[U-Boot] [PATCH] arm: bugfix: save_boot_params_default accesses uninitalized stack when -O0
save_boot_params_default() in cpu.c accesses uninitialized stack area when it compiled with -O0 (not optimized).
Signed-off-by: Tetsuyuki Kobayashi koba@kmckk.co.jp --- arch/arm/cpu/armv7/cpu.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/cpu/armv7/cpu.c b/arch/arm/cpu/armv7/cpu.c index c6fa8ef..6104cb2 100644 --- a/arch/arm/cpu/armv7/cpu.c +++ b/arch/arm/cpu/armv7/cpu.c @@ -37,8 +37,11 @@ #include <asm/cache.h> #include <asm/armv7.h>
+__attribute__((naked)) /* don't save anything to stack even if compiled with -O0 */ void save_boot_params_default(u32 r0, u32 r1, u32 r2, u32 r3) { + /* stack is not yet initialized */ + asm("bx lr"); }
void save_boot_params(u32 r0, u32 r1, u32 r2, u32 r3)
- /* stack is not yet initialized */
- asm("bx lr");
Please add <linux/compiler.h> and use __naked instead. Thanks!
Hi Tom, thank you for reviewing.
Signed-off-by: Tetsuyuki Kobayashikoba@kmckk.co.jp
diff --git a/arch/arm/cpu/armv7/cpu.c b/arch/arm/cpu/armv7/cpu.c index c6fa8ef..6104cb2 100644 --- a/arch/arm/cpu/armv7/cpu.c +++ b/arch/arm/cpu/armv7/cpu.c @@ -37,8 +37,11 @@ #include<asm/cache.h> #include<asm/armv7.h>
- asm("bx lr"); }
Please add<linux/compiler.h> and use __naked instead. Thanks!
OK. I will post V2 patch.
Signed-off-by: Tetsuyuki Kobayashi koba@kmckk.co.jp --- Changes for v2: - include <linux/compiler.h> and use __naked instead of __attribute__((naked))
arch/arm/cpu/armv7/cpu.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/cpu/armv7/cpu.c b/arch/arm/cpu/armv7/cpu.c index c6fa8ef..3e2a75c 100644 --- a/arch/arm/cpu/armv7/cpu.c +++ b/arch/arm/cpu/armv7/cpu.c @@ -36,9 +36,13 @@ #include <asm/system.h> #include <asm/cache.h> #include <asm/armv7.h> +#include <linux/compiler.h>
+__naked /* don't save anything to stack even if compiled with -O0 */ void save_boot_params_default(u32 r0, u32 r1, u32 r2, u32 r3) { + /* stack is not yet initialized */ + asm("bx lr"); }
void save_boot_params(u32 r0, u32 r1, u32 r2, u32 r3) -- 1.7.9.5
Changes for v2:
The usual form (here and kernel) is: void __naked save_boot_params_default(...)
Same for __weak and so on. Thanks!
Changes for v2:
Oh, I should grep __naked before posting this. I will try V3.
Changes for v3: - move __naked after void - reformat comments
arch/arm/cpu/armv7/cpu.c | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/cpu.c b/arch/arm/cpu/armv7/cpu.c index c6fa8ef..9eb484a 100644 --- a/arch/arm/cpu/armv7/cpu.c +++ b/arch/arm/cpu/armv7/cpu.c @@ -36,9 +36,15 @@ #include <asm/system.h> #include <asm/cache.h> #include <asm/armv7.h> +#include <linux/compiler.h>
-void save_boot_params_default(u32 r0, u32 r1, u32 r2, u32 r3) +void __naked save_boot_params_default(u32 r0, u32 r1, u32 r2, u32 r3) { + /* + * Stack pointer is not yet initialized + * Don't save anything to stack even if compiled with -O0 + */ + asm("bx lr"); }
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
Acked-by: Tom Rini trini@ti.com
- -- Tom
Hi Tetsuyuki, Tom,
I'll take it in as soon as marvell and atmel are pulled in.
Amicalement,
Hi Tetsuyuki,
On Fri, 29 Jun 2012 18:36:21 +0900, Tetsuyuki Kobayashi koba@kmckk.co.jp wrote:
Changes for v2:
Changes for v3:
- reformat comments
Applied to u-boot-arm/master, thanks.
Amicalement,
On Thu, Jul 05, 2012 at 01:57:26PM +0200, Albert ARIBAUD wrote:
Hi Tetsuyuki,
Changes for v2:
Changes for v3:
- reformat comments
Oh no... cpu.c: In function 'save_boot_params_default': cpu.c:48:1: warning: -fstack-usage not supported for this target [enabled by default]
Last time we made a const uint32 out of the instruction instead (see 494931a). I don't think that's appropriate here however. Maybe we can declare the function weak in assembly instead, then we won't need the naked part and won't have this warning.
Hi Tom,
Hi Tetsuyuki,
Changes for v2:
Changes for v3:
- reformat comments
Meanwhile I'll remove this patch from my tree.
Amicalement,
Signed-off-by: Tetsuyuki Kobayashi koba@kmckk.co.jp --- Hi Tom, Albert,
I rewrite them in asm language and put it to start.S. No warning now. I tested it quickly on my kzm9g board.
Changes for v4: - v3 causes following warnings cpu.c: In function 'save_boot_params_default': cpu.c:48:1: warning: -fstack-usage not supported for this target [enabled by default] - move save_boot_params_default() and save_boot_params() from cpu.c to start.S and write them in asm language
arch/arm/cpu/armv7/cpu.c | 7 ------- arch/arm/cpu/armv7/start.S | 15 +++++++++++++++ 2 files changed, 15 insertions(+), 7 deletions(-)
diff --git a/arch/arm/cpu/armv7/cpu.c b/arch/arm/cpu/armv7/cpu.c index c6fa8ef..b0677f4 100644 --- a/arch/arm/cpu/armv7/cpu.c +++ b/arch/arm/cpu/armv7/cpu.c @@ -37,13 +37,6 @@ #include <asm/cache.h> #include <asm/armv7.h>
-void save_boot_params_default(u32 r0, u32 r1, u32 r2, u32 r3) -{ -} - -void save_boot_params(u32 r0, u32 r1, u32 r2, u32 r3) - __attribute__((weak, alias("save_boot_params_default"))); - int cleanup_before_linux(void) { /* diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 261835b..4feade5 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -350,6 +350,21 @@ ENTRY(cpu_init_crit) ENDPROC(cpu_init_crit) #endif
+/************************************************************************* + * + * void save_boot_params_default(u32 r0, u32 r1, u32 r2, u32 r3) + * + * Stack pointer is not yet initialized + * Don't save anything to stack even if compiled with -O0 + * + *************************************************************************/ +ENTRY(save_boot_params_default) + bx lr @ back to my caller +ENDPROC(save_boot_params_default) + + .weak save_boot_params + .set save_boot_params, save_boot_params_default + #ifndef CONFIG_SPL_BUILD /* ************************************************************************* -- 1.7.9.5
- void save_boot_params_default(u32 r0, u32 r1, u32 r2, u32 r3)
- Stack pointer is not yet initialized + * Don't save
- bx lr @ back to my caller +ENDPROC(save_boot_params_default) +
- .weak save_boot_params + .set save_boot_params,
We
shouldn't, I believe, need to call this save_boot_params_default and then alias it. We should be able to just call it save_boot_params and declare it weak, then omap3 for example will override a link time (this should be easily verifiable with objdump). Thanks!
- -- Tom
save_boot_params_default() in cpu.c accesses uninitialized stack area when it compiled with -O0 (not optimized). This patch removes save_boot_params_default() and put the equivalent in start.S
I rewrite it again. I tested it quickly on my kzm9g board, and also build it for omap4_panda and checked the generated code by objdump command.
Changes for v5 - rename save_boot_parames_default() to save_boot_params() and drop aliasing - move the code after relocate_code (nearer to callee) - modify commit log
arch/arm/cpu/armv7/cpu.c | 7 ------- arch/arm/cpu/armv7/start.S | 14 ++++++++++++++ 2 files changed, 14 insertions(+), 7 deletions(-)
-void save_boot_params_default(u32 r0, u32 r1, u32 r2, u32 r3) -{ -} - -void save_boot_params(u32 r0, u32 r1, u32 r2, u32 r3) - __attribute__((weak, alias("save_boot_params_default"))); - int cleanup_before_linux(void) { /* diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 261835b..bf734fb 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -293,6 +293,20 @@ ENDPROC(relocate_code)
/************************************************************************* * + * void save_boot_params(u32 r0, u32 r1, u32 r2, u32 r3) + * __attribute__((weak)); + * + * Stack pointer is not yet initialized at this moment + * Don't save anything to stack even if compiled with -O0 + * + *************************************************************************/ +ENTRY(save_boot_params) + bx lr @ back to my caller +ENDPROC(save_boot_params) + .weak save_boot_params + +/************************************************************************* + * * cpu_init_cp15 * * Setup CP15 registers (cache, MMU, TLBs). The I-cache is turned on unless
- -- Tom
Albert ARIBAUD
koba
Tetsuyuki Kobayashi
