[U-Boot] [PATCH] mmc: prevent some warnings with make W=1
Add missing prototypes for global functions and make local functions static.
cc: panto@antoniou-consulting.com Signed-off-by: Jeroen Hofstee jeroen@myspectrum.nl --- drivers/mmc/mmc.c | 6 +++--- drivers/mmc/omap_hsmmc.c | 2 +- include/mmc.h | 4 +++- 3 files changed, 7 insertions(+), 5 deletions(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index b5477b1..50de02f 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -21,7 +21,7 @@ static struct list_head mmc_devices; static int cur_dev_num = -1;
-int __weak board_mmc_getwp(struct mmc *mmc) +__weak int board_mmc_getwp(struct mmc *mmc) { return -1; } @@ -377,7 +377,7 @@ static int mmc_send_op_cond_iter(struct mmc *mmc, struct mmc_cmd *cmd, return 0; }
-int mmc_send_op_cond(struct mmc *mmc) +static int mmc_send_op_cond(struct mmc *mmc) { struct mmc_cmd cmd; int err, i; @@ -399,7 +399,7 @@ int mmc_send_op_cond(struct mmc *mmc) return IN_PROGRESS; }
-int mmc_complete_op_cond(struct mmc *mmc) +static int mmc_complete_op_cond(struct mmc *mmc) { struct mmc_cmd cmd; int timeout = 1000; diff --git a/drivers/mmc/omap_hsmmc.c b/drivers/mmc/omap_hsmmc.c index 17cbb09..5b0c302 100644 --- a/drivers/mmc/omap_hsmmc.c +++ b/drivers/mmc/omap_hsmmc.c @@ -120,7 +120,7 @@ static void omap5_pbias_config(struct mmc *mmc) } #endif
-unsigned char mmc_board_init(struct mmc *mmc) +static unsigned char mmc_board_init(struct mmc *mmc) { #if defined(CONFIG_OMAP34XX) t2_t *t2_base = (t2_t *)T2_BASE; diff --git a/include/mmc.h b/include/mmc.h index f46572e..7f5f9bc 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -327,10 +327,11 @@ struct mmc *find_mmc_device(int dev_num); int mmc_set_dev(int dev_num); void print_mmc_devices(char separator); int get_mmc_num(void); -int board_mmc_getcd(struct mmc *mmc); int mmc_switch_part(int dev_num, unsigned int part_num); int mmc_getcd(struct mmc *mmc); +int board_mmc_getcd(struct mmc *mmc); int mmc_getwp(struct mmc *mmc); +int board_mmc_getwp(struct mmc *mmc); int mmc_set_dsr(struct mmc *mmc, u16 val); /* Function to change the size of boot partition and rpmb partitions */ int mmc_boot_partition_size_change(struct mmc *mmc, unsigned long bootsize, @@ -385,6 +386,7 @@ int mmc_legacy_init(int verbose); #endif
int board_mmc_init(bd_t *bis); +int cpu_mmc_init(bd_t *bis);
/* Set block count limit because of 16 bit register limit on some hardware*/ #ifndef CONFIG_SYS_MMC_MAX_BLK_COUNT
Jeroen Hofstee
