[U-Boot] [PATCH] powerpc/corenet: CPC1 speculation disable
In PBL RAMBOOT(SPI/SD/NAND boot) mode, CPC1 used as SRAM, should disable CPC1 speculation and keep it till relocation. Otherwise, speculation transactions will go to DDR controller, it will cause problem.
Signed-off-by: Dave Liu daveliu@freescale.com Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com --- arch/powerpc/cpu/mpc85xx/start.S | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index 6a81fa7..db84d10 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -886,7 +886,11 @@ delete_ccsr_l2_tlb: erratum_set_dcsr 0xb0008 0x00900000 erratum_set_dcsr 0xb0e40 0xe00a0000 erratum_set_ccsr 0x18600 CONFIG_SYS_FSL_CORENET_SNOOPVEC_COREONLY +#ifdef CONFIG_RAMBOOT_PBL + erratum_set_ccsr 0x10f00 0x495e5000 +#else erratum_set_ccsr 0x10f00 0x415e5000 +#endif erratum_set_ccsr 0x11f00 0x415e5000
/* Make temp mapping uncacheable again, if it was initially */
Applied to u-boot-mpc85xx/master. Thanks.
York
shh.xie@gmail.com
York Sun
