[U-Boot] [PATCH] mmc: return meaningful error codes from mmc_select_hwpart
Rather than just returning -1 everywhere, try to return something meaningful from mmc_select_hwpart(). Note that most other MMC functions don't do this, including functions called from mmc_select_hwpart(), so I'm not sure how effective this will be. Still, it's one less place with hard-coded -1.
Suggested-by: Pantelis Antoniou panto@antoniou-consulting.com Signed-off-by: Stephen Warren swarren@nvidia.com --- drivers/mmc/mmc.c | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 8b53ead98f80..221a293797e9 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -10,6 +10,7 @@ #include <config.h> #include <common.h> #include <command.h> +#include <errno.h> #include <mmc.h> #include <part.h> #include <malloc.h> @@ -558,19 +559,19 @@ int mmc_select_hwpart(int dev_num, int hwpart) int ret;
if (!mmc) - return -1; + return -ENODEV;
if (mmc->part_num == hwpart) return 0;
if (mmc->part_config == MMCPART_NOAVAILABLE) { printf("Card doesn't support part_switch\n"); - return -1; + return -EMEDIUMTYPE; }
ret = mmc_switch_part(dev_num, hwpart); if (ret) - return -1; + return ret;
mmc->part_num = hwpart;
Pantelis, does this look good?
Hi Stephen,
if (!mmc)
return -1;
return -ENODEV;
return -1;
return -1;
return ret;
-- 1.8.1.5
This does indeed look good.
Thanks
-- Pantelis
Acked-by: Pantelis Antoniou panto@antoniou-consulting.com
Are you intending to apply this patch, or were you expecting someone else to?
I will apply the patch, but it will go out with the rest on the next mmc pull request this week.
Regards
-- Pantelis
Pantelis Antoniou
Stephen Warren
