[U-Boot] [PATCH v5] usb: dwc2: add support for external vbus supply
Some board do not use the dwc2 internal VBUS_DRV signal, but use a gpio pin to enable the 5.0V VBUS power, add interface to enable the power in dwc2 driver.
Signed-off-by: Kever Yang kever.yang@rock-chips.com Signed-off-by: Simon Glass sjg@chromium.org ---
Changes in v5: - add ifdef around the function instead of inside the function.
Changes in v4: - Drop no use code comment by Marek.
Changes in v3: - Drop use of static variable
drivers/usb/host/dwc2.c | 43 ++++++++++++++++++++++++++++++++++++++----- 1 file changed, 38 insertions(+), 5 deletions(-)
diff --git a/drivers/usb/host/dwc2.c b/drivers/usb/host/dwc2.c index d253b94..ae7d8fb 100644 --- a/drivers/usb/host/dwc2.c +++ b/drivers/usb/host/dwc2.c @@ -15,6 +15,7 @@ #include <usbroothubdes.h> #include <wait_bit.h> #include <asm/io.h> +#include <power/regulator.h>
#include "dwc2.h"
@@ -159,6 +160,33 @@ static void dwc_otg_core_reset(struct dwc2_core_regs *regs) mdelay(100); }
+#if defined(CONFIG_DM_USB) && defined(CONFIG_DM_REGULATOR) +static int dwc_vbus_supply_init(struct udevice *dev) +{ + struct udevice *vbus_supply; + int ret; + + ret = device_get_supply_regulator(dev, "vbus-supply", &vbus_supply); + if (ret) { + debug("%s: No vbus supply\n", dev->name); + return 0; + } + + ret = regulator_set_enable(vbus_supply, true); + if (ret) { + error("Error enabling vbus supply\n"); + return ret; + } + + return 0; +} +#else +static int dwc_vbus_supply_init(struct udevice *dev) +{ + return 0; +} +#endif + /* * This function initializes the DWC_otg controller registers for * host mode. @@ -167,10 +195,12 @@ static void dwc_otg_core_reset(struct dwc2_core_regs *regs) * request queues. Host channels are reset to ensure that they are ready for * performing transfers. * + * @param dev USB Device (NULL if driver model is not being used) * @param regs Programming view of DWC_otg controller * */ -static void dwc_otg_core_host_init(struct dwc2_core_regs *regs) +static void dwc_otg_core_host_init(struct udevice *dev, + struct dwc2_core_regs *regs) { uint32_t nptxfifosize = 0; uint32_t ptxfifosize = 0; @@ -248,6 +278,9 @@ static void dwc_otg_core_host_init(struct dwc2_core_regs *regs) writel(hprt0, ®s->hprt0); } } + + if (dev) + dwc_vbus_supply_init(dev); }
/* @@ -1048,7 +1081,7 @@ int _submit_int_msg(struct dwc2_priv *priv, struct usb_device *dev, } }
-static int dwc2_init_common(struct dwc2_priv *priv) +static int dwc2_init_common(struct udevice *dev, struct dwc2_priv *priv) { struct dwc2_core_regs *regs = priv->regs; uint32_t snpsid; @@ -1070,7 +1103,7 @@ static int dwc2_init_common(struct dwc2_priv *priv) #endif
dwc_otg_core_init(priv); - dwc_otg_core_host_init(regs); + dwc_otg_core_host_init(dev, regs);
clrsetbits_le32(®s->hprt0, DWC2_HPRT0_PRTENA | DWC2_HPRT0_PRTCONNDET | DWC2_HPRT0_PRTENCHNG | @@ -1143,7 +1176,7 @@ int usb_lowlevel_init(int index, enum usb_init_type init, void **controller) if (board_usb_init(index, USB_INIT_HOST)) return -1;
- return dwc2_init_common(priv); + return dwc2_init_common(NULL, priv); }
int usb_lowlevel_stop(int index) @@ -1214,7 +1247,7 @@ static int dwc2_usb_probe(struct udevice *dev)
bus_priv->desc_before_addr = true;
- return dwc2_init_common(priv); + return dwc2_init_common(dev, priv); }
static int dwc2_usb_remove(struct udevice *dev)
Applied, thanks.
Kever Yang
