Re: [U-Boot-Users] Can't Compile u-boot-1.1.5_atmel_1.2!!
Argh, ignoring the plain-text restriction myself. Sorry about that!
On 27.02.2007 15:23, 25an wrote:
I manged to solve the problem but now I get another one. The first problem was solved by edit the cpu/arm926ejs/at91sam926x/config.mk file accordingly
#PLATFORM_CPPFLAGS += -mapcs-32 -march=armv5te -mtune=arm926ejs PLATFORM_CPPFLAGS += -march=armv5te -Wa,-mapcs-32 -mtune=arm926ej-s
I suggest not using -mtune at all, it will most likely not produce different (more efficient) code than using -march=armv5te alone when compiling U-Boot.
The gcc flag -mapcs-32 was deprecated since gcc-3.4.0 and finally removed in gcc-4.0.0 which unconditionally generates 32bit ARM code. You should not need to pass this flag to the assembler either.
Now the error that I am getting is
usb_ohci.c: In function 'usb_lowlevel_init': usb_ohci.c:1659: error: invalid lvalue in assignment make[1]: *** [usb_ohci.o] Error 1 make[1]: Leaving directory `/opt/x-compile/eldk/workingarea/u-boot-1.1.5_atmel_1.2/cpu/arm926ejs/at91sam926x' make: *** [cpu/arm926ejs/at91sam926x/libat91sam926x.a] Error 2
Again, update to a more recent version of U-Boot. Or, if that is not possible, use an older toolchain/compiler (for example gcc-3.4.6 should work with U-Boot 1.1.5).
U-Boot 1.1.5 DOES NOT WORK with gcc-4.x! Expect more (hidden) problems!
Content-Type: text/plain; charset="utf-8" Content-Transfer-Encoding: base64
Please post plain-text messages to this list.
Regards, Daniel
Daniel Hobi
