[U-Boot] [PATCH] spi: mxc_spi: Fix ECSPI reset handling
Reviewing the ECSPI reset handling shows two issues:
1. For the enable/reset bit (MXC_CSPICTRL_EN) in the control reg (ECSPIx_CONGREG) the i.MX6 technical reference manual states:
-- cut -- ECSPIx_CONREG[0]: EN: Writing zero to this bit disables the block and resets the internal logic with the exception of the ECSPI_CONREG. -- cut --
Note the exception mentioned: The CONREG itself isn't reset.
Fix this by manually writing the reset value 0 to the whole register. This sets the EN bit to zero, too (i.e. includes the old ~MXC_CSPICTRL_EN).
2. We want to reset the whole SPI block here. So it makes no sense to first read the old value of the CONREG and write it back, later. This will give us the old (historic/random) value of the CONREG back. And doesn't reset the CONREG.
To get a clean CONREG after the reset of the block, too, don't use the old (historic/random) value of the CONREG while doing the reset. And read the clean CONREG after the reset.
This was found while working on a SPI boot device where the i.MX6 boot ROM has already initialized the SPI block. The initialization by the boot ROM might be different to what the U-Boot driver wants to configure. I.e. we need a clean reset of SPI block, including the CONREG.
Signed-off-by: Dirk Behme dirk.behme@de.bosch.com CC: Stefano Babic sbabic@denx.de CC: Fabio Estevam fabio.estevam@freescale.com --- drivers/spi/mxc_spi.c | 8 ++++---- 1 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/spi/mxc_spi.c b/drivers/spi/mxc_spi.c index d792d8d..cb48019 100644 --- a/drivers/spi/mxc_spi.c +++ b/drivers/spi/mxc_spi.c @@ -137,11 +137,11 @@ static s32 spi_cfg_mxc(struct mxc_spi_slave *mxcs, unsigned int cs, return -1; }
- reg_ctrl = reg_read(®s->ctrl); - /* Reset spi */ - reg_write(®s->ctrl, (reg_ctrl & ~MXC_CSPICTRL_EN)); - reg_write(®s->ctrl, (reg_ctrl | MXC_CSPICTRL_EN)); + reg_write(®s->ctrl, 0); + reg_write(®s->ctrl, MXC_CSPICTRL_EN); + + reg_ctrl = reg_read(®s->ctrl);
/* * The following computation is taken directly from Freescale's code.
Hi Dirk,
agree completely, only a very minor question..
As you says, it makes no sense to read back the value of the register, also because reg_ctrl is overwritten some lines later ;-)
Best regards, Stefano Babic
Am 03.04.2013 11:12, schrieb Stefano Babic:
Hi Dirk,
Hmm, sorry if I overlooked something, but we have to initialize the variable 'reg_ctrl' with the recent register content because it is first used and _then_ overwritten in the next step:
reg_ctrl = (reg_ctrl & ~MXC_CSPICTRL_SELCHAN(3)) | MXC_CSPICTRL_SELCHAN(cs);
http://git.denx.de/cgi-bin/gitweb.cgi?p=u-boot.git;a=blob;f=drivers/spi/mxc_...
Best regards
Dirk
Hi Dirk,
What I meant is that we know already the value of the register. Your patch set it to MXC_CSPICTRL_EN, and this could be put in or later when you set again the register ;-)
Nevermind, your patch is ok and fixes a real problem. What I commented are more or less style-related.
I merge it and push for the release.
Dirk Behme
Dirk Behme
Stefano Babic
