[U-Boot] Please pull u-boot-marvell/master
Hi Tom,
please pull the Kirkwood DT patches from Chris.
Thanks, Stefan
The following changes since commit 0315d6959fdd9d2a4d89016c311e9c8c8d239a10:
ARM: mvebu: a38x: Add missing SPDX license identfier (2018-05-15 09:08:00 -0400)
git://www.denx.de/git/u-boot-marvell.git
for you to fetch changes up to a7925926dc7f81fb5c137d2b4b7c6457694b1ac0:
ARM: kirkwood: Add device-tree for sheevaplug (2018-05-16 10:29:53 +0200)
---------------------------------------------------------------- Chris Packham (11): ARM: add devicetree files for kirkwood SoC ARM: kirkwood: Add device-tree for dns325 ARM: kirkwood: Add device-tree for dockstar ARM: kirkwood: Add device-tree for goflexhome ARM: kirkwood: Add device-tree for guruplug ARM: kirkwood: Add device-tree for ib62x0 ARM: kirkwood: Add device-tree for iconnect ARM: kirkwood: Add device-tree for nas220 ARM: kirkwood: Add device-tree for openrd ARM: kirkwood: Add device-tree for pogo_e02 ARM: kirkwood: Add device-tree for sheevaplug
arch/arm/dts/kirkwood-6192.dtsi | 88 ++++++ arch/arm/dts/kirkwood-6281.dtsi | 90 ++++++ arch/arm/dts/kirkwood-98dx4122.dtsi | 53 ++++ arch/arm/dts/kirkwood-blackarmor-nas220.dts | 172 +++++++++++ arch/arm/dts/kirkwood-dns325.dts | 63 ++++ arch/arm/dts/kirkwood-dnskw.dtsi | 235 +++++++++++++++ arch/arm/dts/kirkwood-dockstar.dts | 110 +++++++ arch/arm/dts/kirkwood-goflexnet.dts | 190 ++++++++++++ arch/arm/dts/kirkwood-guruplug-server-plus.dts | 133 +++++++++ arch/arm/dts/kirkwood-ib62x0.dts | 146 +++++++++ arch/arm/dts/kirkwood-iconnect.dts | 195 ++++++++++++ arch/arm/dts/kirkwood-openrd-base.dts | 39 +++ arch/arm/dts/kirkwood-openrd-client.dts | 73 +++++ arch/arm/dts/kirkwood-openrd-ultimate.dts | 55 ++++ arch/arm/dts/kirkwood-openrd.dtsi | 122 ++++++++ arch/arm/dts/kirkwood-pogo_e02.dts | 132 +++++++++ arch/arm/dts/kirkwood-sheevaplug-common.dtsi | 104 +++++++ arch/arm/dts/kirkwood-sheevaplug.dts | 42 +++ arch/arm/dts/kirkwood.dtsi | 393 +++++++++++++++++++++++++ configs/dns325_defconfig | 3 +- configs/dockstar_defconfig | 3 +- configs/goflexhome_defconfig | 3 +- configs/guruplug_defconfig | 3 +- configs/ib62x0_defconfig | 3 +- configs/iconnect_defconfig | 3 +- configs/nas220_defconfig | 3 +- configs/openrd_base_defconfig | 3 +- configs/openrd_client_defconfig | 3 +- configs/openrd_ultimate_defconfig | 3 +- configs/pogo_e02_defconfig | 3 +- configs/sheevaplug_defconfig | 3 +- 31 files changed, 2459 insertions(+), 12 deletions(-) create mode 100644 arch/arm/dts/kirkwood-6192.dtsi create mode 100644 arch/arm/dts/kirkwood-6281.dtsi create mode 100644 arch/arm/dts/kirkwood-98dx4122.dtsi create mode 100644 arch/arm/dts/kirkwood-blackarmor-nas220.dts create mode 100644 arch/arm/dts/kirkwood-dns325.dts create mode 100644 arch/arm/dts/kirkwood-dnskw.dtsi create mode 100644 arch/arm/dts/kirkwood-dockstar.dts create mode 100644 arch/arm/dts/kirkwood-goflexnet.dts create mode 100644 arch/arm/dts/kirkwood-guruplug-server-plus.dts create mode 100644 arch/arm/dts/kirkwood-ib62x0.dts create mode 100644 arch/arm/dts/kirkwood-iconnect.dts create mode 100644 arch/arm/dts/kirkwood-openrd-base.dts create mode 100644 arch/arm/dts/kirkwood-openrd-client.dts create mode 100644 arch/arm/dts/kirkwood-openrd-ultimate.dts create mode 100644 arch/arm/dts/kirkwood-openrd.dtsi create mode 100644 arch/arm/dts/kirkwood-pogo_e02.dts create mode 100644 arch/arm/dts/kirkwood-sheevaplug-common.dtsi create mode 100644 arch/arm/dts/kirkwood-sheevaplug.dts create mode 100644 arch/arm/dts/kirkwood.dtsi
On Wed, May 16, 2018 at 02:05:03PM +0200, Stefan Roese wrote:
Hi Tom,
Thanks, Stefan
NAK. With gcc-7.3 (https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/7.3.0/) I get: arm: + openrd_base openrd_ultimate openrd_client +(openrd_base,openrd_ultimate,openrd_client) u-boot-nodtb.bin exceeds file size limit: +(openrd_base,openrd_ultimate,openrd_client) limit: 393216 bytes +(openrd_base) actual: 395632 bytes +(openrd_base) excess: 2416 bytes +(openrd_base,openrd_ultimate,openrd_client) make[1]: *** [Makefile:1014: u-boot-nodtb.bin] Error 1 +(openrd_ultimate) actual: 395664 bytes +(openrd_ultimate) excess: 2448 bytes +(openrd_client) actual: 395680 bytes +(openrd_client) excess: 2464 bytes
And I will be pushing those changes to finally switch travis over to gcc-7.3 soon (I had thought I had posted them a long while back so that I could have pulled them in right after v2018.05, but I forgot, so here we are now..).
Hi Tom,
Thanks, Stefan
09:08:00 -0400)
+0200)
NAK. With gcc-7.3 (
file size limit:
Odd I did get those failures initially but then I rebased against master and didn't see them again. I've been using gcc 7.3 throughout. At the time I assumed there were some other changes that had shrunk openrd enough for the dtb to fit. I see Stefan's patch to move the env location. Is that sufficient or do you want me to either drop openrd or find something that can be left out?
Hi Tom,
Thanks, Stefan
09:08:00 -0400)
+0200)
NAK. With gcc-7.3 (
file size limit:
(gmail seems to have forgotten how to wrap quotes)
Sure enough my local branch with this series based on commit cc95535867f4 ("bootm.c: Correct the flush_len used in bootm_load_os()") builds openrd_ultimate is fine. But if I rebase onto commit f2d0f5e7ab3b ("ARM: re-enable MVGBE for edminiv2") I see the build size errors. I'll do some digging. Chances are my other MVGBE patch has enabled something unwanted.
Hi Chris,
Hi Tom,
Thanks, Stefan
09:08:00 -0400)
+0200)
NAK. With gcc-7.3 (
file size limit:
Thanks Chris. But perhaps its also good to increase the image size for those openrd boards, since we most likely will increase the size in the near future even further (addition of DM support etc). Please see:
http://patchwork.ozlabs.org/patch/915135/
Thanks, Stefan
On Thu, May 17, 2018 at 8:48 PM Stefan Roese sr@denx.de wrote:
Hi Chris,
Hi Tom,
Thanks, Stefan
09:08:00 -0400)
+0200)
NAK. With gcc-7.3 (
file size limit:
that
here
we are now..).
master
time
for
that
can be left out?
cc95535867f4
unwanted.
I'm fine with that. We'll probably end up needing it.
I've just sent a patch to not automatically select PHYLIB anyway since my MVGBE changes weren't the no-op they should have been.
Chris Packham
Stefan Roese
