[U-Boot] [PATCH V2] sf: Add support for flag status register on Micron chips
Enter 3 Byte address mode at first, because it may change to 4 Byte address mode in kernel driver and not reset to 3 Byte address mode after reboot.
Add clear flag status register operation that some Micron SPI flash chips required after reading the flag status register to check some operations completion.
Signed-off-by: Hou Zhiqiang B48286@freescale.com Signed-off-by: Mingkai.Hu Mingkai.Hu@freescale.com --- V1: Based on git://git.denx.de/u-boot.git. Also can be applied to git://www.denx.de/git/u-boot-mpc85xx.git. Tested on board T2080QDS and T2080RDB.
V2: Add the operation of enter 3 Byte address mode in probe.
drivers/mtd/spi/sf_internal.h | 17 ++++++++++++ drivers/mtd/spi/sf_ops.c | 64 +++++++++++++++++++++++++++++++++++++------ drivers/mtd/spi/sf_probe.c | 5 ++++ 3 files changed, 78 insertions(+), 8 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 19d4914..49e5a2c 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -36,6 +36,11 @@ #define CMD_WRITE_ENABLE 0x06 #define CMD_READ_CONFIG 0x35 #define CMD_FLAG_STATUS 0x70 +#define CMD_CLEAR_FLAG_STATUS 0x50 + +/* Used for Macronix and Winbond flashes */ +#define CMD_ENTER_4B_ADDR 0xB7 +#define CMD_EXIT_4B_ADDR 0xE9
/* Read commands */ #define CMD_READ_ARRAY_SLOW 0x03 @@ -59,6 +64,8 @@ #define STATUS_QEB_WINSPAN (1 << 1) #define STATUS_QEB_MXIC (1 << 6) #define STATUS_PEC (1 << 7) +#define STATUS_PROT (1 << 1) +#define STATUS_ERASE (1 << 5)
#ifdef CONFIG_SYS_SPI_ST_ENABLE_WP_PIN #define STATUS_SRWD (1 << 7) /* SR write protect */ @@ -124,6 +131,12 @@ static inline int spi_flash_cmd_write_disable(struct spi_flash *flash) return spi_flash_cmd(flash->spi, CMD_WRITE_DISABLE, NULL, 0); }
+/* Clear flag status register */ +static inline int spi_flash_cmd_clear_flag_status(struct spi_flash *flash) +{ + return spi_flash_cmd(flash->spi, CMD_CLEAR_FLAG_STATUS, NULL, 0); +} + /* * Send the read status command to the device and wait for the wip * (write-in-progress) bit to clear itself. @@ -160,4 +173,8 @@ int spi_flash_read_common(struct spi_flash *flash, const u8 *cmd, int spi_flash_cmd_read_ops(struct spi_flash *flash, u32 offset, size_t len, void *data);
+#if defined(CONFIG_SPI_FLASH_STMICRO) +int spi_flash_cmd_4B_addr_switch(struct spi_flash *flash, int enable); +#endif + #endif /* _SF_INTERNAL_H_ */ diff --git a/drivers/mtd/spi/sf_ops.c b/drivers/mtd/spi/sf_ops.c index 85cf22d..8a532b8 100644 --- a/drivers/mtd/spi/sf_ops.c +++ b/drivers/mtd/spi/sf_ops.c @@ -93,6 +93,30 @@ int spi_flash_cmd_write_config(struct spi_flash *flash, u8 wc) } #endif
+#if defined(CONFIG_SPI_FLASH_STMICRO) +int spi_flash_cmd_4B_addr_switch(struct spi_flash *flash, int enable) +{ + int ret; + u8 cmd; + + cmd = enable ? CMD_ENTER_4B_ADDR : CMD_EXIT_4B_ADDR; + + ret = spi_claim_bus(flash->spi); + if (ret) { + debug("SF: unable to claim SPI bus\n"); + return ret; + } + + ret = spi_flash_cmd_write_enable(flash); + if (ret < 0) { + debug("SF: enabling write failed\n"); + return ret; + } + + return spi_flash_cmd(flash->spi, cmd, NULL, 0); +} +#endif + #ifdef CONFIG_SPI_FLASH_BAR static int spi_flash_cmd_bankaddr_write(struct spi_flash *flash, u8 bank_sel) { @@ -160,6 +184,7 @@ int spi_flash_cmd_wait_ready(struct spi_flash *flash, unsigned long timeout) unsigned long timebase; unsigned long flags = SPI_XFER_BEGIN; int ret; + int out_of_time = 1; u8 status; u8 check_status = 0x0; u8 poll_bit = STATUS_WIP; @@ -186,22 +211,45 @@ int spi_flash_cmd_wait_ready(struct spi_flash *flash, unsigned long timeout) WATCHDOG_RESET();
ret = spi_xfer(spi, 8, NULL, &status, 0); - if (ret) + if (ret) { + spi_xfer(spi, 0, NULL, NULL, SPI_XFER_END); return -1; + }
- if ((status & poll_bit) == check_status) + if ((status & poll_bit) == check_status) { + out_of_time = 0; break; + }
} while (get_timer(timebase) < timeout);
- if ((status & poll_bit) == check_status) - return 0; + if (out_of_time) { + /* Timed out */ + debug("SF: time out!\n"); + if (cmd == CMD_FLAG_STATUS) { + if (spi_flash_cmd_clear_flag_status(flash) < 0) + debug("SF: clear flag status failed\n"); + } + ret = -1; + } +#ifdef CONFIG_SPI_FLASH_STMICRO + else if (cmd == CMD_FLAG_STATUS) { + if (!(status & (STATUS_PROT | STATUS_ERASE))) { + ret = 0; + } else { + debug("SF: flag status error"); + ret = -1; + }
- /* Timed out */ - debug("SF: time out!\n"); - return -1; + if (spi_flash_cmd_clear_flag_status(flash) < 0) { + debug("SF: clear flag status failed\n"); + ret = -1; + } + } +#endif + return ret; }
int spi_flash_write_common(struct spi_flash *flash, const u8 *cmd, @@ -234,7 +282,7 @@ int spi_flash_write_common(struct spi_flash *flash, const u8 *cmd,
ret = spi_flash_cmd_wait_ready(flash, timeout); if (ret < 0) { - debug("SF: write %s timed out\n", + debug("SF: write %s failed\n", timeout == SPI_FLASH_PROG_TIMEOUT ? "program" : "page erase"); return ret; diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index 4d148d1..79b876d 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -221,6 +221,11 @@ static struct spi_flash *spi_flash_validate_params(struct spi_slave *spi, #ifdef CONFIG_SPI_FLASH_STMICRO if (params->flags & E_FSR) flash->poll_cmd = CMD_FLAG_STATUS; + + if (flash->size > SPI_FLASH_16MB_BOUN) { + if (spi_flash_cmd_4B_addr_switch(flash, 0) < 0) + debug("SF: enter 3B address mode failed\n"); + } #endif
/* Configure the BAR - discover bank cmds and read current bank */
Hi Jagan,
So much long time no feedback, could you please apply this patch?
Thanks, Zhiqiang
-----Original Message----- From: Hou Zhiqiang [mailto:B48286@freescale.com] Sent: Saturday, October 11, 2014 2:40 PM To: u-boot@lists.denx.de Cc: Sun York-R58495; Hu Mingkai-B21284; Hou Zhiqiang-B48286; Hu Mingkai-B21284 Subject: [PATCH V2] sf: Add support for flag status register on Micron chips
+/* Clear flag status register */ +static inline int spi_flash_cmd_clear_flag_status(struct spi_flash +*flash) { + return spi_flash_cmd(flash->spi, CMD_CLEAR_FLAG_STATUS, NULL, 0); } + /* * Send the read status command to the device and wait for the wip * (write-in-progress) bit to clear itself. @@ -160,4 +173,8 @@ int spi_flash_read_common(struct spi_flash *flash, const u8 *cmd, int spi_flash_cmd_read_ops(struct spi_flash *flash, u32 offset, size_t len, void *data);
+#if defined(CONFIG_SPI_FLASH_STMICRO) +int spi_flash_cmd_4B_addr_switch(struct spi_flash *flash, int enable) { + int ret; + u8 cmd; + + cmd = enable ? CMD_ENTER_4B_ADDR : CMD_EXIT_4B_ADDR; + + ret = spi_claim_bus(flash->spi); + if (ret) { + debug("SF: unable to claim SPI bus\n"); + return ret; + } + + ret = spi_flash_cmd_write_enable(flash); + if (ret < 0) { + debug("SF: enabling write failed\n"); + return ret; + } + + return spi_flash_cmd(flash->spi, cmd, NULL, 0); } #endif + #ifdef CONFIG_SPI_FLASH_BAR static int spi_flash_cmd_bankaddr_write(struct spi_flash *flash, u8 bank_sel) { @@ -160,6 +184,7 @@ int spi_flash_cmd_wait_ready(struct spi_flash *flash, unsigned long timeout) unsigned long timebase; unsigned long flags = SPI_XFER_BEGIN; int ret; + int out_of_time = 1; u8 status; u8 check_status = 0x0; u8 poll_bit = STATUS_WIP; @@ -186,22 +211,45 @@ int spi_flash_cmd_wait_ready(struct spi_flash *flash, unsigned long timeout) WATCHDOG_RESET();
/* Configure the BAR - discover bank cmds and read current bank */ -- 2.1.0.27.g96db324
On 8 May 2015 at 15:25, B48286@freescale.com B48286@freescale.com wrote:
Hi Jagan,
Please test master, some patches been posted regarding FSR.
Thanks, Zhiqiang
- Send the read status command to the device and wait for the wip
- (write-in-progress) bit to clear itself.
int ret;
u8 cmd;
if (ret) {
return ret;
if (ret < 0) {
return ret;
if (ret)
if (ret) {
} } while (get_timer(timebase) < timeout); spi_xfer(spi, 0, NULL, NULL, SPI_XFER_END);
if (out_of_time) {
/* Timed out */
ret = -1;
ret = 0;
} else {
ret = -1;
/* Timed out */
return -1;
ret = -1;
return ret;
#endif
thanks!
B48286ļ¼ freescale.com
Hou Zhiqiang
Jagan Teki
