[PATCH v3 0/8] migrate u-boot-rockchip.bin to binman and generate an image for SPI
From: Quentin Schulz quentin.schulz@theobroma-systems.com
This migrates the generation of u-boot-rockchip.bin from Makefile to binman completely.
This also adds support for generating the same kind of image than u-boot-rockchip.bin but for SPI flashes (specifically, a different image type generated by mkimage is necessary, in addition to a different offset in the storage medium).
This has been tested on Puma RK3399 with patch series from https://lore.kernel.org/u-boot/20220722160655.3904213-1-foss+uboot@0leil.net... (plus https://lore.kernel.org/u-boot/20220722113505.3875669-4-foss+uboot@0leil.net...).
Cheers, Quentin
v3: - removed https://lore.kernel.org/u-boot/20220722113505.3875669-4-foss+uboot@0leil.net..., it'll be added later on in a separate patch series, - added "binman: allow user-defined filenames for mkimage entry," - kept idbloader.img binary creation even with binman as requested by community, - generate idbloader-spi.img binary with binman, - added "rockchip: remove binman temporary files when cleaning"
v2: - removed patch 4/8 rockchip: pad u-boot-rockchip.bin correctly because it would break partitions table, - rebased on top of master, changes to patch 3/7 rockchip: remove unneeded CONFIG_SPL_PAD_TO compared to the RFC 3/8 rockchip: remove unneeded CONFIG_SPL_PAD_TO,
Quentin Schulz (8): binman: add support for skipping file concatenation for mkimage binman: allow user-defined filenames for mkimage entry rockchip: remove binman temporary files when cleaning rockchip: generate idbloader.img content for u-boot-rockchip.bin with binman for ARM rockchip: generate u-boot-rockchip.bin with binman for ARM64 boards rockchip: simplify binman image dependencies addition to INPUTS rockchip: allow to build SPI images even without HAS_ROM option rockchip: add u-boot-rockchip-spi.bin image for booting from SPI-NOR flash
Makefile | 41 +++++--------------------- arch/arm/Kconfig | 2 +- arch/arm/dts/rk3288-u-boot.dtsi | 2 +- arch/arm/dts/rk3399-u-boot.dtsi | 2 +- arch/arm/dts/rockchip-u-boot.dtsi | 46 ++++++++++++++++++++++++++++- arch/arm/mach-rockchip/Kconfig | 6 ++-- tools/binman/entries.rst | 22 ++++++++++++++ tools/binman/etype/mkimage.py | 48 +++++++++++++++++++++++++++---- 8 files changed, 121 insertions(+), 48 deletions(-)
Some image types handled by mkimage require the datafiles to be passed independently (-d data1:data2) for specific handling of each. A concatenation of datafiles prior to passing them to mkimage wouldn't work.
That is the case for rkspi for example which requires page alignment and only writing 2KB every 4KB.
This adds the ability to tell binman to pass the datafiles without prior concatenation to mkimage, by adding the multiple-data-files boolean property to the mkimage node.
Cc: Quentin Schulz foss+uboot@0leil.net Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- tools/binman/entries.rst | 22 +++++++++++++++++++ tools/binman/etype/mkimage.py | 41 +++++++++++++++++++++++++++++++---- 2 files changed, 59 insertions(+), 4 deletions(-)
diff --git a/tools/binman/entries.rst b/tools/binman/entries.rst index ae4305c99e..60c89aec59 100644 --- a/tools/binman/entries.rst +++ b/tools/binman/entries.rst @@ -1101,6 +1101,9 @@ Entry: mkimage: Binary produced by mkimage
Properties / Entry arguments: - datafile: Filename for -d argument + - multiple-data-files: boolean to tell binman to pass all files as + datafiles to mkimage instead of creating a temporary file the result + of datafiles concatenation - args: Other arguments to pass
The data passed to mkimage is collected from subnodes of the mkimage node, @@ -1117,6 +1120,25 @@ This calls mkimage to create an imximage with u-boot-spl.bin as the input file. The output from mkimage then becomes part of the image produced by binman.
+To pass all datafiles untouched to mkimage:: + + mkimage { + args = "-n rk3399 -T rkspi"; + multiple-data-files; + + u-boot-tpl { + }; + + u-boot-spl { + }; + }; + +This calls mkimage to create a Rockchip RK3399-specific first stage +bootloader, made of TPL+SPL. Since this first stage bootloader requires to +align the TPL and SPL but also some weird hacks that is handled by mkimage +directly, binman is told to not perform the concatenation of datafiles prior +to passing the data to mkimage. + To use CONFIG options in the arguments, use a string list instead, as in this example which also produces four arguments::
diff --git a/tools/binman/etype/mkimage.py b/tools/binman/etype/mkimage.py index 5f6def2287..52297c23ea 100644 --- a/tools/binman/etype/mkimage.py +++ b/tools/binman/etype/mkimage.py @@ -16,6 +16,9 @@ class Entry_mkimage(Entry):
The data passed to mkimage is collected from subnodes of the mkimage node, @@ -32,6 +35,25 @@ class Entry_mkimage(Entry): file. The output from mkimage then becomes part of the image produced by binman.
+ To pass all datafiles untouched to mkimage:: + + mkimage { + args = "-n rk3399 -T rkspi"; + multiple-data-files; + + u-boot-tpl { + }; + + u-boot-spl { + }; + }; + + This calls mkimage to create a Rockchip RK3399-specific first stage + bootloader, made of TPL+SPL. Since this first stage bootloader requires to + align the TPL and SPL but also some weird hacks that is handled by mkimage + directly, binman is told to not perform the concatenation of datafiles prior + to passing the data to mkimage. + To use CONFIG options in the arguments, use a string list instead, as in this example which also produces four arguments::
@@ -46,16 +68,27 @@ class Entry_mkimage(Entry): def __init__(self, section, etype, node): super().__init__(section, etype, node) self._args = fdt_util.GetArgs(self._node, 'args') + self._multiple_data_files = fdt_util.GetBool(self._node, 'multiple-data-files') self._mkimage_entries = OrderedDict() self.align_default = None self.ReadEntries()
def ObtainContents(self): # Use a non-zero size for any fake files to keep mkimage happy - data, input_fname, uniq = self.collect_contents_to_file( - self._mkimage_entries.values(), 'mkimage', 1024) - if data is None: - return False + fake_size = 1024 + if self._multiple_data_files: + fnames = [] + uniq = self.GetUniqueName() + for entry in self._mkimage_entries.values(): + if not entry.ObtainContents(fake_size=fake_size): + return False + fnames.append(entry.GetDefaultFilename()) + input_fname = ":".join(fnames) + else: + data, input_fname, uniq = self.collect_contents_to_file( + self._mkimage_entries.values(), 'mkimage', fake_size) + if data is None: + return False output_fname = tools.get_output_filename('mkimage-out.%s' % uniq) if self.mkimage.run_cmd('-d', input_fname, *self._args, output_fname) is not None:
mkimage entry currently creates a file whose name is derived from the section name containing said entry.
Let's allow the user to define a filename for the mkimage-generated binary by using the 'filename' DT property.
Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com ---
added in v3
tools/binman/etype/mkimage.py | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/tools/binman/etype/mkimage.py b/tools/binman/etype/mkimage.py index 52297c23ea..902c254425 100644 --- a/tools/binman/etype/mkimage.py +++ b/tools/binman/etype/mkimage.py @@ -20,11 +20,13 @@ class Entry_mkimage(Entry): datafiles to mkimage instead of creating a temporary file the result of datafiles concatenation - args: Other arguments to pass + - filename: filename of output binary generated by mkimage
The data passed to mkimage is collected from subnodes of the mkimage node, e.g.::
mkimage { + filename = "imximage.bin"; args = "-n test -T imximage";
u-boot-spl { @@ -33,7 +35,7 @@ class Entry_mkimage(Entry):
This calls mkimage to create an imximage with u-boot-spl.bin as the input file. The output from mkimage then becomes part of the image produced by - binman. + binman but also is written into imximage.bin file.
@@ -70,6 +72,7 @@ class Entry_mkimage(Entry): self._args = fdt_util.GetArgs(self._node, 'args') self._multiple_data_files = fdt_util.GetBool(self._node, 'multiple-data-files') self._mkimage_entries = OrderedDict() + self._filename = fdt_util.GetString(self._node, 'filename') self.align_default = None self.ReadEntries()
@@ -89,7 +92,7 @@ class Entry_mkimage(Entry): self._mkimage_entries.values(), 'mkimage', fake_size) if data is None: return False - output_fname = tools.get_output_filename('mkimage-out.%s' % uniq) + output_fname = tools.get_output_filename(self._filename if self._filename else 'mkimage-out.%s' % uniq) if self.mkimage.run_cmd('-d', input_fname, *self._args, output_fname) is not None: self.SetContents(tools.read_file(output_fname))
Hi Quentin,
added in v3
This does need a test (should be able to update the mkimage one).
mkimage {
filename = "imximage.bin"; args = "-n test -T imximage"; u-boot-spl {
- binman.
Check <80cols?
-- 2.37.1
Regards, SImon
Binman mkimage entry generates temporary files so let's remove them when calling `make clean`.
Fixes: 9b312e26fc77 ("rockchip: Enable building a SPI ROM image on jerry") Cc: Quentin Schulz foss+uboot@0leil.net Reported-by: Johan Jonker jbx6244@gmail.com Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com ---
added in v3
Makefile | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index ff25f92974..bbb2a4c088 100644 --- a/Makefile +++ b/Makefile @@ -2220,7 +2220,8 @@ CLEAN_FILES += include/bmp_logo.h include/bmp_logo_data.h \ lpc32xx-* bl31.c bl31.elf bl31_*.bin image.map tispl.bin* \ idbloader.img flash.bin flash.log defconfig keep-syms-lto.c \ mkimage-out.spl.mkimage mkimage.spl.mkimage imx-boot.map \ - itb.fit.fit itb.fit.itb itb.map spl.map + itb.fit.fit itb.fit.itb itb.map spl.map mkimage-out.rom.mkimage \ + mkimage.rom.mkimage rom.map simple-bin.map
# Directories & files removed with 'make mrproper' MRPROPER_DIRS += include/config include/generated spl tpl \
Hi Quentin,
Beside removing the "real" annoyance is that these files popup when adding with "git add ." and are blocking branch changing with "git branch ...". Maybe add to ".gitignore" as well or delete immediately. What's the use to keep them around?
Johan
added in v3
Hi Johan,
On Mon, 1 Aug 2022 at 12:59, Johan Jonker jbx6244@gmail.com wrote:
Hi Quentin,
At this point I have to remind people to consider moving to out-of-tree builds (make O=...)
idbloader.img content - currently created by way of Makefile - can be created by binman directly.
So let's do that for Rockchip ARM platforms.
v3: - moved spl back into mkimage section, - added filename property so that the idbloader.img binary is still generated,
Makefile | 2 +- arch/arm/dts/rockchip-u-boot.dtsi | 11 ++++++++++- 2 files changed, 11 insertions(+), 2 deletions(-)
diff --git a/Makefile b/Makefile index bbb2a4c088..ceb5b5e0d9 100644 --- a/Makefile +++ b/Makefile @@ -1005,7 +1005,7 @@ endif else ifeq ($(CONFIG_SPL),y) # Generate these inputs for binman which will create the output files -INPUTS-y += idbloader.img u-boot.img +INPUTS-y += u-boot.img endif endif endif diff --git a/arch/arm/dts/rockchip-u-boot.dtsi b/arch/arm/dts/rockchip-u-boot.dtsi index eae3ee715d..ad72ca9700 100644 --- a/arch/arm/dts/rockchip-u-boot.dtsi +++ b/arch/arm/dts/rockchip-u-boot.dtsi @@ -17,8 +17,17 @@ filename = "u-boot-rockchip.bin"; pad-byte = <0xff>;
- blob { + mkimage { filename = "idbloader.img"; + args = "-n", CONFIG_SYS_SOC, "-T", "rksd"; +#ifdef CONFIG_TPL + multiple-data-files; + + u-boot-tpl { + }; +#endif + u-boot-spl { + }; };
u-boot-img {
v3:
generated,
This allows to build u-boot-rockchip.bin binary with binman for Rockchip ARM64 boards instead of the legacy Makefile way.
Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- Makefile | 26 +------------------------- arch/arm/Kconfig | 2 +- arch/arm/dts/rockchip-u-boot.dtsi | 5 +++++ 3 files changed, 7 insertions(+), 26 deletions(-)
diff --git a/Makefile b/Makefile index ceb5b5e0d9..f8e919e136 100644 --- a/Makefile +++ b/Makefile @@ -999,8 +999,7 @@ ifeq ($(CONFIG_ARCH_ROCKCHIP),y) # On ARM64 this target is produced by binman so we don't need this dep ifeq ($(CONFIG_ARM64),y) ifeq ($(CONFIG_SPL),y) -# TODO: Get binman to generate this too -INPUTS-y += u-boot-rockchip.bin +INPUTS-y += u-boot.itb endif else ifeq ($(CONFIG_SPL),y) @@ -1493,29 +1492,6 @@ OBJCOPYFLAGS_u-boot-with-spl.bin = -I binary -O binary \ u-boot-with-spl.bin: $(SPL_IMAGE) $(SPL_PAYLOAD) FORCE $(call if_changed,pad_cat)
-ifeq ($(CONFIG_ARCH_ROCKCHIP),y) - -# TPL + SPL -ifeq ($(CONFIG_SPL)$(CONFIG_TPL),yy) -MKIMAGEFLAGS_u-boot-tpl-rockchip.bin = -n $(CONFIG_SYS_SOC) -T rksd -tpl/u-boot-tpl-rockchip.bin: tpl/u-boot-tpl.bin FORCE - $(call if_changed,mkimage) -idbloader.img: tpl/u-boot-tpl-rockchip.bin spl/u-boot-spl.bin FORCE - $(call if_changed,cat) -else -MKIMAGEFLAGS_idbloader.img = -n $(CONFIG_SYS_SOC) -T rksd -idbloader.img: spl/u-boot-spl.bin FORCE - $(call if_changed,mkimage) -endif - -ifeq ($(CONFIG_ARM64),y) -OBJCOPYFLAGS_u-boot-rockchip.bin = -I binary -O binary \ - --pad-to=$(CONFIG_SPL_PAD_TO) --gap-fill=0xff -u-boot-rockchip.bin: idbloader.img u-boot.itb FORCE - $(call if_changed,pad_cat) -endif # CONFIG_ARM64 - -endif # CONFIG_ARCH_ROCKCHIP
ifeq ($(CONFIG_ARCH_LPC32XX)$(CONFIG_SPL),yy) MKIMAGEFLAGS_lpc32xx-spl.img = -T lpc32xximage -a $(CONFIG_SPL_TEXT_BASE) diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 949ebb46ba..c973146f8d 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1974,7 +1974,7 @@ config ARCH_STM32MP config ARCH_ROCKCHIP bool "Support Rockchip SoCs" select BLK - select BINMAN if SPL_OPTEE || (SPL && !ARM64) + select BINMAN if SPL_OPTEE || SPL select DM select DM_GPIO select DM_I2C diff --git a/arch/arm/dts/rockchip-u-boot.dtsi b/arch/arm/dts/rockchip-u-boot.dtsi index ad72ca9700..f90a8bf085 100644 --- a/arch/arm/dts/rockchip-u-boot.dtsi +++ b/arch/arm/dts/rockchip-u-boot.dtsi @@ -30,7 +30,12 @@ }; };
+#ifdef CONFIG_ARM64 + blob { + filename = "u-boot.itb"; +#else u-boot-img { +#endif offset = <CONFIG_SPL_PAD_TO>; }; };
Nice!
By factoring SPL check in the first condition, this makes the checks a bit less convoluted and more readable.
Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- Makefile | 9 ++------- 1 file changed, 2 insertions(+), 7 deletions(-)
diff --git a/Makefile b/Makefile index f8e919e136..640d4b8f65 100644 --- a/Makefile +++ b/Makefile @@ -995,19 +995,14 @@ ifeq ($(CONFIG_MPC85xx)$(CONFIG_OF_SEPARATE),yy) INPUTS-y += u-boot-with-dtb.bin endif
-ifeq ($(CONFIG_ARCH_ROCKCHIP),y) -# On ARM64 this target is produced by binman so we don't need this dep +ifeq ($(CONFIG_ARCH_ROCKCHIP)$(CONFIG_SPL),yy) +# Binman image dependencies ifeq ($(CONFIG_ARM64),y) -ifeq ($(CONFIG_SPL),y) INPUTS-y += u-boot.itb endif else -ifeq ($(CONFIG_SPL),y) -# Generate these inputs for binman which will create the output files INPUTS-y += u-boot.img endif -endif -endif
INPUTS-$(CONFIG_X86) += u-boot-x86-start16.bin u-boot-x86-reset16.bin \ $(if $(CONFIG_SPL_X86_16BIT_INIT),spl/u-boot-spl.bin) \
HI all,
This one should be moved....
....down here to keep the same behavior. Will update for v4.
Cheers, Quentin
This prepares for the creation of a u-boot-rockchip-spi.bin image similar to u-boot-rockchip.bin to the exception it's destined for SPI-NOR flashes instead of MMC storage medium.
Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- arch/arm/dts/rk3288-u-boot.dtsi | 2 +- arch/arm/dts/rk3399-u-boot.dtsi | 2 +- arch/arm/mach-rockchip/Kconfig | 6 ++---- 3 files changed, 4 insertions(+), 6 deletions(-)
diff --git a/arch/arm/dts/rk3288-u-boot.dtsi b/arch/arm/dts/rk3288-u-boot.dtsi index 9eb696b141..e411445ed6 100644 --- a/arch/arm/dts/rk3288-u-boot.dtsi +++ b/arch/arm/dts/rk3288-u-boot.dtsi @@ -56,7 +56,7 @@ }; };
-#ifdef CONFIG_ROCKCHIP_SPI_IMAGE +#if defined(CONFIG_ROCKCHIP_SPI_IMAGE) && defined(CONFIG_HAS_ROM) &binman { rom { filename = "u-boot.rom"; diff --git a/arch/arm/dts/rk3399-u-boot.dtsi b/arch/arm/dts/rk3399-u-boot.dtsi index 716b9a433a..3c1a15fe51 100644 --- a/arch/arm/dts/rk3399-u-boot.dtsi +++ b/arch/arm/dts/rk3399-u-boot.dtsi @@ -60,7 +60,7 @@
-#ifdef CONFIG_ROCKCHIP_SPI_IMAGE +#if defined(CONFIG_ROCKCHIP_SPI_IMAGE) && defined(CONFIG_HAS_ROM) &binman { rom { filename = "u-boot.rom"; diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index c561a77e6a..b46cea2f91 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -425,12 +425,10 @@ config SPL_MMC
config ROCKCHIP_SPI_IMAGE bool "Build a SPI image for rockchip" - depends on HAS_ROM help Some Rockchip SoCs support booting from SPI flash. Enable this - option to produce a 4MB SPI-flash image (called u-boot.rom) - containing U-Boot. The image is built by binman. U-Boot sits near - the start of the image. + option to produce a SPI-flash image containing U-Boot. The image + is built by binman. U-Boot sits near the start of the image.
config LNX_KRNL_IMG_TEXT_OFFSET_BASE default SYS_TEXT_BASE
This new image is similar to u-boot-rockchip.bin except that it's destined to be flashed on SPI-NOR flashes.
v3: - added filename property so that idblaoder-spi.img binary is generated by binman, as per community request, - added new temporary files to the list of files to clean up on `make clean`,
Makefile | 3 ++- arch/arm/dts/rockchip-u-boot.dtsi | 30 ++++++++++++++++++++++++++++++ 2 files changed, 32 insertions(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index 640d4b8f65..6979dfb28d 100644 --- a/Makefile +++ b/Makefile @@ -2192,7 +2192,8 @@ CLEAN_FILES += include/bmp_logo.h include/bmp_logo_data.h \ idbloader.img flash.bin flash.log defconfig keep-syms-lto.c \ mkimage-out.spl.mkimage mkimage.spl.mkimage imx-boot.map \ itb.fit.fit itb.fit.itb itb.map spl.map mkimage-out.rom.mkimage \ - mkimage.rom.mkimage rom.map simple-bin.map + mkimage.rom.mkimage rom.map simple-bin.map simple-bin-spi.map \ + idbloader-spi.img
# Directories & files removed with 'make mrproper' MRPROPER_DIRS += include/config include/generated spl tpl \ diff --git a/arch/arm/dts/rockchip-u-boot.dtsi b/arch/arm/dts/rockchip-u-boot.dtsi index f90a8bf085..584f21eb5b 100644 --- a/arch/arm/dts/rockchip-u-boot.dtsi +++ b/arch/arm/dts/rockchip-u-boot.dtsi @@ -39,5 +39,35 @@ offset = <CONFIG_SPL_PAD_TO>; }; }; + +#ifdef CONFIG_ROCKCHIP_SPI_IMAGE + simple-bin-spi { + filename = "u-boot-rockchip-spi.bin"; + pad-byte = <0xff>; + + mkimage { + filename = "idbloader-spi.img"; + args = "-n", CONFIG_SYS_SOC, "-T", "rkspi"; +#ifdef CONFIG_TPL + multiple-data-files; + + u-boot-tpl { + }; +#endif + u-boot-spl { + }; + }; + +#ifdef CONFIG_ARM64 + blob { + filename = "u-boot.itb"; +#else + u-boot-img { +#endif + /* Sync with u-boot,spl-payload-offset if present */ + offset = <CONFIG_SYS_SPI_U_BOOT_OFFS>; + }; + }; +#endif }; #endif
Johan Jonker
Quentin Schulz
Quentin Schulz
