[U-Boot-Users] Problems with tftp-transfers on u-boot (with Linux ok)
Dear u-boot community,
First of all, thank you very much for this great bootloader!
From time to time we have some problems on the ethernet-communication at
the bootloader level. When we are trying to download an image via tftp, the communication isn't running fluently, there are some interruptions as we can see with ethereal, or even the communication isn't running at all. These problems do not occure on every hardware and may be caused by some chip/hardware tolerances. On the other side, after starting the Linux-Kernel and running tftp in userspace there is no problem anymore.
We haven't found any related changes on the source since the u-boot 1.0.2. Had anbody similar effects on the ethernet-communication or any idea how we could solve the problem?
Kind regards Patrick Roesli
software components: - u-boot 1.0.2 (denx-tree) U-Boot-1_0_2 - kernel 2.4 (denx-tree linuxppc_2_4_devel) LABEL_2005_06_20_1300
hardware components(NSCU Board): - Freescale MPC855TVR66D4(66Mhz) on a TQ systems TQM855-AC(32MB SDRAM/16MB flash) - Ethernet Controller LXT971A http://developer.intel.com/design/network/products/LAN/applnots/24940101 .pdf (single port)
Hi, Patrick!
Roesli, Patrick schrieb:
From time to time we have some problems on the ethernet-communication at the bootloader level. When we are trying to download an image via tftp, the communication isn't running fluently, there are some interruptions as we can see with ethereal, or even the communication isn't running at all. These problems do not occure on every hardware and may be caused by some chip/hardware tolerances.
Did you evaluate the dependencies of the tolerances already? (varying temperatures, voltages, speed, cable length, ...)
Mhm... an U-Boot update seems to be appropriate in that case.
That's all old stuff, nobody wants to talk about. Can you try the latest U-Boot git tree, please?
SDRAM/16MB flash)
I have the LXT971A working fine on one of my MPC8540 boards. (Running some u-boot-1.2.0-git) Please verify the hardware setup of the PHY if applicable. (configuration, autonegotiation, ...)
Regards,
Clemens Koller
Roesli, Patrick
