU: TI AM335x
Changes in v2:
Hmmm ... nope, never got that one !!
I'll repost an updated patch.
Cheers
Mark Jackson
