[U-Boot] [PATCH] mx31ads: Use the new relocation scheme
This fixes the MX31ADS build by using the new relocation scheme.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Build tested only.
Do not have the hardware handy to test.
board/freescale/mx31ads/mx31ads.c | 19 ++++++++++++--- board/freescale/mx31ads/u-boot.lds | 42 ++++++++++++++++++++++++++++------- include/configs/mx31ads.h | 7 ++++++ 3 files changed, 55 insertions(+), 13 deletions(-)
diff --git a/board/freescale/mx31ads/mx31ads.c b/board/freescale/mx31ads/mx31ads.c index a298e05..3286399 100644 --- a/board/freescale/mx31ads/mx31ads.c +++ b/board/freescale/mx31ads/mx31ads.c @@ -28,15 +28,21 @@
DECLARE_GLOBAL_DATA_PTR;
-int dram_init (void) +int dram_init(void) +{ + /* dram_init must store complete ramsize in gd->ram_size */ + gd->ram_size = get_ram_size((volatile void *)CONFIG_SYS_SDRAM_BASE, + PHYS_SDRAM_1_SIZE); + return 0; +} + +void dram_init_banksize(void) { gd->bd->bi_dram[0].start = PHYS_SDRAM_1; gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - - return 0; }
-int board_init (void) +int board_early_init_f(void) { int i;
@@ -94,6 +100,11 @@ int board_init (void) readb(CS4_BASE + 8); readb(CS4_BASE + 7);
+ return 0; +} + +int board_init(void) +{ gd->bd->bi_arch_number = MACH_TYPE_MX31ADS; /* board id for linux */ gd->bd->bi_boot_params = 0x80000100; /* adress of boot parameters */
diff --git a/board/freescale/mx31ads/u-boot.lds b/board/freescale/mx31ads/u-boot.lds index b081b21..79eb7ac 100644 --- a/board/freescale/mx31ads/u-boot.lds +++ b/board/freescale/mx31ads/u-boot.lds @@ -48,23 +48,47 @@ SECTIONS
*(.text) } - . = ALIGN(4); - .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + .rodata : { *(.rodata) }
. = ALIGN(4); - .data : { *(.data) } + .data : { + *(.data) + }
. = ALIGN(4); - .got : { *(.got) } - - . = .; __u_boot_cmd_start = .; .u_boot_cmd : { *(.u_boot_cmd) } __u_boot_cmd_end = .;
. = ALIGN(4); - __bss_start = .; - .bss : { *(.bss) . = ALIGN(4); } - __bss_end__ = .; + + .rel.dyn : { + __rel_dyn_start = .; + *(.rel*) + __rel_dyn_end = .; + } + + .dynsym : { + __dynsym_start = .; + *(.dynsym) + } + + _end = .; + + .bss __rel_dyn_start (OVERLAY) : { + __bss_start = .; + *(.bss) + . = ALIGN(4); + __bss_end__ = .; + } + + /DISCARD/ : { *(.bss*) } + /DISCARD/ : { *(.dynstr*) } + /DISCARD/ : { *(.dynsym*) } + /DISCARD/ : { *(.dynamic*) } + /DISCARD/ : { *(.hash*) } + /DISCARD/ : { *(.plt*) } + /DISCARD/ : { *(.interp*) } + /DISCARD/ : { *(.gnu*) } } diff --git a/include/configs/mx31ads.h b/include/configs/mx31ads.h index 5ea59b4..01ff528 100644 --- a/include/configs/mx31ads.h +++ b/include/configs/mx31ads.h @@ -160,6 +160,13 @@ #define CONFIG_NR_DRAM_BANKS 1 #define PHYS_SDRAM_1 CSD0_BASE #define PHYS_SDRAM_1_SIZE (128 * 1024 * 1024) +#define CONFIG_BOARD_EARLY_INIT_F + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_GBL_DATA_OFFSET)
/*----------------------------------------------------------------------- * FLASH and environment organization
Dear Fabio Estevam,
In message 1306953993-13430-1-git-send-email-fabio.estevam@freescale.com you wrote:
Lines too long!
Please use checkpatch!
Fabio Estevam
