Re: [U-Boot] i.MX53 USB Client not working
It appears that setting CONFIG_MXC_USB_PORT to 0 then loads the OTG port on the i.MX53. The code appears to be in drivers/usb/host/ehci-mx5.c. The problem then is that the USB host port is then not usable since my i.MX53 board dedicates the OTG port to USB client functionality only.
Now I am trying to get both USB Host port 1 and USB OTG port 0 working at the same time. Does u-boot allow using multiple USB controller ports at the same time?
Best regards, Matthew Starr
-----Original Message----- From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Matthew Starr Sent: Thursday, May 14, 2015 9:37 AM To: u-boot@lists.denx.de Subject: [U-Boot] i.MX53 USB Client not working
I have a custom board loosely based off the i.MX53 QSB with a dedicated USB client port and separate dedicated USB host port. I am trying to get USB client functionality working in mainline u-boot 2015.04. I have verified that USB client/gadget functionality works when booted into Linux on the board. In u-boot I have tried testing USB client with USB Mass Storage, DFU, and FastBoot and none of them seem to work.
Here is my USB client #defines from my config header file: #define CONFIG_CI_UDC #define CONFIG_USBD_HS #define CONFIG_USB_GADGET_DUALSPEED #define CONFIG_USB_GADGET #define CONFIG_CMD_USB_MASS_STORAGE #define CONFIG_USB_GADGET_MASS_STORAGE #define CONFIG_USBDOWNLOAD_GADGET #define CONFIG_USB_GADGET_VBUS_DRAW 2 #define CONFIG_USB_ETHER #define CONFIG_USB_ETH_CDC #define CONFIG_G_DNL_VENDOR_NUM 0x0525 #define CONFIG_G_DNL_PRODUCT_NUM 0xa4a5 #define CONFIG_G_DNL_MANUFACTURER "FSL" #define CONFIG_SYS_CACHELINE_SIZE 64
Additionally here are my #defines for the USB host functionality: /* USB Host Configs */ #define CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX5 #define CONFIG_USB_STORAGE #define CONFIG_USB_HOST_ETHER #define CONFIG_USB_ETHER_ASIX #define CONFIG_USB_ETHER_MCS7830 #define CONFIG_USB_ETHER_SMSC95XX #define CONFIG_MXC_USB_PORT 1 #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_MXC_USB_FLAGS 0
Here is my board file content related to USB: #ifdef CONFIG_USB_EHCI_MX5 static void setup_usb(void) { imx_iomux_v3_setup_pad(MX53_PAD_GPIO_0__GPIO1_0); }
int board_ehci_hcd_init(int port) { /* Enable USB_H1_VBUS power with GPIO1_0 */ gpio_direction_output(IMX_GPIO_NR(1, 0), 1); return 0; } #endif
int board_usb_phy_mode(int port) { if (port == 1) return USB_INIT_HOST; else return USB_INIT_DEVICE; }
Then later on in board_init(), I have: #ifdef CONFIG_USB_EHCI_MX5 setup_usb(); #endif
When I run the 'ums 0 mmc 0' command, I get the following: UMS: disk start sector: 0x0, count: 0xe88000 and then I get an infinite spinning progress indicator. At this point when I connect the USB cable to a Host PC, I see nothing on the host PC side (Windows or Liunx).
Any ideas on what I am missing to get USB client working or any hints on how to debug this further.
Best regards, Matthew Starr _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Matthew,
Yes, you can use both ports.
In order to do so, you need to pass #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 in your config file.
Regards,
Fabio Estevam
Fabio,
I added the '#define CONFIG_USB_MAX_CONTROLLER_COUNT 2' to my include config file and I see that it loads both USB port 0 and 1.
To me it looks like using CONFIG_USB_MAX_CONTROLLER_COUNT produces that number of duplicate devices all of the USB port defined by CONFIG_MXC_USB_PORT.
If CONFIG_MXC_USB_PORT is set 0, I only get port 0 duplicated CONFIG_USB_MAX_CONTROLLER_COUNT times. The ums command works, but I don't see any USB devices connected to port 1. If CONFIG_MXC_USB_PORT is set 1, I only get port 1 duplicated CONFIG_USB_MAX_CONTROLLER_COUNT times. The ums command shows nothing on the host side, but I can see USB devices (although multiple of the same single device, one on each port)
I looked at drivers/usb/host/ehci-mx5.c and found that the loading of USB is not dynamic and depends on the CONFIG_MXC_USB_PORT value. In drivers/usb/host/ehci-hcd.c, the CONFIG_USB_MAX_CONTROLLER_COUNT value defines how many devices to create and the index of the current device is passed to the usb_lowlevel_init() function in drivers/usb/host/ehci-mx5.c but is ignored.
Here is the output when running 'usb start' and then 'usb tree' when CONFIG_MXC_USB_PORT is 1 and CONFIG_USB_MAX_CONTROLLER_COUNT is 2 and a USB mass storage device is only connected to port 1:
U-Boot > usb start starting USB... USB0: USB EHCI 1.00 scanning bus 0 for devices... 2 USB Device(s) found USB1: USB EHCI 1.00 scanning bus 1 for devices... 2 USB Device(s) found scanning usb for storage devices... EHCI timed out on TD - token=0x80008c80 EHCI timed out on TD - token=0x80008d80 EHCI timed out on TD - token=0x80008d80 EHCI timed out on TD - token=0x80008d80 EHCI timed out on TD - token=0x80008d80 EHCI timed out on TD - token=0x80008d80 error in inquiry 1 Storage Device(s) found scanning usb for ethernet devices... 0 Ethernet Device(s) found U-Boot > usb tree USB device tree: 1 Hub (480 Mb/s, 0mA) | u-boot EHCI Host Controller | +-2 Mass Storage (480 Mb/s, 100mA) Generic Mass Storage 30820100
3 Hub (480 Mb/s, 0mA) | u-boot EHCI Host Controller | +-4 Mass Storage (480 Mb/s, 100mA) Generic Mass Storage 30820100
I fixed the issues by switching all instances of CONFIG_MXC_USB_PORT with index in drivers/usb/host/ehci-mx5.c and CONFIG_MXC_USB_PORT is no longer used. Even if index is used in place of CONFIG_MXC_USB_PORT, if you wanted to just use port 1 you would need to populate both port 0 and 1 by setting CONFIG_USB_MAX_CONTROLLER_COUNT to 2.
Here is the patch I made to drivers/usb/host/ehci-hcd.c to make USB client work on port 0 and USB host work on port 1 at the same time:
diff --git a/drivers/usb/host/ehci-mx5.c b/drivers/usb/host/ehci-mx5.c index 7566c61..f7ecff5 100644 --- a/drivers/usb/host/ehci-mx5.c +++ b/drivers/usb/host/ehci-mx5.c @@ -231,10 +231,10 @@ int ehci_hcd_init(int index, enum usb_init_type init, mdelay(1);
/* Do board specific initialization */ - board_ehci_hcd_init(CONFIG_MXC_USB_PORT); + board_ehci_hcd_init(index);
ehci = (struct usb_ehci *)(OTG_BASE_ADDR + - (0x200 * CONFIG_MXC_USB_PORT)); + (0x200 * index)); *hccr = (struct ehci_hccr *)((uint32_t)&ehci->caplength); *hcor = (struct ehci_hcor *)((uint32_t)*hccr + HC_LENGTH(ehci_readl(&(*hccr)->cr_capbase))); @@ -243,11 +243,11 @@ int ehci_hcd_init(int index, enum usb_init_type init, __raw_writel(CONFIG_MXC_USB_PORTSC, &ehci->portsc); setbits_le32(&ehci->portsc, USB_EN);
- mxc_set_usbcontrol(CONFIG_MXC_USB_PORT, CONFIG_MXC_USB_FLAGS); + mxc_set_usbcontrol(index, CONFIG_MXC_USB_FLAGS); mdelay(10);
/* Do board specific post-initialization */ - board_ehci_hcd_postinit(ehci, CONFIG_MXC_USB_PORT); + board_ehci_hcd_postinit(ehci, index);
return 0; }
Regards,
Matthew Starr
-----Original Message----- From: Fabio Estevam [mailto:festevam@gmail.com] Sent: Tuesday, May 19, 2015 9:45 PM To: Matthew Starr Cc: U-Boot-Denx; Marek Vašut Subject: Re: [U-Boot] i.MX53 USB Client not working
Hi Matthew,
Regards,
Fabio Estevam
Hi Matthew,
Please send it as a formal patch to this list.
Regards,
Fabio Estevam
Fabio Estevam
Matthew Starr
