[U-Boot-Users] [PATCH] pp44xx: Remove implementation of testdram() from Korat board support
Signed-off-by: Larry Johnson lrj@acm.org --- This patch requires the previously-submitted patch for these files.
board/korat/korat.c | 38 -------------------------------------- include/configs/korat.h | 1 - 2 files changed, 0 insertions(+), 39 deletions(-)
diff --git a/board/korat/korat.c b/board/korat/korat.c index dc97724..51874ea 100644 --- a/board/korat/korat.c +++ b/board/korat/korat.c @@ -569,44 +569,6 @@ int checkboard(void) return 0; }
-#if defined(CFG_DRAM_TEST) -int testdram(void) -{ - unsigned long *mem = (unsigned long *)0; - const unsigned long kend = (1024 / sizeof(unsigned long)); - unsigned long k, n; - - mtmsr(0); - - /* TODO: find correct size of SDRAM */ - for (k = 0; k < CFG_MBYTES_SDRAM; - ++k, mem += (1024 / sizeof(unsigned long))) { - if ((k & 1023) == 0) - printf("%3d MB\r", k / 1024); - - memset(mem, 0xaaaaaaaa, 1024); - for (n = 0; n < kend; ++n) { - if (mem[n] != 0xaaaaaaaa) { - printf("SDRAM test fails at: %08x\n", - (uint) & mem[n]); - return 1; - } - } - - memset(mem, 0x55555555, 1024); - for (n = 0; n < kend; ++n) { - if (mem[n] != 0x55555555) { - printf("SDRAM test fails at: %08x\n", - (uint) & mem[n]); - return 1; - } - } - } - printf("SDRAM test passes\n"); - return 0; -} -#endif /* defined(CFG_DRAM_TEST) */ - #if defined(CONFIG_PCI) && defined(CONFIG_PCI_PNP) /* * Assign interrupts to PCI devices. diff --git a/include/configs/korat.h b/include/configs/korat.h index e2610be..4ca4ed0 100644 --- a/include/configs/korat.h +++ b/include/configs/korat.h @@ -145,7 +145,6 @@ #define CONFIG_DDR_ECC /* Use ECC when available */ #define SPD_EEPROM_ADDRESS {0x50} #define CONFIG_PROG_SDRAM_TLB -#define CFG_DRAM_TEST #define CFG_MEM_TOP_HIDE (4 << 10) /* don't use last 4kbytes */ /* 440EPx errata CHIP 11 */
Applied to u-boot-ppc4xx. Thanks.
Best regards, Stefan
Larry Johnson
Stefan Roese
