[U-Boot] [PATCH 1/1] lmb: only force on arches that use it
Signed-off-by: Mike Frysinger vapier@gentoo.org --- common/cmd_bootm.c | 34 ++++++++++++++++------------------ include/asm-m68k/config.h | 2 ++ include/asm-ppc/config.h | 2 ++ include/asm-sparc/config.h | 2 ++ include/image.h | 2 +- include/lmb.h | 4 ++++ lib_generic/Makefile | 2 +- lib_generic/lmb.c | 12 ++++++++++++ 8 files changed, 40 insertions(+), 20 deletions(-)
diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index 8f83598..22aa7f8 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -154,18 +154,6 @@ boot_os_fn * boot_os[] = { ulong load_addr = CONFIG_SYS_LOAD_ADDR; /* Default Load Address */ static bootm_headers_t images; /* pointers to os/initrd/fdt images */
-void __board_lmb_reserve(struct lmb *lmb) -{ - /* please define platform specific board_lmb_reserve() */ -} -void board_lmb_reserve(struct lmb *lmb) __attribute__((weak, alias("__board_lmb_reserve"))); - -void __arch_lmb_reserve(struct lmb *lmb) -{ - /* please define platform specific arch_lmb_reserve() */ -} -void arch_lmb_reserve(struct lmb *lmb) __attribute__((weak, alias("__arch_lmb_reserve"))); - /* Allow for arch specific config before we boot */ void __arch_preboot_os(void) { @@ -201,15 +189,11 @@ void arch_preboot_os(void) __attribute__((weak, alias("__arch_preboot_os"))); # error Unknown CPU type #endif
-static int bootm_start(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +static void bootm_start_lmb(void) { +#ifdef CONFIG_LMB ulong mem_start; phys_size_t mem_size; - void *os_hdr; - int ret; - - memset ((void *)&images, 0, sizeof (images)); - images.verify = getenv_yesno ("verify");
lmb_init(&images.lmb);
@@ -220,6 +204,20 @@ static int bootm_start(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[])
arch_lmb_reserve(&images.lmb); board_lmb_reserve(&images.lmb); +#else +# define lmb_reserve(lmb, base, size) +#endif +} + +static int bootm_start(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + void *os_hdr; + int ret; + + memset ((void *)&images, 0, sizeof (images)); + images.verify = getenv_yesno ("verify"); + + bootm_start_lmb();
/* get kernel image header, start address and length */ os_hdr = boot_get_kernel (cmdtp, flag, argc, argv, diff --git a/include/asm-m68k/config.h b/include/asm-m68k/config.h index 049c44e..36438be 100644 --- a/include/asm-m68k/config.h +++ b/include/asm-m68k/config.h @@ -21,4 +21,6 @@ #ifndef _ASM_CONFIG_H_ #define _ASM_CONFIG_H_
+#define CONFIG_LMB + #endif diff --git a/include/asm-ppc/config.h b/include/asm-ppc/config.h index af0853b..a735e8d 100644 --- a/include/asm-ppc/config.h +++ b/include/asm-ppc/config.h @@ -21,6 +21,8 @@ #ifndef _ASM_CONFIG_H_ #define _ASM_CONFIG_H_
+#define CONFIG_LMB + #ifndef CONFIG_MAX_MEM_MAPPED #if defined(CONFIG_4xx) || defined(CONFIG_E500) || defined(CONFIG_MPC86xx) #define CONFIG_MAX_MEM_MAPPED ((phys_size_t)2 << 30) diff --git a/include/asm-sparc/config.h b/include/asm-sparc/config.h index 049c44e..36438be 100644 --- a/include/asm-sparc/config.h +++ b/include/asm-sparc/config.h @@ -21,4 +21,6 @@ #ifndef _ASM_CONFIG_H_ #define _ASM_CONFIG_H_
+#define CONFIG_LMB + #endif diff --git a/include/image.h b/include/image.h index 5a424e6..b82f4b9 100644 --- a/include/image.h +++ b/include/image.h @@ -256,7 +256,7 @@ typedef struct bootm_headers { #define BOOTM_STATE_OS_GO (0x00000080) int state;
-#ifndef USE_HOSTCC +#ifdef CONFIG_LMB struct lmb lmb; /* for memory mgmt */ #endif } bootm_headers_t; diff --git a/include/lmb.h b/include/lmb.h index 14e8727..43082a3 100644 --- a/include/lmb.h +++ b/include/lmb.h @@ -52,6 +52,10 @@ lmb_size_bytes(struct lmb_region *type, unsigned long region_nr) { return type->region[region_nr].size; } + +void board_lmb_reserve(struct lmb *lmb); +void arch_lmb_reserve(struct lmb *lmb); + #endif /* __KERNEL__ */
#endif /* _LINUX_LMB_H */ diff --git a/lib_generic/Makefile b/lib_generic/Makefile index 686601c..8d23c5d 100644 --- a/lib_generic/Makefile +++ b/lib_generic/Makefile @@ -37,7 +37,7 @@ COBJS-y += ctype.o COBJS-y += display_options.o COBJS-y += div64.o COBJS-y += gunzip.o -COBJS-y += lmb.o +COBJS-$(CONFIG_LMB) += lmb.o COBJS-y += ldiv.o COBJS-$(CONFIG_MD5) += md5.o COBJS-y += sha1.o diff --git a/lib_generic/lmb.c b/lib_generic/lmb.c index 1c6cf7c..c5e75fb 100644 --- a/lib_generic/lmb.c +++ b/lib_generic/lmb.c @@ -334,3 +334,15 @@ int lmb_is_reserved(struct lmb *lmb, phys_addr_t addr) } return 0; } + +void __board_lmb_reserve(struct lmb *lmb) +{ + /* please define platform specific board_lmb_reserve() */ +} +void board_lmb_reserve(struct lmb *lmb) __attribute__((weak, alias("__board_lmb_reserve"))); + +void __arch_lmb_reserve(struct lmb *lmb) +{ + /* please define platform specific arch_lmb_reserve() */ +} +void arch_lmb_reserve(struct lmb *lmb) __attribute__((weak, alias("__arch_lmb_reserve")));
sorry Scott, didnt mean to direct this to you. meant to send the nand one only to you. -mike
Dear Mike Frysinger,
So what is supposed to happen with this patch? Do we consider this a fix for the upcoming release? Or is it for "next"? Or none of that?
it's been broken (i.e. adding useless bloat to most people) for so long that one more release (i.e. adding to "next") is fine -mike
Applied.
Mike Frysinger
