[U-Boot] [PATCH] Kconfig: ifc: Moving IFC_BANK_COUNT from Kconfig to config.h
Migration of IFC_BANK_COUNT from Kconfig to config.h avoids adding SoC name in Kconfig as Dependencies. It will help in having all SoC related defines in config.h - easy to maintain.
Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com --- This patch provide base for defining SYS_FSL_IFC_CLK_DIV required for v3 version of below patch-set http://patchwork.ozlabs.org/patch/666844/ http://patchwork.ozlabs.org/patch/666849/ http://patchwork.ozlabs.org/patch/666848/
README | 3 +++ arch/arm/cpu/armv7/ls102xa/Kconfig | 5 ----- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 7 ------- arch/arm/include/asm/arch-fsl-layerscape/config.h | 4 ++++ arch/arm/include/asm/arch-ls102xa/config.h | 1 + arch/powerpc/include/asm/config_mpc85xx.h | 18 +++++++++--------- drivers/misc/fsl_ifc.c | 2 +- drivers/mtd/nand/fsl_ifc_nand.c | 6 +++--- include/fsl_ifc.h | 20 ++++++++++---------- 9 files changed, 31 insertions(+), 35 deletions(-)
diff --git a/README b/README index 68d6a49..c83171a 100644 --- a/README +++ b/README @@ -507,6 +507,9 @@ The following options need to be configured: Board config to use DDR4. It can be enabled for SoCs with DDR4 controllers.
+ SYS_FSL_IFC_BANK_COUNT + Maximum banks of Integrated flash controller + CONFIG_SYS_FSL_IFC_BE Defines the IFC controller register space as Big Endian
diff --git a/arch/arm/cpu/armv7/ls102xa/Kconfig b/arch/arm/cpu/armv7/ls102xa/Kconfig index 28bf778..68d03ab 100644 --- a/arch/arm/cpu/armv7/ls102xa/Kconfig +++ b/arch/arm/cpu/armv7/ls102xa/Kconfig @@ -81,9 +81,4 @@ config SYS_FSL_DDR4 help Enable Freescale DDR4 controller.
-config SYS_FSL_IFC_BANK_COUNT - int "Maximum banks of Integrated flash controller" - depends on ARCH_LS1021A - default 8 - endmenu diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 94ec8d5..0587559 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -71,13 +71,6 @@ config NUM_DDR_CONTROLLERS default 3 if ARCH_LS2080A default 1
-config SYS_FSL_IFC_BANK_COUNT - int "Maximum banks of Integrated flash controller" - depends on ARCH_LS1043A || ARCH_LS1046A || ARCH_LS2080A - default 4 if ARCH_LS1043A - default 4 if ARCH_LS1046A - default 8 if ARCH_LS2080A - config SYS_FSL_HAS_DP_DDR bool
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index 4201e0f..28d3974 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -27,6 +27,8 @@ #define L1_CACHE_BYTES BIT(L1_CACHE_SHIFT) #endif
+#define SYS_FSL_IFC_BANK_COUNT 8 + #define CONFIG_SYS_FSL_OCRAM_BASE 0x18000000 /* initial RAM */ #define CONFIG_SYS_FSL_OCRAM_SIZE 0x00200000 /* 2M */
@@ -150,6 +152,7 @@
/* SoC related */ #ifdef CONFIG_LS1043A +#define SYS_FSL_IFC_BANK_COUNT 4 #define CONFIG_SYS_FMAN_V3 #define CONFIG_SYS_NUM_FMAN 1 #define CONFIG_SYS_NUM_FM1_DTSEC 7 @@ -187,6 +190,7 @@ #define GICD_BASE 0x01401000 #define GICC_BASE 0x01402000 #elif defined(CONFIG_ARCH_LS1046A) +#define SYS_FSL_IFC_BANK_COUNT 4 #define CONFIG_SYS_FMAN_V3 #define CONFIG_SYS_NUM_FMAN 1 #define CONFIG_SYS_NUM_FM1_DTSEC 8 diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index ec65cc0..d65f5bf 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -120,6 +120,7 @@ #define CONFIG_SYS_FSL_ERRATUM_A009663 #define CONFIG_SYS_FSL_ERRATUM_A009942 #define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1 +#define SYS_FSL_IFC_BANK_COUNT 8 #else #error SoC not defined #endif diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 6d845e8..073a7b5 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -150,7 +150,7 @@ #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_NUM_DDR_CONTROLLERS 1 #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 -#define CONFIG_SYS_FSL_IFC_BANK_COUNT 4 +#define SYS_FSL_IFC_BANK_COUNT 4 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2" #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY @@ -590,7 +590,7 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 #define CONFIG_SYS_FSL_DSP_M2_RAM_ADDR 0xb0000000 #define CONFIG_SYS_FSL_DSP_CCSRBAR_DEFAULT 0xff600000 -#define CONFIG_SYS_FSL_IFC_BANK_COUNT 3 +#define SYS_FSL_IFC_BANK_COUNT 3 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_NAND_FSL_IFC #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 @@ -612,7 +612,7 @@ #define CONFIG_SYS_FSL_DSP_M2_RAM_ADDR 0xb0000000 #define CONFIG_SYS_FSL_DSP_M3_RAM_ADDR 0xc0000000 #define CONFIG_SYS_FSL_DSP_CCSRBAR_DEFAULT 0xff600000 -#define CONFIG_SYS_FSL_IFC_BANK_COUNT 3 +#define SYS_FSL_IFC_BANK_COUNT 3 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_NAND_FSL_IFC #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 @@ -667,7 +667,7 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_PME_CLK 0 #define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_7 -#define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 +#define SYS_FSL_IFC_BANK_COUNT 8 #define CONFIG_SYS_FMAN_V3 #define CONFIG_SYS_FM1_CLK 3 #define CONFIG_SYS_FM2_CLK 3 @@ -714,7 +714,7 @@ #define CONFIG_SYS_ULB_CLK 4 #define CONFIG_SYS_ETVPE_CLK 1 #define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_7 -#define CONFIG_SYS_FSL_IFC_BANK_COUNT 4 +#define SYS_FSL_IFC_BANK_COUNT 4 #define CONFIG_SYS_FMAN_V3 #define CONFIG_SYS_FM_MURAM_SIZE 0x60000 #define CONFIG_SYS_FSL_TBCLK_DIV 16 @@ -786,7 +786,7 @@ defined(CONFIG_PPC_T1020) || defined(CONFIG_PPC_T1022) #define CONFIG_PME_PLAT_CLK_DIV 2 #define CONFIG_SYS_PME_CLK CONFIG_PME_PLAT_CLK_DIV #define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_5_0 -#define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 +#define SYS_FSL_IFC_BANK_COUNT 8 #define CONFIG_SYS_FSL_ERRATUM_A008044 #define CONFIG_SYS_FMAN_V3 #define CONFIG_FM_PLAT_CLK_DIV 1 @@ -838,7 +838,7 @@ defined(CONFIG_PPC_T1014) || defined(CONFIG_PPC_T1013) #define CONFIG_NUM_DDR_CONTROLLERS 1 #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_5_0 -#define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 +#define SYS_FSL_IFC_BANK_COUNT 8 #define CONFIG_SYS_FM1_CLK 0 #define CONFIG_SYS_SDHC_CLK 0/* Select SDHC CLK begining from PLL1 per rcw field value */ @@ -895,7 +895,7 @@ defined(CONFIG_PPC_T1014) || defined(CONFIG_PPC_T1013) per rcw field value */ #define CONFIG_SYS_SDHC_CLK_2_PLL /* Select SDHC CLK from 2 PLLs */ #define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_7 -#define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 +#define SYS_FSL_IFC_BANK_COUNT 8 #define CONFIG_SYS_FMAN_V3 #define CONFIG_SYS_FM_MURAM_SIZE 0x28000 #define CONFIG_SYS_FSL_TBCLK_DIV 16 @@ -924,7 +924,7 @@ defined(CONFIG_PPC_T1014) || defined(CONFIG_PPC_T1013) #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_NUM_DDR_CONTROLLERS 1 #define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_4_6 -#define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 +#define SYS_FSL_IFC_BANK_COUNT 8 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 #define CONFIG_SYS_FSL_ERRATUM_A005125 #define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 3 diff --git a/drivers/misc/fsl_ifc.c b/drivers/misc/fsl_ifc.c index a33efdb..c3e59f0 100644 --- a/drivers/misc/fsl_ifc.c +++ b/drivers/misc/fsl_ifc.c @@ -13,7 +13,7 @@ void print_ifc_regs(void) int i, j;
printf("IFC Controller Registers\n"); - for (i = 0; i < CONFIG_SYS_FSL_IFC_BANK_COUNT; i++) { + for (i = 0; i < SYS_FSL_IFC_BANK_COUNT; i++) { printf("CSPR%d:0x%08X\tAMASK%d:0x%08X\tCSOR%d:0x%08X\n", i, get_ifc_cspr(i), i, get_ifc_amask(i), i, get_ifc_csor(i)); diff --git a/drivers/mtd/nand/fsl_ifc_nand.c b/drivers/mtd/nand/fsl_ifc_nand.c index bc6bdc9..d3ad210 100644 --- a/drivers/mtd/nand/fsl_ifc_nand.c +++ b/drivers/mtd/nand/fsl_ifc_nand.c @@ -19,11 +19,11 @@ #include <linux/errno.h> #include <fsl_ifc.h>
-#ifndef CONFIG_SYS_FSL_IFC_BANK_COUNT -#define CONFIG_SYS_FSL_IFC_BANK_COUNT 4 +#ifndef SYS_FSL_IFC_BANK_COUNT +#define SYS_FSL_IFC_BANK_COUNT 4 #endif
-#define MAX_BANKS CONFIG_SYS_FSL_IFC_BANK_COUNT +#define MAX_BANKS SYS_FSL_IFC_BANK_COUNT #define ERR_BYTE 0xFF /* Value returned for read bytes when read failed */
diff --git a/include/fsl_ifc.h b/include/fsl_ifc.h index a86f216..29c98a1 100644 --- a/include/fsl_ifc.h +++ b/include/fsl_ifc.h @@ -939,21 +939,21 @@ struct fsl_ifc_gpcm { u32 gpcm_stat; };
-#ifdef CONFIG_SYS_FSL_IFC_BANK_COUNT -#if (CONFIG_SYS_FSL_IFC_BANK_COUNT <= 8) +#ifdef SYS_FSL_IFC_BANK_COUNT +#if (SYS_FSL_IFC_BANK_COUNT <= 8) #define IFC_CSPR_REG_LEN 148 #define IFC_AMASK_REG_LEN 144 #define IFC_CSOR_REG_LEN 144 #define IFC_FTIM_REG_LEN 576
#define IFC_CSPR_USED_LEN sizeof(struct fsl_ifc_cspr) * \ - CONFIG_SYS_FSL_IFC_BANK_COUNT + SYS_FSL_IFC_BANK_COUNT #define IFC_AMASK_USED_LEN sizeof(struct fsl_ifc_amask) * \ - CONFIG_SYS_FSL_IFC_BANK_COUNT + SYS_FSL_IFC_BANK_COUNT #define IFC_CSOR_USED_LEN sizeof(struct fsl_ifc_csor) * \ - CONFIG_SYS_FSL_IFC_BANK_COUNT + SYS_FSL_IFC_BANK_COUNT #define IFC_FTIM_USED_LEN sizeof(struct fsl_ifc_ftim) * \ - CONFIG_SYS_FSL_IFC_BANK_COUNT + SYS_FSL_IFC_BANK_COUNT #else #error IFC BANK count not vaild #endif @@ -991,13 +991,13 @@ struct fsl_ifc_ftim { struct fsl_ifc_fcm { u32 ifc_rev; u32 res1[0x2]; - struct fsl_ifc_cspr cspr_cs[CONFIG_SYS_FSL_IFC_BANK_COUNT]; + struct fsl_ifc_cspr cspr_cs[SYS_FSL_IFC_BANK_COUNT]; u8 res2[IFC_CSPR_REG_LEN - IFC_CSPR_USED_LEN]; - struct fsl_ifc_amask amask_cs[CONFIG_SYS_FSL_IFC_BANK_COUNT]; + struct fsl_ifc_amask amask_cs[SYS_FSL_IFC_BANK_COUNT]; u8 res3[IFC_AMASK_REG_LEN - IFC_AMASK_USED_LEN]; - struct fsl_ifc_csor csor_cs[CONFIG_SYS_FSL_IFC_BANK_COUNT]; + struct fsl_ifc_csor csor_cs[SYS_FSL_IFC_BANK_COUNT]; u8 res4[IFC_CSOR_REG_LEN - IFC_CSOR_USED_LEN]; - struct fsl_ifc_ftim ftim_cs[CONFIG_SYS_FSL_IFC_BANK_COUNT]; + struct fsl_ifc_ftim ftim_cs[SYS_FSL_IFC_BANK_COUNT]; u8 res5[IFC_FTIM_REG_LEN - IFC_FTIM_USED_LEN]; u32 rb_stat; u32 rb_map;
Prabhakar,
Why do you want to go back to config.h? I think we are going with Kconfig. Having everything in one config file conflicts with Kconfig. The former has centralized config per SoC, the latter has centralized config per feature.
York
Hi York,
-----Original Message----- From: york sun Sent: Friday, October 21, 2016 7:55 PM To: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; u- boot@lists.denx.de Cc: oss@buserror.net Subject: Re: [PATCH] Kconfig: ifc: Moving IFC_BANK_COUNT from Kconfig to config.h
Prabhakar,
There are 2 reason for this
1) in File arch/arm/cpu/armv8/fsl-layerscape/Kconfig, "depends" row will keep on increasing with SoC. And if I add new field CONFIG_SYS_FSL_IFC_CLK_DIV, similar entry will be done and it will also keep on increasing with SoC. I want to avoid it.
config SYS_FSL_IFC_BANK_COUNT int "Maximum banks of Integrated flash controller" depends on ARCH_LS1043A || ARCH_LS1046A || ARCH_LS2080A default 4 if ARCH_LS1043A default 4 if ARCH_LS1046A default 8 if ARCH_LS2080A
2) There is no file similar to " arch/arm/cpu/armv8/fsl-layerscape/Kconfig" for powerpc platform. So how to add new " CONFIG SYS_FSL_IFC_CLK_DIV" with different values per SoC. This problem will come for defining other clocks for " armv8/fsl-lsch3: consolidate the clock system initialization"
--prabhakar
On 10/23/2016 07:04 AM, Prabhakar Kushwaha wrote:
Hi York,
Prabhakar,
- in File arch/arm/cpu/armv8/fsl-layerscape/Kconfig, "depends" row will keep on increasing with SoC.
The "depends" line can be rewritten with HAS_* feature macro.
You can simplify the "default 4" for all and only use different number for others.
- There is no file similar to " arch/arm/cpu/armv8/fsl-layerscape/Kconfig" for powerpc platform. So how to add new " CONFIG SYS_FSL_IFC_CLK_DIV" with different values per SoC. This problem will come for defining other clocks for " armv8/fsl-lsch3: consolidate the clock system initialization"
We will convert powerpc as well.
York
-----Original Message----- From: york sun Sent: Monday, October 24, 2016 9:41 PM To: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; u- boot@lists.denx.de Cc: oss@buserror.net Subject: Re: [PATCH] Kconfig: ifc: Moving IFC_BANK_COUNT from Kconfig to config.h
Hi York,
Prabhakar,
I want to avoid it.
ok
This means, IFC and clock related patches needs to wait till powerpc is converted as well.
-prabhakar
Hi York,
Prabhakar,
I want to avoid it.
ok
Maybe. If you have bandwidth, you can take it. Or you can wait for me to get it done. My plate is full, so it will take a while before I start.
York
Prabhakar Kushwaha
york sun
