[U-Boot] [PATCH v6] arm: ep9315: Return back Cirrus Logic EDB9315A board support
This patch returns back support for old ep93xx processors family
Signed-off-by: Sergey Kostanbaev sergey.kostanbaev@gmail.com Cc: albert.u.boot@aribaud.net --- Changes for v6: - Update patch to cleanly apply
Changes for v5: - Fix license that dropped during merge - Better formatting - Update loader script
Changes for v4: - Update patch to cleanly apply
Changes for v3: - Update makefiles to the new style
Changes for v2: - Replace constants in lowlevel_init.S to defines - Add more coments in non-trivial places in lowlevel_init.S - Get rid of ep93xx_sdram_find_bank in lowlevel_init.S and move it to dram_fill_bank_addr in edb93xx.c. This procedure may be executed later at any time, so no need to be in lowlevel
arch/arm/cpu/arm920t/ep93xx/lowlevel_init.S | 465 ++++++++++++++++++++++++++-- arch/arm/include/asm/arch-ep93xx/ep93xx.h | 86 +++++ board/cirrus/edb93xx/Makefile | 37 +++ board/cirrus/edb93xx/edb93xx.c | 382 +++++++++++++++++++++++ board/cirrus/edb93xx/u-boot.lds | 106 +++++++ boards.cfg | 1 + drivers/spi/Makefile | 1 + drivers/spi/ep93xx_spi.c | 274 ++++++++++++++++ drivers/usb/host/Makefile | 1 + drivers/usb/host/ohci-ep93xx.c | 38 +++ include/configs/edb93xx.h | 292 +++++++++++++++++ 11 files changed, 1654 insertions(+), 29 deletions(-) create mode 100644 board/cirrus/edb93xx/Makefile create mode 100644 board/cirrus/edb93xx/edb93xx.c create mode 100644 board/cirrus/edb93xx/u-boot.lds create mode 100644 drivers/spi/ep93xx_spi.c create mode 100644 drivers/usb/host/ohci-ep93xx.c create mode 100644 include/configs/edb93xx.h
diff --git a/arch/arm/cpu/arm920t/ep93xx/lowlevel_init.S b/arch/arm/cpu/arm920t/ep93xx/lowlevel_init.S index bf2fa2a..3ac0f88 100644 --- a/arch/arm/cpu/arm920t/ep93xx/lowlevel_init.S +++ b/arch/arm/cpu/arm920t/ep93xx/lowlevel_init.S @@ -1,49 +1,458 @@ /* * Low-level initialization for EP93xx * * Copyright (C) 2009 Matthias Kaehlcke matthias@kaehlcke.net + * Copyright (C) 2013 + * Sergey Kostanabev <sergey.kostanbaev <at> fairwaves.ru> * * Copyright (C) 2006 Dominic Rath Dominic.Rath@gmx.de + * Copyright (C) 2006 Cirrus Logic Inc. + * + * See file CREDITS for list of people who contributed to this + * project. * * SPDX-License-Identifier: GPL-2.0+ */
-#include <version.h> -#include <asm/arch/ep93xx.h> +#include <config.h> +#include <asm/arch-ep93xx/ep93xx.h> + +/* +/* Configure the SDRAM based on the supplied settings. + * + * Input: r0 - SDRAM DEVCFG register + * r2 - configuration for SDRAM chips + * Output: none + * Modifies: r3, r4 + */ +ep93xx_sdram_config: + /* Program the SDRAM device configuration register. */ + ldr r3, =SDRAM_BASE +#ifdef CONFIG_EDB93XX_SDCS0 + str r0, [r3, #SDRAM_OFF_DEVCFG0] +#endif +#ifdef CONFIG_EDB93XX_SDCS1 + str r0, [r3, #SDRAM_OFF_DEVCFG1] +#endif +#ifdef CONFIG_EDB93XX_SDCS2 + str r0, [r3, #SDRAM_OFF_DEVCFG2] +#endif +#ifdef CONFIG_EDB93XX_SDCS3 + str r0, [r3, #SDRAM_OFF_DEVCFG3] +#endif + + /* Set the Initialize and MRS bits (issue continuous NOP commands + * (INIT & MRS set)) + */ + ldr r4, =(EP93XX_SDRAMCTRL_GLOBALCFG_INIT | \ + EP93XX_SDRAMCTRL_GLOBALCFG_MRS | \ + EP93XX_SDRAMCTRL_GLOBALCFG_CKE) + str r4, [r3, #SDRAM_OFF_GLCONFIG] + + /* Delay for 200us. */ + mov r4, #0x3000 +delay1: + subs r4, r4, #1 + bne delay1 + + /* Clear the MRS bit to issue a precharge all. */ + ldr r4, =(EP93XX_SDRAMCTRL_GLOBALCFG_INIT | \ + EP93XX_SDRAMCTRL_GLOBALCFG_CKE) + str r4, [r3, #SDRAM_OFF_GLCONFIG] + + /* Temporarily set the refresh timer to 0x10. Make it really low so + * that refresh cycles are generated. + */ + ldr r4, =0x10 + str r4, [r3, #SDRAM_OFF_REFRSHTIMR] + + /* Delay for at least 80 SDRAM clock cycles. */ + mov r4, #80 +delay2: + subs r4, r4, #1 + bne delay2 + + /* Set the refresh timer to the fastest required for any device + * that might be used. Set 9.6 ms refresh time. + */ + ldr r4, =0x01e0 + str r4, [r3, #SDRAM_OFF_REFRSHTIMR] + + /* Select mode register update mode. */ + ldr r4, =(EP93XX_SDRAMCTRL_GLOBALCFG_CKE | \ + EP93XX_SDRAMCTRL_GLOBALCFG_MRS) + str r4, [r3, #SDRAM_OFF_GLCONFIG] + + /* Program the mode register on the SDRAM by performing fake read */ + ldr r4, [r2] + + /* Select normal operating mode. */ + ldr r4, =EP93XX_SDRAMCTRL_GLOBALCFG_CKE + str r4, [r3, #SDRAM_OFF_GLCONFIG] + + /* Return to the caller. */ + mov pc, lr + +/* + * Test to see if the SDRAM has been configured in a usable mode. + * + * Input: r0 - Test address of SDRAM + * Output: r0 - 0 -- Test OK, -1 -- Failed + * Modifies: r0-r5 + */ +ep93xx_sdram_test: + /* Load the test patterns to be written to SDRAM. */ + ldr r1, =0xf00dface + ldr r2, =0xdeadbeef + ldr r3, =0x08675309 + ldr r4, =0xdeafc0ed + + /* Store the test patterns to SDRAM. */ + stmia r0, {r1-r4} + + /* Load the test patterns from SDRAM one at a time and compare them + * to the actual pattern. + */ + ldr r5, [r0] + cmp r5, r1 + ldreq r5, [r0, #0x0004] + cmpeq r5, r2 + ldreq r5, [r0, #0x0008] + cmpeq r5, r3 + ldreq r5, [r0, #0x000c] + cmpeq r5, r4 + + /* Return -1 if a mismatch was encountered, 0 otherwise. */ + mvnne r0, #0xffffffff + moveq r0, #0x00000000 + + /* Return to the caller. */ + mov pc, lr + +/* + * Determine the size of the SDRAM. Use data=address for the scan. + * + * Input: r0 - Start SDRAM address + * Return: r0 - Single block size + * r1 - Valid block mask + * r2 - Total block count + * Modifies: r0-r5 + */ +ep93xx_sdram_size: + /* Store zero at offset zero. */ + str r0, [r0] + + /* Start checking for an alias at 1MB into SDRAM. */ + ldr r1, =0x00100000 + + /* Store the offset at the current offset. */ +check_block_size: + str r1, [r0, r1] + + /* Read back from zero. */ + ldr r2, [r0] + + /* Stop searching of an alias was found. */ + cmp r1, r2 + beq found_block_size + + /* Advance to the next power of two boundary. */ + mov r1, r1, lsl #1 + + /* Loop back if the size has not reached 256MB. */ + cmp r1, #0x10000000 + bne check_block_size + + /* A full 256MB of memory was found, so return it now. */ + ldr r0, =0x10000000 + ldr r1, =0x00000000 + ldr r2, =0x00000001 + mov pc, lr + + /* An alias was found. See if the first block is 128MB in size. */ +found_block_size: + cmp r1, #0x08000000 + + /* The first block is 128MB, so there is no further memory. Return it + * now. + */ + ldreq r0, =0x08000000 + ldreq r1, =0x00000000 + ldreq r2, =0x00000001 + moveq pc, lr + + /* Save the block size, set the block address bits to zero, and + * initialize the block count to one. + */ + mov r3, r1 + ldr r4, =0x00000000 + ldr r5, =0x00000001 + + /* Look for additional blocks of memory by searching for non-aliases. */ +find_blocks: + /* Store zero back to address zero. It may be overwritten. */ + str r0, [r0] + + /* Advance to the next power of two boundary. */ + mov r1, r1, lsl #1 + + /* Store the offset at the current offset. */ + str r1, [r0, r1] + + /* Read back from zero. */ + ldr r2, [r0] + + /* See if a non-alias was found. */ + cmp r1, r2 + + /* If a non-alias was found, then or in the block address bit and + * multiply the block count by two (since there are two unique + * blocks, one with this bit zero and one with it one). + */ + orrne r4, r4, r1 + movne r5, r5, lsl #1 + + /* Continue searching if there are more address bits to check. */ + cmp r1, #0x08000000 + bne find_blocks + + /* Return the block size, address mask, and count. */ + mov r0, r3 + mov r1, r4 + mov r2, r5 + + /* Return to the caller. */ + mov pc, lr +
.globl lowlevel_init lowlevel_init: - /* backup return address */ - ldr r1, =SYSCON_SCRATCH0 - str lr, [r1]
- /* Turn on both LEDs */ - bl red_led_on - bl green_led_on + mov r6, lr + + /* Make sure caches are off and invalidated. */ + ldr r0, =0x00000000 + mcr p15, 0, r0, c1, c0, 0 + nop + nop + nop + nop + nop + + /* Turn off the green LED and turn on the red LED. If the red LED + * is left on for too long, the external reset circuit described + * by application note AN258 will cause the system to reset. + */ + ldr r1, =EP93XX_LED_DATA + ldr r0, [r1] + bic r0, r0, #EP93XX_LED_GREEN_ON + orr r0, r0, #EP93XX_LED_RED_ON + str r0, [r1] + + /* Undo the silly static memory controller programming performed + * by the boot rom. + */ + ldr r0, =SMC_BASE + + /* Set WST1 and WST2 to 31 HCLK cycles (slowest access) */ + ldr r1, =0x0000fbe0 + + /* Reset EP93XX_OFF_SMCBCR0 */ + ldr r2, [r0] + orr r2, r2, r1 + str r2, [r0] + + ldr r2, [r0, #EP93XX_OFF_SMCBCR1] + orr r2, r2, r1 + str r2, [r0, #EP93XX_OFF_SMCBCR1] + + ldr r2, [r0, #EP93XX_OFF_SMCBCR2] + orr r2, r2, r1 + str r2, [r0, #EP93XX_OFF_SMCBCR2] + + ldr r2, [r0, #EP93XX_OFF_SMCBCR3] + orr r2, r2, r1 + str r2, [r0, #EP93XX_OFF_SMCBCR3] + + ldr r2, [r0, #EP93XX_OFF_SMCBCR6] + orr r2, r2, r1 + str r2, [r0, #EP93XX_OFF_SMCBCR6] + + ldr r2, [r0, #EP93XX_OFF_SMCBCR7] + orr r2, r2, r1 + str r2, [r0, #EP93XX_OFF_SMCBCR7] + + /* Set the PLL1 and processor clock. */ + ldr r0, =SYSCON_BASE +#ifdef CONFIG_EDB9301 + /* 332MHz, giving a 166MHz processor clock. */ + ldr r1, = 0x02b49907 +#else + +#ifdef CONFIG_EDB93XX_INDUSTRIAL + /* 384MHz, giving a 196MHz processor clock. */ + ldr r1, =0x02a4bb38 +#else + /* 400MHz, giving a 200MHz processor clock. */ + ldr r1, =0x02a4e39e +#endif +#endif + str r1, [r0, #SYSCON_OFF_CLKSET1] + + nop + nop + nop + nop + nop + + /* Need to make sure that SDRAM is configured correctly before + * coping the code into it. + */ + +#ifdef CONFIG_EDB93XX_SDCS0 + mov r11, #SDRAM_DEVCFG0_BASE +#endif +#ifdef CONFIG_EDB93XX_SDCS1 + mov r11, #SDRAM_DEVCFG1_BASE +#endif +#ifdef CONFIG_EDB93XX_SDCS2 + mov r11, #SDRAM_DEVCFG2_BASE +#endif +#ifdef CONFIG_EDB93XX_SDCS3 + ldr r0, =SYSCON_BASE + ldr r0, [r0, #SYSCON_OFF_SYSCFG] + ands r0, r0, #SYSCON_SYSCFG_LASDO + moveq r11, #SDRAM_DEVCFG3_ASD0_BASE + movne r11, #SDRAM_DEVCFG3_ASD1_BASE +#endif + /* See Table 13-5 in EP93xx datasheet for more info about DRAM + * register mapping */ + + /* Try a 32-bit wide configuration of SDRAM. */ + ldr r0, =(EP93XX_SDRAMCTRL_DEVCFG_BANKCOUNT | \ + EP93XX_SDRAMCTRL_DEVCFG_SROMLL | \ + EP93XX_SDRAMCTRL_DEVCFG_CASLAT_2 | \ + EP93XX_SDRAMCTRL_DEVCFG_RASTOCAS_2) + + /* Set burst count: 4 and CAS: 2 + * Burst mode [A11:A10]; CAS [A16:A14] + */ + orr r2, r11, #0x00008800 + bl ep93xx_sdram_config + + /* Test the SDRAM. */ + mov r0, r11 + bl ep93xx_sdram_test + cmp r0, #0x00000000 + beq ep93xx_sdram_done + + /* Try a 16-bit wide configuration of SDRAM. */ + ldr r0, =(EP93XX_SDRAMCTRL_DEVCFG_BANKCOUNT | \ + EP93XX_SDRAMCTRL_DEVCFG_SROMLL | \ + EP93XX_SDRAMCTRL_DEVCFG_CASLAT_2 | \ + EP93XX_SDRAMCTRL_DEVCFG_RASTOCAS_2 | \ + EP93XX_SDRAMCTRL_DEVCFG_EXTBUSWIDTH) + + /* Set burst count: 8, CAS: 2, sequential burst + * Accoring to Table 13-3 for 16bit operations mapping must be shifted. + * Burst mode [A10:A9]; CAS [A15:A13] + */ + orr r2, r11, #0x00004600 + bl ep93xx_sdram_config + + /* Test the SDRAM. */ + mov r0, r11 + bl ep93xx_sdram_test + cmp r0, #0x00000000 + beq ep93xx_sdram_done + + /* Turn off the red LED. */ + ldr r0, =EP93XX_LED_DATA + ldr r1, [r0] + bic r1, r1, #EP93XX_LED_RED_ON + str r1, [r0] + + /* There is no SDRAM so flash the green LED. */ +flash_green: + orr r1, r1, #EP93XX_LED_GREEN_ON + str r1, [r0] + ldr r2, =0x00010000 +flash_green_delay_1: + subs r2, r2, #1 + bne flash_green_delay_1 + bic r1, r1, #EP93XX_LED_GREEN_ON + str r1, [r0] + ldr r2, =0x00010000 +flash_green_delay_2: + subs r2, r2, #1 + bne flash_green_delay_2 + orr r1, r1, #EP93XX_LED_GREEN_ON + str r1, [r0] + ldr r2, =0x00010000 +flash_green_delay_3: + subs r2, r2, #1 + bne flash_green_delay_3 + bic r1, r1, #EP93XX_LED_GREEN_ON + str r1, [r0] + ldr r2, =0x00050000 +flash_green_delay_4: + subs r2, r2, #1 + bne flash_green_delay_4 + b flash_green +
- /* Configure flash wait states before we switch to the PLL */ - bl flash_cfg +ep93xx_sdram_done: + ldr r1, =EP93XX_LED_DATA + ldr r0, [r1] + bic r0, r0, #EP93XX_LED_RED_ON + str r0, [r1]
- /* Set up PLL */ - bl pll_cfg + /* Determine the size of the SDRAM. */ + mov r0, r11 + bl ep93xx_sdram_size
- /* Turn off the Green LED and leave the Red LED on */ - bl green_led_off + /* Save the SDRAM characteristics. */ + mov r8, r0 + mov r9, r1 + mov r10, r2
- /* Setup SDRAM */ - bl sdram_cfg + /* Compute total memory size into r1 */ + mul r1, r8, r10 +#ifdef CONFIG_EDB93XX_SDCS0 + ldr r2, [r0, #SDRAM_OFF_DEVCFG0] +#endif +#ifdef CONFIG_EDB93XX_SDCS1 + ldr r2, [r0, #SDRAM_OFF_DEVCFG1] +#endif +#ifdef CONFIG_EDB93XX_SDCS2 + ldr r2, [r0, #SDRAM_OFF_DEVCFG2] +#endif +#ifdef CONFIG_EDB93XX_SDCS3 + ldr r2, [r0, #SDRAM_OFF_DEVCFG3] +#endif
- /* Turn on Green LED, Turn off the Red LED */ - bl green_led_on - bl red_led_off + /* Consider small DRAM size as: + * < 32Mb for 32bit bus + * < 64Mb for 16bit bus + */ + tst r2, #EP93XX_SDRAMCTRL_DEVCFG_EXTBUSWIDTH + moveq r1, r1, lsr #1 + cmp r1, #0x02000000
- /* FIXME: we use async mode for now */ - mrc p15, 0, r0, c1, c0, 0 - orr r0, r0, #0xc0000000 - mcr p15, 0, r0, c1, c0, 0 +#if defined(CONFIG_EDB9301) + /* Set refresh counter to 20ms for small DRAM size, otherwise 9.6ms */ + movlt r1, #0x03f0 + movge r1, #0x01e0 +#else + /* Set refresh counter to 30.7ms for small DRAM size, otherwise 15ms */ + movlt r1, #0x0600 + movge r1, #0x2f0 +#endif + str r1, [r0, #SDRAM_OFF_REFRSHTIMR]
- /* restore return address */ - ldr r1, =SYSCON_SCRATCH0 - ldr lr, [r1] + /* Save the memory configuration information. */ + orr r0, r11, #UBOOT_MEMORYCNF_BANK_SIZE + stmia r0, {r8-r11}
- mov pc, lr + mov lr, r6 + mov pc, lr diff --git a/arch/arm/include/asm/arch-ep93xx/ep93xx.h b/arch/arm/include/asm/arch-ep93xx/ep93xx.h index 9e7f2f3..71aa601 100644 --- a/arch/arm/include/asm/arch-ep93xx/ep93xx.h +++ b/arch/arm/include/asm/arch-ep93xx/ep93xx.h @@ -1,6 +1,9 @@ /* * Cirrus Logic EP93xx register definitions. * + * Copyright (C) 2013 + * Sergey Kostanbaev <sergey.kostanbaev <at> fairwaves.ru> + * * Copyright (C) 2009 * Matthias Kaehlcke matthias@kaehlcke.net * @@ -287,6 +290,20 @@ struct sdram_regs { #define SDRAM_DEVCFG_CASLAT_2 0x00010000 #define SDRAM_DEVCFG_RASTOCAS_2 0x00200000
+#define SDRAM_OFF_GLCONFIG 0x0004 +#define SDRAM_OFF_REFRSHTIMR 0x0008 + +#define SDRAM_OFF_DEVCFG0 0x0010 +#define SDRAM_OFF_DEVCFG1 0x0014 +#define SDRAM_OFF_DEVCFG2 0x0018 +#define SDRAM_OFF_DEVCFG3 0x001C + +#define SDRAM_DEVCFG0_BASE 0xC0000000 +#define SDRAM_DEVCFG1_BASE 0xD0000000 +#define SDRAM_DEVCFG2_BASE 0xE0000000 +#define SDRAM_DEVCFG3_ASD0_BASE 0xF0000000 +#define SDRAM_DEVCFG3_ASD1_BASE 0x00000000 + #define GLCONFIG_INIT (1 << 0) #define GLCONFIG_MRS (1 << 1) #define GLCONFIG_SMEMBUSY (1 << 5) @@ -295,6 +312,43 @@ struct sdram_regs { #define GLCONFIG_CLKSHUTDOWN (1 << 30) #define GLCONFIG_CKE (1 << 31)
+#define EP93XX_SDRAMCTRL 0x80060000 +#define EP93XX_SDRAMCTRL_GLOBALCFG_INIT 0x00000001 +#define EP93XX_SDRAMCTRL_GLOBALCFG_MRS 0x00000002 +#define EP93XX_SDRAMCTRL_GLOBALCFG_SMEMBUSY 0x00000020 +#define EP93XX_SDRAMCTRL_GLOBALCFG_LCR 0x00000040 +#define EP93XX_SDRAMCTRL_GLOBALCFG_REARBEN 0x00000080 +#define EP93XX_SDRAMCTRL_GLOBALCFG_CLKSHUTDOWN 0x40000000 +#define EP93XX_SDRAMCTRL_GLOBALCFG_CKE 0x80000000 + +#define EP93XX_SDRAMCTRL_REFRESH_MASK 0x0000FFFF + +#define EP93XX_SDRAMCTRL_BOOTSTATUS_WIDTH_32 0x00000002 +#define EP93XX_SDRAMCTRL_BOOTSTATUS_WIDTH_16 0x00000001 +#define EP93XX_SDRAMCTRL_BOOTSTATUS_WIDTH_8 0x00000000 +#define EP93XX_SDRAMCTRL_BOOTSTATUS_WIDTH_MASK 0x00000003 +#define EP93XX_SDRAMCTRL_BOOTSTATUS_MEDIA 0x00000004 + +#define EP93XX_SDRAMCTRL_DEVCFG_EXTBUSWIDTH 0x00000004 +#define EP93XX_SDRAMCTRL_DEVCFG_BANKCOUNT 0x00000008 +#define EP93XX_SDRAMCTRL_DEVCFG_SROM512 0x00000010 +#define EP93XX_SDRAMCTRL_DEVCFG_SROMLL 0x00000020 +#define EP93XX_SDRAMCTRL_DEVCFG_2KPAGE 0x00000040 +#define EP93XX_SDRAMCTRL_DEVCFG_SFCONFIGADDR 0x00000080 +#define EP93XX_SDRAMCTRL_DEVCFG_CASLAT_MASK 0x00070000 +#define EP93XX_SDRAMCTRL_DEVCFG_CASLAT_2 0x00010000 +#define EP93XX_SDRAMCTRL_DEVCFG_CASLAT_3 0x00020000 +#define EP93XX_SDRAMCTRL_DEVCFG_CASLAT_4 0x00030000 +#define EP93XX_SDRAMCTRL_DEVCFG_CASLAT_5 0x00040000 +#define EP93XX_SDRAMCTRL_DEVCFG_CASLAT_6 0x00050000 +#define EP93XX_SDRAMCTRL_DEVCFG_CASLAT_7 0x00060000 +#define EP93XX_SDRAMCTRL_DEVCFG_CASLAT_8 0x00070000 +#define EP93XX_SDRAMCTRL_DEVCFG_WBL 0x00080000 +#define EP93XX_SDRAMCTRL_DEVCFG_RASTOCAS_MASK 0x00300000 +#define EP93XX_SDRAMCTRL_DEVCFG_RASTOCAS_2 0x00200000 +#define EP93XX_SDRAMCTRL_DEVCFG_RASTOCAS_3 0x00300000 +#define EP93XX_SDRAMCTRL_DEVCFG_AUTOPRECHARGE 0x01000000 + /* * 0x80070000 - 0x8007FFFF: Reserved */ @@ -324,6 +378,13 @@ struct smc_regs { }; #endif
+#define EP93XX_OFF_SMCBCR0 0x00 +#define EP93XX_OFF_SMCBCR1 0x04 +#define EP93XX_OFF_SMCBCR2 0x08 +#define EP93XX_OFF_SMCBCR3 0x0C +#define EP93XX_OFF_SMCBCR6 0x18 +#define EP93XX_OFF_SMCBCR7 0x1C + #define SMC_BCR_IDCY_SHIFT 0 #define SMC_BCR_WST1_SHIFT 5 #define SMC_BCR_BLE (1 << 10) @@ -445,6 +506,14 @@ struct gpio_regs { }; #endif
+#define EP93XX_LED_DATA 0x80840020 +#define EP93XX_LED_GREEN_ON 0x0001 +#define EP93XX_LED_RED_ON 0x0002 + +#define EP93XX_LED_DDR 0x80840024 +#define EP93XX_LED_GREEN_ENABLE 0x0001 +#define EP93XX_LED_RED_ENABLE 0x00020000 + /* * 0x80850000 - 0x8087FFFF: Reserved */ @@ -519,6 +588,9 @@ struct gpio_regs { #define SYSCON_OFFSET 0x930000 #define SYSCON_BASE (EP93XX_APB_BASE | SYSCON_OFFSET)
+/* Security */ +#define SECURITY_EXTENSIONID 0x80832714 + #ifndef __ASSEMBLY__ struct syscon_regs { uint32_t pwrsts; @@ -553,7 +625,11 @@ struct syscon_regs { #define SYSCON_SCRATCH0 (SYSCON_BASE + 0x0040) #endif
+#define SYSCON_OFF_CLKSET1 0x0020 +#define SYSCON_OFF_SYSCFG 0x009c + #define SYSCON_PWRCNT_UART_BAUD (1 << 29) +#define SYSCON_PWRCNT_USH_EN (1 << 28)
#define SYSCON_CLKSET_PLL_X2IPD_SHIFT 0 #define SYSCON_CLKSET_PLL_X2FBD2_SHIFT 5 @@ -571,6 +647,8 @@ struct syscon_regs { #define SYSCON_CHIPID_REV_MASK 0xF0000000 #define SYSCON_DEVICECFG_SWRST (1 << 31)
+#define SYSCON_SYSCFG_LASDO 0x00000020 + /* * 0x80930000 - 0x8093FFFF: Watchdog Timer */ @@ -580,3 +658,10 @@ struct syscon_regs { /* * 0x80950000 - 0x9000FFFF: Reserved */ + +/* + * During low_level init we store memory layout in memory at specific location + */ +#define UBOOT_MEMORYCNF_BANK_SIZE 0x2000 +#define UBOOT_MEMORYCNF_BANK_MASK 0x2004 +#define UBOOT_MEMORYCNF_BANK_COUNT 0x2008 diff --git a/board/cirrus/edb93xx/Makefile b/board/cirrus/edb93xx/Makefile new file mode 100644 index 0000000..d03c498 --- /dev/null +++ b/board/cirrus/edb93xx/Makefile @@ -0,0 +1,11 @@ +# +# (C) Copyright 2013 +# Sergey Kostanbaev <sergey.kostanbaev <at> fairwaves.ru> +# +# (C) Copyright 2003-2006 +# Wolfgang Denk, DENX Software Engineering, wd <at> denx.de. +# +# * SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := edb93xx.o diff --git a/board/cirrus/edb93xx/edb93xx.c b/board/cirrus/edb93xx/edb93xx.c new file mode 100644 index 0000000..8963d3a --- /dev/null +++ b/board/cirrus/edb93xx/edb93xx.c @@ -0,0 +1,382 @@ +/* + * Board initialization for EP93xx + * + * Copyright (C) 2013 + * Sergey Kostanbaev <sergey.kostanbaev <at> fairwaves.ru> + * + * Copyright (C) 2009 + * Matthias Kaehlcke <matthias <at> kaehlcke.net> + * + * (C) Copyright 2002 2003 + * Network Audio Technologies, Inc. <www.netaudiotech.com> + * Adam Bezanson <bezanson <at> netaudiotech.com> + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <common.h> +#include <netdev.h> +#include <asm/io.h> +#include <asm/arch/ep93xx.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * usb_div: 4, nbyp2: 1, pll2_en: 1 + * pll2_x1: 368640000.000000, pll2_x2ip: 15360000.000000, + * pll2_x2: 384000000.000000, pll2_out: 192000000.000000 + */ +#define CLKSET2_VAL (23 << SYSCON_CLKSET_PLL_X2IPD_SHIFT | \ + 24 << SYSCON_CLKSET_PLL_X2FBD2_SHIFT | \ + 24 << SYSCON_CLKSET_PLL_X1FBD1_SHIFT | \ + 1 << SYSCON_CLKSET_PLL_PS_SHIFT | \ + SYSCON_CLKSET2_PLL2_EN | \ + SYSCON_CLKSET2_NBYP2 | \ + 3 << SYSCON_CLKSET2_USB_DIV_SHIFT) + +#define SMC_BCR6_VALUE (2 << SMC_BCR_IDCY_SHIFT | 5 << SMC_BCR_WST1_SHIFT | \ + SMC_BCR_BLE | 2 << SMC_BCR_WST2_SHIFT | \ + 1 << SMC_BCR_MW_SHIFT) + +/* delay execution before timers are initialized */ +static inline void early_udelay(uint32_t usecs) +{ + /* loop takes 4 cycles at 5.0ns (fastest case, running at 200MHz) */ + register uint32_t loops = (usecs * 1000) / 20; + + __asm__ volatile ("1:\n" + "subs %0, %1, #1\n" + "bne 1b" : "=r" (loops) : "0" (loops)); +} + +#ifndef CONFIG_EP93XX_NO_FLASH_CFG +static void flash_cfg(void) +{ + struct smc_regs *smc = (struct smc_regs *)SMC_BASE; + + writel(SMC_BCR6_VALUE, &smc->bcr6); +} +#else +#define flash_cfg() +#endif + +int board_init(void) +{ + /* + * Setup PLL2, PPL1 has been set during lowlevel init + */ + struct syscon_regs *syscon = (struct syscon_regs *)SYSCON_BASE; + writel(CLKSET2_VAL, &syscon->clkset2); + + /* + * the user's guide recommends to wait at least 1 ms for PLL2 to + * stabilize + */ + early_udelay(1000); + + /* Go to Async mode */ + __asm__ volatile ("mrc p15, 0, r0, c1, c0, 0"); + __asm__ volatile ("orr r0, r0, #0xc0000000"); + __asm__ volatile ("mcr p15, 0, r0, c1, c0, 0"); + + icache_enable(); + +#ifdef USE_920T_MMU + dcache_enable(); +#endif + + /* Machine number, as defined in linux/arch/arm/tools/mach-types */ + gd->bd->bi_arch_number = CONFIG_MACH_TYPE; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = LINUX_BOOT_PARAM_ADDR; + + /* We have a console */ + gd->have_console = 1; + + enable_interrupts(); + + flash_cfg(); + + green_led_on(); + red_led_off(); + + return 0; +} + +int board_early_init_f(void) +{ + /* + * set UARTBAUD bit to drive UARTs with 14.7456MHz instead of + * 14.7456/2 MHz + */ + struct syscon_regs *syscon = (struct syscon_regs *)SYSCON_BASE; + writel(SYSCON_PWRCNT_UART_BAUD, &syscon->pwrcnt); + return 0; +} + +int board_eth_init(bd_t *bd) +{ + return ep93xx_eth_initialize(0, MAC_BASE); +} + +static void dram_fill_bank_addr(unsigned dram_addr_mask, unsigned dram_bank_cnt, + unsigned dram_bank_base[CONFIG_NR_DRAM_BANKS]) +{ + if (dram_bank_cnt == 1) { + dram_bank_base[0] = PHYS_SDRAM_1; + } else { + /* Table lookup for holes in address space. Maximum memory + * for the single SDCS may be up to 256Mb. We start scanning + * banks from 1Mb, so it could be up to 128 banks theoretically. + * We need at maximum 7 bits for the loockup, 8 slots is + * enough for the worst case. + */ + unsigned tbl[8]; + unsigned i = dram_bank_cnt / 2; + unsigned j = 0x00100000; /* 1 Mb */ + unsigned *ptbl = tbl; + do { + while (!(dram_addr_mask & j)) { + j <<= 1; + } + *ptbl++ = j; + j <<= 1; + i >>= 1; + } while (i != 0); + + for (i = dram_bank_cnt, j = 0; + (i != 0) && (j < CONFIG_NR_DRAM_BANKS); --i, ++j) { + unsigned addr = PHYS_SDRAM_1; + unsigned k; + unsigned bit; + + for (k = 0, bit = 1; k < 8; k++, bit <<= 1) { + if (bit & j) + addr |= tbl[k]; + } + + dram_bank_base[j] = addr; + } + } +} + +/* called in board_init_f (before relocation) */ +static unsigned dram_init_banksize_int(int print) +{ + /* + * Collect information of banks that has been filled during lowlevel + * initialization + */ + unsigned i; + unsigned dram_bank_base[CONFIG_NR_DRAM_BANKS]; + unsigned dram_total = 0; + unsigned dram_bank_size = *(unsigned *) + (PHYS_SDRAM_1 | UBOOT_MEMORYCNF_BANK_SIZE); + unsigned dram_addr_mask = *(unsigned *) + (PHYS_SDRAM_1 | UBOOT_MEMORYCNF_BANK_MASK); + unsigned dram_bank_cnt = *(unsigned *) + (PHYS_SDRAM_1 | UBOOT_MEMORYCNF_BANK_COUNT); + + dram_fill_bank_addr(dram_addr_mask, dram_bank_cnt, dram_bank_base); + + for (i = 0; i < dram_bank_cnt; i++) { + gd->bd->bi_dram[i].start = dram_bank_base[i]; + gd->bd->bi_dram[i].size = dram_bank_size; + dram_total += dram_bank_size; + } + for (; i < CONFIG_NR_DRAM_BANKS; i++) { + gd->bd->bi_dram[i].start = 0; + gd->bd->bi_dram[i].size = 0; + } + + if (print) { + printf("DRAM mask: %08x\n", dram_addr_mask); + printf("DRAM total %u banks:\n", dram_bank_cnt); + printf("bank base-address size\n"); + + if (dram_bank_cnt > CONFIG_NR_DRAM_BANKS) { + printf("WARNING! UBoot was configured for %u banks,\n" + "but %u has been found. " + "Supressing extra memory banks\n", + CONFIG_NR_DRAM_BANKS, dram_bank_cnt); + dram_bank_cnt = CONFIG_NR_DRAM_BANKS; + } + + for (i = 0; i < dram_bank_cnt; i++) { + printf(" %u %08x %08x\n", + i, dram_bank_base[i], dram_bank_size); + } + printf(" ------------------------------------------\n" + "Total %9d\n\n", + dram_total); + } + + return dram_total; +} + +void dram_init_banksize(void) +{ + dram_init_banksize_int(0); +} + +/* called in board_init_f (before relocation) */ +int dram_init(void) +{ + struct syscon_regs *syscon = (struct syscon_regs *)SYSCON_BASE; + unsigned sec_id = readl(SECURITY_EXTENSIONID); + unsigned chip_id = readl(&syscon->chipid); + + printf("CPU: Cirrus Logic "); + switch (sec_id & 0x000001FE) { + case 0x00000008: + printf("EP9301"); + break; + case 0x00000004: + printf("EP9307"); + break; + case 0x00000002: + printf("EP931x"); + break; + case 0x00000000: + printf("EP9315"); + break; + default: + printf("<unknown>"); + break; + } + + printf(" - Rev. "); + switch (chip_id & 0xF0000000) { + case 0x00000000: + printf("A"); + break; + case 0x10000000: + printf("B"); + break; + case 0x20000000: + printf("C"); + break; + case 0x30000000: + printf("D0"); + break; + case 0x40000000: + printf("D1"); + break; + case 0x50000000: + printf("E0"); + break; + case 0x60000000: + printf("E1"); + break; + case 0x70000000: + printf("E2"); + break; + default: + printf("?"); + break; + } + printf(" (SecExtID=%.8x/ChipID=%.8x)\n", sec_id, chip_id); + + gd->ram_size = dram_init_banksize_int(1); + return 0; +} + + +#ifdef CONFIG_EP93XX_SPI +#include <spi.h> + +/* + * EGIO0-EGIPO7 -> port A + * EGIO8-EGIP15 -> port B + */ + +static void ep93xx_set_epgio(unsigned num) +{ + struct gpio_regs *regs = (struct gpio_regs *)GPIO_BASE; + if (num < 8) + writel(readl(®s->padr) | (1<<num), ®s->padr); + else + writel(readl(®s->pbdr) | (1<<(num-8)), ®s->pbdr); +} + +static void ep93xx_clear_epgio(unsigned num) +{ + struct gpio_regs *regs = (struct gpio_regs *)GPIO_BASE; + if (num < 8) + writel(readl(®s->padr) & (~(1<<num)), ®s->padr); + else + writel(readl(®s->pbdr) & (~(1<<(num-8))), ®s->pbdr); +} + +static void ep93xx_dir_epgio_out(unsigned num) +{ + struct gpio_regs *regs = (struct gpio_regs *)GPIO_BASE; + if (num < 8) + writel(readl(®s->paddr) | (1<<num), ®s->paddr); + else + writel(readl(®s->pbddr) | (1<<(num-8)), ®s->pbddr); +} + +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + if (bus == 0 && cs < 16) + return 1; + + return 0; +} + +void spi_cs_activate(struct spi_slave *slave) +{ + ep93xx_clear_epgio(slave->cs); +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + ep93xx_set_epgio(slave->cs); +} + +#ifdef CONFIG_MMC_SPI +#include <mmc.h> + +#ifndef CONFIG_MMC_SPI_CS_EPGIO +# define CONFIG_MMC_SPI_CS_EPGIO 4 +#endif + +#ifndef CONFIG_MMC_SPI_SPEED +# define CONFIG_MMC_SPI_SPEED 25000000 +#endif + +#ifndef CONFIG_MMC_SPI_MODE +# define CONFIG_MMC_SPI_MODE SPI_MODE_0 +#endif + +int board_mmc_init(bd_t *bis) +{ + struct gpio_regs *regs = (struct gpio_regs *)GPIO_BASE; + + ep93xx_set_epgio(CONFIG_MMC_SPI_CS_EPGIO); + ep93xx_dir_epgio_out(CONFIG_MMC_SPI_CS_EPGIO); + +#ifdef CONFIG_MMC_SPI_POWER_EGPIO + ep93xx_dir_epgio_out(CONFIG_MMC_SPI_POWER_EGPIO); + ep93xx_set_epgio(CONFIG_MMC_SPI_POWER_EGPIO); +#elif defined(CONFIG_MMC_SPI_NPOWER_EGPIO) + ep93xx_dir_epgio_out(CONFIG_MMC_SPI_NPOWER_EGPIO); + ep93xx_clear_epgio(CONFIG_MMC_SPI_NPOWER_EGPIO); +#endif + struct mmc *mmc = mmc_spi_init(0, CONFIG_MMC_SPI_CS_EPGIO, + CONFIG_MMC_SPI_SPEED, CONFIG_MMC_SPI_MODE); + + if (!mmc) { + printf("Failed to create MMC Device\n"); + return 1; + } + mmc_init(mmc); + return 0; +} + + +#endif /* CONFIG_MMC_SPI */ +#endif /* CONFIG_EP93XX_SPI */ diff --git a/board/cirrus/edb93xx/u-boot.lds b/board/cirrus/edb93xx/u-boot.lds new file mode 100644 index 0000000..e61aa36 --- /dev/null +++ b/board/cirrus/edb93xx/u-boot.lds @@ -0,0 +1,115 @@ +/* + * + * Copyright (C) 2013 + * Sergey Kostanbaev <sergey.kostanbaev <at> fairwaves.ru> + * + * Copyright (c) 2004-2008 Texas Instruments + * + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : { + *(.__image_copy_start) + arch/arm/cpu/arm920t/start.o (.text*) + . = 0x1000; + + LONG(0x53555243) + *(.text*) + } + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + + . = ALIGN(4); + .data : { + *(.data*) + } + + . = ALIGN(4); + + . = .; + + . = ALIGN(4); + .u_boot_list : { + KEEP(*(SORT(.u_boot_list*))); + } + + . = ALIGN(4); + + .image_copy_end : + { + *(.__image_copy_end) + } + + .rel_dyn_start : + { + *(.__rel_dyn_start) + } + + .rel.dyn : { + *(.rel*) + } + + .rel_dyn_end : + { + *(.__rel_dyn_end) + } + + .end : + { + *(.__end) + } + + _image_binary_end = .; + + /* + * Deprecated: this MMU section is used by pxa at present but + * should not be used by new boards/CPUs. + */ + . = ALIGN(4096); + .mmutable : { + *(.mmutable) + } + +/* + * Compiler-generated __bss_start and __bss_end, see arch/arm/lib/bss.c + * __bss_base and __bss_limit are for linker only (overlay ordering) + */ + + .bss_start __rel_dyn_start (OVERLAY) : { + KEEP(*(.__bss_start)); + __bss_base = .; + } + + .bss __bss_base (OVERLAY) : { + *(.bss*) + . = ALIGN(4); + __bss_limit = .; + } + + .bss_end __bss_limit (OVERLAY) : { + KEEP(*(.__bss_end)); + } + + .dynsym _image_binary_end : { *(.dynsym) } + .dynbss : { *(.dynbss) } + .dynstr : { *(.dynstr*) } + .dynamic : { *(.dynamic*) } + .plt : { *(.plt*) } + .interp : { *(.interp*) } + .gnu.hash : { *(.gnu.hash) } + .gnu : { *(.gnu*) } + .ARM.exidx : { *(.ARM.exidx*) } + .gnu.linkonce.armexidx : { *(.gnu.linkonce.armexidx.*) } +} diff --git a/boards.cfg b/boards.cfg index 2128996..4c5f1b8 100644 --- a/boards.cfg +++ b/boards.cfg @@ -74,6 +74,7 @@ Active arm arm920t ks8695 - - Active arm arm920t ks8695 - - cm41xx - - Active arm arm920t s3c24x0 mpl vcma9 VCMA9 - David Müller d.mueller@elsoft.ch Active arm arm920t s3c24x0 samsung - smdk2410 - David Müller d.mueller@elsoft.ch +Active arm arm920t ep93xx cirrus edb93xx edb9315a edb93xx:MK_edb9315a Sergey Kostanbaev sergey.kostanbaev@fairwaves.ru Active arm arm926ejs - armltd integrator integratorap_cm926ejs integratorap:CM926EJ_S Linus Walleij linus.walleij@linaro.org Active arm arm926ejs - armltd integrator integratorcp_cm926ejs integratorcp:CM924EJ_S Linus Walleij linus.walleij@linaro.org Active arm arm926ejs armada100 Marvell - aspenite - Prafulla Wadaskar prafulla@marvell.com diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index ed4ecd7..c5d6c6a 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -8,6 +8,7 @@ # There are many options which enable SPI, so make this library available obj-y += spi.o
+obj-$(CONFIG_EP93XX_SPI) += ep93xx_spi.o obj-$(CONFIG_ALTERA_SPI) += altera_spi.o obj-$(CONFIG_ANDES_SPI) += andes_spi.o obj-$(CONFIG_ARMADA100_SPI) += armada100_spi.o diff --git a/drivers/spi/ep93xx_spi.c b/drivers/spi/ep93xx_spi.c new file mode 100644 index 0000000..235557e --- /dev/null +++ b/drivers/spi/ep93xx_spi.c @@ -0,0 +1,274 @@ +/* + * SPI Driver for EP93xx + * + * Copyright (C) 2013 Sergey Kostanabev <sergey.kostanbaev <at> fairwaves.ru> + * + * Inspired form linux kernel driver and atmel uboot driver + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <spi.h> +#include <malloc.h> + +#include <asm/io.h> + +#include <asm/arch/ep93xx.h> + + +#define BIT(x) (1<<(x)) +#define SSPBASE SPI_BASE + +#define SSPCR0 0x0000 +#define SSPCR0_MODE_SHIFT 6 +#define SSPCR0_SCR_SHIFT 8 +#define SSPCR0_SPH BIT(7) +#define SSPCR0_SPO BIT(6) +#define SSPCR0_FRF_SPI 0 +#define SSPCR0_DSS_8BIT 7 + +#define SSPCR1 0x0004 +#define SSPCR1_RIE BIT(0) +#define SSPCR1_TIE BIT(1) +#define SSPCR1_RORIE BIT(2) +#define SSPCR1_LBM BIT(3) +#define SSPCR1_SSE BIT(4) +#define SSPCR1_MS BIT(5) +#define SSPCR1_SOD BIT(6) + +#define SSPDR 0x0008 + +#define SSPSR 0x000c +#define SSPSR_TFE BIT(0) +#define SSPSR_TNF BIT(1) +#define SSPSR_RNE BIT(2) +#define SSPSR_RFF BIT(3) +#define SSPSR_BSY BIT(4) +#define SSPCPSR 0x0010 + +#define SSPIIR 0x0014 +#define SSPIIR_RIS BIT(0) +#define SSPIIR_TIS BIT(1) +#define SSPIIR_RORIS BIT(2) +#define SSPICR SSPIIR + +#define SSPCLOCK 14745600 +#define SSP_MAX_RATE (SSPCLOCK / 2) +#define SSP_MIN_RATE (SSPCLOCK / (254 * 256)) + +/* timeout in milliseconds */ +#define SPI_TIMEOUT 5 +/* maximum depth of RX/TX FIFO */ +#define SPI_FIFO_SIZE 8 + +struct ep93xx_spi_slave { + struct spi_slave slave; + + unsigned sspcr0; + unsigned sspcpsr; +}; + +static inline struct ep93xx_spi_slave *to_ep93xx_spi(struct spi_slave *slave) +{ + return container_of(slave, struct ep93xx_spi_slave, slave); +} + +void spi_init() +{ +} + +static inline void ep93xx_spi_write_u8(u16 reg, u8 value) +{ + writel(value, (unsigned int *)(SSPBASE + reg)); +} + +static inline u8 ep93xx_spi_read_u8(u16 reg) +{ + return readl((unsigned int *)(SSPBASE + reg)); +} + +static inline void ep93xx_spi_write_u16(u16 reg, u16 value) +{ + writel(value, (unsigned int *)(SSPBASE + reg)); +} + +static inline u16 ep93xx_spi_read_u16(u16 reg) +{ + return (u16)readl((unsigned int *)(SSPBASE + reg)); +} + +static int ep93xx_spi_init_hw(unsigned int rate, unsigned int mode, + struct ep93xx_spi_slave *slave) +{ + unsigned cpsr, scr; + + if (rate > SSP_MAX_RATE) + rate = SSP_MAX_RATE; + + if (rate < SSP_MIN_RATE) + return -1; + + /* Calculate divisors so that we can get speed according the + * following formula: + * rate = spi_clock_rate / (cpsr * (1 + scr)) + * + * cpsr must be even number and starts from 2, scr can be any number + * between 0 and 255. + */ + for (cpsr = 2; cpsr <= 254; cpsr += 2) { + for (scr = 0; scr <= 255; scr++) { + if ((SSPCLOCK / (cpsr * (scr + 1))) <= rate) { + /* Set CHPA and CPOL, SPI format and 8bit */ + unsigned sspcr0 = (scr << SSPCR0_SCR_SHIFT) | + SSPCR0_FRF_SPI | SSPCR0_DSS_8BIT; + if (mode & SPI_CPHA) + sspcr0 |= SSPCR0_SPH; + if (mode & SPI_CPOL) + sspcr0 |= SSPCR0_SPO; + + slave->sspcr0 = sspcr0; + slave->sspcpsr = cpsr; + return 0; + } + } + } + + return -1; +} + +void spi_set_speed(struct spi_slave *slave, unsigned int hz) +{ + struct ep93xx_spi_slave *as = to_ep93xx_spi(slave); + + unsigned int mode = 0; + if (as->sspcr0 & SSPCR0_SPH) + mode |= SPI_CPHA; + if (as->sspcr0 & SSPCR0_SPO) + mode |= SPI_CPOL; + + ep93xx_spi_init_hw(hz, mode, as); +} + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct ep93xx_spi_slave *as; + + if (!spi_cs_is_valid(bus, cs)) + return NULL; + + as = spi_alloc_slave(struct ep93xx_spi_slave, bus, cs); + if (!as) + return NULL; + + if (ep93xx_spi_init_hw(max_hz, mode, as)) { + free(as); + return NULL; + } + + return &as->slave; +} + +void spi_free_slave(struct spi_slave *slave) +{ + struct ep93xx_spi_slave *as = to_ep93xx_spi(slave); + + free(as); +} + +int spi_claim_bus(struct spi_slave *slave) +{ + struct ep93xx_spi_slave *as = to_ep93xx_spi(slave); + + /* Enable the SPI hardware */ + ep93xx_spi_write_u8(SSPCR1, SSPCR1_SSE); + + + ep93xx_spi_write_u8(SSPCPSR, as->sspcpsr); + ep93xx_spi_write_u16(SSPCR0, as->sspcr0); + + debug("Select CS:%d SSPCPSR=%02x SSPCR0=%04x\n", + slave->cs, as->sspcpsr, as->sspcr0); + return 0; +} + +void spi_release_bus(struct spi_slave *slave) +{ + /* Disable the SPI hardware */ + ep93xx_spi_write_u8(SSPCR1, 0); +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + unsigned int len_tx; + unsigned int len_rx; + unsigned int len; + u32 status; + const u8 *txp = dout; + u8 *rxp = din; + u8 value; + + debug("spi_xfer: slave %u:%u dout %p din %p bitlen %u\n", + slave->bus, slave->cs, (uint *)dout, (uint *)din, bitlen); + + + if (bitlen == 0) + /* Finish any previously submitted transfers */ + goto out; + + if (bitlen % 8) { + /* Errors always terminate an ongoing transfer */ + flags |= SPI_XFER_END; + goto out; + } + + len = bitlen / 8; + + + if (flags & SPI_XFER_BEGIN) { + /* Empty RX FIFO */ + while ((ep93xx_spi_read_u8(SSPSR) & SSPSR_RNE)) + ep93xx_spi_read_u8(SSPDR); + + spi_cs_activate(slave); + } + + for (len_tx = 0, len_rx = 0; len_rx < len; ) { + status = ep93xx_spi_read_u8(SSPSR); + + if ((len_tx < len) && (status & SSPSR_TNF)) { + if (txp) + value = *txp++; + else + value = 0xff; + + ep93xx_spi_write_u8(SSPDR, value); + len_tx++; + } + + if (status & SSPSR_RNE) { + value = ep93xx_spi_read_u8(SSPDR); + + if (rxp) + *rxp++ = value; + len_rx++; + } + } + +out: + if (flags & SPI_XFER_END) { + /* + * Wait until the transfer is completely done before + * we deactivate CS. + */ + do { + status = ep93xx_spi_read_u8(SSPSR); + } while (status & SSPSR_BSY); + + spi_cs_deactivate(slave); + } + + return 0; +} diff --git a/drivers/usb/host/Makefile b/drivers/usb/host/Makefile index 1417028..5cab359 100644 --- a/drivers/usb/host/Makefile +++ b/drivers/usb/host/Makefile @@ -13,6 +13,7 @@ obj-$(CONFIG_USB_ISP116X_HCD) += isp116x-hcd.o obj-$(CONFIG_USB_R8A66597_HCD) += r8a66597-hcd.o obj-$(CONFIG_USB_SL811HS) += sl811-hcd.o obj-$(CONFIG_USB_OHCI_S3C24XX) += ohci-s3c24xx.o +obj-$(CONFIG_USB_OHCI_EP93XX) += ohci-ep93xx.o
# echi obj-$(CONFIG_USB_EHCI) += ehci-hcd.o diff --git a/drivers/usb/host/ohci-ep93xx.c b/drivers/usb/host/ohci-ep93xx.c new file mode 100644 index 0000000..8fb4aba --- /dev/null +++ b/drivers/usb/host/ohci-ep93xx.c @@ -0,0 +1,38 @@ +/* + * (C) Copyright 2013 + * Sergey Kostanbaev < sergey.kostanbaev <at> fairwaves.ru > + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <common.h> + +#if defined(CONFIG_USB_OHCI_NEW) && defined(CONFIG_SYS_USB_OHCI_CPU_INIT) +#include <asm/io.h> +#include <asm/arch/ep93xx.h> + +int usb_cpu_init(void) +{ + struct syscon_regs *syscon = (struct syscon_regs *)SYSCON_BASE; + unsigned long pwr = readl(&syscon->pwrcnt); + writel(pwr | SYSCON_PWRCNT_USH_EN, &syscon->pwrcnt); + + return 0; +} + +int usb_cpu_stop(void) +{ + struct syscon_regs *syscon = (struct syscon_regs *)SYSCON_BASE; + unsigned long pwr = readl(&syscon->pwrcnt); + writel(pwr & ~SYSCON_PWRCNT_USH_EN, &syscon->pwrcnt); + + return 0; +} + +int usb_cpu_init_fail(void) +{ + return usb_cpu_stop(); +} + +#endif /* defined(CONFIG_USB_OHCI) && defined(CONFIG_SYS_USB_OHCI_CPU_INIT) */ diff --git a/include/configs/edb93xx.h b/include/configs/edb93xx.h new file mode 100644 index 0000000..37bdcc0 --- /dev/null +++ b/include/configs/edb93xx.h @@ -0,0 +1,292 @@ +/* + * U-boot - Configuration file for Cirrus Logic EDB93xx boards + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#ifdef CONFIG_MK_edb9301 +#define CONFIG_EDB9301 +#elif defined(CONFIG_MK_edb9302) +#define CONFIG_EDB9302 +#elif defined(CONFIG_MK_edb9302a) +#define CONFIG_EDB9302A +#elif defined(CONFIG_MK_edb9307) +#define CONFIG_EDB9307 +#elif defined(CONFIG_MK_edb9307a) +#define CONFIG_EDB9307A +#elif defined(CONFIG_MK_edb9312) +#define CONFIG_EDB9312 +#elif defined(CONFIG_MK_edb9315) +#define CONFIG_EDB9315 +#elif defined(CONFIG_MK_edb9315a) +#define CONFIG_EDB9315A +#else +#error "no board defined" +#endif + +/* Initial environment and monitor configuration options. */ +#define CONFIG_BOOTDELAY 2 +#define CONFIG_CMDLINE_TAG 1 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_BOOTARGS "root=/dev/nfs console=ttyAM0,115200 ip=dhcp" +#define CONFIG_BOOTFILE "edb93xx.img" + +#define CONFIG_SYS_HUSH_PARSER 1 +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + + +#define CONFIG_SYS_LDSCRIPT "board/cirrus/edb93xx/u-boot.lds" + + +#ifdef CONFIG_EDB9301 +#define CONFIG_EP9301 +#define CONFIG_MACH_TYPE MACH_TYPE_EDB9301 +#define CONFIG_SYS_PROMPT "EDB9301> " +#define CONFIG_ENV_SECT_SIZE 0x00020000 +#elif defined(CONFIG_EDB9302) +#define CONFIG_EP9302 +#define CONFIG_MACH_TYPE MACH_TYPE_EDB9302 +#define CONFIG_SYS_PROMPT "EDB9302> " +#define CONFIG_ENV_SECT_SIZE 0x00020000 +#elif defined(CONFIG_EDB9302A) +#define CONFIG_EP9302 +#define CONFIG_MACH_TYPE MACH_TYPE_EDB9302A +#define CONFIG_SYS_PROMPT "EDB9302A> " +#define CONFIG_ENV_SECT_SIZE 0x00020000 +#elif defined(CONFIG_EDB9307) +#define CONFIG_EP9307 +#define CONFIG_MACH_TYPE MACH_TYPE_EDB9307 +#define CONFIG_SYS_PROMPT "EDB9307> " +#define CONFIG_ENV_SECT_SIZE 0x00040000 +#elif defined(CONFIG_EDB9307A) +#define CONFIG_EP9307 +#define CONFIG_MACH_TYPE MACH_TYPE_EDB9307A +#define CONFIG_SYS_PROMPT "EDB9307A> " +#define CONFIG_ENV_SECT_SIZE 0x00020000 +#elif defined(CONFIG_EDB9312) +#define CONFIG_EP9312 +#define CONFIG_MACH_TYPE MACH_TYPE_EDB9312 +#define CONFIG_SYS_PROMPT "EDB9312> " +#define CONFIG_ENV_SECT_SIZE 0x00040000 +#elif defined(CONFIG_EDB9315) +#define CONFIG_EP9315 +#define CONFIG_MACH_TYPE MACH_TYPE_EDB9315 +#define CONFIG_SYS_PROMPT "EDB9315> " +#define CONFIG_ENV_SECT_SIZE 0x00040000 +#elif defined(CONFIG_EDB9315A) +#define CONFIG_EP9315 +#define CONFIG_MACH_TYPE MACH_TYPE_EDB9315A +#define CONFIG_SYS_PROMPT "EDB9315A> " +#define CONFIG_ENV_SECT_SIZE 0x00020000 +#else +#error "no board defined" +#endif + +/* High-level configuration options */ +#define CONFIG_ARM920T 1 /* This is an ARM920T core... */ +#define CONFIG_EP93XX 1 /* in a Cirrus Logic 93xx SoC */ + +#define CONFIG_SYS_CLK_FREQ 14745600 /* EP93xx has a 14.7456 clock */ +#define CONFIG_SYS_HZ 1000 /* decr freq: 1 ms ticks */ +#undef CONFIG_USE_IRQ /* Don't need IRQ/FIQ */ + +/* Monitor configuration */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_SETGETDCR +#undef CONFIG_CMD_XIMG + +#undef CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_JFFS2 + +#define CONFIG_SYS_LONGHELP /* Enable "long" help in mon */ +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O buffer size */ +/* Print buffer size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +/* Boot argument buffer size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_MAXARGS 16 /* Max number of command args */ + +/* Serial port hardware configuration */ +#define CONFIG_PL010_SERIAL +#define CONFIG_CONS_INDEX 0 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, \ + 115200, 230400} +#define CONFIG_SYS_SERIAL0 0x808C0000 +#define CONFIG_SYS_SERIAL1 0x808D0000 +/*#define CONFIG_PL01x_PORTS {(void *)CONFIG_SYS_SERIAL0, \ + (void *)CONFIG_SYS_SERIAL1} */ + +#define CONFIG_PL01x_PORTS {(void *)CONFIG_SYS_SERIAL0} + +/* Status LED */ +#define CONFIG_STATUS_LED 1 /* Status LED enabled */ +#define CONFIG_BOARD_SPECIFIC_LED 1 +#define STATUS_LED_GREEN 0 +#define STATUS_LED_RED 1 +/* Green */ +#define STATUS_LED_BIT STATUS_LED_GREEN +#define STATUS_LED_STATE STATUS_LED_ON +#define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 2) +/* Red */ +#define STATUS_LED_BIT1 STATUS_LED_RED +#define STATUS_LED_STATE1 STATUS_LED_OFF +#define STATUS_LED_PERIOD1 (CONFIG_SYS_HZ / 2) +/* Optional value */ +#define STATUS_LED_BOOT STATUS_LED_BIT + +/* Network hardware configuration */ +#define CONFIG_DRIVER_EP93XX_MAC +#define CONFIG_MII_SUPPRESS_PREAMBLE +#define CONFIG_MII +#define CONFIG_PHY_ADDR 1 +#define CONFIG_NET_MULTI +#undef CONFIG_NETCONSOLE + +/* SDRAM configuration */ +#if defined(CONFIG_EDB9301) || defined(CONFIG_EDB9302) || \ + defined(CONFIG_EDB9307) || defined CONFIG_EDB9312 || \ + defined(CONFIG_EDB9315) +/* + * EDB9301/2 has 4 banks of SDRAM consisting of 1x Samsung K4S561632E-TC75 + * 256 Mbit SDRAM on a 16-bit data bus, for a total of 32MB of SDRAM. We set + * the SROMLL bit on the processor, resulting in this non-contiguous memory map. + * + * The EDB9307, EDB9312, and EDB9315 have 2 banks of SDRAM consisting of + * 2x Samsung K4S561632E-TC75 256 Mbit on a 32-bit data bus, for a total of + * 64 MB of SDRAM. + */ + +#define CONFIG_EDB93XX_SDCS3 + +#elif defined(CONFIG_EDB9302A) || \ + defined(CONFIG_EDB9307A) || defined(CONFIG_EDB9315A) +/* + * EDB9302a has 4 banks of SDRAM consisting of 1x Samsung K4S561632E-TC75 + * 256 Mbit SDRAM on a 16-bit data bus, for a total of 32MB of SDRAM. We set + * the SROMLL bit on the processor, resulting in this non-contiguous memory map. + * + * The EDB9307A and EDB9315A have 2 banks of SDRAM consisting of 2x Samsung + * K4S561632E-TC75 256 Mbit on a 32-bit data bus, for a total of 64 MB of SDRAM. + */ +#define CONFIG_EDB93XX_SDCS0 + +#else +#error "no SDCS configuration for this board" +#endif + + +#if defined(CONFIG_EDB93XX_SDCS3) +#define CONFIG_SYS_LOAD_ADDR 0x01000000 /* Default load address */ +#define PHYS_SDRAM_1 0x00000000 +#elif defined(CONFIG_EDB93XX_SDCS0) +#define CONFIG_SYS_LOAD_ADDR 0xc1000000 /* Default load address */ +#define PHYS_SDRAM_1 0xc0000000 +#endif + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_NR_DRAM_BANKS 8 + +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_SDRAM_BASE + 32*1024 - GENERATED_GBL_DATA_SIZE) + + +/* Must match kernel config */ +#define LINUX_BOOT_PARAM_ADDR (PHYS_SDRAM_1 + 0x100) + +/* Run-time memory allocatons */ +#define CONFIG_SYS_GBL_DATA_SIZE 128 +#define CONFIG_STACKSIZE (128 * 1024) + +#if defined(CONFIG_USE_IRQ) +#define CONFIG_STACKSIZE_IRQ (4 * 1024) +#define CONFIG_STACKSIZE_FIQ (4 * 1024) +#endif + +#define CONFIG_SYS_MALLOC_LEN (512 * 1024) + +/* ----------------------------------------------------------------------------- + * FLASH and environment organization + * + * The EDB9301, EDB9302(a), EDB9307a, EDB9315a have 1 bank of flash memory at + * 0x60000000 consisting of 1x Intel TE28F128J3C-150 128 Mbit flash on a 16-bit + * data bus, for a total of 16 MB of CFI-compatible flash. + * + * The EDB9307, EDB9312, and EDB9315 have 1 bank of flash memory at + * 0x60000000 consisting of 2x Micron MT28F128J3-12 128 Mbit flash on a 32-bit + * data bus, for a total of 32 MB of CFI-compatible flash. + * + * + * EDB9301/02(a)7a/15a EDB9307/12/15 + * 0x60000000 - 0x0003FFFF u-boot u-boot + * 0x60040000 - 0x0005FFFF environment #1 environment #1 + * 0x60060000 - 0x0007FFFF environment #2 environment #1 (continued) + * 0x60080000 - 0x0009FFFF unused environment #2 + * 0x600A0000 - 0x000BFFFF unused environment #2 (continued) + * 0x600C0000 - 0x00FFFFFF unused unused + * 0x61000000 - 0x01FFFFFF not present unused + */ +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE + + +#define CONFIG_SYS_FLASH_PROTECTION +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT (256+8) + +#define CONFIG_SYS_TEXT_BASE 0x60000000 +#define PHYS_FLASH_1 CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_TEXT_BASE + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE +#define CONFIG_SYS_MONITOR_LEN (256 * 1024) + +#define CONFIG_ENV_OVERWRITE /* Vendor params unprotected */ +#define CONFIG_ENV_IS_IN_FLASH + +#define CONFIG_ENV_ADDR 0x60040000 +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) + +#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE + +/* Define to enable MMC on SPI support */ +/* #define CONFIG_EP93XX_SPI_MMC */ + +#ifdef CONFIG_EP93XX_SPI_MMC +#define CONFIG_EP93XX_SPI +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_MMC_SPI +#define CONFIG_CMD_MMC +#define CONFIG_MMC_SPI_NPOWER_EGPIO 9 +#endif + +#define CONFIG_USB_STORAGE +#define CONFIG_USB_OHCI_NEW +#define CONFIG_USB_OHCI_EP93XX +#define CONFIG_SYS_USB_OHCI_CPU_INIT +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 3 +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "ep93xx-ohci" +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x80020000 + +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_EXT4 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_USB + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_CMD_BOOTZ + +/* Define to disable flash configuration*/ +/* #define CONFIG_EP93XX_NO_FLASH_CFG */ + +/* Define this for indusrial rated chips */ +/* #define CONFIG_EDB93XX_INDUSTRIAL */ + +#endif /* !defined (__CONFIG_H) */
Hi Sergey,
On Wed, 25 Jun 2014 23:44:29 +0400, Sergey Kostanbev sergey.kostanbaev@gmail.com wrote:
- Low-level initialization for EP93xx
- Copyright (C) 2009 Matthias Kaehlcke matthias@kaehlcke.net
- Copyright (C) 2013
- Sergey Kostanabev <sergey.kostanbaev <at> fairwaves.ru>
- Copyright (C) 2006 Dominic Rath Dominic.Rath@gmx.de
- Copyright (C) 2006 Cirrus Logic Inc.
- project.
- Input: r0 - SDRAM DEVCFG register
- Output: none
- Modifies: r3, r4
- /* Program the SDRAM device configuration register. */
- ldr r3, =SDRAM_BASE
- str r0, [r3, #SDRAM_OFF_DEVCFG0]
- str r0, [r3, #SDRAM_OFF_DEVCFG1]
- str r0, [r3, #SDRAM_OFF_DEVCFG2]
- str r0, [r3, #SDRAM_OFF_DEVCFG3]
- /* Set the Initialize and MRS bits (issue continuous NOP commands
* (INIT & MRS set))
- ldr r4, =(EP93XX_SDRAMCTRL_GLOBALCFG_INIT | \
- str r4, [r3, #SDRAM_OFF_GLCONFIG]
- /* Delay for 200us. */
- mov r4, #0x3000
+delay1:
- subs r4, r4, #1
- bne delay1
- /* Clear the MRS bit to issue a precharge all. */
- /* Temporarily set the refresh timer to 0x10. Make it really low so
- ldr r4, =0x10
- str r4, [r3, #SDRAM_OFF_REFRSHTIMR]
- /* Delay for at least 80 SDRAM clock cycles. */
- mov r4, #80
+delay2:
- subs r4, r4, #1
- bne delay2
- /* Set the refresh timer to the fastest required for any device
- ldr r4, =0x01e0
- /* Select mode register update mode. */
- ldr r4, =(EP93XX_SDRAMCTRL_GLOBALCFG_CKE | \
- /* Program the mode register on the SDRAM by performing fake read */
- ldr r4, [r2]
- /* Select normal operating mode. */
- ldr r4, =EP93XX_SDRAMCTRL_GLOBALCFG_CKE
- /* Return to the caller. */
- mov pc, lr
- Test to see if the SDRAM has been configured in a usable mode.
- Input: r0 - Test address of SDRAM
- Output: r0 - 0 -- Test OK, -1 -- Failed
- Modifies: r0-r5
+ep93xx_sdram_test:
- /* Load the test patterns to be written to SDRAM. */
- ldr r1, =0xf00dface
- ldr r2, =0xdeadbeef
- ldr r3, =0x08675309
- ldr r4, =0xdeafc0ed
- /* Store the test patterns to SDRAM. */
- stmia r0, {r1-r4}
- /* Load the test patterns from SDRAM one at a time and compare them
- ldr r5, [r0]
- cmp r5, r1
- ldreq r5, [r0, #0x0004]
- cmpeq r5, r2
- ldreq r5, [r0, #0x0008]
- cmpeq r5, r3
- ldreq r5, [r0, #0x000c]
- cmpeq r5, r4
- /* Return -1 if a mismatch was encountered, 0 otherwise. */
- mvnne r0, #0xffffffff
- moveq r0, #0x00000000
- mov pc, lr
- Determine the size of the SDRAM. Use data=address for the scan.
- Input: r0 - Start SDRAM address
- Return: r0 - Single block size
- Modifies: r0-r5
+ep93xx_sdram_size:
- /* Store zero at offset zero. */
- str r0, [r0]
- /* Start checking for an alias at 1MB into SDRAM. */
- ldr r1, =0x00100000
- /* Store the offset at the current offset. */
+check_block_size:
- str r1, [r0, r1]
- /* Read back from zero. */
- ldr r2, [r0]
- /* Stop searching of an alias was found. */
- cmp r1, r2
- beq found_block_size
- /* Advance to the next power of two boundary. */
- mov r1, r1, lsl #1
- /* Loop back if the size has not reached 256MB. */
- cmp r1, #0x10000000
- bne check_block_size
- /* A full 256MB of memory was found, so return it now. */
- ldr r0, =0x10000000
- ldr r1, =0x00000000
- ldr r2, =0x00000001
- mov pc, lr
- /* An alias was found. See if the first block is 128MB in size. */
+found_block_size:
- cmp r1, #0x08000000
- /* The first block is 128MB, so there is no further memory. Return it
* now.
- ldreq r0, =0x08000000
- ldreq r1, =0x00000000
- ldreq r2, =0x00000001
- moveq pc, lr
- /* Save the block size, set the block address bits to zero, and
- mov r3, r1
- ldr r4, =0x00000000
- ldr r5, =0x00000001
- /* Look for additional blocks of memory by searching for non-aliases. */
+find_blocks:
- /* Store zero back to address zero. It may be overwritten. */
- str r0, [r0]
- str r1, [r0, r1]
- ldr r2, [r0]
- /* See if a non-alias was found. */
- cmp r1, r2
- /* If a non-alias was found, then or in the block address bit and
- orrne r4, r4, r1
- movne r5, r5, lsl #1
- /* Continue searching if there are more address bits to check. */
- bne find_blocks
- /* Return the block size, address mask, and count. */
- mov r0, r3
- mov r1, r4
- mov r2, r5
- mov pc, lr
str lr, [r1]
bl red_led_on
bl green_led_on
- mov r6, lr
- /* Make sure caches are off and invalidated. */
- ldr r0, =0x00000000
- nop
- nop
- nop
- nop
- nop
- /* Turn off the green LED and turn on the red LED. If the red LED
- ldr r1, =EP93XX_LED_DATA
- ldr r0, [r1]
- bic r0, r0, #EP93XX_LED_GREEN_ON
- orr r0, r0, #EP93XX_LED_RED_ON
- str r0, [r1]
- /* Undo the silly static memory controller programming performed
* by the boot rom.
- ldr r0, =SMC_BASE
- /* Set WST1 and WST2 to 31 HCLK cycles (slowest access) */
- ldr r1, =0x0000fbe0
- /* Reset EP93XX_OFF_SMCBCR0 */
- ldr r2, [r0]
- orr r2, r2, r1
- str r2, [r0]
- ldr r2, [r0, #EP93XX_OFF_SMCBCR1]
- orr r2, r2, r1
- str r2, [r0, #EP93XX_OFF_SMCBCR1]
- ldr r2, [r0, #EP93XX_OFF_SMCBCR2]
- orr r2, r2, r1
- str r2, [r0, #EP93XX_OFF_SMCBCR2]
- ldr r2, [r0, #EP93XX_OFF_SMCBCR3]
- orr r2, r2, r1
- str r2, [r0, #EP93XX_OFF_SMCBCR3]
- ldr r2, [r0, #EP93XX_OFF_SMCBCR6]
- orr r2, r2, r1
- str r2, [r0, #EP93XX_OFF_SMCBCR6]
- ldr r2, [r0, #EP93XX_OFF_SMCBCR7]
- orr r2, r2, r1
- str r2, [r0, #EP93XX_OFF_SMCBCR7]
- /* Set the PLL1 and processor clock. */
- ldr r0, =SYSCON_BASE
- /* 332MHz, giving a 166MHz processor clock. */
- ldr r1, = 0x02b49907
+#else
- /* 384MHz, giving a 196MHz processor clock. */
- ldr r1, =0x02a4bb38
+#else
- /* 400MHz, giving a 200MHz processor clock. */
- ldr r1, =0x02a4e39e
+#endif +#endif
- str r1, [r0, #SYSCON_OFF_CLKSET1]
- nop
- nop
- nop
- nop
- nop
- /* Need to make sure that SDRAM is configured correctly before
- mov r11, #SDRAM_DEVCFG0_BASE
- mov r11, #SDRAM_DEVCFG1_BASE
- mov r11, #SDRAM_DEVCFG2_BASE
- ldr r0, [r0, #SYSCON_OFF_SYSCFG]
- ands r0, r0, #SYSCON_SYSCFG_LASDO
- moveq r11, #SDRAM_DEVCFG3_ASD0_BASE
- movne r11, #SDRAM_DEVCFG3_ASD1_BASE
- /* See Table 13-5 in EP93xx datasheet for more info about DRAM
- /* Try a 32-bit wide configuration of SDRAM. */
- ldr r0, =(EP93XX_SDRAMCTRL_DEVCFG_BANKCOUNT | \
- /* Set burst count: 4 and CAS: 2
- orr r2, r11, #0x00008800
- bl ep93xx_sdram_config
- /* Test the SDRAM. */
- mov r0, r11
- bl ep93xx_sdram_test
- cmp r0, #0x00000000
- beq ep93xx_sdram_done
- /* Try a 16-bit wide configuration of SDRAM. */
- /* Set burst count: 8, CAS: 2, sequential burst
- orr r2, r11, #0x00004600
- mov r0, r11
- /* Turn off the red LED. */
- ldr r0, =EP93XX_LED_DATA
- ldr r1, [r0]
- bic r1, r1, #EP93XX_LED_RED_ON
- str r1, [r0]
- /* There is no SDRAM so flash the green LED. */
+flash_green:
- orr r1, r1, #EP93XX_LED_GREEN_ON
- str r1, [r0]
- ldr r2, =0x00010000
- subs r2, r2, #1
- bne flash_green_delay_1
- bic r1, r1, #EP93XX_LED_GREEN_ON
- str r1, [r0]
- subs r2, r2, #1
- bne flash_green_delay_2
- str r1, [r0]
- subs r2, r2, #1
- bne flash_green_delay_3
- str r1, [r0]
- ldr r2, =0x00050000
- subs r2, r2, #1
- bne flash_green_delay_4
- b flash_green
- bl flash_cfg
+ep93xx_sdram_done:
- ldr r0, [r1]
- bic r0, r0, #EP93XX_LED_RED_ON
- str r0, [r1]
- /* Set up PLL */
- bl pll_cfg
- /* Determine the size of the SDRAM. */
- mov r0, r11
- bl ep93xx_sdram_size
- bl green_led_off
- /* Save the SDRAM characteristics. */
- mov r8, r0
- mov r9, r1
- mov r10, r2
- /* Setup SDRAM */
- bl sdram_cfg
- /* Compute total memory size into r1 */
- mul r1, r8, r10
- ldr r2, [r0, #SDRAM_OFF_DEVCFG0]
- ldr r2, [r0, #SDRAM_OFF_DEVCFG1]
- ldr r2, [r0, #SDRAM_OFF_DEVCFG2]
- ldr r2, [r0, #SDRAM_OFF_DEVCFG3]
- bl green_led_on
- bl red_led_off
- /* Consider small DRAM size as:
- tst r2, #EP93XX_SDRAMCTRL_DEVCFG_EXTBUSWIDTH
- moveq r1, r1, lsr #1
- cmp r1, #0x02000000
- /* Set refresh counter to 20ms for small DRAM size, otherwise 9.6ms */
- movlt r1, #0x03f0
- movge r1, #0x01e0
+#else
- /* Set refresh counter to 30.7ms for small DRAM size, otherwise 15ms */
- movlt r1, #0x0600
- movge r1, #0x2f0
- str r1, [r0, #SDRAM_OFF_REFRSHTIMR]
- ldr lr, [r1]
- /* Save the memory configuration information. */
- orr r0, r11, #UBOOT_MEMORYCNF_BANK_SIZE
- stmia r0, {r8-r11}
- mov pc, lr
- mov lr, r6
- mov pc, lr
- Cirrus Logic EP93xx register definitions.
- Sergey Kostanbaev <sergey.kostanbaev <at> fairwaves.ru>
- Matthias Kaehlcke matthias@kaehlcke.net
- 0x80070000 - 0x8007FFFF: Reserved
- 0x80850000 - 0x8087FFFF: Reserved
- 0x80930000 - 0x8093FFFF: Watchdog Timer
- 0x80950000 - 0x9000FFFF: Reserved
- During low_level init we store memory layout in memory at specific location
- Board initialization for EP93xx
- Matthias Kaehlcke <matthias <at> kaehlcke.net>
- (C) Copyright 2002 2003
- Network Audio Technologies, Inc. <www.netaudiotech.com>
- Adam Bezanson <bezanson <at> netaudiotech.com>
- usb_div: 4, nbyp2: 1, pll2_en: 1
- pll2_x1: 368640000.000000, pll2_x2ip: 15360000.000000,
- pll2_x2: 384000000.000000, pll2_out: 192000000.000000
- /* loop takes 4 cycles at 5.0ns (fastest case, running at 200MHz) */
- register uint32_t loops = (usecs * 1000) / 20;
- __asm__ volatile ("1:\n"
"subs %0, %1, #1\n"
- struct smc_regs *smc = (struct smc_regs *)SMC_BASE;
- writel(SMC_BCR6_VALUE, &smc->bcr6);
- struct syscon_regs *syscon = (struct syscon_regs *)SYSCON_BASE;
- writel(CLKSET2_VAL, &syscon->clkset2);
* stabilize
- early_udelay(1000);
- /* Go to Async mode */
- __asm__ volatile ("mrc p15, 0, r0, c1, c0, 0");
- __asm__ volatile ("orr r0, r0, #0xc0000000");
- __asm__ volatile ("mcr p15, 0, r0, c1, c0, 0");
- icache_enable();
- dcache_enable();
- /* Machine number, as defined in linux/arch/arm/tools/mach-types */
- gd->bd->bi_arch_number = CONFIG_MACH_TYPE;
- /* adress of boot parameters */
- gd->bd->bi_boot_params = LINUX_BOOT_PARAM_ADDR;
- /* We have a console */
- gd->have_console = 1;
- enable_interrupts();
- flash_cfg();
- green_led_on();
- red_led_off();
* 14.7456/2 MHz
- writel(SYSCON_PWRCNT_UART_BAUD, &syscon->pwrcnt);
- return ep93xx_eth_initialize(0, MAC_BASE);
- if (dram_bank_cnt == 1) {
- } else {
unsigned tbl[8];
do {
j <<= 1;
*ptbl++ = j;
j <<= 1;
i >>= 1;
} while (i != 0);
unsigned k;
unsigned bit;
if (bit & j)
addr |= tbl[k];
* initialization
- unsigned i;
- unsigned dram_bank_base[CONFIG_NR_DRAM_BANKS];
- unsigned dram_total = 0;
- unsigned dram_bank_size = *(unsigned *)
- unsigned dram_addr_mask = *(unsigned *)
- unsigned dram_bank_cnt = *(unsigned *)
- dram_fill_bank_addr(dram_addr_mask, dram_bank_cnt, dram_bank_base);
- for (i = 0; i < dram_bank_cnt; i++) {
- for (; i < CONFIG_NR_DRAM_BANKS; i++) {
- if (print) {
"Total %9d\n\n",
dram_total);
- return dram_total;
- dram_init_banksize_int(0);
- unsigned sec_id = readl(SECURITY_EXTENSIONID);
- unsigned chip_id = readl(&syscon->chipid);
- printf("CPU: Cirrus Logic ");
- switch (sec_id & 0x000001FE) {
- case 0x00000008:
printf("EP9301");
break;
- case 0x00000004:
printf("EP9307");
break;
- case 0x00000002:
printf("EP931x");
break;
- case 0x00000000:
printf("EP9315");
break;
- default:
break;
- printf(" - Rev. ");
- switch (chip_id & 0xF0000000) {
- case 0x00000000:
printf("A");
break;
- case 0x10000000:
printf("B");
break;
- case 0x20000000:
printf("C");
break;
- case 0x30000000:
printf("D0");
break;
- case 0x40000000:
printf("D1");
break;
- case 0x50000000:
printf("E0");
break;
- case 0x60000000:
printf("E1");
break;
- case 0x70000000:
printf("E2");
break;
- default:
printf("?");
break;
- printf(" (SecExtID=%.8x/ChipID=%.8x)\n", sec_id, chip_id);
- gd->ram_size = dram_init_banksize_int(1);
- EGIO0-EGIPO7 -> port A
- EGIO8-EGIP15 -> port B
- struct gpio_regs *regs = (struct gpio_regs *)GPIO_BASE;
- if (num < 8)
- else
- if (num < 8)
- else
- if (num < 8)
- else
- if (bus == 0 && cs < 16)
return 1;
- ep93xx_clear_epgio(slave->cs);
- ep93xx_set_epgio(slave->cs);
- ep93xx_set_epgio(CONFIG_MMC_SPI_CS_EPGIO);
- ep93xx_dir_epgio_out(CONFIG_MMC_SPI_CS_EPGIO);
- ep93xx_dir_epgio_out(CONFIG_MMC_SPI_POWER_EGPIO);
- ep93xx_set_epgio(CONFIG_MMC_SPI_POWER_EGPIO);
- ep93xx_dir_epgio_out(CONFIG_MMC_SPI_NPOWER_EGPIO);
- ep93xx_clear_epgio(CONFIG_MMC_SPI_NPOWER_EGPIO);
- struct mmc *mmc = mmc_spi_init(0, CONFIG_MMC_SPI_CS_EPGIO,
- if (!mmc) {
return 1;
- mmc_init(mmc);
- Copyright (c) 2004-2008 Texas Instruments
- Gary Jennejohn, DENX Software Engineering, garyj@denx.de
- . = 0x00000000;
- . = ALIGN(4);
- .text : {
. = 0x1000;
LONG(0x53555243)
*(.text*)
- . = ALIGN(4);
- .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) }
- . = ALIGN(4);
- .data : {
*(.data*)
- . = ALIGN(4);
- . = ALIGN(4);
- .u_boot_list : {
- . = ALIGN(4);
- .image_copy_end :
- .rel_dyn_start :
*(.__rel_dyn_start)
- .rel.dyn : {
*(.rel*)
- .rel_dyn_end :
*(.__rel_dyn_end)
- .end :
*(.__end)
- _image_binary_end = .;
- . = ALIGN(4096);
- .mmutable : {
*(.mmutable)
- Compiler-generated __bss_start and __bss_end, see arch/arm/lib/bss.c
- __bss_base and __bss_limit are for linker only (overlay ordering)
- .bss_start __rel_dyn_start (OVERLAY) : {
__bss_base = .;
- .bss __bss_base (OVERLAY) : {
*(.bss*)
. = ALIGN(4);
__bss_limit = .;
- .bss_end __bss_limit (OVERLAY) : {
- .dynsym _image_binary_end : { *(.dynsym) }
- .dynbss : { *(.dynbss) }
- .dynstr : { *(.dynstr*) }
- .dynamic : { *(.dynamic*) }
- .plt : { *(.plt*) }
- .interp : { *(.interp*) }
- .gnu.hash : { *(.gnu.hash) }
- .gnu : { *(.gnu*) }
- .ARM.exidx : { *(.ARM.exidx*) }
- .gnu.linkonce.armexidx : { *(.gnu.linkonce.armexidx.*) }
- SPI Driver for EP93xx
- Copyright (C) 2013 Sergey Kostanabev <sergey.kostanbaev <at> fairwaves.ru>
- Inspired form linux kernel driver and atmel uboot driver
- struct spi_slave slave;
- unsigned sspcr0;
- unsigned sspcpsr;
- return container_of(slave, struct ep93xx_spi_slave, slave);
- writel(value, (unsigned int *)(SSPBASE + reg));
- return readl((unsigned int *)(SSPBASE + reg));
- return (u16)readl((unsigned int *)(SSPBASE + reg));
- unsigned cpsr, scr;
- if (rate > SSP_MAX_RATE)
- if (rate < SSP_MIN_RATE)
return -1;
- /* Calculate divisors so that we can get speed according the
- for (cpsr = 2; cpsr <= 254; cpsr += 2) {
- return -1;
- struct ep93xx_spi_slave *as = to_ep93xx_spi(slave);
- unsigned int mode = 0;
- if (as->sspcr0 & SSPCR0_SPH)
mode |= SPI_CPHA;
- if (as->sspcr0 & SSPCR0_SPO)
mode |= SPI_CPOL;
- ep93xx_spi_init_hw(hz, mode, as);
- struct ep93xx_spi_slave *as;
- if (!spi_cs_is_valid(bus, cs))
return NULL;
- as = spi_alloc_slave(struct ep93xx_spi_slave, bus, cs);
- if (!as)
return NULL;
- if (ep93xx_spi_init_hw(max_hz, mode, as)) {
free(as);
return NULL;
- return &as->slave;
- free(as);
- /* Enable the SPI hardware */
- ep93xx_spi_write_u8(SSPCR1, SSPCR1_SSE);
- ep93xx_spi_write_u8(SSPCPSR, as->sspcpsr);
- ep93xx_spi_write_u16(SSPCR0, as->sspcr0);
- debug("Select CS:%d SSPCPSR=%02x SSPCR0=%04x\n",
- /* Disable the SPI hardware */
- ep93xx_spi_write_u8(SSPCR1, 0);
- unsigned int len_tx;
- unsigned int len_rx;
- unsigned int len;
- u32 status;
- const u8 *txp = dout;
- u8 *rxp = din;
- u8 value;
- debug("spi_xfer: slave %u:%u dout %p din %p bitlen %u\n",
- if (bitlen == 0)
goto out;
- if (bitlen % 8) {
goto out;
- len = bitlen / 8;
- if (flags & SPI_XFER_BEGIN) {
/* Empty RX FIFO */
- for (len_tx = 0, len_rx = 0; len_rx < len; ) {
if (txp)
value = *txp++;
else
value = 0xff;
len_tx++;
if (rxp)
*rxp++ = value;
len_rx++;
+out:
- if (flags & SPI_XFER_END) {
* we deactivate CS.
do {
- (C) Copyright 2013
- Sergey Kostanbaev < sergey.kostanbaev <at> fairwaves.ru >
- unsigned long pwr = readl(&syscon->pwrcnt);
- writel(pwr | SYSCON_PWRCNT_USH_EN, &syscon->pwrcnt);
- writel(pwr & ~SYSCON_PWRCNT_USH_EN, &syscon->pwrcnt);
- return usb_cpu_stop();
- U-boot - Configuration file for Cirrus Logic EDB93xx boards
115200, 230400}
- defined(CONFIG_EDB9307) || defined CONFIG_EDB9312 || \
- defined(CONFIG_EDB9315)
- EDB9301/2 has 4 banks of SDRAM consisting of 1x Samsung K4S561632E-TC75
- 256 Mbit SDRAM on a 16-bit data bus, for a total of 32MB of SDRAM. We set
- the SROMLL bit on the processor, resulting in this non-contiguous memory map.
- The EDB9307, EDB9312, and EDB9315 have 2 banks of SDRAM consisting of
- 2x Samsung K4S561632E-TC75 256 Mbit on a 32-bit data bus, for a total of
- 64 MB of SDRAM.
- defined(CONFIG_EDB9307A) || defined(CONFIG_EDB9315A)
- EDB9302a has 4 banks of SDRAM consisting of 1x Samsung K4S561632E-TC75
- The EDB9307A and EDB9315A have 2 banks of SDRAM consisting of 2x Samsung
- K4S561632E-TC75 256 Mbit on a 32-bit data bus, for a total of 64 MB of SDRAM.
- (CONFIG_SYS_SDRAM_BASE + 32*1024 - GENERATED_GBL_DATA_SIZE)
- FLASH and environment organization
- The EDB9301, EDB9302(a), EDB9307a, EDB9315a have 1 bank of flash memory at
- 0x60000000 consisting of 1x Intel TE28F128J3C-150 128 Mbit flash on a 16-bit
- data bus, for a total of 16 MB of CFI-compatible flash.
- The EDB9307, EDB9312, and EDB9315 have 1 bank of flash memory at
- 0x60000000 consisting of 2x Micron MT28F128J3-12 128 Mbit flash on a 32-bit
- data bus, for a total of 32 MB of CFI-compatible flash.
- 0x60000000 - 0x0003FFFF u-boot u-boot
- 0x60040000 - 0x0005FFFF environment #1 environment #1
- 0x60060000 - 0x0007FFFF environment #2 environment #1 (continued)
- 0x60080000 - 0x0009FFFF unused environment #2
- 0x600A0000 - 0x000BFFFF unused environment #2 (continued)
- 0x600C0000 - 0x00FFFFFF unused unused
- 0x61000000 - 0x01FFFFFF not present unused
Applied to u-boot-arm/master, thanks!
Amicalement,
Hi. Sergey, Arbert.
On Sat, 5 Jul 2014 00:22:05 +0200 Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Sergey,
This patch returns back support for old ep93xx processors family
Signed-off-by: Sergey Kostanbaev sergey.kostanbaev@gmail.com Cc: albert.u.boot@aribaud.net
[snip]
Amicalement,
Albert.
I have two questions:
[1] Is this board really working?
This patch added a linker script board/cirrus/edb93xx/u-boot.lds
But '.vectors' section is missing from it.
In my understanding, commit 41623c91b0 expects '.vectors' section handling for all ARM linker scripts.
[2] Why was board/cirrus/edb93xx/u-boot.lds added instead of re-using (or modifying) arch/arm/cpu/arm920t/ep93xx/u-boot.lds ?
'edb9315a' is the only one board with 'ep93xx' SoC.
It means, if you add 'board/cirrus/edb93xx/u-boot.lds', 'arch/arm/cpu/arm920t/ep93xx/u-boot.lds' is never used.
Please delete either of them.
Best Regards Masahiro Yamada
Hi Masahiro,
Sorry I missed you mail since I was on vacation.
On Mon, Jul 7, 2014 at 2:57 PM, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
On the time I made the patch it worked fine. I'll test version in master.
Yes, I missed it I'll delete unneeded file.
Thank you for your remarks
Hi Masahiro,
You were right, .vectors is needed now, but for the other reason. Although the edb93xx board in uboot doesn't exploit any interrupts but the _start symbol is needed to calculate the monitor size. gd->mon_len = (ulong)&__bss_end - (ulong)_start;
Without .vectors _start is 0 and gd->mon_len is about 1.5GB. Some time ago it worked fine without .vectors section at all.
Adding .vectors to lds fixes mon_len to actual size and uboot works fine.
So I'll add this section and remove extra lds script.
Thank you for pointing out the problem.
Besrt Regards, Sergey
On Fri, Jul 25, 2014 at 8:27 PM, sergey kostanbaev < sergey.kostanbaev@gmail.com> wrote:
Hi Masahiro,
On Mon, Jul 7, 2014 at 2:57 PM, Masahiro Yamada <yamada.m@jp.panasonic.com
Albert ARIBAUD
Masahiro Yamada
sergey kostanbaev
Sergey Kostanbev
