[PATCH v5 0/9] Inline ECC Series
Hello,
This series is to:
Add support for Inline ECC in DDR for AM64X, AM62X, AM62AX, AM62PX, J721S2 and J784S4 devices.
(1/9) Add ss_cfg reg entry (2/9) Enable ECC priming with BIST engine (3/9) Add a function to store base address and size of RAM's banks in a 64-bit device private data (4/9) Setup the ECC region start and range (5/9) Enable ECC 1-bit error, 2-bit error and multiple-bit error interrupts (6/9) Add CONFIG_K3_INLINE_ECC (7/9) Remove 'ti,ecc-enable' flag (8/9) Set default NR_DRAM_BANKS to 2 (9/9) Pull Redundant DDR functions to a common location and Fixup DDR size when ECC is enabled
Changes since v4: 1. Make dram_init and dram_init_banksize weak at mach-k3/ and define at board/ti/ 2. Remove 'ti,ecc-enable' flag 3. Minor changes like patch order change (8/8 in v4 to 1/9 in v5), use 'u64'
v4: https://lore.kernel.org/u-boot/20241021044024.835846-1-s-k6@ti.com/
Changes since v3: Pull redundant DDR functions to arch/arm/mach-k3/*
v3: https://lore.kernel.org/all/20240523050430.455201-1-s-k6@ti.com/
Changes since v2: Removed 'default n' in Kconfig as that is default setting
v2: https://lore.kernel.org/u-boot/20240510084707.1903133-1-s-k6@ti.com/
Changes since v1: Add support for J7* devices.
v1: https://lore.kernel.org/u-boot/20240131060213.1128024-1-s-k6@ti.com/
Test Results: https://gist.github.com/santhosh21/88de920771ed2efa0463a5a367cb8d7b
Thanks and Regards, Santhosh.
Georgi Vlaev (1): ram: k3-ddrss: Use the DDR controller BIST engine for ECC priming
Neha Malcom Francis (2): drivers: ram: Kconfig: Add CONFIG_K3_INLINE_ECC arm: mach-k3: Set NR_DRAM_BANKS to 2
Santhosh Kumar K (6): arm: dts: k3-*-ddr: Add ss_cfg reg entry ram: k3-ddrss: Add k3_ddrss_ddr_bank_base_size_calc() to solve 'calculations restricted to 32 bits' issue ram: k3-ddrss: Setup ECC region start and range ram: k3-ddrss: Enable ECC interrupts ram: k3-ddrss: Remove 'ti,ecc-enable' support board: ti: Pull redundant DDR functions to a common location and Fixup DDR size when ECC is enabled
arch/arm/dts/k3-am62a-ddr.dtsi | 7 +- arch/arm/dts/k3-j721s2-ddr.dtsi | 12 +- arch/arm/dts/k3-j784s4-ddr.dtsi | 24 ++- arch/arm/mach-k3/Kconfig | 3 + arch/arm/mach-k3/Makefile | 2 +- arch/arm/mach-k3/include/mach/k3-ddr.h | 15 ++ arch/arm/mach-k3/k3-ddr.c | 72 ++++++++ board/ti/am62ax/evm.c | 17 +- board/ti/am62px/evm.c | 17 +- board/ti/am62x/evm.c | 63 +------ board/ti/am64x/evm.c | 73 +-------- board/ti/am65x/evm.c | 29 +--- board/ti/common/Makefile | 1 + board/ti/common/k3-ddr.c | 33 ++++ board/ti/common/k3-ddr.h | 12 ++ board/ti/j721e/evm.c | 29 +--- board/ti/j721s2/evm.c | 35 ++-- board/ti/j784s4/evm.c | 17 +- configs/am62ax_evm_a53_defconfig | 1 - configs/am62px_evm_a53_defconfig | 1 - configs/am62x_evm_a53_defconfig | 1 - configs/am62x_evm_r5_defconfig | 1 - configs/am64x_evm_a53_defconfig | 1 - configs/am64x_evm_r5_defconfig | 1 - configs/am65x_evm_a53_defconfig | 1 - configs/am65x_evm_r5_defconfig | 1 - configs/am65x_evm_r5_usbdfu_defconfig | 1 - configs/am65x_evm_r5_usbmsc_defconfig | 1 - configs/j7200_evm_a72_defconfig | 1 - configs/j721e_evm_a72_defconfig | 1 - configs/j721s2_evm_a72_defconfig | 1 - configs/j722s_evm_a53_defconfig | 1 - configs/j784s4_evm_a72_defconfig | 1 - drivers/ram/Kconfig | 10 ++ drivers/ram/k3-ddrss/k3-ddrss.c | 219 +++++++++++++++++++++---- 35 files changed, 417 insertions(+), 288 deletions(-) create mode 100644 arch/arm/mach-k3/include/mach/k3-ddr.h create mode 100644 arch/arm/mach-k3/k3-ddr.c create mode 100644 board/ti/common/k3-ddr.c create mode 100644 board/ti/common/k3-ddr.h
Add ss_cfg memory region which maps the DDRSS configuration region for the memory controller node.
Signed-off-by: Santhosh Kumar K s-k6@ti.com Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/dts/k3-am62a-ddr.dtsi | 7 ++++--- arch/arm/dts/k3-j721s2-ddr.dtsi | 12 ++++++++---- arch/arm/dts/k3-j784s4-ddr.dtsi | 24 ++++++++++++++++-------- 3 files changed, 28 insertions(+), 15 deletions(-)
diff --git a/arch/arm/dts/k3-am62a-ddr.dtsi b/arch/arm/dts/k3-am62a-ddr.dtsi index 8629ea45b847..42e41f78505a 100644 --- a/arch/arm/dts/k3-am62a-ddr.dtsi +++ b/arch/arm/dts/k3-am62a-ddr.dtsi @@ -4,11 +4,12 @@ */
/ { - memorycontroller: memory-controller@f308000 { + memorycontroller: memory-controller@f300000 { compatible = "ti,am62a-ddrss"; reg = <0x00 0x0f308000 0x00 0x4000>, - <0x00 0x43014000 0x00 0x100>; - reg-names = "cfg", "ctrl_mmr_lp4"; + <0x00 0x43014000 0x00 0x100>, + <0x00 0x0f300000 0x00 0x200>; + reg-names = "cfg", "ctrl_mmr_lp4", "ss_cfg"; ti,ddr-freq1 = <DDRSS_PLL_FREQUENCY_1>; ti,ddr-freq2 = <DDRSS_PLL_FREQUENCY_2>; ti,ddr-fhs-cnt = <DDRSS_PLL_FHS_CNT>; diff --git a/arch/arm/dts/k3-j721s2-ddr.dtsi b/arch/arm/dts/k3-j721s2-ddr.dtsi index 345e2b84f9e8..9764085163c4 100644 --- a/arch/arm/dts/k3-j721s2-ddr.dtsi +++ b/arch/arm/dts/k3-j721s2-ddr.dtsi @@ -5,6 +5,8 @@
&main_navss { ranges = <0x00 0x00114000 0x00 0x00114000 0x00 0x00000100>, // ctrl_mmr_lpr + <0x00 0x02980000 0x00 0x02980000 0x00 0x00000200>, // ss cfg 0 + <0x00 0x029a0000 0x00 0x029a0000 0x00 0x00000200>, // ss cfg 1 <0x00 0x02990000 0x00 0x02990000 0x00 0x00004000>, // ddr0 cfg <0x00 0x029b0000 0x00 0x029b0000 0x00 0x00004000>, // ddr1 cfg <0x00 0x30000000 0x00 0x30000000 0x00 0x0c400000>; @@ -24,8 +26,9 @@ memorycontroller0: memorycontroller@2990000 { compatible = "ti,j721s2-ddrss"; reg = <0x0 0x02990000 0x0 0x4000>, - <0x0 0x0114000 0x0 0x100>; - reg-names = "cfg", "ctrl_mmr_lp4"; + <0x0 0x0114000 0x0 0x100>, + <0x0 0x02980000 0x0 0x200>; + reg-names = "cfg", "ctrl_mmr_lp4", "ss_cfg"; power-domains = <&k3_pds 138 TI_SCI_PD_SHARED>, <&k3_pds 96 TI_SCI_PD_SHARED>; clocks = <&k3_clks 138 0>, <&k3_clks 43 2>; @@ -2232,8 +2235,9 @@ memorycontroller1: memorycontroller@29b0000 { compatible = "ti,j721s2-ddrss"; reg = <0x0 0x029b0000 0x0 0x4000>, - <0x0 0x0114000 0x0 0x100>; - reg-names = "cfg", "ctrl_mmr_lp4"; + <0x0 0x0114000 0x0 0x100>, + <0x0 0x029a0000 0x0 0x200>; + reg-names = "cfg", "ctrl_mmr_lp4", "ss_cfg"; power-domains = <&k3_pds 139 TI_SCI_PD_SHARED>, <&k3_pds 97 TI_SCI_PD_SHARED>; clocks = <&k3_clks 139 0>, <&k3_clks 43 2>; diff --git a/arch/arm/dts/k3-j784s4-ddr.dtsi b/arch/arm/dts/k3-j784s4-ddr.dtsi index 1c3242b0870c..fc74c539331e 100644 --- a/arch/arm/dts/k3-j784s4-ddr.dtsi +++ b/arch/arm/dts/k3-j784s4-ddr.dtsi @@ -9,6 +9,10 @@ <0x00 0x029b0000 0x00 0x029b0000 0x00 0x00004000>, // ddr1 cfg <0x00 0x029d0000 0x00 0x029d0000 0x00 0x00004000>, // ddr2 cfg <0x00 0x029f0000 0x00 0x029f0000 0x00 0x00004000>, // ddr3 cfg + <0x00 0x02980000 0x00 0x02980000 0x00 0x00000200>, // ss cfg 0 + <0x00 0x029a0000 0x00 0x029a0000 0x00 0x00000200>, // ss cfg 1 + <0x00 0x029c0000 0x00 0x029c0000 0x00 0x00000200>, // ss cfg 2 + <0x00 0x029e0000 0x00 0x029e0000 0x00 0x00000200>, // ss cfg 3 <0x00 0x30000000 0x00 0x30000000 0x00 0x0c400000>;
msmc0: msmc { @@ -26,8 +30,9 @@ memorycontroller0: memorycontroller@2990000 { compatible = "ti,j721s2-ddrss"; reg = <0x0 0x02990000 0x0 0x4000>, - <0x0 0x0114000 0x0 0x100>; - reg-names = "cfg", "ctrl_mmr_lp4"; + <0x0 0x0114000 0x0 0x100>, + <0x0 0x02980000 0x0 0x200>; + reg-names = "cfg", "ctrl_mmr_lp4", "ss_cfg"; power-domains = <&k3_pds 191 TI_SCI_PD_SHARED>, <&k3_pds 131 TI_SCI_PD_SHARED>; clocks = <&k3_clks 191 1>, <&k3_clks 78 2>; @@ -2234,8 +2239,9 @@ memorycontroller1: memorycontroller@29b0000 { compatible = "ti,j721s2-ddrss"; reg = <0x0 0x029b0000 0x0 0x4000>, - <0x0 0x0114000 0x0 0x100>; - reg-names = "cfg", "ctrl_mmr_lp4"; + <0x0 0x0114000 0x0 0x100>, + <0x0 0x029a0000 0x0 0x200>; + reg-names = "cfg", "ctrl_mmr_lp4", "ss_cfg"; power-domains = <&k3_pds 192 TI_SCI_PD_SHARED>, <&k3_pds 132 TI_SCI_PD_SHARED>; clocks = <&k3_clks 192 1>, <&k3_clks 78 2>; @@ -4442,8 +4448,9 @@ memorycontroller2: memorycontroller@29d0000 { compatible = "ti,j721s2-ddrss"; reg = <0x0 0x029d0000 0x0 0x4000>, - <0x0 0x0114000 0x0 0x100>; - reg-names = "cfg", "ctrl_mmr_lp4"; + <0x0 0x0114000 0x0 0x100>, + <0x0 0x029c0000 0x0 0x200>; + reg-names = "cfg", "ctrl_mmr_lp4", "ss_cfg"; power-domains = <&k3_pds 193 TI_SCI_PD_SHARED>, <&k3_pds 133 TI_SCI_PD_SHARED>; clocks = <&k3_clks 193 1>, <&k3_clks 78 2>; @@ -6650,8 +6657,9 @@ memorycontroller3: memorycontroller@29f0000 { compatible = "ti,j721s2-ddrss"; reg = <0x0 0x029f0000 0x0 0x4000>, - <0x0 0x0114000 0x0 0x100>; - reg-names = "cfg", "ctrl_mmr_lp4"; + <0x0 0x0114000 0x0 0x100>, + <0x0 0x29e0000 0x0 0x200>; + reg-names = "cfg", "ctrl_mmr_lp4", "ss_cfg"; power-domains = <&k3_pds 194 TI_SCI_PD_SHARED>, <&k3_pds 139 TI_SCI_PD_SHARED>; clocks = <&k3_clks 194 1>, <&k3_clks 78 2>;
The 1-bit inline ECC support in TI's DDRSS bridge requires the configured memory regions to be preloaded with a pattern before use. This is done by the k3-ddrss driver from the R5 SPL in a 'for' loop. It takes around 10 seconds to fill 2GB of memory, for example. Memset can cut the time in half and using DMA currently yields a similar result.
The BIST engine of DDR controller provides support for initializing any memory region with a pattern. This bypasses the DDRSS bridge, so the required inline ECC data is not computed and populated in the memory. For some values like zero, the computed ECC syndrome is also zero and we can use these values to preload the memory from the DDR controller, without the assistance of the bridge.
The registers involved in the process are described in the 'DDR controller registers' topic in [1] AM62 and [2] J721E reference manuals.
The patch replaces the 'for' loop memory fill function with the BIST memory initialization procedure. This cuts the time to preload the 2GB memory from 10 seconds down to 1 second. The bist preload function uses the lpddr4 APIs in the k3-ddrss, so this is compatible with devices with both 16-bit LPDDR4 and 32-bit LPDDR4 interfaces (e.g J721E).
[1] AM62x: https://www.ti.com/lit/pdf/spruiv7 [2] DRA829/TDA4VM: https://www.ti.com/lit/zip/spruil1
Signed-off-by: Georgi Vlaev g-vlaev@ti.com Signed-off-by: Santhosh Kumar K s-k6@ti.com --- drivers/ram/k3-ddrss/k3-ddrss.c | 122 +++++++++++++++++++++++++++++--- 1 file changed, 114 insertions(+), 8 deletions(-)
diff --git a/drivers/ram/k3-ddrss/k3-ddrss.c b/drivers/ram/k3-ddrss/k3-ddrss.c index 6e9202b95796..c29eec62bd8f 100644 --- a/drivers/ram/k3-ddrss/k3-ddrss.c +++ b/drivers/ram/k3-ddrss/k3-ddrss.c @@ -6,6 +6,7 @@ */
#include <config.h> +#include <time.h> #include <clk.h> #include <div64.h> #include <dm.h> @@ -548,14 +549,118 @@ static void k3_ddrss_set_ecc_range_r0(u32 base, u32 start_address, u32 size) writel((start_address + size - 1) >> 16, base + DDRSS_ECC_R0_END_ADDR_REG); }
-static void k3_ddrss_preload_ecc_mem_region(u32 *addr, u32 size, u32 word) +#define BIST_MODE_MEM_INIT 4 +#define BIST_MEM_INIT_TIMEOUT 10000 /* 1msec loops per block = 10s */ +static void k3_lpddr4_bist_init_mem_region(struct k3_ddrss_desc *ddrss, + u64 addr, u64 size, + u32 pattern) { - int i; + lpddr4_obj *driverdt = ddrss->driverdt; + lpddr4_privatedata *pd = &ddrss->pd; + u32 status, offset, regval; + bool int_status; + int i = 0; + + /* Set BIST_START_ADDR_0 [31:0] */ + regval = (u32)(addr & TH_FLD_MASK(LPDDR4__BIST_START_ADDRESS_0__FLD)); + TH_OFFSET_FROM_REG(LPDDR4__BIST_START_ADDRESS_0__REG, CTL_SHIFT, offset); + driverdt->writereg(pd, LPDDR4_CTL_REGS, offset, regval); + + /* Set BIST_START_ADDR_1 [32 or 34:32] */ + regval = (u32)(addr >> TH_FLD_WIDTH(LPDDR4__BIST_START_ADDRESS_0__FLD)); + regval &= TH_FLD_MASK(LPDDR4__BIST_START_ADDRESS_1__FLD); + TH_OFFSET_FROM_REG(LPDDR4__BIST_START_ADDRESS_1__REG, CTL_SHIFT, offset); + driverdt->writereg(pd, LPDDR4_CTL_REGS, offset, regval); + + /* Set ADDR_SPACE = log2(size) */ + regval = (u32)(ilog2(size) << TH_FLD_SHIFT(LPDDR4__ADDR_SPACE__FLD)); + TH_OFFSET_FROM_REG(LPDDR4__ADDR_SPACE__REG, CTL_SHIFT, offset); + driverdt->writereg(pd, LPDDR4_CTL_REGS, offset, regval); + + /* Enable the BIST data check. On 32bit lpddr4 (e.g J7) this shares a + * register with ADDR_SPACE and BIST_GO. + */ + TH_OFFSET_FROM_REG(LPDDR4__BIST_DATA_CHECK__REG, CTL_SHIFT, offset); + driverdt->readreg(pd, LPDDR4_CTL_REGS, offset, ®val); + regval |= TH_FLD_MASK(LPDDR4__BIST_DATA_CHECK__FLD); + driverdt->writereg(pd, LPDDR4_CTL_REGS, offset, regval); + /* Clear the address check bit */ + TH_OFFSET_FROM_REG(LPDDR4__BIST_ADDR_CHECK__REG, CTL_SHIFT, offset); + driverdt->readreg(pd, LPDDR4_CTL_REGS, offset, ®val); + regval &= ~TH_FLD_MASK(LPDDR4__BIST_ADDR_CHECK__FLD); + driverdt->writereg(pd, LPDDR4_CTL_REGS, offset, regval); + + /* Set BIST_TEST_MODE[2:0] to memory initialize (4) */ + regval = BIST_MODE_MEM_INIT; + TH_OFFSET_FROM_REG(LPDDR4__BIST_TEST_MODE__REG, CTL_SHIFT, offset); + driverdt->writereg(pd, LPDDR4_CTL_REGS, offset, regval); + + /* Set BIST_DATA_PATTERN[31:0] */ + TH_OFFSET_FROM_REG(LPDDR4__BIST_DATA_PATTERN_0__REG, CTL_SHIFT, offset); + driverdt->writereg(pd, LPDDR4_CTL_REGS, offset, pattern); + + /* Set BIST_DATA_PATTERN[63:32] */ + TH_OFFSET_FROM_REG(LPDDR4__BIST_DATA_PATTERN_1__REG, CTL_SHIFT, offset); + driverdt->writereg(pd, LPDDR4_CTL_REGS, offset, pattern); + + udelay(1000); + + /* Enable the programmed BIST operation - BIST_GO = 1 */ + TH_OFFSET_FROM_REG(LPDDR4__BIST_GO__REG, CTL_SHIFT, offset); + driverdt->readreg(pd, LPDDR4_CTL_REGS, offset, ®val); + regval |= TH_FLD_MASK(LPDDR4__BIST_GO__FLD); + driverdt->writereg(pd, LPDDR4_CTL_REGS, offset, regval); + + /* Wait for the BIST_DONE interrupt */ + while (i < BIST_MEM_INIT_TIMEOUT) { + status = driverdt->checkctlinterrupt(pd, LPDDR4_INTR_BIST_DONE, + &int_status); + if (!status & int_status) { + /* Clear LPDDR4_INTR_BIST_DONE */ + driverdt->ackctlinterrupt(pd, LPDDR4_INTR_BIST_DONE); + break; + } + udelay(1000); + i++; + }
- printf("ECC is enabled, priming DDR which will take several seconds.\n"); + /* Before continuing we have to stop BIST - BIST_GO = 0 */ + TH_OFFSET_FROM_REG(LPDDR4__BIST_GO__REG, CTL_SHIFT, offset); + driverdt->writereg(pd, LPDDR4_CTL_REGS, offset, 0); + + /* Timeout hit while priming the memory. We can't continue, + * since the memory is not fully initialized and we most + * likely get an uncorrectable error exception while booting. + */ + if (i == BIST_MEM_INIT_TIMEOUT) { + printf("ERROR: Timeout while priming the memory.\n"); + hang(); + } +}
- for (i = 0; i < (size / 4); i++) - addr[i] = word; +static void k3_ddrss_lpddr4_preload_full_mem(struct k3_ddrss_desc *ddrss, + u64 total_size, u32 pattern) +{ + u32 done, max_size2; + + /* Get the max size (log2) supported in this config (16/32 lpddr4) + * from the start_addess width - 16bit: 8G, 32bit: 32G + */ + max_size2 = TH_FLD_WIDTH(LPDDR4__BIST_START_ADDRESS_0__FLD) + + TH_FLD_WIDTH(LPDDR4__BIST_START_ADDRESS_1__FLD) + 1; + + /* ECC is enabled in dt but we can't preload the memory if + * the memory configuration is recognized and supported. + */ + if (!total_size || total_size > (1ull << max_size2) || + total_size & (total_size - 1)) { + printf("ECC: the memory configuration is not supported\n"); + hang(); + } + printf("ECC is enabled, priming DDR which will take several seconds.\n"); + done = get_timer(0); + k3_lpddr4_bist_init_mem_region(ddrss, 0, total_size, pattern); + printf("ECC: priming DDR completed in %lu msec\n", get_timer(done)); }
static void k3_ddrss_lpddr4_ecc_calc_reserved_mem(struct k3_ddrss_desc *ddrss) @@ -583,9 +688,10 @@ static void k3_ddrss_lpddr4_ecc_init(struct k3_ddrss_desc *ddrss) writel(DDRSS_ECC_CTRL_REG_ECC_EN | DDRSS_ECC_CTRL_REG_RMW_EN | DDRSS_ECC_CTRL_REG_WR_ALLOC, base + DDRSS_ECC_CTRL_REG);
- /* Preload ECC Mem region with 0's */ - k3_ddrss_preload_ecc_mem_region((u32 *)ecc_region_start, ecc_range, - 0x00000000); + /* Preload the full memory with 0's using the BIST engine of + * the LPDDR4 controller. + */ + k3_ddrss_lpddr4_preload_full_mem(ddrss, gd->ram_size, 0);
/* Clear Error Count Register */ writel(0x1, base + DDRSS_ECC_1B_ERR_CNT_REG);
As R5 is a 32 bit processor, the RAM banks' base and size calculation is restricted to 32 bits, which results in wrong values if bank's base is greater than 32 bits or bank's size is greater than or equal to 4GB.
So, add k3_ddrss_ddr_bank_base_size_calc() to get the base address and size of RAM's banks from the device tree memory node, and store in a 64 bit device private data which can be used for ECC reserved memory calculation, Setting ECC range and Fixing up bank size in device tree when ECC is enabled.
Signed-off-by: Santhosh Kumar K s-k6@ti.com --- drivers/ram/k3-ddrss/k3-ddrss.c | 72 ++++++++++++++++++++++++++------- 1 file changed, 57 insertions(+), 15 deletions(-)
diff --git a/drivers/ram/k3-ddrss/k3-ddrss.c b/drivers/ram/k3-ddrss/k3-ddrss.c index c29eec62bd8f..29ce53453c1f 100644 --- a/drivers/ram/k3-ddrss/k3-ddrss.c +++ b/drivers/ram/k3-ddrss/k3-ddrss.c @@ -147,6 +147,9 @@ struct k3_ddrss_desc { struct k3_ddrss_ecc_region ecc_regions[K3_DDRSS_MAX_ECC_REGIONS]; u64 ecc_reserved_space; bool ti_ecc_enabled; + u64 ddr_bank_base[CONFIG_NR_DRAM_BANKS]; + u64 ddr_bank_size[CONFIG_NR_DRAM_BANKS]; + u64 ddr_ram_size; };
struct reginitdata { @@ -663,11 +666,54 @@ static void k3_ddrss_lpddr4_preload_full_mem(struct k3_ddrss_desc *ddrss, printf("ECC: priming DDR completed in %lu msec\n", get_timer(done)); }
+static void k3_ddrss_ddr_bank_base_size_calc(struct k3_ddrss_desc *ddrss) +{ + int bank, na, ns, len, parent; + const fdt32_t *ptr, *end; + + for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) { + ddrss->ddr_bank_base[bank] = 0; + ddrss->ddr_bank_size[bank] = 0; + } + + ofnode mem = ofnode_null(); + + do { + mem = ofnode_by_prop_value(mem, "device_type", "memory", 7); + } while (!ofnode_is_enabled(mem)); + + const void *fdt = ofnode_to_fdt(mem); + int node = ofnode_to_offset(mem); + const char *property = "reg"; + + parent = fdt_parent_offset(fdt, node); + na = fdt_address_cells(fdt, parent); + ns = fdt_size_cells(fdt, parent); + ptr = fdt_getprop(fdt, node, property, &len); + end = ptr + len / sizeof(*ptr); + + for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) { + if (ptr + na + ns <= end) { + if (CONFIG_IS_ENABLED(OF_TRANSLATE)) + ddrss->ddr_bank_base[bank] = fdt_translate_address(fdt, node, ptr); + else + ddrss->ddr_bank_base[bank] = fdtdec_get_number(ptr, na); + + ddrss->ddr_bank_size[bank] = fdtdec_get_number(&ptr[na], ns); + } + + ptr += na + ns; + } + + for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) + ddrss->ddr_ram_size += ddrss->ddr_bank_size[bank]; +} + static void k3_ddrss_lpddr4_ecc_calc_reserved_mem(struct k3_ddrss_desc *ddrss) { fdtdec_setup_mem_size_base_lowest();
- ddrss->ecc_reserved_space = gd->ram_size; + ddrss->ecc_reserved_space = ddrss->ddr_ram_size; do_div(ddrss->ecc_reserved_space, 9);
/* Round to clean number */ @@ -691,7 +737,7 @@ static void k3_ddrss_lpddr4_ecc_init(struct k3_ddrss_desc *ddrss) /* Preload the full memory with 0's using the BIST engine of * the LPDDR4 controller. */ - k3_ddrss_lpddr4_preload_full_mem(ddrss, gd->ram_size, 0); + k3_ddrss_lpddr4_preload_full_mem(ddrss, ddrss->ddr_ram_size, 0);
/* Clear Error Count Register */ writel(0x1, base + DDRSS_ECC_1B_ERR_CNT_REG); @@ -736,6 +782,8 @@ static int k3_ddrss_probe(struct udevice *dev)
k3_lpddr4_start(ddrss);
+ k3_ddrss_ddr_bank_base_size_calc(ddrss); + if (ddrss->ti_ecc_enabled) { if (!ddrss->ddrss_ss_cfg) { printf("%s: ss_cfg is required if ecc is enabled but not provided.", @@ -756,30 +804,24 @@ static int k3_ddrss_probe(struct udevice *dev)
int k3_ddrss_ddr_fdt_fixup(struct udevice *dev, void *blob, struct bd_info *bd) { - struct k3_ddrss_desc *ddrss = dev_get_priv(dev); - u64 start[CONFIG_NR_DRAM_BANKS]; - u64 size[CONFIG_NR_DRAM_BANKS]; int bank; + struct k3_ddrss_desc *ddrss = dev_get_priv(dev);
if (ddrss->ecc_reserved_space == 0) return 0;
for (bank = CONFIG_NR_DRAM_BANKS - 1; bank >= 0; bank--) { - if (ddrss->ecc_reserved_space > bd->bi_dram[bank].size) { - ddrss->ecc_reserved_space -= bd->bi_dram[bank].size; - bd->bi_dram[bank].size = 0; + if (ddrss->ecc_reserved_space > ddrss->ddr_bank_size[bank]) { + ddrss->ecc_reserved_space -= ddrss->ddr_bank_size[bank]; + ddrss->ddr_bank_size[bank] = 0; } else { - bd->bi_dram[bank].size -= ddrss->ecc_reserved_space; + ddrss->ddr_bank_size[bank] -= ddrss->ecc_reserved_space; break; } }
- for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) { - start[bank] = bd->bi_dram[bank].start; - size[bank] = bd->bi_dram[bank].size; - } - - return fdt_fixup_memory_banks(blob, start, size, CONFIG_NR_DRAM_BANKS); + return fdt_fixup_memory_banks(blob, ddrss->ddr_bank_base, + ddrss->ddr_bank_size, CONFIG_NR_DRAM_BANKS); }
static int k3_ddrss_get_info(struct udevice *dev, struct ram_info *info)
Am 13.12.24 um 17:31 schrieb Santhosh Kumar K:
Reviewed-by: Wadim Egorov w.egorov@phytec.de
- int bank, na, ns, len, parent;
- const fdt32_t *ptr, *end;
- ofnode mem = ofnode_null();
- do {
- } while (!ofnode_is_enabled(mem));
- const void *fdt = ofnode_to_fdt(mem);
- int node = ofnode_to_offset(mem);
- const char *property = "reg";
- parent = fdt_parent_offset(fdt, node);
- na = fdt_address_cells(fdt, parent);
- ns = fdt_size_cells(fdt, parent);
- ptr = fdt_getprop(fdt, node, property, &len);
- end = ptr + len / sizeof(*ptr);
else
ptr += na + ns;
- static void k3_ddrss_lpddr4_ecc_calc_reserved_mem(struct k3_ddrss_desc *ddrss) { fdtdec_setup_mem_size_base_lowest();
- k3_ddrss_ddr_bank_base_size_calc(ddrss);
- if (ddrss->ti_ecc_enabled) { if (!ddrss->ddrss_ss_cfg) { printf("%s: ss_cfg is required if ecc is enabled but not provided.",
} else {ddrss->ddr_bank_size[bank] = 0;
} }ddrss->ddr_bank_size[bank] -= ddrss->ecc_reserved_space; break;
Setup the ECC region's start and range using the device private data, ddrss->ddr_bank_base[0] and ddrss->ddr_ram_size. Also, move start and range of ECC regions from 32 bits to 64 bits to accommodate for DDR greater than or equal to 4GB.
Signed-off-by: Santhosh Kumar K s-k6@ti.com --- drivers/ram/k3-ddrss/k3-ddrss.c | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/drivers/ram/k3-ddrss/k3-ddrss.c b/drivers/ram/k3-ddrss/k3-ddrss.c index 29ce53453c1f..0678db3b418b 100644 --- a/drivers/ram/k3-ddrss/k3-ddrss.c +++ b/drivers/ram/k3-ddrss/k3-ddrss.c @@ -121,8 +121,8 @@ struct k3_msmc { #define K3_DDRSS_MAX_ECC_REGIONS 3
struct k3_ddrss_ecc_region { - u32 start; - u32 range; + u64 start; + u64 range; };
struct k3_ddrss_desc { @@ -546,7 +546,7 @@ void k3_lpddr4_start(struct k3_ddrss_desc *ddrss) } }
-static void k3_ddrss_set_ecc_range_r0(u32 base, u32 start_address, u32 size) +static void k3_ddrss_set_ecc_range_r0(u32 base, u64 start_address, u64 size) { writel((start_address) >> 16, base + DDRSS_ECC_R0_STR_ADDR_REG); writel((start_address + size - 1) >> 16, base + DDRSS_ECC_R0_END_ADDR_REG); @@ -722,13 +722,13 @@ static void k3_ddrss_lpddr4_ecc_calc_reserved_mem(struct k3_ddrss_desc *ddrss)
static void k3_ddrss_lpddr4_ecc_init(struct k3_ddrss_desc *ddrss) { - u32 ecc_region_start = ddrss->ecc_regions[0].start; - u32 ecc_range = ddrss->ecc_regions[0].range; + u64 ecc_region_start = ddrss->ecc_regions[0].start; + u64 ecc_range = ddrss->ecc_regions[0].range; u32 base = (u32)ddrss->ddrss_ss_cfg; u32 val;
/* Only Program region 0 which covers full ddr space */ - k3_ddrss_set_ecc_range_r0(base, ecc_region_start - gd->ram_base, ecc_range); + k3_ddrss_set_ecc_range_r0(base, ecc_region_start - ddrss->ddr_bank_base[0], ecc_range);
/* Enable ECC, RMW, WR_ALLOC */ writel(DDRSS_ECC_CTRL_REG_ECC_EN | DDRSS_ECC_CTRL_REG_RMW_EN | @@ -794,8 +794,8 @@ static int k3_ddrss_probe(struct udevice *dev) k3_ddrss_lpddr4_ecc_calc_reserved_mem(ddrss);
/* Always configure one region that covers full DDR space */ - ddrss->ecc_regions[0].start = gd->ram_base; - ddrss->ecc_regions[0].range = gd->ram_size - ddrss->ecc_reserved_space; + ddrss->ecc_regions[0].start = ddrss->ddr_bank_base[0]; + ddrss->ecc_regions[0].range = ddrss->ddr_ram_size - ddrss->ecc_reserved_space; k3_ddrss_lpddr4_ecc_init(ddrss); }
Enable ECC 1-bit error, 2-bit error, multiple 1-bit error interrupts by setting the respective bits in the DDRSS_V2A_INT_SET_REG register.
Signed-off-by: Santhosh Kumar K s-k6@ti.com --- drivers/ram/k3-ddrss/k3-ddrss.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/drivers/ram/k3-ddrss/k3-ddrss.c b/drivers/ram/k3-ddrss/k3-ddrss.c index 0678db3b418b..e4f9891bee20 100644 --- a/drivers/ram/k3-ddrss/k3-ddrss.c +++ b/drivers/ram/k3-ddrss/k3-ddrss.c @@ -45,6 +45,11 @@ #define DDRSS_ECC_R2_STR_ADDR_REG 0x0140 #define DDRSS_ECC_R2_END_ADDR_REG 0x0144 #define DDRSS_ECC_1B_ERR_CNT_REG 0x0150 +#define DDRSS_V2A_INT_SET_REG 0x00a8 + +#define DDRSS_V2A_INT_SET_REG_ECC1BERR_EN BIT(3) +#define DDRSS_V2A_INT_SET_REG_ECC2BERR_EN BIT(4) +#define DDRSS_V2A_INT_SET_REG_ECCM1BERR_EN BIT(5)
#define SINGLE_DDR_SUBSYSTEM 0x1 #define MULTI_DDR_SUBSYSTEM 0x2 @@ -742,6 +747,9 @@ static void k3_ddrss_lpddr4_ecc_init(struct k3_ddrss_desc *ddrss) /* Clear Error Count Register */ writel(0x1, base + DDRSS_ECC_1B_ERR_CNT_REG);
+ writel(DDRSS_V2A_INT_SET_REG_ECC1BERR_EN | DDRSS_V2A_INT_SET_REG_ECC2BERR_EN | + DDRSS_V2A_INT_SET_REG_ECCM1BERR_EN, base + DDRSS_V2A_INT_SET_REG); + /* Enable ECC Check */ val = readl(base + DDRSS_ECC_CTRL_REG); val |= DDRSS_ECC_CTRL_REG_ECC_CK;
Add CONFIG_K3_INLINE_ECC so that ECC functions can be compiled into R5 SPL only when the config has been enabled.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- drivers/ram/Kconfig | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/drivers/ram/Kconfig b/drivers/ram/Kconfig index f7e357f24da7..533d0c629a64 100644 --- a/drivers/ram/Kconfig +++ b/drivers/ram/Kconfig @@ -116,6 +116,16 @@ config IMXRT_SDRAM to support external memories like sdram, psram & nand. This driver is for the sdram memory interface with the SEMC.
+config K3_INLINE_ECC + bool "Enable TI Inline ECC support" + depends on K3_DDRSS + help + Enable Inline ECC support on K3 platforms. 1/9th of the SDRAM space + is used for ECC storage and the rest 8/9th is available for system + use. Enabling ECC increases boot time as the ECC protected regions + need to be primed with a predefined value prior to enabling ECC + check. + source "drivers/ram/aspeed/Kconfig" source "drivers/ram/cadence/Kconfig" source "drivers/ram/octeon/Kconfig"
- bool "Enable TI Inline ECC support"
- depends on K3_DDRSS
- help
check.
- source "drivers/ram/aspeed/Kconfig" source "drivers/ram/cadence/Kconfig" source "drivers/ram/octeon/Kconfig"
The functionality of enabling Inline ECC is now controlled by CONFIG_K3_INLINE_ECC. So, remove the support for 'ti,ecc-enable' property to avoid redundancy and to ensure the Inline ECC feature is mananged through build-time config.
Signed-off-by: Santhosh Kumar K s-k6@ti.com --- drivers/ram/k3-ddrss/k3-ddrss.c | 5 +---- 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/drivers/ram/k3-ddrss/k3-ddrss.c b/drivers/ram/k3-ddrss/k3-ddrss.c index e4f9891bee20..05ea61bbfe9a 100644 --- a/drivers/ram/k3-ddrss/k3-ddrss.c +++ b/drivers/ram/k3-ddrss/k3-ddrss.c @@ -151,7 +151,6 @@ struct k3_ddrss_desc { lpddr4_privatedata pd; struct k3_ddrss_ecc_region ecc_regions[K3_DDRSS_MAX_ECC_REGIONS]; u64 ecc_reserved_space; - bool ti_ecc_enabled; u64 ddr_bank_base[CONFIG_NR_DRAM_BANKS]; u64 ddr_bank_size[CONFIG_NR_DRAM_BANKS]; u64 ddr_ram_size; @@ -408,8 +407,6 @@ static int k3_ddrss_ofdata_to_priv(struct udevice *dev) if (ret) dev_err(dev, "ddr fhs cnt not populated %d\n", ret);
- ddrss->ti_ecc_enabled = dev_read_bool(dev, "ti,ecc-enable"); - return ret; }
@@ -792,7 +789,7 @@ static int k3_ddrss_probe(struct udevice *dev)
- if (ddrss->ti_ecc_enabled) { + if (IS_ENABLED(CONFIG_K3_INLINE_ECC)) { if (!ddrss->ddrss_ss_cfg) { printf("%s: ss_cfg is required if ecc is enabled but not provided.", __func__);
- return ret; }
- if (IS_ENABLED(CONFIG_K3_INLINE_ECC)) { if (!ddrss->ddrss_ss_cfg) { printf("%s: ss_cfg is required if ecc is enabled but not provided.", __func__);
Set CONFIG_NR_DRAM_BANKS to 2 as we have two banks described in the memory/ node for lower and higher addressible DDR regions.
This allows use of FDT functions from fdt_support.c to set up and fix up the memory/ node correctly.
Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/mach-k3/Kconfig | 3 +++ configs/am62ax_evm_a53_defconfig | 1 - configs/am62px_evm_a53_defconfig | 1 - configs/am62x_evm_a53_defconfig | 1 - configs/am62x_evm_r5_defconfig | 1 - configs/am64x_evm_a53_defconfig | 1 - configs/am64x_evm_r5_defconfig | 1 - configs/am65x_evm_a53_defconfig | 1 - configs/am65x_evm_r5_defconfig | 1 - configs/am65x_evm_r5_usbdfu_defconfig | 1 - configs/am65x_evm_r5_usbmsc_defconfig | 1 - configs/j7200_evm_a72_defconfig | 1 - configs/j721e_evm_a72_defconfig | 1 - configs/j721s2_evm_a72_defconfig | 1 - configs/j722s_evm_a53_defconfig | 1 - configs/j784s4_evm_a72_defconfig | 1 - 16 files changed, 3 insertions(+), 15 deletions(-)
diff --git a/arch/arm/mach-k3/Kconfig b/arch/arm/mach-k3/Kconfig index f3f42b392139..a3ac490f6774 100644 --- a/arch/arm/mach-k3/Kconfig +++ b/arch/arm/mach-k3/Kconfig @@ -156,6 +156,9 @@ config K3_X509_SWRV help SWRV for X509 certificate used for boot images
+config NR_DRAM_BANKS + default 2 + if CPU_V7R source "arch/arm/mach-k3/r5/Kconfig" endif diff --git a/configs/am62ax_evm_a53_defconfig b/configs/am62ax_evm_a53_defconfig index 7d63340c903f..107d6c6becfe 100644 --- a/configs/am62ax_evm_a53_defconfig +++ b/configs/am62ax_evm_a53_defconfig @@ -3,7 +3,6 @@ CONFIG_ARCH_K3=y CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 CONFIG_SOC_K3_AM62A7=y CONFIG_TARGET_AM62A7_A53_EVM=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y diff --git a/configs/am62px_evm_a53_defconfig b/configs/am62px_evm_a53_defconfig index 9635beb1b27e..30b4a24ee9ae 100644 --- a/configs/am62px_evm_a53_defconfig +++ b/configs/am62px_evm_a53_defconfig @@ -4,7 +4,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 CONFIG_SOC_K3_AM62P5=y CONFIG_TARGET_AM62P5_A53_EVM=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y diff --git a/configs/am62x_evm_a53_defconfig b/configs/am62x_evm_a53_defconfig index 003fa4f86814..2509a91cf628 100644 --- a/configs/am62x_evm_a53_defconfig +++ b/configs/am62x_evm_a53_defconfig @@ -3,7 +3,6 @@ CONFIG_ARCH_K3=y CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 CONFIG_SOC_K3_AM625=y CONFIG_TARGET_AM625_A53_EVM=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y diff --git a/configs/am62x_evm_r5_defconfig b/configs/am62x_evm_r5_defconfig index fcc5eb028679..b47f2f2d1f3a 100644 --- a/configs/am62x_evm_r5_defconfig +++ b/configs/am62x_evm_r5_defconfig @@ -4,7 +4,6 @@ CONFIG_SYS_MALLOC_LEN=0x08000000 CONFIG_SYS_MALLOC_F_LEN=0x9000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 CONFIG_SOC_K3_AM625=y CONFIG_TARGET_AM625_R5_EVM=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y diff --git a/configs/am64x_evm_a53_defconfig b/configs/am64x_evm_a53_defconfig index e6e3e018da64..a501f3f567e5 100644 --- a/configs/am64x_evm_a53_defconfig +++ b/configs/am64x_evm_a53_defconfig @@ -6,7 +6,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 CONFIG_SOC_K3_AM642=y CONFIG_K3_ATF_LOAD_ADDR=0x701c0000 CONFIG_TARGET_AM642_A53_EVM=y diff --git a/configs/am64x_evm_r5_defconfig b/configs/am64x_evm_r5_defconfig index c4e498a6ae7a..c7fc9d124c7b 100644 --- a/configs/am64x_evm_r5_defconfig +++ b/configs/am64x_evm_r5_defconfig @@ -5,7 +5,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x80000 CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 CONFIG_SOC_K3_AM642=y CONFIG_TARGET_AM642_R5_EVM=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y diff --git a/configs/am65x_evm_a53_defconfig b/configs/am65x_evm_a53_defconfig index b6df8b428c65..e9b736714a5b 100644 --- a/configs/am65x_evm_a53_defconfig +++ b/configs/am65x_evm_a53_defconfig @@ -5,7 +5,6 @@ CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 CONFIG_SOC_K3_AM654=y CONFIG_TARGET_AM654_A53_EVM=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y diff --git a/configs/am65x_evm_r5_defconfig b/configs/am65x_evm_r5_defconfig index 083522ce9b49..4bd5e8f63ff1 100644 --- a/configs/am65x_evm_r5_defconfig +++ b/configs/am65x_evm_r5_defconfig @@ -5,7 +5,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x55000 CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 CONFIG_SOC_K3_AM654=y CONFIG_K3_EARLY_CONS=y CONFIG_TARGET_AM654_R5_EVM=y diff --git a/configs/am65x_evm_r5_usbdfu_defconfig b/configs/am65x_evm_r5_usbdfu_defconfig index e60e0d6588d3..ae57007d8985 100644 --- a/configs/am65x_evm_r5_usbdfu_defconfig +++ b/configs/am65x_evm_r5_usbdfu_defconfig @@ -5,7 +5,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x55000 CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 CONFIG_SOC_K3_AM654=y CONFIG_K3_EARLY_CONS=y CONFIG_TARGET_AM654_R5_EVM=y diff --git a/configs/am65x_evm_r5_usbmsc_defconfig b/configs/am65x_evm_r5_usbmsc_defconfig index ecd48c45ea16..3aa17eb77f0f 100644 --- a/configs/am65x_evm_r5_usbmsc_defconfig +++ b/configs/am65x_evm_r5_usbmsc_defconfig @@ -5,7 +5,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x55000 CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 CONFIG_SOC_K3_AM654=y CONFIG_K3_EARLY_CONS=y CONFIG_TARGET_AM654_R5_EVM=y diff --git a/configs/j7200_evm_a72_defconfig b/configs/j7200_evm_a72_defconfig index eb6203f2b4c2..7e598eeadbeb 100644 --- a/configs/j7200_evm_a72_defconfig +++ b/configs/j7200_evm_a72_defconfig @@ -5,7 +5,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 CONFIG_SOC_K3_J721E=y CONFIG_TARGET_J7200_A72_EVM=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig index bd5563492449..86c746d5064e 100644 --- a/configs/j721e_evm_a72_defconfig +++ b/configs/j721e_evm_a72_defconfig @@ -5,7 +5,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 CONFIG_SOC_K3_J721E=y CONFIG_TARGET_J721E_A72_EVM=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y diff --git a/configs/j721s2_evm_a72_defconfig b/configs/j721s2_evm_a72_defconfig index 2a0ccfb581ea..640aa00a0241 100644 --- a/configs/j721s2_evm_a72_defconfig +++ b/configs/j721s2_evm_a72_defconfig @@ -5,7 +5,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 CONFIG_SOC_K3_J721S2=y CONFIG_TARGET_J721S2_A72_EVM=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y diff --git a/configs/j722s_evm_a53_defconfig b/configs/j722s_evm_a53_defconfig index 35329fb336bf..17595e3c4514 100644 --- a/configs/j722s_evm_a53_defconfig +++ b/configs/j722s_evm_a53_defconfig @@ -4,7 +4,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 CONFIG_SOC_K3_J722S=y CONFIG_TARGET_J722S_A53_EVM=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y diff --git a/configs/j784s4_evm_a72_defconfig b/configs/j784s4_evm_a72_defconfig index c7fc6bedda3b..7176ec85cd90 100644 --- a/configs/j784s4_evm_a72_defconfig +++ b/configs/j784s4_evm_a72_defconfig @@ -5,7 +5,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x8000 CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=2 CONFIG_SOC_K3_J784S4=y CONFIG_TARGET_J784S4_A72_EVM=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y
As there are few redundant functions in board/ti/*/evm.c files, pull them to a common location of access to reuse and include the common file to access the functions.
Call k3-ddrss driver through fixup_ddr_driver_for_ecc() to fixup the device tree and resize the available amount of DDR, if ECC is enabled. Otherwise, fixup the device tree using the regular fdt_fixup_memory_banks().
Also call dram_init_banksize() after every call to fixup_ddr_driver_for_ecc() is made so that gd->bd is populated correctly.
Ensure that fixup_ddr_driver_for_ecc() is agnostic to the number of DDR controllers present.
Signed-off-by: Santhosh Kumar K s-k6@ti.com Signed-off-by: Neha Malcom Francis n-francis@ti.com --- arch/arm/mach-k3/Makefile | 2 +- arch/arm/mach-k3/include/mach/k3-ddr.h | 15 ++++++ arch/arm/mach-k3/k3-ddr.c | 72 +++++++++++++++++++++++++ board/ti/am62ax/evm.c | 17 +++--- board/ti/am62px/evm.c | 17 +++--- board/ti/am62x/evm.c | 63 +++------------------- board/ti/am64x/evm.c | 73 +++----------------------- board/ti/am65x/evm.c | 29 +--------- board/ti/common/Makefile | 1 + board/ti/common/k3-ddr.c | 33 ++++++++++++ board/ti/common/k3-ddr.h | 12 +++++ board/ti/j721e/evm.c | 29 +--------- board/ti/j721s2/evm.c | 35 ++++-------- board/ti/j784s4/evm.c | 17 +++--- 14 files changed, 190 insertions(+), 225 deletions(-) create mode 100644 arch/arm/mach-k3/include/mach/k3-ddr.h create mode 100644 arch/arm/mach-k3/k3-ddr.c create mode 100644 board/ti/common/k3-ddr.c create mode 100644 board/ti/common/k3-ddr.h
diff --git a/arch/arm/mach-k3/Makefile b/arch/arm/mach-k3/Makefile index 8c4f6786a5b5..5ce7fc62d80c 100644 --- a/arch/arm/mach-k3/Makefile +++ b/arch/arm/mach-k3/Makefile @@ -6,7 +6,7 @@ obj-$(CONFIG_ARM64) += arm64/ obj-$(CONFIG_CPU_V7R) += r5/ obj-$(CONFIG_OF_LIBFDT) += common_fdt.o -obj-y += common.o security.o +obj-y += common.o security.o k3-ddr.o obj-$(CONFIG_SOC_K3_AM62A7) += am62ax/ obj-$(CONFIG_SOC_K3_AM62P5) += am62px/ obj-$(CONFIG_SOC_K3_AM625) += am62x/ diff --git a/arch/arm/mach-k3/include/mach/k3-ddr.h b/arch/arm/mach-k3/include/mach/k3-ddr.h new file mode 100644 index 000000000000..95496e1c59dc --- /dev/null +++ b/arch/arm/mach-k3/include/mach/k3-ddr.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2024, Texas Instruments Incorporated - https://www.ti.com/ + */ + +#ifndef _K3_DDR_H_ +#define _K3_DDR_H_ + +int dram_init(void); +int dram_init_banksize(void); + +void fixup_ddr_driver_for_ecc(struct spl_image_info *spl_image); +void fixup_memory_node(struct spl_image_info *spl_image); + +#endif /* _K3_DDR_H_ */ diff --git a/arch/arm/mach-k3/k3-ddr.c b/arch/arm/mach-k3/k3-ddr.c new file mode 100644 index 000000000000..6e3e60cdc865 --- /dev/null +++ b/arch/arm/mach-k3/k3-ddr.c @@ -0,0 +1,72 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2024, Texas Instruments Incorporated - https://www.ti.com/ + */ + +#include <fdt_support.h> +#include <dm/uclass.h> +#include <k3-ddrss.h> +#include <spl.h> + +#include <asm/arch/k3-ddr.h> + +__weak int dram_init(void) +{ + return 0; +} + +__weak int dram_init_banksize(void) +{ + return 0; +} + +#if defined(CONFIG_SPL_BUILD) +void fixup_ddr_driver_for_ecc(struct spl_image_info *spl_image) +{ + struct udevice *dev; + int ret, ctr = 1; + + dram_init_banksize(); + + ret = uclass_get_device(UCLASS_RAM, 0, &dev); + if (ret) + panic("Cannnot get RAM device for ddr size fixup: %d\n", ret); + + ret = k3_ddrss_ddr_fdt_fixup(dev, spl_image->fdt_addr, gd->bd); + if (ret) + printf("Error fixing up ddr node for ECC use! %d\n", ret); + + ret = uclass_next_device_err(&dev); + + while (ret && ret != -ENODEV) { + ret = k3_ddrss_ddr_fdt_fixup(dev, spl_image->fdt_addr, gd->bd); + if (ret) + printf("Error fixing up ddr node %d for ECC use! %d\n", ctr, ret); + + ret = uclass_next_device_err(&dev); + ctr++; + } +} + +void fixup_memory_node(struct spl_image_info *spl_image) +{ + u64 start[CONFIG_NR_DRAM_BANKS]; + u64 size[CONFIG_NR_DRAM_BANKS]; + int bank; + int ret; + + dram_init(); + dram_init_banksize(); + + for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) { + start[bank] = gd->bd->bi_dram[bank].start; + size[bank] = gd->bd->bi_dram[bank].size; + } + + ret = fdt_fixup_memory_banks(spl_image->fdt_addr, start, size, + CONFIG_NR_DRAM_BANKS); + + if (ret) + printf("Error fixing up memory node! %d\n", ret); +} +#endif diff --git a/board/ti/am62ax/evm.c b/board/ti/am62ax/evm.c index 62d3664936e7..3351544c5b37 100644 --- a/board/ti/am62ax/evm.c +++ b/board/ti/am62ax/evm.c @@ -12,6 +12,7 @@ #include <env.h> #include <fdt_support.h> #include <spl.h> +#include <asm/arch/k3-ddr.h>
#include "../common/fdt_ops.h"
@@ -20,15 +21,17 @@ int board_init(void) return 0; }
-int dram_init(void) +#if defined(CONFIG_XPL_BUILD) +void spl_perform_fixups(struct spl_image_info *spl_image) { - return fdtdec_setup_mem_size_base(); -} - -int dram_init_banksize(void) -{ - return fdtdec_setup_memory_banksize(); + if (IS_ENABLED(CONFIG_K3_DDRSS)) { + if (IS_ENABLED(CONFIG_K3_INLINE_ECC)) + fixup_ddr_driver_for_ecc(spl_image); + } else { + fixup_memory_node(spl_image); + } } +#endif
#ifdef CONFIG_BOARD_LATE_INIT int board_late_init(void) diff --git a/board/ti/am62px/evm.c b/board/ti/am62px/evm.c index 7362fa4520a3..75359fa1614c 100644 --- a/board/ti/am62px/evm.c +++ b/board/ti/am62px/evm.c @@ -13,6 +13,7 @@ #include <env.h> #include <fdt_support.h> #include <spl.h> +#include <asm/arch/k3-ddr.h> #include "../common/fdt_ops.h"
struct efi_fw_image fw_images[] = { @@ -53,15 +54,17 @@ int board_init(void) return 0; }
#if IS_ENABLED(CONFIG_BOARD_LATE_INIT) int board_late_init(void) diff --git a/board/ti/am62x/evm.c b/board/ti/am62x/evm.c index 9075df01cac6..279ceba95547 100644 --- a/board/ti/am62x/evm.c +++ b/board/ti/am62x/evm.c @@ -20,6 +20,7 @@ #include <asm/io.h> #include <asm/arch/hardware.h> #include <dm/uclass.h> +#include <asm/arch/k3-ddr.h>
@@ -86,11 +87,6 @@ int board_init(void) return 0; }
-int dram_init(void) -{ - return fdtdec_setup_mem_size_base(); -} - #ifdef CONFIG_BOARD_LATE_INIT int board_late_init(void) { @@ -99,13 +95,7 @@ int board_late_init(void) } #endif
-int dram_init_banksize(void) -{ - return fdtdec_setup_memory_banksize(); -} - #if defined(CONFIG_XPL_BUILD) - void spl_board_init(void) { enable_caches(); @@ -114,53 +104,14 @@ void spl_board_init(void)
-#if defined(CONFIG_K3_AM64_DDRSS) -static void fixup_ddr_driver_for_ecc(struct spl_image_info *spl_image) -{ - struct udevice *dev; - int ret; - - dram_init_banksize(); - - ret = uclass_get_device(UCLASS_RAM, 0, &dev); - if (ret) - panic("Cannot get RAM device for ddr size fixup: %d\n", ret); - - ret = k3_ddrss_ddr_fdt_fixup(dev, spl_image->fdt_addr, gd->bd); - if (ret) - printf("Error fixing up ddr node for ECC use! %d\n", ret); -} -#else -static void fixup_memory_node(struct spl_image_info *spl_image) -{ - u64 start[CONFIG_NR_DRAM_BANKS]; - u64 size[CONFIG_NR_DRAM_BANKS]; - int bank; - int ret; - - dram_init(); - dram_init_banksize(); - - for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) { - start[bank] = gd->bd->bi_dram[bank].start; - size[bank] = gd->bd->bi_dram[bank].size; - } - - /* dram_init functions use SPL fdt, and we must fixup u-boot fdt */ - ret = fdt_fixup_memory_banks(spl_image->fdt_addr, start, size, - CONFIG_NR_DRAM_BANKS); - if (ret) - printf("Error fixing up memory node! %d\n", ret); -} -#endif - void spl_perform_fixups(struct spl_image_info *spl_image) { -#if defined(CONFIG_K3_AM64_DDRSS) - fixup_ddr_driver_for_ecc(spl_image); -#else - fixup_memory_node(spl_image); -#endif + if (IS_ENABLED(CONFIG_K3_DDRSS)) { + if (IS_ENABLED(CONFIG_K3_INLINE_ECC)) + fixup_ddr_driver_for_ecc(spl_image); + } else { + fixup_memory_node(spl_image); + } } #endif
diff --git a/board/ti/am64x/evm.c b/board/ti/am64x/evm.c index 00b8317d6bf9..6f7e1f828668 100644 --- a/board/ti/am64x/evm.c +++ b/board/ti/am64x/evm.c @@ -15,6 +15,7 @@ #include <fdt_support.h> #include <asm/arch/hardware.h> #include <env.h> +#include <asm/arch/k3-ddr.h>
#include "../common/board_detect.h" #include "../common/fdt_ops.h" @@ -66,28 +67,6 @@ int board_init(void) return 0; }
-int dram_init(void) -{ - s32 ret; - - ret = fdtdec_setup_mem_size_base(); - if (ret) - printf("Error setting up mem size and base. %d\n", ret); - - return ret; -} - -int dram_init_banksize(void) -{ - s32 ret; - - ret = fdtdec_setup_memory_banksize(); - if (ret) - printf("Error setting up memory banksize. %d\n", ret); - - return ret; -} - #if defined(CONFIG_SPL_LOAD_FIT) int board_fit_config_name_match(const char *name) { @@ -132,52 +111,14 @@ static int fixup_usb_boot(const void *fdt_blob) } #endif
-#if defined(CONFIG_K3_AM64_DDRSS) -static void fixup_ddr_driver_for_ecc(struct spl_image_info *spl_image) -{ - struct udevice *dev; - int ret; - - dram_init_banksize(); - - ret = uclass_get_device(UCLASS_RAM, 0, &dev); - if (ret) - panic("Cannot get RAM device for ddr size fixup: %d\n", ret); - - ret = k3_ddrss_ddr_fdt_fixup(dev, spl_image->fdt_addr, gd->bd); - if (ret) - printf("Error fixing up ddr node for ECC use! %d\n", ret); -} -#else -static void fixup_memory_node(struct spl_image_info *spl_image) -{ - u64 start[CONFIG_NR_DRAM_BANKS]; - u64 size[CONFIG_NR_DRAM_BANKS]; - int bank; - int ret; - - dram_init(); - dram_init_banksize(); - - for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) { - start[bank] = gd->bd->bi_dram[bank].start; - size[bank] = gd->bd->bi_dram[bank].size; - } - - /* dram_init functions use SPL fdt, and we must fixup u-boot fdt */ - ret = fdt_fixup_memory_banks(spl_image->fdt_addr, start, size, CONFIG_NR_DRAM_BANKS); - if (ret) - printf("Error fixing up memory node! %d\n", ret); -} -#endif - void spl_perform_fixups(struct spl_image_info *spl_image) { -#if defined(CONFIG_K3_AM64_DDRSS) - fixup_ddr_driver_for_ecc(spl_image); -#else - fixup_memory_node(spl_image); -#endif + if (IS_ENABLED(CONFIG_K3_DDRSS)) { + if (IS_ENABLED(CONFIG_K3_INLINE_ECC)) + fixup_ddr_driver_for_ecc(spl_image); + } else { + fixup_memory_node(spl_image); + }
#if CONFIG_IS_ENABLED(USB_STORAGE) fixup_usb_boot(spl_image->fdt_addr); diff --git a/board/ti/am65x/evm.c b/board/ti/am65x/evm.c index 07073a5940b1..6658794a1375 100644 --- a/board/ti/am65x/evm.c +++ b/board/ti/am65x/evm.c @@ -20,6 +20,7 @@ #include <env.h> #include <spl.h> #include <linux/printk.h> +#include <asm/arch/k3-ddr.h>
#include "../common/board_detect.h" #include "../common/fdt_ops.h" @@ -49,17 +50,6 @@ int board_init(void) return 0; }
-int dram_init(void) -{ -#ifdef CONFIG_PHYS_64BIT - gd->ram_size = 0x100000000; -#else - gd->ram_size = 0x80000000; -#endif - - return 0; -} - phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { #ifdef CONFIG_PHYS_64BIT @@ -71,23 +61,6 @@ phys_addr_t board_get_usable_ram_top(phys_size_t total_size) return gd->ram_top; }
-int dram_init_banksize(void) -{ - /* Bank 0 declares the memory available in the DDR low region */ - gd->bd->bi_dram[0].start = 0x80000000; - gd->bd->bi_dram[0].size = 0x80000000; - gd->ram_size = 0x80000000; - -#ifdef CONFIG_PHYS_64BIT - /* Bank 1 declares the memory available in the DDR high region */ - gd->bd->bi_dram[1].start = 0x880000000; - gd->bd->bi_dram[1].size = 0x80000000; - gd->ram_size = 0x100000000; -#endif - - return 0; -} - #ifdef CONFIG_SPL_LOAD_FIT int board_fit_config_name_match(const char *name) { diff --git a/board/ti/common/Makefile b/board/ti/common/Makefile index 5ac361ba7fcf..caf6b9fa8c14 100644 --- a/board/ti/common/Makefile +++ b/board/ti/common/Makefile @@ -4,3 +4,4 @@ obj-${CONFIG_TI_I2C_BOARD_DETECT} += board_detect.o obj-${CONFIG_CMD_EXTENSION} += cape_detect.o obj-${CONFIG_OF_LIBFDT} += fdt_ops.o +obj-${CONFIG_ARCH_K3} += k3-ddr.o diff --git a/board/ti/common/k3-ddr.c b/board/ti/common/k3-ddr.c new file mode 100644 index 000000000000..a8425da8de5c --- /dev/null +++ b/board/ti/common/k3-ddr.c @@ -0,0 +1,33 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2024, Texas Instruments Incorporated - https://www.ti.com/ + */ + +#include <fdt_support.h> +#include <dm/uclass.h> +#include <k3-ddrss.h> +#include <spl.h> + +#include "k3-ddr.h" + +int dram_init(void) +{ + s32 ret; + + ret = fdtdec_setup_mem_size_base_lowest(); + if (ret) + printf("Error setting up mem size and base. %d\n", ret); + + return ret; +} + +int dram_init_banksize(void) +{ + s32 ret; + + ret = fdtdec_setup_memory_banksize(); + if (ret) + printf("Error setting up memory banksize. %d\n", ret); + + return ret; +} diff --git a/board/ti/common/k3-ddr.h b/board/ti/common/k3-ddr.h new file mode 100644 index 000000000000..737d45e2e509 --- /dev/null +++ b/board/ti/common/k3-ddr.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2024, Texas Instruments Incorporated - https://www.ti.com/ + */ + +#ifndef __K3_DDR_INIT_H +#define __K3_DDR_INIT_H + +int dram_init(void); +int dram_init_banksize(void); + +#endif /* __K3_DDR_INIT_H */ diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index 6221be9dcff8..4b5b9dded7b0 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -15,6 +15,7 @@ #include <asm/gpio.h> #include <spl.h> #include <dm.h> +#include <asm/arch/k3-ddr.h>
#include "../common/board_detect.h" #include "../common/fdt_ops.h" @@ -77,17 +78,6 @@ int board_init(void) return 0; }
-int dram_init(void) -{ -#ifdef CONFIG_PHYS_64BIT - gd->ram_size = 0x100000000; -#else - gd->ram_size = 0x80000000; -#endif - - return 0; -} - phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { #ifdef CONFIG_PHYS_64BIT @@ -99,23 +89,6 @@ phys_addr_t board_get_usable_ram_top(phys_size_t total_size) return gd->ram_top; }
-int dram_init_banksize(void) -{ - /* Bank 0 declares the memory available in the DDR low region */ - gd->bd->bi_dram[0].start = 0x80000000; - gd->bd->bi_dram[0].size = 0x80000000; - gd->ram_size = 0x80000000; - -#ifdef CONFIG_PHYS_64BIT - /* Bank 1 declares the memory available in the DDR high region */ - gd->bd->bi_dram[1].start = 0x880000000; - gd->bd->bi_dram[1].size = 0x80000000; - gd->ram_size = 0x100000000; -#endif - - return 0; -} - #ifdef CONFIG_SPL_LOAD_FIT int board_fit_config_name_match(const char *name) { diff --git a/board/ti/j721s2/evm.c b/board/ti/j721s2/evm.c index 2cfeb3bec6c2..1b5ad19df7f4 100644 --- a/board/ti/j721s2/evm.c +++ b/board/ti/j721s2/evm.c @@ -21,6 +21,7 @@ #include <dm.h> #include <dm/uclass-internal.h> #include <dm/root.h> +#include <asm/arch/k3-ddr.h>
#include "../common/board_detect.h" #include "../common/fdt_ops.h" @@ -32,17 +33,6 @@ int board_init(void) return 0; }
-int dram_init(void) -{ -#ifdef CONFIG_PHYS_64BIT - gd->ram_size = 0x100000000; -#else - gd->ram_size = 0x80000000; -#endif - - return 0; -} - phys_addr_t board_get_usable_ram_top(phys_size_t total_size) { #ifdef CONFIG_PHYS_64BIT @@ -54,22 +44,17 @@ phys_addr_t board_get_usable_ram_top(phys_size_t total_size) return gd->ram_top; }
-int dram_init_banksize(void) +#if defined(CONFIG_XPL_BUILD) +void spl_perform_fixups(struct spl_image_info *spl_image) { - /* Bank 0 declares the memory available in the DDR low region */ - gd->bd->bi_dram[0].start = 0x80000000; - gd->bd->bi_dram[0].size = 0x7fffffff; - gd->ram_size = 0x80000000; - -#ifdef CONFIG_PHYS_64BIT - /* Bank 1 declares the memory available in the DDR high region */ - gd->bd->bi_dram[1].start = 0x880000000; - gd->bd->bi_dram[1].size = 0x37fffffff; - gd->ram_size = 0x400000000; -#endif - - return 0; + if (IS_ENABLED(CONFIG_K3_DDRSS)) { + if (IS_ENABLED(CONFIG_K3_INLINE_ECC)) + fixup_ddr_driver_for_ecc(spl_image); + } else { + fixup_memory_node(spl_image); + } } +#endif
#ifdef CONFIG_TI_I2C_BOARD_DETECT /* diff --git a/board/ti/j784s4/evm.c b/board/ti/j784s4/evm.c index 548dbd5925df..d317f3eccbba 100644 --- a/board/ti/j784s4/evm.c +++ b/board/ti/j784s4/evm.c @@ -10,6 +10,7 @@ #include <efi_loader.h> #include <init.h> #include <spl.h> +#include <asm/arch/k3-ddr.h> #include "../common/fdt_ops.h"
DECLARE_GLOBAL_DATA_PTR; @@ -52,15 +53,17 @@ int board_init(void) return 0; }
- Copyright (C) 2024, Texas Instruments Incorporated - https://www.ti.com/
- int ret, ctr = 1;
- if (ret)
- if (ret)
- ret = uclass_next_device_err(&dev);
- while (ret && ret != -ENODEV) {
if (ret)
ctr++;
- int bank;
- int ret;
- dram_init();
- if (ret)
- if (IS_ENABLED(CONFIG_K3_DDRSS)) {
- } else {
- } else {
- int ret;
- if (ret)
- if (ret)
- int bank;
- int ret;
- dram_init();
- if (ret)
-} -#endif
-#else
-#endif
- } else {
- } } #endif
- s32 ret;
- if (ret)
- return ret;
- s32 ret;
- if (ret)
- return ret;
- int ret;
- if (ret)
- if (ret)
- int bank;
- int ret;
- dram_init();
- if (ret)
-} -#endif
-#else
-#endif
} else {
-#else
-#endif
-#endif
- s32 ret;
- ret = fdtdec_setup_mem_size_base_lowest();
- if (ret)
- return ret;
- s32 ret;
- if (ret)
- return ret;
-#else
-#endif
-#endif
-#else
-#endif
-#endif
- } else {
- } else {
This causes a failure to build on current next on j722s_evm_a53 so please rebase and repost, thanks.
Hi, Tom,
Sure, thanks for pointing out.
Regards, Santhosh.
Hi Santhosh,
Hello,
This series is to:
Changes since v4:
- Make dram_init and dram_init_banksize weak at mach-k3/ and define at board/ti/
- Remove 'ti,ecc-enable' flag
- Minor changes like patch order change (8/8 in v4 to 1/9 in v5), use 'u64'
Tested on a phycore-am62x with a 1 and 2 GB variant, so you can have my
Tested-by: Wadim Egorov w.egorov@phytec.de
for this series.
Santhosh Kumar K
Wadim Egorov
