[U-Boot-Users] [PATCH] POST: Add disable interrupts in some of the missing CPU POST tests
Some CPU POST tests did not disable the interrupts while running. This seems to be necessary to protect this self modifying code.
Signed-off-by: Stefan Roese sr@denx.de --- post/lib_ppc/b.c | 4 ++++ post/lib_ppc/cmp.c | 4 ++++ post/lib_ppc/cmpi.c | 4 ++++ post/lib_ppc/complex.c | 4 ++++ post/lib_ppc/cr.c | 4 ++++ post/lib_ppc/load.c | 4 ++++ post/lib_ppc/multi.c | 4 ++++ post/lib_ppc/store.c | 4 ++++ post/lib_ppc/string.c | 4 ++++ 9 files changed, 36 insertions(+), 0 deletions(-)
diff --git a/post/lib_ppc/b.c b/post/lib_ppc/b.c index 45b9ff2..7a2583d 100644 --- a/post/lib_ppc/b.c +++ b/post/lib_ppc/b.c @@ -95,6 +95,7 @@ int cpu_post_test_b (void) { int ret = 0; unsigned int i; + int flag = disable_interrupts();
if (ret == 0) { @@ -188,6 +189,9 @@ int cpu_post_test_b (void) } }
+ if (flag) + enable_interrupts(); + return ret; }
diff --git a/post/lib_ppc/cmp.c b/post/lib_ppc/cmp.c index 8d80f86..13809d4 100644 --- a/post/lib_ppc/cmp.c +++ b/post/lib_ppc/cmp.c @@ -102,6 +102,7 @@ int cpu_post_test_cmp (void) { int ret = 0; unsigned int i; + int flag = disable_interrupts();
for (i = 0; i < cpu_post_cmp_size && ret == 0; i++) { @@ -124,6 +125,9 @@ int cpu_post_test_cmp (void) } }
diff --git a/post/lib_ppc/cmpi.c b/post/lib_ppc/cmpi.c index 92b4d57..5ecfe87 100644 --- a/post/lib_ppc/cmpi.c +++ b/post/lib_ppc/cmpi.c @@ -102,6 +102,7 @@ int cpu_post_test_cmpi (void) { int ret = 0; unsigned int i; + int flag = disable_interrupts();
for (i = 0; i < cpu_post_cmpi_size && ret == 0; i++) { @@ -124,6 +125,9 @@ int cpu_post_test_cmpi (void) } }
diff --git a/post/lib_ppc/complex.c b/post/lib_ppc/complex.c index 271392a..4983c51 100644 --- a/post/lib_ppc/complex.c +++ b/post/lib_ppc/complex.c @@ -101,6 +101,7 @@ static int cpu_post_test_complex_2 (void) int cpu_post_test_complex (void) { int ret = 0; + int flag = disable_interrupts();
if (ret == 0) { @@ -117,6 +118,9 @@ int cpu_post_test_complex (void) post_log ("Error at complex test !\n"); }
diff --git a/post/lib_ppc/cr.c b/post/lib_ppc/cr.c index 0bd9e74..2c7976a 100644 --- a/post/lib_ppc/cr.c +++ b/post/lib_ppc/cr.c @@ -248,6 +248,7 @@ int cpu_post_test_cr (void) int ret = 0; unsigned int i; unsigned long cr_sav; + int flag = disable_interrupts();
asm ( "mfcr %0" : "=r" (cr_sav) : );
@@ -347,6 +348,9 @@ int cpu_post_test_cr (void)
asm ( "mtcr %0" : : "r" (cr_sav));
diff --git a/post/lib_ppc/load.c b/post/lib_ppc/load.c index 86bc223..eccebb7 100644 --- a/post/lib_ppc/load.c +++ b/post/lib_ppc/load.c @@ -178,6 +178,7 @@ int cpu_post_test_load (void) { int ret = 0; unsigned int i; + int flag = disable_interrupts();
for (i = 0; i < cpu_post_load_size && ret == 0; i++) { @@ -246,6 +247,9 @@ int cpu_post_test_load (void) } }
diff --git a/post/lib_ppc/multi.c b/post/lib_ppc/multi.c index 5d3f584..47135ab 100644 --- a/post/lib_ppc/multi.c +++ b/post/lib_ppc/multi.c @@ -44,6 +44,7 @@ int cpu_post_test_multi (void) { int ret = 0; unsigned int i; + int flag = disable_interrupts();
if (ret == 0) { @@ -72,6 +73,9 @@ int cpu_post_test_multi (void) post_log ("Error at multi test !\n"); }
diff --git a/post/lib_ppc/store.c b/post/lib_ppc/store.c index 09ec485..c96f263 100644 --- a/post/lib_ppc/store.c +++ b/post/lib_ppc/store.c @@ -163,6 +163,7 @@ int cpu_post_test_store (void) { int ret = 0; unsigned int i; + int flag = disable_interrupts();
for (i = 0; i < cpu_post_store_size && ret == 0; i++) { @@ -226,6 +227,9 @@ int cpu_post_test_store (void) } }
diff --git a/post/lib_ppc/string.c b/post/lib_ppc/string.c index b2daa88..3683ac9 100644 --- a/post/lib_ppc/string.c +++ b/post/lib_ppc/string.c @@ -47,6 +47,7 @@ int cpu_post_test_string (void) { int ret = 0; unsigned int i; + int flag = disable_interrupts();
if (ret == 0) { @@ -97,6 +98,9 @@ int cpu_post_test_string (void) post_log ("Error at string test !\n"); }
Applied, thanks.
Stefan Roese
