[U-Boot] [PATCH V2 1/3] test: dm: adc: use the real device name
"adc" is not the real device name, "adc@0" is.
Signed-off-by: Peng Fan peng.fan@nxp.com ---
V2: new
test/dm/adc.c | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/test/dm/adc.c b/test/dm/adc.c index 1f82304f41..da7bd4bf1f 100644 --- a/test/dm/adc.c +++ b/test/dm/adc.c @@ -24,7 +24,7 @@ static int dm_test_adc_bind(struct unit_test_state *uts) struct udevice *dev; unsigned int channel_mask;
- ut_assertok(uclass_get_device_by_name(UCLASS_ADC, "adc", &dev)); + ut_assertok(uclass_get_device_by_name(UCLASS_ADC, "adc@0", &dev)); ut_asserteq_str(SANDBOX_ADC_DEVNAME, dev->name);
ut_assertok(adc_channel_mask(dev, &channel_mask)); @@ -38,7 +38,7 @@ static int dm_test_adc_wrong_channel_selection(struct unit_test_state *uts) { struct udevice *dev;
- ut_assertok(uclass_get_device_by_name(UCLASS_ADC, "adc", &dev)); + ut_assertok(uclass_get_device_by_name(UCLASS_ADC, "adc@0", &dev)); ut_asserteq(-EINVAL, adc_start_channel(dev, SANDBOX_ADC_CHANNELS));
return 0; @@ -51,7 +51,7 @@ static int dm_test_adc_supply(struct unit_test_state *uts) struct udevice *dev; int uV;
/* Test Vss value - predefined 0 uV */ ut_assertok(adc_vss_value(dev, &uV)); @@ -94,7 +94,7 @@ static int dm_test_adc_single_channel_conversion(struct unit_test_state *uts) unsigned int i, data; struct udevice *dev;
- ut_assertok(uclass_get_device_by_name(UCLASS_ADC, "adc", &dev)); + ut_assertok(uclass_get_device_by_name(UCLASS_ADC, "adc@0", &dev)); /* Test each ADC channel's value */ for (i = 0; i < SANDBOX_ADC_CHANNELS; i++, tdata++) { ut_assertok(adc_start_channel(dev, tdata->id)); @@ -117,7 +117,7 @@ static int dm_test_adc_multi_channel_conversion(struct unit_test_state *uts) ADC_CHANNEL(2) | ADC_CHANNEL(3);
/* Start multi channel conversion */ - ut_assertok(uclass_get_device_by_name(UCLASS_ADC, "adc", &dev)); + ut_assertok(uclass_get_device_by_name(UCLASS_ADC, "adc@0", &dev)); ut_assertok(adc_start_channels(dev, channel_mask)); ut_assertok(adc_channels_data(dev, channel_mask, channels));
@@ -136,7 +136,7 @@ static int dm_test_adc_single_channel_shot(struct unit_test_state *uts)
for (i = 0; i < SANDBOX_ADC_CHANNELS; i++, tdata++) { /* Start single channel conversion */ - ut_assertok(adc_channel_single_shot("adc", tdata->id, &data)); + ut_assertok(adc_channel_single_shot("adc@0", tdata->id, &data)); /* Compare the expected and returned conversion data. */ ut_asserteq(tdata->data, data); } @@ -155,7 +155,7 @@ static int dm_test_adc_multi_channel_shot(struct unit_test_state *uts) ADC_CHANNEL(2) | ADC_CHANNEL(3);
/* Start single call and multi channel conversion */ - ut_assertok(adc_channels_single_shot("adc", channel_mask, channels)); + ut_assertok(adc_channels_single_shot("adc@0", channel_mask, channels));
/* Compare the expected and returned conversion data. */ for (i = 0; i < SANDBOX_ADC_CHANNELS; i++, tdata++) @@ -183,7 +183,7 @@ static int dm_test_adc_raw_to_uV(struct unit_test_state *uts) struct udevice *dev; int uV;
- ut_assertok(uclass_get_device_by_name(UCLASS_ADC, "adc", &dev)); + ut_assertok(uclass_get_device_by_name(UCLASS_ADC, "adc@0", &dev)); /* Test each ADC channel's value in microvolts */ for (i = 0; i < SANDBOX_ADC_CHANNELS; i++, tdata++) { ut_assertok(adc_start_channel(dev, tdata->id));
"keyb" is not the real device name, "keyb@3" is.
V2: New
test/dm/usb.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/test/dm/usb.c b/test/dm/usb.c index 3493617544..ef454b0ae5 100644 --- a/test/dm/usb.c +++ b/test/dm/usb.c @@ -125,7 +125,7 @@ static int dm_test_usb_keyb(struct unit_test_state *uts) /* Initially there should be no characters */ ut_asserteq(0, tstc());
- ut_assertok(uclass_get_device_by_name(UCLASS_USB_EMUL, "keyb", + ut_assertok(uclass_get_device_by_name(UCLASS_USB_EMUL, "keyb@3", &dev));
V2: New
Signed-off-by: Peng Fan peng.fan@nxp.com Reviewed-by: Bin Meng bmeng.cn@gmail.com
`if (!strncmp(dev->name, name, strlen(name)))` might find out the wrong device, it might find out `dram_pll_ref_sel`, when name is `dram_pll`. So use strcmp to avoid such issue.
Signed-off-by: Peng Fan peng.fan@nxp.com Reviewed-by: Simon Glass sjg@chromium.org ---
V2: None
drivers/core/uclass.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/core/uclass.c b/drivers/core/uclass.c index fc3157de39..e2f35393a9 100644 --- a/drivers/core/uclass.c +++ b/drivers/core/uclass.c @@ -260,7 +260,7 @@ int uclass_find_device_by_name(enum uclass_id id, const char *name, return ret;
uclass_foreach_dev(dev, uc) { - if (!strncmp(dev->name, name, strlen(name))) { + if (!strcmp(dev->name, name)) { *devp = dev; return 0; }
V2: None
Signed-off-by: Peng Fan peng.fan@nxp.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com
V2: new
Hi Simon, Tom
Subject: [PATCH V2 1/3] test: dm: adc: use the real device name
Will you pick up this patchset? https://patchwork.ozlabs.org/patch/1103212/ https://patchwork.ozlabs.org/patch/1103213/ https://patchwork.ozlabs.org/patch/1103214/
Thanks, Peng.
V2: new
- ut_assertok(uclass_get_device_by_name(UCLASS_ADC, "adc@0",
&dev));
/* Compare the expected and returned conversion data. */ ut_asserteq(tdata->data, data); }ut_assertok(adc_channel_single_shot("adc@0", tdata->id, &data));
- ut_assertok(adc_channels_single_shot("adc@0", channel_mask,
+channels));
&dev)); /* Test each ADC channel's value in microvolts */ for (i = 0; i < SANDBOX_ADC_CHANNELS; i++, tdata++) { ut_assertok(adc_start_channel(dev, tdata->id)); -- 2.16.4
On Wed, Jun 19, 2019 at 02:17:59AM +0000, Peng Fan wrote:
Hi Simon, Tom
For the next release. Or should they really come in now? Thanks!
Subject: Re: [PATCH V2 1/3] test: dm: adc: use the real device name
Hi Simon, Tom
Could wait next release.
Thanks, Peng.
-- Tom
Bin Meng
Peng Fan
