[U-Boot] [PATCH 2/2] Replace __asm references with __asm__
__asm__ follows gcc's documented syntax and is generally more common than __asm. This change is only asthetic and should not affect functionality.
Signed-off-by: Peter Tyser ptyser@xes-inc.com --- board/MAI/AmigaOneG3SE/enet.c | 16 ++++++++-------- board/MAI/AmigaOneG3SE/flash_new.c | 10 +++++----- board/MAI/AmigaOneG3SE/serial.c | 6 +++--- board/MAI/AmigaOneG3SE/via686.c | 2 +- board/trab/vfd.c | 2 +- cpu/ixp/npe/IxFeatureCtrl.c | 2 +- tools/updater/flash_hw.c | 10 +++++----- 7 files changed, 24 insertions(+), 24 deletions(-)
diff --git a/board/MAI/AmigaOneG3SE/enet.c b/board/MAI/AmigaOneG3SE/enet.c index ac969a9..b9df55c 100644 --- a/board/MAI/AmigaOneG3SE/enet.c +++ b/board/MAI/AmigaOneG3SE/enet.c @@ -297,50 +297,50 @@ static void eth_3com_halt(struct eth_device* dev);
static inline int ETH_INL(struct eth_device* dev, u_long addr) { - __asm volatile ("eieio"); + __asm__ volatile ("eieio"); return le32_to_cpu(*(volatile u32 *)io_to_phys(addr + dev->iobase)); }
static inline int ETH_INW(struct eth_device* dev, u_long addr) { - __asm volatile ("eieio"); + __asm__ volatile ("eieio"); return le16_to_cpu(*(volatile u16 *)io_to_phys(addr + dev->iobase)); }
static inline int ETH_INB(struct eth_device* dev, u_long addr) { - __asm volatile ("eieio"); + __asm__ volatile ("eieio"); return *(volatile u8 *)io_to_phys(addr + dev->iobase); }
static inline void ETH_OUTB(struct eth_device* dev, int command, u_long addr) { *(volatile u8 *)io_to_phys(addr + dev->iobase) = command; - __asm volatile ("eieio"); + __asm__ volatile ("eieio"); }
static inline void ETH_OUTW(struct eth_device* dev, int command, u_long addr) { *(volatile u16 *)io_to_phys(addr + dev->iobase) = cpu_to_le16(command); - __asm volatile ("eieio"); + __asm__ volatile ("eieio"); }
static inline void ETH_OUTL(struct eth_device* dev, int command, u_long addr) { *(volatile u32 *)io_to_phys(addr + dev->iobase) = cpu_to_le32(command); - __asm volatile ("eieio"); + __asm__ volatile ("eieio"); }
static inline int ETH_STATUS(struct eth_device* dev) { - __asm volatile ("eieio"); + __asm__ volatile ("eieio"); return le16_to_cpu(*(volatile u16 *)io_to_phys(EL3_STATUS + dev->iobase)); }
static inline void ETH_CMD(struct eth_device* dev, int command) { *(volatile u16 *)io_to_phys(EL3_CMD + dev->iobase) = cpu_to_le16(command); - __asm volatile ("eieio"); + __asm__ volatile ("eieio"); }
/* Command register is always in the same spot in all the register windows */ diff --git a/board/MAI/AmigaOneG3SE/flash_new.c b/board/MAI/AmigaOneG3SE/flash_new.c index 7b7ea16..9beb048 100644 --- a/board/MAI/AmigaOneG3SE/flash_new.c +++ b/board/MAI/AmigaOneG3SE/flash_new.c @@ -153,14 +153,14 @@ static ulong flash_get_size (ulong addr, flash_info_t *info)
/* Write auto select command: read Manufacturer ID */ x[0x0555] = 0xAA; - __asm volatile ("sync\n eieio"); + __asm__ volatile ("sync\n eieio"); x[0x02AA] = 0x55; - __asm volatile ("sync\n eieio"); + __asm__ volatile ("sync\n eieio"); x[0x0555] = 0x90; - __asm volatile ("sync\n eieio"); + __asm__ volatile ("sync\n eieio");
value = x[0]; - __asm volatile ("sync\n eieio"); + __asm__ volatile ("sync\n eieio");
DEBUGF("Manuf. ID @ 0x%08lx: 0x%08x\n", (ulong)addr, value);
@@ -186,7 +186,7 @@ static ulong flash_get_size (ulong addr, flash_info_t *info) }
value = x[1]; - __asm volatile ("sync\n eieio"); + __asm__ volatile ("sync\n eieio");
DEBUGF("Device ID @ 0x%08lx: 0x%08x\n", addr+1, value);
diff --git a/board/MAI/AmigaOneG3SE/serial.c b/board/MAI/AmigaOneG3SE/serial.c index 88039f3..84a913e 100644 --- a/board/MAI/AmigaOneG3SE/serial.c +++ b/board/MAI/AmigaOneG3SE/serial.c @@ -75,17 +75,17 @@ void serial_init (void) /* COM_WRITE_BYTE(LINE_CONTROL, 0x83); */ /* COM_WRITE_BYTE(DIVISOR_LATCH_LSB, (uint8)(clock_divisor & 0xFF)); */ /* COM_WRITE_BYTE(DIVISOR_LATCH_MSB, (uint8)(clock_divisor >> 8)); */ - /* __asm("eieio"); */ + /* __asm__("eieio"); */
/* Set 8-N-1 */ COM_WRITE_BYTE (LINE_CONTROL, 0x03); - __asm ("eieio"); + __asm__ ("eieio");
/* Disable FIFO */ COM_WRITE_BYTE (MODEM_CONTROL, 0x03); COM_WRITE_BYTE (FIFO_CONTROL, 0x07);
- __asm ("eieio"); + __asm__ ("eieio"); serial_init_done = 1; }
diff --git a/board/MAI/AmigaOneG3SE/via686.c b/board/MAI/AmigaOneG3SE/via686.c index 2427ce5..752a464 100644 --- a/board/MAI/AmigaOneG3SE/via686.c +++ b/board/MAI/AmigaOneG3SE/via686.c @@ -211,7 +211,7 @@ void via_cfgfunc_via686(struct pci_controller *host, pci_dev_t dev, struct pci_c } }
-__asm (" .globl via_calibrate_time_base \n" +__asm__ (" .globl via_calibrate_time_base \n" "via_calibrate_time_base: \n" " lis 9, 0xfe00 \n" " li 0, 0x00 \n" diff --git a/board/trab/vfd.c b/board/trab/vfd.c index eb506f3..37d3aa4 100644 --- a/board/trab/vfd.c +++ b/board/trab/vfd.c @@ -369,7 +369,7 @@ int vfd_init_clocks (void) gpio->PCCON = (gpio->PCCON & 0xFFFFFF00); /* configure GPC0...GPC3 as inputs */ /* allow signals to settle */ for (i=0; i<10000; i++) /* udelay isn't working yet at this point! */ - __asm("NOP"); + __asm__("NOP"); vfd_board_id = (~gpio->PCDAT) & 0x000F; /* read GPC0...GPC3 port pins */
VFD_DISABLE; /* activate blank for the vfd */ diff --git a/cpu/ixp/npe/IxFeatureCtrl.c b/cpu/ixp/npe/IxFeatureCtrl.c index e02aabf..2e196a1 100644 --- a/cpu/ixp/npe/IxFeatureCtrl.c +++ b/cpu/ixp/npe/IxFeatureCtrl.c @@ -317,7 +317,7 @@ ixFeatureCtrlProductIdRead () /* Use ARM instruction to move register0 from coprocessor to ARM register */
#ifndef __wince - __asm("mrc p15, 0, %0, cr0, cr0, 0;" : "=r"(pdId) :); + __asm__("mrc p15, 0, %0, cr0, cr0, 0;" : "=r"(pdId) :); #else
#ifndef IN_KERNEL diff --git a/tools/updater/flash_hw.c b/tools/updater/flash_hw.c index 8af4b45..b5058b3 100644 --- a/tools/updater/flash_hw.c +++ b/tools/updater/flash_hw.c @@ -153,14 +153,14 @@ static ulong flash_get_size (ulong addr, flash_info_t *info)
Dear Peter Tyser,
Applied, thanks.
Peter Tyser
