[U-Boot] [u-boot][PATCH][2/2] i2c_mxc: Add I2C support for i.MX27 chip processor.
Add support for I2C in i.MX27 chip.
Tested on imx27_visstrim_m10 board.
Signed-off-by: Javier Martin javier.martin@vista-silicon.com -- diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index 8e10fbb..63a8085 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -2,6 +2,8 @@ * i2c driver for Freescale mx31 * * (c) 2007 Pengutronix, Sascha Hauer s.hauer@pengutronix.de + * (c) 2009 Vista Silicon, Javier Martin + * javier.martin@vista-silicon.com * * See file CREDITS for list of people who contributed to this * project. @@ -21,13 +23,19 @@ * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA */ - #include <common.h>
#if defined(CONFIG_HARD_I2C)
+#ifdef CONFIG_MX31 #include <asm/arch/mx31.h> #include <asm/arch/mx31-regs.h> +#elif defined (CONFIG_MX27) +#include <asm/arch/imx-regs.h> +#include <asm/arch/asm-offsets.h> +#else +#error "architecture not supported by mxc_i2c driver" +#endif
#define IADR 0x00 #define IFDR 0x04 @@ -47,6 +55,7 @@ #define I2SR_IIF (1 << 1) #define I2SR_RX_NO_AK (1 << 0)
+#ifdef CONFIG_MX31 #ifdef CONFIG_SYS_I2C_MX31_PORT1 #define I2C_BASE 0x43f80000 #define I2C_CLK_OFFSET 26 @@ -59,6 +68,18 @@ #else #error "define CONFIG_SYS_I2C_MX31_PORTx to use the mx31 I2C driver" #endif +#endif /* CONFIG_MX31 */ + +#ifdef CONFIG_MX27 +#ifdef CONFIG_SYS_I2C_MX27_PORT1 +#define I2C_BASE IMX_I2C1_BASE +#elif defined (CONFIG_SYS_I2C_MX27_PORT2) +#define I2C_BASE IMX_I2C2_BASE +#else +#error "define CONFIG_SYS_I2C_MX27_PORTx to use the mx27 I2C driver" +#endif +#endif /* CONFIG_MX27 */ +
#ifdef DEBUG #define DPRINTF(args...) printf(args) @@ -70,17 +91,37 @@ static u16 div[] = { 30, 32, 36, 42, 48, 52, 60, 72, 80, 88, 104, 128, 144, 160, 192, 240, 288, 320, 384, 480, 576, 640, 768, 960, 1152, 1280, 1536, 1920, 2304, 2560, 3072, 3840};
+static void i2c_clken(void) +{ +#ifdef CONFIG_MX31 + __REG(CCM_CGR0) = __REG(CCM_CGR0) | (3 << I2C_CLK_OFFSET); +#elif defined(CONFIG_MX27) +#ifdef CONFIG_SYS_I2C_MX27_PORT1 + __REG(PCCR0) = __REG(PCCR0) | PCCR0_I2C1_EN; +#else + __REG(PCCR0) = __REG(PCCR0) | PCCR0_I2C2_EN; +#endif +#endif /* CONFIG_MX31 */ +} + void i2c_init(int speed, int unused) { - int freq = mx31_get_ipg_clk(); + int freq; int i;
+#ifdef CONFIG_MX31 + freq = mx31_get_ipg_clk(); +#elif defined(CONFIG_MX27) + freq = imx_get_ipgclk(); +#endif /* start the required I2C clock */ - __REG(CCM_CGR0) = __REG(CCM_CGR0) | (3 << I2C_CLK_OFFSET); + i2c_clken();
+ DPRINTF("ipg_freq is %d\n", freq); for (i = 0; i < 0x1f; i++) if (freq / div[i] <= speed) break; + DPRINTF("i2c_clk divisor is %d\n", div[i]);
DPRINTF("%s: speed: %d\n",__FUNCTION__, speed);
@@ -121,7 +162,6 @@ static int rx_byte(void) int i2c_probe(uchar chip) { int ret; - __REG16(I2C_BASE + I2CR) = 0; /* Reset module */ __REG16(I2C_BASE + I2CR) = I2CR_IEN; -- Javier Martin Vista Silicon S.L. CDTUC - FASE C - Oficina S-345 Avda de los Castros s/n 39005- Santander. Cantabria. Spain +34 942 25 32 60 www.vista-silicon.com
Javier Martin
