[U-Boot] [PATCH] i.mx: i.mx6x: NO_MUX_I/NO_PAD_I not set correctly
If one PAD does not have mux or pad config register, we need set the NO_MUX_I/NO_PAD_I to 0, the old value is not correct
Signed-off-by: Jason Liu jason.hui@linaro.org CC: Stefano Babic sbabic@denx.de --- arch/arm/include/asm/arch-mx6/mx6x_pins.h | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx6/mx6x_pins.h b/arch/arm/include/asm/arch-mx6/mx6x_pins.h index afaa068..9979651 100644 --- a/arch/arm/include/asm/arch-mx6/mx6x_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6x_pins.h @@ -48,8 +48,8 @@ #define PAD_CTL_SRE_FAST (1 << 0) #define PAD_CTL_SRE_SLOW (0 << 0)
-#define NO_MUX_I 0x3FF -#define NO_PAD_I 0x7FF +#define NO_MUX_I 0 +#define NO_PAD_I 0
enum { MX6Q_PAD_SD2_DAT1__USDHC2_DAT1 = IOMUX_PAD(0x0360, 0x004C, 0, 0x0000, 0, 0),
Agree. Please correct me if I am wrong, but with these changes we should sure that the iomux register are not set if we do not want, because in imx_iomux_v3_setup_pad:
if (sel_input_ofs) __raw_writel(sel_input, base + sel_input_ofs);
and NO_MUX_I = 0 should set sel_input_ofs to 0.
It is then difficult to understand why we have up now 0x3FF as value, but it neverminds..
Acked-by: Stefano Babic sbabic@denx.de
(This is a fix, I will merge it for the release)
Best regards, Stefano Babic
I have this patch on my list of pending patches.
Should it be applied now?
Best regards
Dirk
Applied to u-boot-imx, thanks. Sorry that it was not applied before ;-)
Dirk Behme
Jason Liu
Stefano Babic
