[U-Boot] [PATCH 1/2] drivers: i2c: mxc: Update SYS_I2C_MXC_I2C support in Kconfig
NXP layerscape platforms like ls1088a, ls2088a uses MXC I2C Controller. -Remove dependency of MX6 for the same.
Update related configs to use Kconfig file. -Add SYS_I2C_MXC_I2C1,_I2C2,_I2C3,_I2C4 in Kconfig -Add CONFIG_SYS_MXC_I2C1_SPEED,_I2C2_,_I2C3_,_I2C4_ in Kconfig -Add CONFIG_SYS_MXC_I2C1_SLAVE,_I2C2_,_I2C3_,_I2C4_ in Kconfig
Signed-off-by: Sriram Dash sriram.dash@nxp.com Signed-off-by: Priyanka Jain priyanka.jain@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 23 ++++++++ drivers/i2c/Kconfig | 89 +++++++++++++++++++++++++++++-- include/configs/ls1012a_common.h | 3 -- include/configs/ls1043a_common.h | 5 -- include/configs/ls1046a_common.h | 5 -- include/configs/ls1088a_common.h | 5 -- include/configs/ls2080a_common.h | 5 -- include/configs/ls2080a_emu.h | 3 -- include/configs/ls2080a_simu.h | 3 -- 9 files changed, 109 insertions(+), 32 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index cefbdfe..ebccd16 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -12,6 +12,9 @@ config ARCH_LS1012A select SYS_FSL_ERRATUM_A009008 select ARCH_EARLY_INIT_R select BOARD_EARLY_INIT_F + select SYS_I2C_MXC + select SYS_I2C_MXC_I2C1 + select SYS_I2C_MXC_I2C2 imply PANIC_HANG
config ARCH_LS1043A @@ -37,6 +40,11 @@ config ARCH_LS1043A select SYS_FSL_HAS_DDR4 select ARCH_EARLY_INIT_R select BOARD_EARLY_INIT_F + select SYS_I2C_MXC + select SYS_I2C_MXC_I2C1 + select SYS_I2C_MXC_I2C2 + select SYS_I2C_MXC_I2C3 + select SYS_I2C_MXC_I2C4 imply SCSI imply SCSI_AHCI imply CMD_PCI @@ -64,6 +72,11 @@ config ARCH_LS1046A select SYS_FSL_SRDS_2 select ARCH_EARLY_INIT_R select BOARD_EARLY_INIT_F + select SYS_I2C_MXC + select SYS_I2C_MXC_I2C1 + select SYS_I2C_MXC_I2C2 + select SYS_I2C_MXC_I2C3 + select SYS_I2C_MXC_I2C4 imply SCSI imply SCSI_AHCI
@@ -94,6 +107,11 @@ config ARCH_LS1088A select FSL_TZASC_1 select ARCH_EARLY_INIT_R select BOARD_EARLY_INIT_F + select SYS_I2C_MXC + select SYS_I2C_MXC_I2C1 + select SYS_I2C_MXC_I2C2 + select SYS_I2C_MXC_I2C3 + select SYS_I2C_MXC_I2C4 imply SCSI imply PANIC_HANG
@@ -134,6 +152,11 @@ config ARCH_LS2080A select SYS_FSL_ERRATUM_A009203 select ARCH_EARLY_INIT_R select BOARD_EARLY_INIT_F + select SYS_I2C_MXC + select SYS_I2C_MXC_I2C1 + select SYS_I2C_MXC_I2C2 + select SYS_I2C_MXC_I2C3 + select SYS_I2C_MXC_I2C4 imply PANIC_HANG
config FSL_LSCH2 diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index 17d21bb..7cad493 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -149,13 +149,96 @@ config SYS_I2C_MESON both 7-bit and 10-bit addresses.
config SYS_I2C_MXC - bool "NXP i.MX I2C driver" - depends on MX6 + bool "NXP MXC I2C driver" help - Add support for the NXP i.MX I2C driver. This supports upto for bus + Add support for the NXP I2C driver. This supports upto for bus channels and operating on standard mode upto 100 kbits/s and fast mode upto 400 kbits/s.
+if SYS_I2C_MXC +config SYS_I2C_MXC_I2C1 + bool "NXP MXC I2C1" + help + Add support for NXP MXC I2C Controller 1. + Required for SoCs which have I2C MXC controller 1 eg LS1088A, LS2080A + +config SYS_I2C_MXC_I2C2 + bool "NXP MXC I2C2" + help + Add support for NXP MXC I2C Controller 2. + Required for SoCs which have I2C MXC controller 2 eg LS1088A, LS2080A + +config SYS_I2C_MXC_I2C3 + bool "NXP MXC I2C3" + help + Add support for NXP MXC I2C Controller 3. + Required for SoCs which have I2C MXC controller 3 eg LS1088A, LS2080A + +config SYS_I2C_MXC_I2C4 + bool "NXP MXC I2C4" + help + Add support for NXP MXC I2C Controller 4. + Required for SoCs which have I2C MXC controller 4 eg LS1088A, LS2080A +endif + +if SYS_I2C_MXC_I2C1 +config SYS_MXC_I2C1_SPEED + int "I2C Channel 1 speed" + default 40000000 if TARGET_LS2080A_SIMU || TARGET_LS2080A_EMU + default 100000 + help + MXC I2C Channel 1 speed + +config SYS_MXC_I2C1_SLAVE + int "I2C1 Slave" + default 0 + help + MXC I2C1 Slave +endif + +if SYS_I2C_MXC_I2C2 +config SYS_MXC_I2C2_SPEED + int "I2C Channel 2 speed" + default 40000000 if TARGET_LS2080A_SIMU || TARGET_LS2080A_EMU + default 100000 + help + MXC I2C Channel 2 speed + +config SYS_MXC_I2C2_SLAVE + int "I2C2 Slave" + default 0 + help + MXC I2C2 Slave +endif + +if SYS_I2C_MXC_I2C3 +config SYS_MXC_I2C3_SPEED + int "I2C Channel 3 speed" + default 100000 + help + MXC I2C Channel 3 speed + +config SYS_MXC_I2C3_SLAVE + int "I2C3 Slave" + default 0 + help + MXC I2C3 Slave +endif + +if SYS_I2C_MXC_I2C4 +config SYS_MXC_I2C4_SPEED + int "I2C Channel 4 speed" + default 100000 + help + MXC I2C Channel 4 speed + +config SYS_MXC_I2C4_SLAVE + int "I2C4 Slave" + default 0 + help + MXC I2C4 Slave +endif + config SYS_I2C_OMAP24XX bool "TI OMAP2+ I2C driver" depends on ARCH_OMAP2PLUS diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index 7dbe231..61aeaf9 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -81,9 +81,6 @@
/* I2C */ #define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_MXC -#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ -#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */
#define CONFIG_CONS_INDEX 1 #define CONFIG_SYS_NS16550_SERIAL diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 67b5ea7..baf1305 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -152,11 +152,6 @@
/* I2C */ #define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_MXC -#define CONFIG_SYS_I2C_MXC_I2C1 -#define CONFIG_SYS_I2C_MXC_I2C2 -#define CONFIG_SYS_I2C_MXC_I2C3 -#define CONFIG_SYS_I2C_MXC_I2C4
/* PCIe */ #ifndef SPL_NO_PCIE diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index bef4dd4..5667ce7 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -130,11 +130,6 @@
/* PCIe */ #define CONFIG_PCIE1 /* PCIE controller 1 */ diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h index 61c30c9..d7b81f3 100644 --- a/include/configs/ls1088a_common.h +++ b/include/configs/ls1088a_common.h @@ -78,11 +78,6 @@
/* I2C */ #define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_MXC -#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ -#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ -#define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ -#define CONFIG_SYS_I2C_MXC_I2C4 /* enable I2C bus 4 */
/* Serial Port */ #define CONFIG_CONS_INDEX 1 diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index b995513..6ad5e36 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -85,11 +85,6 @@
/* Serial Port */ #define CONFIG_CONS_INDEX 1 diff --git a/include/configs/ls2080a_emu.h b/include/configs/ls2080a_emu.h index 6b34edf..c2fdc4d 100644 --- a/include/configs/ls2080a_emu.h +++ b/include/configs/ls2080a_emu.h @@ -12,9 +12,6 @@ #define CONFIG_SYS_CLK_FREQ 100000000 #define CONFIG_DDR_CLK_FREQ 133333333
-#define CONFIG_SYS_MXC_I2C1_SPEED 40000000 -#define CONFIG_SYS_MXC_I2C2_SPEED 40000000 - #define CONFIG_DDR_SPD #define CONFIG_SYS_FSL_DDR_EMU /* Support emulator */ #define SPD_EEPROM_ADDRESS1 0x51 diff --git a/include/configs/ls2080a_simu.h b/include/configs/ls2080a_simu.h index dad1090..103ebec 100644 --- a/include/configs/ls2080a_simu.h +++ b/include/configs/ls2080a_simu.h @@ -12,9 +12,6 @@ #define CONFIG_SYS_CLK_FREQ 100000000 #define CONFIG_DDR_CLK_FREQ 133333333
-#define CONFIG_SYS_MXC_I2C1_SPEED 40000000 -#define CONFIG_SYS_MXC_I2C2_SPEED 40000000 - #define CONFIG_DIMM_SLOTS_PER_CTLR 1 #define CONFIG_CHIP_SELECTS_PER_CTRL 4 #ifdef CONFIG_SYS_FSL_HAS_DP_DDR
Existing driver supports upto 4 I2C controllers. But some of future NXPs SoCs like lx2160a has eight I2C controllers.
Update MXC driver to support upto 8 I2C controllers
Signed-off-by: Sriram Dash sriram.dash@nxp.com Signed-off-by: Priyanka Jain priyanka.jain@nxp.com --- drivers/i2c/Kconfig | 80 +++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/i2c/mxc_i2c.c | 56 ++++++++++++++++++++++++++++++++++++ 2 files changed, 136 insertions(+)
diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index 7cad493..c863a6e 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -179,6 +179,30 @@ config SYS_I2C_MXC_I2C4 help Add support for NXP MXC I2C Controller 4. Required for SoCs which have I2C MXC controller 4 eg LS1088A, LS2080A + +config SYS_I2C_MXC_I2C5 + bool "NXP MXC I2C5" + help + Add support for NXP MXC I2C Controller 5. + Required for SoCs which have I2C MXC controller 5 eg LX2160A + +config SYS_I2C_MXC_I2C6 + bool "NXP MXC I2C6" + help + Add support for NXP MXC I2C Controller 6. + Required for SoCs which have I2C MXC controller 6 eg LX2160A + +config SYS_I2C_MXC_I2C7 + bool "NXP MXC I2C7" + help + Add support for NXP MXC I2C Controller 7. + Required for SoCs which have I2C MXC controller 7 eg LX2160A + +config SYS_I2C_MXC_I2C8 + bool "NXP MXC I2C8" + help + Add support for NXP MXC I2C Controller 8. + Required for SoCs which have I2C MXC controller 8 eg LX2160A endif
if SYS_I2C_MXC_I2C1 @@ -239,6 +263,62 @@ config SYS_MXC_I2C4_SLAVE MXC I2C4 Slave endif
+if SYS_I2C_MXC_I2C5 +config SYS_MXC_I2C5_SPEED + int "I2C Channel 5 speed" + default 100000 + help + MXC I2C Channel 5 speed + +config SYS_MXC_I2C5_SLAVE + int "I2C5 Slave" + default 0 + help + MXC I2C5 Slave +endif + +if SYS_I2C_MXC_I2C6 +config SYS_MXC_I2C6_SPEED + int "I2C Channel 6 speed" + default 100000 + help + MXC I2C Channel 6 speed + +config SYS_MXC_I2C6_SLAVE + int "I2C6 Slave" + default 0 + help + MXC I2C6 Slave +endif + +if SYS_I2C_MXC_I2C7 +config SYS_MXC_I2C7_SPEED + int "I2C Channel 7 speed" + default 100000 + help + MXC I2C Channel 7 speed + +config SYS_MXC_I2C7_SLAVE + int "I2C7 Slave" + default 0 + help + MXC I2C7 Slave +endif + +if SYS_I2C_MXC_I2C8 +config SYS_MXC_I2C8_SPEED + int "I2C Channel 8 speed" + default 100000 + help + MXC I2C Channel 8 speed + +config SYS_MXC_I2C8_SLAVE + int "I2C8 Slave" + default 0 + help + MXC I2C8 Slave +endif + config SYS_I2C_OMAP24XX bool "TI OMAP2+ I2C driver" depends on ARCH_OMAP2PLUS diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index 79228c2..a17c1ec 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -589,6 +589,22 @@ static int bus_i2c_write(struct mxc_i2c_bus *i2c_bus, u8 chip, u32 addr, #define I2C4_BASE_ADDR 0 #endif
+#if !defined(I2C5_BASE_ADDR) +#define I2C5_BASE_ADDR 0 +#endif + +#if !defined(I2C6_BASE_ADDR) +#define I2C6_BASE_ADDR 0 +#endif + +#if !defined(I2C7_BASE_ADDR) +#define I2C7_BASE_ADDR 0 +#endif + +#if !defined(I2C8_BASE_ADDR) +#define I2C8_BASE_ADDR 0 +#endif + static struct mxc_i2c_bus mxc_i2c_buses[] = { #if defined(CONFIG_ARCH_LS1021A) || defined(CONFIG_VF610) || \ defined(CONFIG_FSL_LAYERSCAPE) @@ -596,11 +612,19 @@ static struct mxc_i2c_bus mxc_i2c_buses[] = { { 1, I2C2_BASE_ADDR, I2C_QUIRK_FLAG }, { 2, I2C3_BASE_ADDR, I2C_QUIRK_FLAG }, { 3, I2C4_BASE_ADDR, I2C_QUIRK_FLAG }, + { 4, I2C5_BASE_ADDR, I2C_QUIRK_FLAG }, + { 5, I2C6_BASE_ADDR, I2C_QUIRK_FLAG }, + { 6, I2C7_BASE_ADDR, I2C_QUIRK_FLAG }, + { 7, I2C8_BASE_ADDR, I2C_QUIRK_FLAG }, #else { 0, I2C1_BASE_ADDR, 0 }, { 1, I2C2_BASE_ADDR, 0 }, { 2, I2C3_BASE_ADDR, 0 }, { 3, I2C4_BASE_ADDR, 0 }, + { 4, I2C5_BASE_ADDR, 0 }, + { 5, I2C6_BASE_ADDR, 0 }, + { 6, I2C7_BASE_ADDR, 0 }, + { 7, I2C8_BASE_ADDR, 0 }, #endif };
@@ -738,6 +762,38 @@ U_BOOT_I2C_ADAP_COMPLETE(mxc3, mxc_i2c_init, mxc_i2c_probe, CONFIG_SYS_MXC_I2C4_SLAVE, 3) #endif
+#ifdef CONFIG_SYS_I2C_MXC_I2C5 +U_BOOT_I2C_ADAP_COMPLETE(mxc4, mxc_i2c_init, mxc_i2c_probe, + mxc_i2c_read, mxc_i2c_write, + mxc_i2c_set_bus_speed, + CONFIG_SYS_MXC_I2C5_SPEED, + CONFIG_SYS_MXC_I2C5_SLAVE, 4) +#endif + +#ifdef CONFIG_SYS_I2C_MXC_I2C6 +U_BOOT_I2C_ADAP_COMPLETE(mxc5, mxc_i2c_init, mxc_i2c_probe, + mxc_i2c_read, mxc_i2c_write, + mxc_i2c_set_bus_speed, + CONFIG_SYS_MXC_I2C6_SPEED, + CONFIG_SYS_MXC_I2C6_SLAVE, 5) +#endif + +#ifdef CONFIG_SYS_I2C_MXC_I2C7 +U_BOOT_I2C_ADAP_COMPLETE(mxc6, mxc_i2c_init, mxc_i2c_probe, + mxc_i2c_read, mxc_i2c_write, + mxc_i2c_set_bus_speed, + CONFIG_SYS_MXC_I2C7_SPEED, + CONFIG_SYS_MXC_I2C7_SLAVE, 6) +#endif + +#ifdef CONFIG_SYS_I2C_MXC_I2C8 +U_BOOT_I2C_ADAP_COMPLETE(mxc7, mxc_i2c_init, mxc_i2c_probe, + mxc_i2c_read, mxc_i2c_write, + mxc_i2c_set_bus_speed, + CONFIG_SYS_MXC_I2C8_SPEED, + CONFIG_SYS_MXC_I2C8_SLAVE, 7) +#endif + #else
static int mxc_i2c_set_bus_speed(struct udevice *bus, unsigned int speed)
From: Sriram Dash Subject: [PATCH 1/2] drivers: i2c: mxc: Update SYS_I2C_MXC_I2C support in Kconfig
Hello Stefano,
Any updates.
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl- layerscape/Kconfig index cefbdfe..ebccd16 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -12,6 +12,9 @@ config ARCH_LS1012A select SYS_FSL_ERRATUM_A009008 select ARCH_EARLY_INIT_R select BOARD_EARLY_INIT_F
- select SYS_I2C_MXC
- select SYS_I2C_MXC_I2C1
- select SYS_I2C_MXC_I2C2 imply PANIC_HANG
- select SYS_I2C_MXC_I2C3
- select SYS_I2C_MXC_I2C4 imply SCSI imply SCSI_AHCI imply CMD_PCI
- select SYS_I2C_MXC_I2C4 imply SCSI imply PANIC_HANG
- select SYS_I2C_MXC_I2C4 imply PANIC_HANG
config SYS_I2C_MXC
- depends on MX6
- bool "NXP MXC I2C driver" help
channels and operating on standard mode upto 100 kbits/s and fast mode upto 400 kbits/s.Add support for the NXP I2C driver. This supports upto for bus
- bool "NXP MXC I2C1"
- help
- bool "NXP MXC I2C2"
- help
- bool "NXP MXC I2C3"
- help
- bool "NXP MXC I2C4"
- help
+endif
- int "I2C Channel 1 speed"
- default 40000000 if TARGET_LS2080A_SIMU || TARGET_LS2080A_EMU
- default 100000
- help
- int "I2C1 Slave"
- default 0
- help
MXC I2C1 Slave
+endif
- int "I2C Channel 2 speed"
- default 100000
- help
- int "I2C2 Slave"
- default 0
- help
MXC I2C2 Slave
+endif
- int "I2C Channel 3 speed"
- default 100000
- help
- int "I2C3 Slave"
- default 0
- help
MXC I2C3 Slave
+endif
- int "I2C Channel 4 speed"
- default 100000
- help
- int "I2C4 Slave"
- default 0
- help
MXC I2C4 Slave
+endif
1.9.1
Hello Stefano,
Any updates.
Sorry for late answer - I have no comments about these patches, I have not seen any comments at all, I will aply them.
Regards, Stefano
config SYS_I2C_MXC
- depends on MX6
- help
- help
- help
- help
+endif
- default 100000
- help
- int "I2C1 Slave"
- default 0
- help
MXC I2C1 Slave
+endif
- default 100000
- help
- int "I2C2 Slave"
- default 0
- help
MXC I2C2 Slave
+endif
- default 100000
- help
- int "I2C3 Slave"
- default 0
- help
MXC I2C3 Slave
+endif
- default 100000
- help
- int "I2C4 Slave"
- default 0
- help
MXC I2C4 Slave
+endif
1.9.1
Sriram Dash
Stefano Babic
