[PATCH] [RFC] cmd: pxe_utils: Limit fdtcontroladdr usage to non-fitImage
Commit d5ba6188dfb ("cmd: pxe_utils: Check fdtcontroladdr in label_boot") forces '$fdtcontroladdr' DT address as a third parameter of bootm command even if the PXE transfer pulls in a fitImage which contains configuration node with its own DT that is preferrable to be passed to Linux. Limit the $fdtcontroladdr fallback utilization to non-fitImages, since it is highly likely a fitImage would come with its own DT, while single-file images do need a separate DT.
Fixes: d5ba6188dfb ("cmd: pxe_utils: Check fdtcontroladdr in label_boot") Signed-off-by: Marek Vasut marex@denx.de --- Cc: Peter Hoyes Peter.Hoyes@arm.com Cc: Ramon Fried rfried.dev@gmail.com Cc: Simon Glass sjg@chromium.org --- boot/pxe_utils.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/boot/pxe_utils.c b/boot/pxe_utils.c index 8133006875f..a25f0c22888 100644 --- a/boot/pxe_utils.c +++ b/boot/pxe_utils.c @@ -724,7 +724,7 @@ static int label_boot(struct pxe_context *ctx, struct pxe_label *label) if (!bootm_argv[3]) bootm_argv[3] = env_get("fdt_addr");
- if (!bootm_argv[3]) + if (!bootm_argv[3] && genimg_get_format(buf) != IMAGE_FORMAT_FIT) bootm_argv[3] = env_get("fdtcontroladdr");
if (bootm_argv[3]) {
I'd suggest adding an explicit comment in the code too, so it is easier to understand when this gets refactored later.
I sent a fixed version of this patch, can you add this RB to it too ?
Regarding comment in the code, there is already one massive comment explaining it just above, see the pxe_utils.c content in the sources.
Hi Marek,
" * Scenario 3: If there is an fdtcontroladdr specified, pass it along to * bootm, and adjust argc appropriately."
But are you not changing that? So update the comment?
