[PATCH v7 00/10] Add support for loading main_r5fss0_core0
This patch series enables mcu_r5fss0_core0 & main_r5fss0_core0. Tested for firmware loading and execution on J721e.
Changes in v7:
* Added BSD-2 SPDX on lib/elf.c file. * Added Tom's Reviewed-by for the relevant patches.
Changes in v6:
* Fixed the imx build issue.
Changes in v5:
* Moved the fs_loader node under r5-common-proc-board-u-boot.dtsi * Added more information on the envnowhere patch. * Added help LIB_ELF option and removed user configurable description.
Changes in v4:
* Changed env variable names, config names and enhanced commit logs.
Changes in v3:
* Removed saving env in MMC and fixed env saving in SPL when nowhere option is set.
Changes in v2:
* Factored out all the generic elf handling functions under lib/elf.c
Keerthy (10): env: nowhere: set default enviroment lib: elf: Move the generic elf loading/validating functions to lib arm: k3: Add support for loading non linux remote cores armv7R: K3: r5_mpu: Enable execute permission for MCU0 BTCM armv7R: K3: Add support for jumping to firmware arm: dts: k3-j721e-r5-u-boot: Add fs_loader node arm: dts: k3-j721e-r5: Enable r5fss0 cluster in SPL include: configs: j721e_evm: Add env variables for mcu_r5fss0_core0 & main_r5fss0_core0 configs: j721e_evm_r5: Enable R5F remoteproc support configs: j721e_evm_r5_defconfig: Remove saving ENV in eMMC
.../k3-j721e-r5-common-proc-board-u-boot.dtsi | 27 ++ .../arm/dts/k3-j721e-r5-common-proc-board.dts | 2 + arch/arm/mach-imx/imx_bootaux.c | 46 ---- arch/arm/mach-k3/common.c | 106 +++++++- arch/arm/mach-k3/common.h | 2 + arch/arm/mach-k3/j721e_init.c | 34 +++ arch/arm/mach-k3/r5_mpu.c | 4 +- cmd/Kconfig | 1 + cmd/elf.c | 229 ---------------- configs/j721e_evm_r5_defconfig | 6 +- env/nowhere.c | 1 + include/configs/j721e_evm.h | 4 + include/elf.h | 4 + lib/Kconfig | 6 + lib/Makefile | 1 + lib/elf.c | 246 ++++++++++++++++++ 16 files changed, 428 insertions(+), 291 deletions(-) create mode 100644 arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi create mode 100644 lib/elf.c
In case only CONFIG_ENV_IS_NOWHERE without any of the memory based configs like CONFIG_ENV_IS_IN_MMC the env_set function fails as the gd->flags & GD_FLG_ENV_READY check fails.
Set default enviroment so that set_env calls succeed when only ENV_IS_NOWHERE set.
Signed-off-by: Keerthy j-keerthy@ti.com Reviewed-by: Tom Rini trini@konsulko.com --- env/nowhere.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/env/nowhere.c b/env/nowhere.c index f5b0a17652..70c3b3e011 100644 --- a/env/nowhere.c +++ b/env/nowhere.c @@ -23,6 +23,7 @@ static int env_nowhere_init(void) { gd->env_addr = (ulong)&default_environment[0]; gd->env_valid = ENV_INVALID; + env_set_default(NULL, 0);
return 0; }
Move the generic elf loading/validating functions to lib/ so that they can be re-used and accessed by code existing outside cmd.
While at it remove the duplicate static version of load_elf_image_phdr under arch/arm/mach-imx/imx_bootaux.c.
Signed-off-by: Keerthy j-keerthy@ti.com Suggested-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Reviewed-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com --- arch/arm/mach-imx/imx_bootaux.c | 46 ------ cmd/Kconfig | 1 + cmd/elf.c | 229 ----------------------------- include/elf.h | 4 + lib/Kconfig | 6 + lib/Makefile | 1 + lib/elf.c | 246 ++++++++++++++++++++++++++++++++ 7 files changed, 258 insertions(+), 275 deletions(-) create mode 100644 lib/elf.c
diff --git a/arch/arm/mach-imx/imx_bootaux.c b/arch/arm/mach-imx/imx_bootaux.c index 21e96f8c88..8092268a3b 100644 --- a/arch/arm/mach-imx/imx_bootaux.c +++ b/arch/arm/mach-imx/imx_bootaux.c @@ -28,52 +28,6 @@ static const struct rproc_att *get_host_mapping(unsigned long auxcore)
return NULL; } - -/* - * A very simple elf loader, assumes the image is valid, returns the - * entry point address. - */ -static unsigned long load_elf_image_phdr(unsigned long addr) -{ - Elf32_Ehdr *ehdr; /* ELF header structure pointer */ - Elf32_Phdr *phdr; /* Program header structure pointer */ - int i; - - ehdr = (Elf32_Ehdr *)addr; - phdr = (Elf32_Phdr *)(addr + ehdr->e_phoff); - - /* Load each program header */ - for (i = 0; i < ehdr->e_phnum; ++i, ++phdr) { - const struct rproc_att *mmap = get_host_mapping(phdr->p_paddr); - void *dst, *src; - - if (phdr->p_type != PT_LOAD) - continue; - - if (!mmap) { - printf("Invalid aux core address: %08x", - phdr->p_paddr); - return 0; - } - - dst = (void *)(phdr->p_paddr - mmap->da) + mmap->sa; - src = (void *)addr + phdr->p_offset; - - debug("Loading phdr %i to 0x%p (%i bytes)\n", - i, dst, phdr->p_filesz); - - if (phdr->p_filesz) - memcpy(dst, src, phdr->p_filesz); - if (phdr->p_filesz != phdr->p_memsz) - memset(dst + phdr->p_filesz, 0x00, - phdr->p_memsz - phdr->p_filesz); - flush_cache((unsigned long)dst & - ~(CONFIG_SYS_CACHELINE_SIZE - 1), - ALIGN(phdr->p_filesz, CONFIG_SYS_CACHELINE_SIZE)); - } - - return ehdr->e_entry; -} #endif
int arch_auxiliary_core_up(u32 core_id, ulong addr) diff --git a/cmd/Kconfig b/cmd/Kconfig index e6ba57035e..9819dd1aaf 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -399,6 +399,7 @@ config CMD_ABOOTIMG config CMD_ELF bool "bootelf, bootvx" default y + select LIB_ELF help Boot an ELF/vxWorks image from the memory.
diff --git a/cmd/elf.c b/cmd/elf.c index ba06df06cf..c129077e20 100644 --- a/cmd/elf.c +++ b/cmd/elf.c @@ -27,211 +27,6 @@ #include <linux/linkage.h> #endif
-/* - * A very simple ELF64 loader, assumes the image is valid, returns the - * entry point address. - * - * Note if U-Boot is 32-bit, the loader assumes the to segment's - * physical address and size is within the lower 32-bit address space. - */ -static unsigned long load_elf64_image_phdr(unsigned long addr) -{ - Elf64_Ehdr *ehdr; /* Elf header structure pointer */ - Elf64_Phdr *phdr; /* Program header structure pointer */ - int i; - - ehdr = (Elf64_Ehdr *)addr; - phdr = (Elf64_Phdr *)(addr + (ulong)ehdr->e_phoff); - - /* Load each program header */ - for (i = 0; i < ehdr->e_phnum; ++i) { - void *dst = (void *)(ulong)phdr->p_paddr; - void *src = (void *)addr + phdr->p_offset; - - debug("Loading phdr %i to 0x%p (%lu bytes)\n", - i, dst, (ulong)phdr->p_filesz); - if (phdr->p_filesz) - memcpy(dst, src, phdr->p_filesz); - if (phdr->p_filesz != phdr->p_memsz) - memset(dst + phdr->p_filesz, 0x00, - phdr->p_memsz - phdr->p_filesz); - flush_cache(rounddown((unsigned long)dst, ARCH_DMA_MINALIGN), - roundup(phdr->p_memsz, ARCH_DMA_MINALIGN)); - ++phdr; - } - - if (ehdr->e_machine == EM_PPC64 && (ehdr->e_flags & - EF_PPC64_ELFV1_ABI)) { - /* - * For the 64-bit PowerPC ELF V1 ABI, e_entry is a function - * descriptor pointer with the first double word being the - * address of the entry point of the function. - */ - uintptr_t addr = ehdr->e_entry; - - return *(Elf64_Addr *)addr; - } - - return ehdr->e_entry; -} - -static unsigned long load_elf64_image_shdr(unsigned long addr) -{ - Elf64_Ehdr *ehdr; /* Elf header structure pointer */ - Elf64_Shdr *shdr; /* Section header structure pointer */ - unsigned char *strtab = 0; /* String table pointer */ - unsigned char *image; /* Binary image pointer */ - int i; /* Loop counter */ - - ehdr = (Elf64_Ehdr *)addr; - - /* Find the section header string table for output info */ - shdr = (Elf64_Shdr *)(addr + (ulong)ehdr->e_shoff + - (ehdr->e_shstrndx * sizeof(Elf64_Shdr))); - - if (shdr->sh_type == SHT_STRTAB) - strtab = (unsigned char *)(addr + (ulong)shdr->sh_offset); - - /* Load each appropriate section */ - for (i = 0; i < ehdr->e_shnum; ++i) { - shdr = (Elf64_Shdr *)(addr + (ulong)ehdr->e_shoff + - (i * sizeof(Elf64_Shdr))); - - if (!(shdr->sh_flags & SHF_ALLOC) || - shdr->sh_addr == 0 || shdr->sh_size == 0) { - continue; - } - - if (strtab) { - debug("%sing %s @ 0x%08lx (%ld bytes)\n", - (shdr->sh_type == SHT_NOBITS) ? "Clear" : "Load", - &strtab[shdr->sh_name], - (unsigned long)shdr->sh_addr, - (long)shdr->sh_size); - } - - if (shdr->sh_type == SHT_NOBITS) { - memset((void *)(uintptr_t)shdr->sh_addr, 0, - shdr->sh_size); - } else { - image = (unsigned char *)addr + (ulong)shdr->sh_offset; - memcpy((void *)(uintptr_t)shdr->sh_addr, - (const void *)image, shdr->sh_size); - } - flush_cache(rounddown(shdr->sh_addr, ARCH_DMA_MINALIGN), - roundup((shdr->sh_addr + shdr->sh_size), - ARCH_DMA_MINALIGN) - - rounddown(shdr->sh_addr, ARCH_DMA_MINALIGN)); - } - - if (ehdr->e_machine == EM_PPC64 && (ehdr->e_flags & - EF_PPC64_ELFV1_ABI)) { - /* - * For the 64-bit PowerPC ELF V1 ABI, e_entry is a function - * descriptor pointer with the first double word being the - * address of the entry point of the function. - */ - uintptr_t addr = ehdr->e_entry; - - return *(Elf64_Addr *)addr; - } - - return ehdr->e_entry; -} - -/* - * A very simple ELF loader, assumes the image is valid, returns the - * entry point address. - * - * The loader firstly reads the EFI class to see if it's a 64-bit image. - * If yes, call the ELF64 loader. Otherwise continue with the ELF32 loader. - */ -static unsigned long load_elf_image_phdr(unsigned long addr) -{ - Elf32_Ehdr *ehdr; /* Elf header structure pointer */ - Elf32_Phdr *phdr; /* Program header structure pointer */ - int i; - - ehdr = (Elf32_Ehdr *)addr; - if (ehdr->e_ident[EI_CLASS] == ELFCLASS64) - return load_elf64_image_phdr(addr); - - phdr = (Elf32_Phdr *)(addr + ehdr->e_phoff); - - /* Load each program header */ - for (i = 0; i < ehdr->e_phnum; ++i) { - void *dst = (void *)(uintptr_t)phdr->p_paddr; - void *src = (void *)addr + phdr->p_offset; - - debug("Loading phdr %i to 0x%p (%i bytes)\n", - i, dst, phdr->p_filesz); - if (phdr->p_filesz) - memcpy(dst, src, phdr->p_filesz); - if (phdr->p_filesz != phdr->p_memsz) - memset(dst + phdr->p_filesz, 0x00, - phdr->p_memsz - phdr->p_filesz); - flush_cache(rounddown((unsigned long)dst, ARCH_DMA_MINALIGN), - roundup(phdr->p_memsz, ARCH_DMA_MINALIGN)); - ++phdr; - } - - return ehdr->e_entry; -} - -static unsigned long load_elf_image_shdr(unsigned long addr) -{ - Elf32_Ehdr *ehdr; /* Elf header structure pointer */ - Elf32_Shdr *shdr; /* Section header structure pointer */ - unsigned char *strtab = 0; /* String table pointer */ - unsigned char *image; /* Binary image pointer */ - int i; /* Loop counter */ - - ehdr = (Elf32_Ehdr *)addr; - if (ehdr->e_ident[EI_CLASS] == ELFCLASS64) - return load_elf64_image_shdr(addr); - - /* Find the section header string table for output info */ - shdr = (Elf32_Shdr *)(addr + ehdr->e_shoff + - (ehdr->e_shstrndx * sizeof(Elf32_Shdr))); - - if (shdr->sh_type == SHT_STRTAB) - strtab = (unsigned char *)(addr + shdr->sh_offset); - - /* Load each appropriate section */ - for (i = 0; i < ehdr->e_shnum; ++i) { - shdr = (Elf32_Shdr *)(addr + ehdr->e_shoff + - (i * sizeof(Elf32_Shdr))); - - if (!(shdr->sh_flags & SHF_ALLOC) || - shdr->sh_addr == 0 || shdr->sh_size == 0) { - continue; - } - - if (strtab) { - debug("%sing %s @ 0x%08lx (%ld bytes)\n", - (shdr->sh_type == SHT_NOBITS) ? "Clear" : "Load", - &strtab[shdr->sh_name], - (unsigned long)shdr->sh_addr, - (long)shdr->sh_size); - } - - if (shdr->sh_type == SHT_NOBITS) { - memset((void *)(uintptr_t)shdr->sh_addr, 0, - shdr->sh_size); - } else { - image = (unsigned char *)addr + shdr->sh_offset; - memcpy((void *)(uintptr_t)shdr->sh_addr, - (const void *)image, shdr->sh_size); - } - flush_cache(rounddown(shdr->sh_addr, ARCH_DMA_MINALIGN), - roundup((shdr->sh_addr + shdr->sh_size), - ARCH_DMA_MINALIGN) - - rounddown(shdr->sh_addr, ARCH_DMA_MINALIGN)); - } - - return ehdr->e_entry; -} - /* Allow ports to override the default behavior */ static unsigned long do_bootelf_exec(ulong (*entry)(int, char * const[]), int argc, char * const argv[]) @@ -247,30 +42,6 @@ static unsigned long do_bootelf_exec(ulong (*entry)(int, char * const[]), return ret; }
-/* - * Determine if a valid ELF image exists at the given memory location. - * First look at the ELF header magic field, then make sure that it is - * executable. - */ -int valid_elf_image(unsigned long addr) -{ - Elf32_Ehdr *ehdr; /* Elf header structure pointer */ - - ehdr = (Elf32_Ehdr *)addr; - - if (!IS_ELF(*ehdr)) { - printf("## No elf image at address 0x%08lx\n", addr); - return 0; - } - - if (ehdr->e_type != ET_EXEC) { - printf("## Not a 32-bit elf image at address 0x%08lx\n", addr); - return 0; - } - - return 1; -} - /* Interpreter command to boot an arbitrary ELF image from memory */ int do_bootelf(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { diff --git a/include/elf.h b/include/elf.h index 81f40191d7..e7c51986df 100644 --- a/include/elf.h +++ b/include/elf.h @@ -692,6 +692,10 @@ unsigned long elf_hash(const unsigned char *name);
#ifndef __ASSEMBLER__ int valid_elf_image(unsigned long addr); +unsigned long load_elf64_image_phdr(unsigned long addr); +unsigned long load_elf64_image_shdr(unsigned long addr); +unsigned long load_elf_image_phdr(unsigned long addr); +unsigned long load_elf_image_shdr(unsigned long addr); #endif
#endif /* _ELF_H */ diff --git a/lib/Kconfig b/lib/Kconfig index ab6aff710d..452f390c80 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -602,4 +602,10 @@ config TEST_FDTDEC config LIB_DATE bool
+config LIB_ELF + bool + help + Supoort basic elf loading/validating functions. + This supports fir 32 bit and 64 bit versions. + endmenu diff --git a/lib/Makefile b/lib/Makefile index 15259d0473..32bf3f3693 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -122,6 +122,7 @@ obj-y += vsprintf.o strto.o endif
obj-y += date.o +obj-$(CONFIG_LIB_ELF) += elf.o
# # Build a fast OID lookup registry from include/linux/oid_registry.h diff --git a/lib/elf.c b/lib/elf.c new file mode 100644 index 0000000000..d074e4e0a7 --- /dev/null +++ b/lib/elf.c @@ -0,0 +1,246 @@ +// SPDX-License-Identifier: BSD-2-Clause +/* + Copyright (c) 2001 William L. Pitts +*/ + +#include <common.h> +#include <command.h> +#include <cpu_func.h> +#include <elf.h> +#include <env.h> +#include <net.h> +#include <vxworks.h> +#ifdef CONFIG_X86 +#include <vbe.h> +#include <asm/e820.h> +#include <linux/linkage.h> +#endif + +/* + * A very simple ELF64 loader, assumes the image is valid, returns the + * entry point address. + * + * Note if U-Boot is 32-bit, the loader assumes the to segment's + * physical address and size is within the lower 32-bit address space. + */ +unsigned long load_elf64_image_phdr(unsigned long addr) +{ + Elf64_Ehdr *ehdr; /* Elf header structure pointer */ + Elf64_Phdr *phdr; /* Program header structure pointer */ + int i; + + ehdr = (Elf64_Ehdr *)addr; + phdr = (Elf64_Phdr *)(addr + (ulong)ehdr->e_phoff); + + /* Load each program header */ + for (i = 0; i < ehdr->e_phnum; ++i) { + void *dst = (void *)(ulong)phdr->p_paddr; + void *src = (void *)addr + phdr->p_offset; + + debug("Loading phdr %i to 0x%p (%lu bytes)\n", + i, dst, (ulong)phdr->p_filesz); + if (phdr->p_filesz) + memcpy(dst, src, phdr->p_filesz); + if (phdr->p_filesz != phdr->p_memsz) + memset(dst + phdr->p_filesz, 0x00, + phdr->p_memsz - phdr->p_filesz); + flush_cache(rounddown((unsigned long)dst, ARCH_DMA_MINALIGN), + roundup(phdr->p_memsz, ARCH_DMA_MINALIGN)); + ++phdr; + } + + if (ehdr->e_machine == EM_PPC64 && (ehdr->e_flags & + EF_PPC64_ELFV1_ABI)) { + /* + * For the 64-bit PowerPC ELF V1 ABI, e_entry is a function + * descriptor pointer with the first double word being the + * address of the entry point of the function. + */ + uintptr_t addr = ehdr->e_entry; + + return *(Elf64_Addr *)addr; + } + + return ehdr->e_entry; +} + +unsigned long load_elf64_image_shdr(unsigned long addr) +{ + Elf64_Ehdr *ehdr; /* Elf header structure pointer */ + Elf64_Shdr *shdr; /* Section header structure pointer */ + unsigned char *strtab = 0; /* String table pointer */ + unsigned char *image; /* Binary image pointer */ + int i; /* Loop counter */ + + ehdr = (Elf64_Ehdr *)addr; + + /* Find the section header string table for output info */ + shdr = (Elf64_Shdr *)(addr + (ulong)ehdr->e_shoff + + (ehdr->e_shstrndx * sizeof(Elf64_Shdr))); + + if (shdr->sh_type == SHT_STRTAB) + strtab = (unsigned char *)(addr + (ulong)shdr->sh_offset); + + /* Load each appropriate section */ + for (i = 0; i < ehdr->e_shnum; ++i) { + shdr = (Elf64_Shdr *)(addr + (ulong)ehdr->e_shoff + + (i * sizeof(Elf64_Shdr))); + + if (!(shdr->sh_flags & SHF_ALLOC) || + shdr->sh_addr == 0 || shdr->sh_size == 0) { + continue; + } + + if (strtab) { + debug("%sing %s @ 0x%08lx (%ld bytes)\n", + (shdr->sh_type == SHT_NOBITS) ? "Clear" : "Load", + &strtab[shdr->sh_name], + (unsigned long)shdr->sh_addr, + (long)shdr->sh_size); + } + + if (shdr->sh_type == SHT_NOBITS) { + memset((void *)(uintptr_t)shdr->sh_addr, 0, + shdr->sh_size); + } else { + image = (unsigned char *)addr + (ulong)shdr->sh_offset; + memcpy((void *)(uintptr_t)shdr->sh_addr, + (const void *)image, shdr->sh_size); + } + flush_cache(rounddown(shdr->sh_addr, ARCH_DMA_MINALIGN), + roundup((shdr->sh_addr + shdr->sh_size), + ARCH_DMA_MINALIGN) - + rounddown(shdr->sh_addr, ARCH_DMA_MINALIGN)); + } + + if (ehdr->e_machine == EM_PPC64 && (ehdr->e_flags & + EF_PPC64_ELFV1_ABI)) { + /* + * For the 64-bit PowerPC ELF V1 ABI, e_entry is a function + * descriptor pointer with the first double word being the + * address of the entry point of the function. + */ + uintptr_t addr = ehdr->e_entry; + + return *(Elf64_Addr *)addr; + } + + return ehdr->e_entry; +} + +/* + * A very simple ELF loader, assumes the image is valid, returns the + * entry point address. + * + * The loader firstly reads the EFI class to see if it's a 64-bit image. + * If yes, call the ELF64 loader. Otherwise continue with the ELF32 loader. + */ +unsigned long load_elf_image_phdr(unsigned long addr) +{ + Elf32_Ehdr *ehdr; /* Elf header structure pointer */ + Elf32_Phdr *phdr; /* Program header structure pointer */ + int i; + + ehdr = (Elf32_Ehdr *)addr; + if (ehdr->e_ident[EI_CLASS] == ELFCLASS64) + return load_elf64_image_phdr(addr); + + phdr = (Elf32_Phdr *)(addr + ehdr->e_phoff); + + /* Load each program header */ + for (i = 0; i < ehdr->e_phnum; ++i) { + void *dst = (void *)(uintptr_t)phdr->p_paddr; + void *src = (void *)addr + phdr->p_offset; + + debug("Loading phdr %i to 0x%p (%i bytes)\n", + i, dst, phdr->p_filesz); + if (phdr->p_filesz) + memcpy(dst, src, phdr->p_filesz); + if (phdr->p_filesz != phdr->p_memsz) + memset(dst + phdr->p_filesz, 0x00, + phdr->p_memsz - phdr->p_filesz); + flush_cache(rounddown((unsigned long)dst, ARCH_DMA_MINALIGN), + roundup(phdr->p_memsz, ARCH_DMA_MINALIGN)); + ++phdr; + } + + return ehdr->e_entry; +} + +unsigned long load_elf_image_shdr(unsigned long addr) +{ + Elf32_Ehdr *ehdr; /* Elf header structure pointer */ + Elf32_Shdr *shdr; /* Section header structure pointer */ + unsigned char *strtab = 0; /* String table pointer */ + unsigned char *image; /* Binary image pointer */ + int i; /* Loop counter */ + + ehdr = (Elf32_Ehdr *)addr; + if (ehdr->e_ident[EI_CLASS] == ELFCLASS64) + return load_elf64_image_shdr(addr); + + /* Find the section header string table for output info */ + shdr = (Elf32_Shdr *)(addr + ehdr->e_shoff + + (ehdr->e_shstrndx * sizeof(Elf32_Shdr))); + + if (shdr->sh_type == SHT_STRTAB) + strtab = (unsigned char *)(addr + shdr->sh_offset); + + /* Load each appropriate section */ + for (i = 0; i < ehdr->e_shnum; ++i) { + shdr = (Elf32_Shdr *)(addr + ehdr->e_shoff + + (i * sizeof(Elf32_Shdr))); + + if (!(shdr->sh_flags & SHF_ALLOC) || + shdr->sh_addr == 0 || shdr->sh_size == 0) { + continue; + } + + if (strtab) { + debug("%sing %s @ 0x%08lx (%ld bytes)\n", + (shdr->sh_type == SHT_NOBITS) ? "Clear" : "Load", + &strtab[shdr->sh_name], + (unsigned long)shdr->sh_addr, + (long)shdr->sh_size); + } + + if (shdr->sh_type == SHT_NOBITS) { + memset((void *)(uintptr_t)shdr->sh_addr, 0, + shdr->sh_size); + } else { + image = (unsigned char *)addr + shdr->sh_offset; + memcpy((void *)(uintptr_t)shdr->sh_addr, + (const void *)image, shdr->sh_size); + } + flush_cache(rounddown(shdr->sh_addr, ARCH_DMA_MINALIGN), + roundup((shdr->sh_addr + shdr->sh_size), + ARCH_DMA_MINALIGN) - + rounddown(shdr->sh_addr, ARCH_DMA_MINALIGN)); + } + + return ehdr->e_entry; +} + +/* + * Determine if a valid ELF image exists at the given memory location. + * First look at the ELF header magic field, then make sure that it is + * executable. + */ +int valid_elf_image(unsigned long addr) +{ + Elf32_Ehdr *ehdr; /* Elf header structure pointer */ + + ehdr = (Elf32_Ehdr *)addr; + + if (!IS_ELF(*ehdr)) { + printf("## No elf image at address 0x%08lx\n", addr); + return 0; + } + + if (ehdr->e_type != ET_EXEC) { + printf("## Not a 32-bit elf image at address 0x%08lx\n", addr); + return 0; + } + + return 1; +}
Add MAIN domain R5FSS0 remoteproc support from spl. This enables loading the elf firmware in SPL and starting the remotecore.
In order to start the core, there should be a file with path "/lib/firmware/j7-main-r5f0_0-fw" under filesystem of respective boot mode.
Signed-off-by: Keerthy j-keerthy@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com [Guard start_non_linux_remote_cores under CONFIG_FS_LOADER] Signed-off-by: Andreas Dannenberg dannenberg@ti.com --- arch/arm/mach-k3/common.c | 84 ++++++++++++++++++++++++++++++++--- arch/arm/mach-k3/common.h | 2 + arch/arm/mach-k3/j721e_init.c | 34 ++++++++++++++ 3 files changed, 115 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-k3/common.c b/arch/arm/mach-k3/common.c index 2f82edb970..bddb62ea5e 100644 --- a/arch/arm/mach-k3/common.c +++ b/arch/arm/mach-k3/common.c @@ -17,6 +17,10 @@ #include <asm/arch/sys_proto.h> #include <asm/hardware.h> #include <asm/io.h> +#include <fs_loader.h> +#include <fs.h> +#include <env.h> +#include <elf.h>
struct ti_sci_handle *get_ti_sci_handle(void) { @@ -58,6 +62,74 @@ int early_console_init(void) #endif
#ifdef CONFIG_SYS_K3_SPL_ATF + +void init_env(void) +{ +#ifdef CONFIG_SPL_ENV_SUPPORT + char *part; + + env_init(); + env_load(); + switch (spl_boot_device()) { + case BOOT_DEVICE_MMC2: + part = env_get("bootpart"); + env_set("storage_interface", "mmc"); + env_set("fw_dev_part", part); + break; + case BOOT_DEVICE_SPI: + env_set("storage_interface", "ubi"); + env_set("fw_ubi_mtdpart", "UBI"); + env_set("fw_ubi_volume", "UBI0"); + break; + default: + printf("%s from device %u not supported!\n", + __func__, spl_boot_device()); + return; + } +#endif +} + +#ifdef CONFIG_FS_LOADER +int load_firmware(char *name_fw, char *name_loadaddr, u32 *loadaddr) +{ + struct udevice *fsdev; + char *name = NULL; + int size = 0; + + *loadaddr = 0; +#ifdef CONFIG_SPL_ENV_SUPPORT + switch (spl_boot_device()) { + case BOOT_DEVICE_MMC2: + name = env_get(name_fw); + *loadaddr = env_get_hex(name_loadaddr, *loadaddr); + break; + default: + printf("Loading rproc fw image from device %u not supported!\n", + spl_boot_device()); + return 0; + } +#endif + if (!*loadaddr) + return 0; + + if (!uclass_get_device(UCLASS_FS_FIRMWARE_LOADER, 0, &fsdev)) { + size = request_firmware_into_buf(fsdev, name, (void *)*loadaddr, + 0, 0); + } + + return size; +} +#else +int load_firmware(char *name_fw, char *name_loadaddr, u32 *loadaddr) +{ + return 0; +} +#endif + +__weak void start_non_linux_remote_cores(void) +{ +} + void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) { struct ti_sci_handle *ti_sci = get_ti_sci_handle(); @@ -66,15 +138,17 @@ void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) /* Release all the exclusive devices held by SPL before starting ATF */ ti_sci->ops.dev_ops.release_exclusive_devices(ti_sci);
+ ret = rproc_init(); + if (ret) + panic("rproc failed to be initialized (%d)\n", ret); + + init_env(); + start_non_linux_remote_cores(); + /* * It is assumed that remoteproc device 1 is the corresponding * Cortex-A core which runs ATF. Make sure DT reflects the same. */ - ret = rproc_dev_init(1); - if (ret) - panic("%s: ATF failed to initialize on rproc (%d)\n", __func__, - ret); - ret = rproc_load(1, spl_image->entry_point, 0x200); if (ret) panic("%s: ATF failed to load on rproc (%d)\n", __func__, ret); diff --git a/arch/arm/mach-k3/common.h b/arch/arm/mach-k3/common.h index d8b34fe060..42fb8ee6e7 100644 --- a/arch/arm/mach-k3/common.h +++ b/arch/arm/mach-k3/common.h @@ -24,3 +24,5 @@ void setup_k3_mpu_regions(void); int early_console_init(void); void disable_linefill_optimization(void); void remove_fwl_configs(struct fwl_data *fwl_data, size_t fwl_data_size); +void start_non_linux_remote_cores(void); +int load_firmware(char *name_fw, char *name_loadaddr, u32 *loadaddr); diff --git a/arch/arm/mach-k3/j721e_init.c b/arch/arm/mach-k3/j721e_init.c index f7f7398081..13f3791823 100644 --- a/arch/arm/mach-k3/j721e_init.c +++ b/arch/arm/mach-k3/j721e_init.c @@ -18,6 +18,7 @@ #include <dm.h> #include <dm/uclass-internal.h> #include <dm/pinctrl.h> +#include <remoteproc.h>
#ifdef CONFIG_SPL_BUILD #ifdef CONFIG_K3_LOAD_SYSFW @@ -295,3 +296,36 @@ void release_resources_for_core_shutdown(void) } } #endif + +#ifdef CONFIG_SYS_K3_SPL_ATF +void start_non_linux_remote_cores(void) +{ + int size = 0, ret; + u32 loadaddr = 0; + + size = load_firmware("name_mainr5f0_0fw", "addr_mainr5f0_0load", + &loadaddr); + if (size <= 0) + goto err_load; + + /* assuming remoteproc 2 is aliased for the needed remotecore */ + ret = rproc_load(2, loadaddr, size); + if (ret) { + printf("Firmware failed to start on rproc (%d)\n", ret); + goto err_load; + } + + ret = rproc_start(2); + if (ret) { + printf("Firmware init failed on rproc (%d)\n", ret); + goto err_load; + } + + printf("Remoteproc 2 started successfully\n"); + + return; + +err_load: + rproc_reset(2); +} +#endif
Enable execute permission for mcu_r5fss0_core0 BTCM so that we can jump to a firmware directly from SPL.
Signed-off-by: Keerthy j-keerthy@ti.com --- arch/arm/mach-k3/r5_mpu.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-k3/r5_mpu.c b/arch/arm/mach-k3/r5_mpu.c index ee076ed877..3d2ff6775a 100644 --- a/arch/arm/mach-k3/r5_mpu.c +++ b/arch/arm/mach-k3/r5_mpu.c @@ -26,7 +26,9 @@ struct mpu_region_config k3_mpu_regions[16] = { /* U-Boot's code area marking it as WB and Write allocate */ {CONFIG_SYS_SDRAM_BASE, REGION_2, XN_DIS, PRIV_RW_USR_RW, O_I_WB_RD_WR_ALLOC, REGION_2GB}, - {0x0, 3, 0x0, 0x0, 0x0, 0x0}, + /* mcu_r5fss0_core0 BTCM area marking it as WB and Write allocate. */ + {0x41010000, 3, XN_DIS, PRIV_RW_USR_RW, O_I_WB_RD_WR_ALLOC, + REGION_8MB}, {0x0, 4, 0x0, 0x0, 0x0, 0x0}, {0x0, 5, 0x0, 0x0, 0x0, 0x0}, {0x0, 6, 0x0, 0x0, 0x0, 0x0},
MCU Domain rf50 is currently shutting down after loading the ATF. Load elf firmware and jump to firmware post loading ATF.
ROM doesn't enable ATCM memory, so make sure that firmware that is being loaded doesn't use ATCM memory or override SPL.
Signed-off-by: Keerthy j-keerthy@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/mach-k3/common.c | 22 ++++++++++++++++------ 1 file changed, 16 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-k3/common.c b/arch/arm/mach-k3/common.c index bddb62ea5e..5c5eedb6eb 100644 --- a/arch/arm/mach-k3/common.c +++ b/arch/arm/mach-k3/common.c @@ -132,8 +132,10 @@ __weak void start_non_linux_remote_cores(void)
void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) { + typedef void __noreturn (*image_entry_noargs_t)(void); struct ti_sci_handle *ti_sci = get_ti_sci_handle(); - int ret; + u32 loadaddr = 0; + int ret, size;
/* Release all the exclusive devices held by SPL before starting ATF */ ti_sci->ops.dev_ops.release_exclusive_devices(ti_sci); @@ -144,6 +146,9 @@ void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image)
init_env(); start_non_linux_remote_cores(); + size = load_firmware("name_mcur5f0_0fw", "addr_mcur5f0_0load", + &loadaddr); +
/* * It is assumed that remoteproc device 1 is the corresponding @@ -159,13 +164,18 @@ void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) ret = rproc_start(1); if (ret) panic("%s: ATF failed to start on rproc (%d)\n", __func__, ret); + if (!(size > 0 && valid_elf_image(loadaddr))) { + debug("Shutting down...\n"); + release_resources_for_core_shutdown(); + + while (1) + asm volatile("wfe"); + }
- debug("Releasing resources...\n"); - release_resources_for_core_shutdown(); + image_entry_noargs_t image_entry = + (image_entry_noargs_t)load_elf_image_phdr(loadaddr);
- debug("Finalizing core shutdown...\n"); - while (1) - asm volatile("wfe"); + image_entry(); } #endif
Add fs_loader node which will be needed for loading firmwares from the boot media/filesystem.
Signed-off-by: Keerthy j-keerthy@ti.com Reviewed-by: Tom Rini trini@konsulko.com --- .../dts/k3-j721e-r5-common-proc-board-u-boot.dtsi | 15 +++++++++++++++ 1 file changed, 15 insertions(+) create mode 100644 arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi
diff --git a/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi new file mode 100644 index 0000000000..f98be993e8 --- /dev/null +++ b/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi @@ -0,0 +1,15 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 Texas Instruments Incorporated - http://www.ti.com/ + */ + +/ { + chosen { + firmware-loader = &fs_loader0; + }; + + fs_loader0: fs_loader@0 { + u-boot,dm-pre-reloc; + compatible = "u-boot,fs-loader"; + }; +};
Enable MAIN domain r5fss0 cluster and its core0 in R5 spl.
Signed-off-by: Keerthy j-keerthy@ti.com Reviewed-by: Tom Rini trini@konsulko.com --- .../dts/k3-j721e-r5-common-proc-board-u-boot.dtsi | 12 ++++++++++++ arch/arm/dts/k3-j721e-r5-common-proc-board.dts | 2 ++ 2 files changed, 14 insertions(+)
diff --git a/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi index f98be993e8..526f42e3a9 100644 --- a/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j721e-r5-common-proc-board-u-boot.dtsi @@ -13,3 +13,15 @@ compatible = "u-boot,fs-loader"; }; }; + +&main_r5fss0 { + u-boot,dm-spl; +}; + +&main_r5fss0_core0 { + u-boot,dm-spl; +}; + +&main_r5fss0_core1 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/k3-j721e-r5-common-proc-board.dts b/arch/arm/dts/k3-j721e-r5-common-proc-board.dts index 1f14d71438..ba2a312602 100644 --- a/arch/arm/dts/k3-j721e-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j721e-r5-common-proc-board.dts @@ -13,6 +13,8 @@ aliases { remoteproc0 = &sysctrler; remoteproc1 = &a72_0; + remoteproc2 = &main_r5fss0_core0; + remoteproc3 = &main_r5fss0_core1; };
chosen {
Add env variables for mcu_r5fss0_core0 & main_r5fss0_core0 firmware loadaddr and name.
Signed-off-by: Keerthy j-keerthy@ti.com --- include/configs/j721e_evm.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/include/configs/j721e_evm.h b/include/configs/j721e_evm.h index 4371c471e5..fc73a9c932 100644 --- a/include/configs/j721e_evm.h +++ b/include/configs/j721e_evm.h @@ -88,6 +88,10 @@ "mmcdev=1\0" \ "bootpart=1:2\0" \ "bootdir=/boot\0" \ + "addr_mainr5f0_0load=88000000\0" \ + "name_mainr5f0_0fw=/lib/firmware/j7-main-r5f0_0-fw\0" \ + "addr_mcur5f0_0load=89000000\0" \ + "name_mcur5f0_0fw=/lib/firmware/j7-mcu-r5f0_0-fw\0" \ "rd_spec=-\0" \ "init_mmc=run args_all args_mmc\0" \ "get_fdt_mmc=load mmc ${bootpart} ${fdtaddr} ${bootdir}/${name_fdt}\0" \
Enable R5F remoteproc support in R5 defconfig so that R5s can be started in SPL. While at it enable the SPL_FS_EXT4 config option to load the firmwares from file system.
Signed-off-by: Keerthy j-keerthy@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- configs/j721e_evm_r5_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/j721e_evm_r5_defconfig b/configs/j721e_evm_r5_defconfig index 19fbd450c7..b1fc919f6a 100644 --- a/configs/j721e_evm_r5_defconfig +++ b/configs/j721e_evm_r5_defconfig @@ -26,6 +26,7 @@ CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_EARLY_BSS=y CONFIG_SPL_ENV_SUPPORT=y +CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_DM_MAILBOX=y CONFIG_SPL_DM_RESET=y @@ -96,6 +97,7 @@ CONFIG_SPL_DM_REGULATOR=y CONFIG_DM_REGULATOR_TPS65941=y CONFIG_K3_SYSTEM_CONTROLLER=y CONFIG_REMOTEPROC_TI_K3_ARM64=y +CONFIG_REMOTEPROC_TI_K3_R5F=y CONFIG_DM_RESET=y CONFIG_RESET_TI_SCI=y CONFIG_DM_SERIAL=y
Remove saving ENV in eMMC in R5 as the power domains are not setup. Environment in eMMC cannot be read if we do not boot from eMMC.
Signed-off-by: Keerthy j-keerthy@ti.com --- configs/j721e_evm_r5_defconfig | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/configs/j721e_evm_r5_defconfig b/configs/j721e_evm_r5_defconfig index b1fc919f6a..67fde3bc5d 100644 --- a/configs/j721e_evm_r5_defconfig +++ b/configs/j721e_evm_r5_defconfig @@ -7,7 +7,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x70000 CONFIG_SOC_K3_J721E=y CONFIG_TARGET_J721E_R5_EVM=y CONFIG_ENV_SIZE=0x20000 -CONFIG_ENV_OFFSET=0x680000 CONFIG_DM_GPIO=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y @@ -52,9 +51,6 @@ CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="k3-j721e-r5-common-proc-board" -CONFIG_ENV_IS_IN_MMC=y -CONFIG_SYS_REDUNDAND_ENVIRONMENT=y -CONFIG_ENV_OFFSET_REDUND=0x700000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_SPL_DM=y
I still see build error with multiple imx boards:
=================================================== arm: + mx7dsabresd_qspi +arch/arm/mach-imx/imx_bootaux.c:18:32: error: 'get_host_mapping' defined but not used [-Werror=unused-function] + static const struct rproc_att *get_host_mapping(unsigned long auxcore) + ^~~~~~~~~~~~~~~~ +cc1: all warnings being treated as errors +make[2]: *** [arch/arm/mach-imx/imx_bootaux.o] Error 1 +make[1]: *** [arch/arm/mach-imx] Error 2 +make: *** [sub-make] Error 2
Thanks and regards, Lokesh
Changes in v7:
- Added BSD-2 SPDX on lib/elf.c file.
- Added Tom's Reviewed-by for the relevant patches.
Changes in v6:
- Fixed the imx build issue.
Changes in v5:
- Moved the fs_loader node under r5-common-proc-board-u-boot.dtsi
- Added more information on the envnowhere patch.
- Added help LIB_ELF option and removed user configurable description.
Changes in v4:
- Changed env variable names, config names and enhanced commit logs.
Changes in v3:
- Removed saving env in MMC and fixed env saving in SPL when nowhere option is set.
Changes in v2:
- Factored out all the generic elf handling functions under lib/elf.c
- static const struct rproc_att *get_host_mapping(unsigned long auxcore)
Phew... Local builds did not catch for me. I will make sure i run the travis builds before i submit v8.
Changes in v7:
Changes in v6:
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
Keerthy
keerthy
Lokesh Vutla
