[U-Boot] [PATCH] sandbox: Adjust the order of the NO_SDL check
An option is provided to avoid using SDL in U-Boot sandbox (and drop support for the LCD). However the check in the Makefile is too late and warnings are printed even if NO_SDL=y is given.
Adjust the order to avoid this warning.
arch/sandbox/config.mk | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/arch/sandbox/config.mk b/arch/sandbox/config.mk index e38a44b..7b84f02 100644 --- a/arch/sandbox/config.mk +++ b/arch/sandbox/config.mk @@ -5,10 +5,16 @@ PLATFORM_CPPFLAGS += -D__SANDBOX__ -U_FORTIFY_SOURCE PLATFORM_CPPFLAGS += -DCONFIG_ARCH_MAP_SYSMEM -DCONFIG_SYS_GENERIC_BOARD PLATFORM_LIBS += -lrt
+# Define this to avoid linking with SDL, which requires SDL libraries +# This can solve 'sdl-config: Command not found' errors +ifneq ($(NO_SDL),) +PLATFORM_CPPFLAGS += -DSANDBOX_NO_SDL +else ifdef CONFIG_SANDBOX_SDL PLATFORM_LIBS += $(shell sdl-config --libs) PLATFORM_CPPFLAGS += $(shell sdl-config --cflags) endif +endif
# Support generic board on sandbox __HAVE_ARCH_GENERIC_BOARD := y @@ -18,9 +24,3 @@ cmd_u-boot__ = $(CC) -o $@ -T u-boot.lds \ $(PLATFORM_LIBS) -Wl,-Map -Wl,u-boot.map
CONFIG_ARCH_DEVICE_TREE := sandbox - -# Define this to avoid linking with SDL, which requires SDL libraries -# This can solve 'sdl-config: Command not found' errors -ifneq ($(NO_SDL),) -PLATFORM_CPPFLAGS += -DSANDBOX_NO_SDL -endif
Hello Simon,
yup, feel free to commit this (it can't do any harm just prevents some warnings). Which I guess translates to
Acked-by: Jeroen Hofstee jeroen@myspectrum.nl
Regards, Jeroen
On 12 February 2015 at 16:12, Jeroen Hofstee jeroen@myspectrum.nl wrote:
Hello Simon,
diff --git a/arch/sandbox/config.mk b/arch/sandbox/config.mk index e38a44b..7b84f02 100644 --- a/arch/sandbox/config.mk +++ b/arch/sandbox/config.mk @@ -5,10 +5,16 @@ PLATFORM_CPPFLAGS += -D__SANDBOX__ -U_FORTIFY_SOURCE PLATFORM_CPPFLAGS += -DCONFIG_ARCH_MAP_SYSMEM -DCONFIG_SYS_GENERIC_BOARD PLATFORM_LIBS += -lrt +# Define this to avoid linking with SDL, which requires SDL libraries +# This can solve 'sdl-config: Command not found' errors +ifneq ($(NO_SDL),) +PLATFORM_CPPFLAGS += -DSANDBOX_NO_SDL +else ifdef CONFIG_SANDBOX_SDL PLATFORM_LIBS += $(shell sdl-config --libs) PLATFORM_CPPFLAGS += $(shell sdl-config --cflags) endif +endif # Support generic board on sandbox __HAVE_ARCH_GENERIC_BOARD := y @@ -18,9 +24,3 @@ cmd_u-boot__ = $(CC) -o $@ -T u-boot.lds \ $(PLATFORM_LIBS) -Wl,-Map -Wl,u-boot.map CONFIG_ARCH_DEVICE_TREE := sandbox
Applied to u-boot-x86/sandbox.
Jeroen Hofstee
