[U-Boot] [PATCH] net/sh-ether: Fix build by removing ECSIPR_BRCRXIP and other
When support sh7734 of sh-ether, ECSIPR_BRCRXIP and other were removed. Therefore SH7757 and SH7724 can not build. This revise this probelem.
Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- drivers/net/sh_eth.h | 7 +++---- 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/drivers/net/sh_eth.h b/drivers/net/sh_eth.h index a1ba68b..50f4b69 100644 --- a/drivers/net/sh_eth.h +++ b/drivers/net/sh_eth.h @@ -452,17 +452,16 @@ enum ECSR_STATUS_BIT {
/* ECSIPR */ enum ECSIPR_STATUS_MASK_BIT { -#if defined(CONFIG_CPU_SH7724) +#if defined(CONFIG_CPU_SH7724) || defined(CONFIG_CPU_SH7757) + ECSIPR_BRCRXIP = 0x20, ECSIPR_PSRTOIP = 0x10, - ECSIPR_LCHNGIP = 0x04, - ECSIPR_ICDIP = 0x01, #elif defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) ECSIPR_PSRTOIP = 0x10, ECSIPR_PHYIP = 0x08, +#endif ECSIPR_LCHNGIP = 0x04, ECSIPR_MPDIP = 0x02, ECSIPR_ICDIP = 0x01, -#endif };
#if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734)
I tested this patch. And, it is good.
Tested-by: Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com
Best regards, Yoshihiro Shimoda
Joe, could you pick-up ths patch to your network repository? This is bug fix to 201207.
Best regards, Nobuhiro
2012/6/21 Shimoda, Yoshihiro yoshihiro.shimoda.uh@renesas.com:
Hi Nobuhiro Iwamatsu,
On Mon, Jun 25, 2012 at 11:18 PM, Nobuhiro Iwamatsu iwamatsu@nigauri.org wrote:
Yes.
-Joe
On Tue, Jun 26, 2012 at 1:03 PM, Joe Hershberger joe.hershberger@gmail.com wrote:
Yes.
Applied, thanks.
-Joe
Joe Hershberger
Nobuhiro Iwamatsu
Shimoda, Yoshihiro
