[U-Boot] [PATCH 1/2] ls1088ardb: Add SCSI related configs in header file for RDB
Signed-off-by: Amrita Kumari amrita.kumari@nxp.com Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com --- v1: Rebased to ba39608 ARM: DRA72x: Add support for detection of DRA71x SR 2.1
Depends upon: http://patchwork.ozlabs.org/project/uboot/list/?series=2826
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 1 + include/configs/ls1088ardb.h | 11 +++++++++++ 2 files changed, 12 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 3518d86..d78e143 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -83,6 +83,7 @@ config ARCH_LS1088A select FSL_TZASC_1 select ARCH_EARLY_INIT_R select BOARD_EARLY_INIT_F + imply SCSI
config ARCH_LS2080A bool diff --git a/include/configs/ls1088ardb.h b/include/configs/ls1088ardb.h index 47ee527..6c7a2fe 100644 --- a/include/configs/ls1088ardb.h +++ b/include/configs/ls1088ardb.h @@ -301,6 +301,17 @@ #define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 2
+/* SATA */ +#define CONFIG_LIBATA +#define CONFIG_SCSI_AHCI +#define CONFIG_SCSI_AHCI_PLAT +#define CONFIG_SYS_SATA1 AHCI_BASE_ADDR1 + +#define CONFIG_SYS_SCSI_MAX_SCSI_ID 1 +#define CONFIG_SYS_SCSI_MAX_LUN 1 +#define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ + CONFIG_SYS_SCSI_MAX_LUN) + /* MMC */ #ifdef CONFIG_MMC #define CONFIG_FSL_ESDHC
include/configs/ls1088aqds.h | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/include/configs/ls1088aqds.h b/include/configs/ls1088aqds.h index c57e1f5..0af3ac4 100644 --- a/include/configs/ls1088aqds.h +++ b/include/configs/ls1088aqds.h @@ -368,6 +368,17 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_USB_XHCI_FSL #define CONFIG_USB_MAX_CONTROLLER_COUNT 2
+/* SATA */ +#define CONFIG_LIBATA +#define CONFIG_SCSI_AHCI +#define CONFIG_SCSI_AHCI_PLAT +#define CONFIG_SYS_SATA1 AHCI_BASE_ADDR1 + +#define CONFIG_SYS_SCSI_MAX_SCSI_ID 1 +#define CONFIG_SYS_SCSI_MAX_LUN 1 +#define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ + CONFIG_SYS_SCSI_MAX_LUN) + #ifdef CONFIG_FSL_MC_ENET #define CONFIG_FSL_MEMAC #define CONFIG_PHYLIB
Ashish Kumar
