[PATCH] board: phytec: phycore_imx8mm: Update lpddr4_timing
Update RAM Timings for 2GB RAM based on DDR Controller Configuration Spreadsheet revision 22. Including the update of the refresh rate to workaround errata ERR050805.
Signed-off-by: Cem Tenruh c.tenruh@phytec.de --- board/phytec/phycore_imx8mm/lpddr4_timing.c | 1486 +++++++++---------- 1 file changed, 742 insertions(+), 744 deletions(-)
diff --git a/board/phytec/phycore_imx8mm/lpddr4_timing.c b/board/phytec/phycore_imx8mm/lpddr4_timing.c index 811ac26415..f5a2f3268b 100644 --- a/board/phytec/phycore_imx8mm/lpddr4_timing.c +++ b/board/phytec/phycore_imx8mm/lpddr4_timing.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0-or-later /* - * Copyright (C) 2020 PHYTEC Messtechnik GmbH + * Copyright 2019 NXP + * Copyright (C) 2023 PHYTEC Messtechnik GmbH * * Generated code from MX8M_DDR_tool */ @@ -13,22 +14,22 @@ static struct dram_cfg_param ddr_ddrc_cfg[] = { {0x3d400304, 0x1}, {0x3d400030, 0x1}, {0x3d400000, 0xa1080020}, - {0x3d400020, 0x223}, + {0x3d400020, 0x222}, {0x3d400024, 0x3a980}, - {0x3d400064, 0x5b00d2}, + {0x3d400064, 0x2d00d2}, {0x3d4000d0, 0xc00305ba}, {0x3d4000d4, 0x940000}, {0x3d4000dc, 0xd4002d}, {0x3d4000e0, 0x310000}, {0x3d4000e8, 0x66004d}, {0x3d4000ec, 0x16004d}, - {0x3d400100, 0x191e1920}, + {0x3d400100, 0x191e0c20}, {0x3d400104, 0x60630}, {0x3d40010c, 0xb0b000}, {0x3d400110, 0xe04080e}, {0x3d400114, 0x2040c0c}, {0x3d400118, 0x1010007}, - {0x3d40011c, 0x401}, + {0x3d40011c, 0x402}, {0x3d400130, 0x20600}, {0x3d400134, 0xc100002}, {0x3d400138, 0xd8}, @@ -45,7 +46,7 @@ static struct dram_cfg_param ddr_ddrc_cfg[] = { {0x3d4001b0, 0x11}, {0x3d4001c0, 0x1}, {0x3d4001c4, 0x1}, - {0x3d4000f4, 0xc99}, + {0x3d4000f4, 0x699}, {0x3d400108, 0x70e1617}, {0x3d400200, 0x1f}, {0x3d40020c, 0x0}, @@ -53,6 +54,7 @@ static struct dram_cfg_param ddr_ddrc_cfg[] = { {0x3d400204, 0x80808}, {0x3d400214, 0x7070707}, {0x3d400218, 0x7070707}, + {0x3d40021c, 0xf0f}, {0x3d400250, 0x29001701}, {0x3d400254, 0x2c}, {0x3d40025c, 0x4000030}, @@ -64,22 +66,22 @@ static struct dram_cfg_param ddr_ddrc_cfg[] = { {0x3d400498, 0x620096}, {0x3d40049c, 0x1100e07}, {0x3d4004a0, 0xc8012c}, - {0x3d402020, 0x21}, + {0x3d402020, 0x20}, {0x3d402024, 0x7d00}, {0x3d402050, 0x20d040}, - {0x3d402064, 0xc001c}, + {0x3d402064, 0x6001c}, {0x3d4020dc, 0x840000}, {0x3d4020e0, 0x310000}, {0x3d4020e8, 0x66004d}, {0x3d4020ec, 0x16004d}, - {0x3d402100, 0xa040305}, + {0x3d402100, 0xa040105}, {0x3d402104, 0x30407}, {0x3d402108, 0x203060b}, {0x3d40210c, 0x505000}, {0x3d402110, 0x2040202}, {0x3d402114, 0x2030202}, {0x3d402118, 0x1010004}, - {0x3d40211c, 0x301}, + {0x3d40211c, 0x302}, {0x3d402130, 0x20300}, {0x3d402134, 0xa100002}, {0x3d402138, 0x1d}, @@ -88,8 +90,8 @@ static struct dram_cfg_param ddr_ddrc_cfg[] = { {0x3d402190, 0x3818200}, {0x3d402194, 0x80303}, {0x3d4021b4, 0x100}, - {0x3d4020f4, 0xc99}, - {0x3d403020, 0x21}, + {0x3d4020f4, 0x599}, + {0x3d403020, 0x20}, {0x3d403024, 0x1f40}, {0x3d403050, 0x20d040}, {0x3d403064, 0x30007}, @@ -104,7 +106,7 @@ static struct dram_cfg_param ddr_ddrc_cfg[] = { {0x3d403110, 0x2040202}, {0x3d403114, 0x2030202}, {0x3d403118, 0x1010004}, - {0x3d40311c, 0x301}, + {0x3d40311c, 0x302}, {0x3d403130, 0x20300}, {0x3d403134, 0xa100002}, {0x3d403138, 0x8}, @@ -113,7 +115,7 @@ static struct dram_cfg_param ddr_ddrc_cfg[] = { {0x3d403190, 0x3818200}, {0x3d403194, 0x80303}, {0x3d4031b4, 0x100}, - {0x3d4030f4, 0xc99}, + {0x3d4030f4, 0x599}, {0x3d400028, 0x0}, };
@@ -201,8 +203,8 @@ static struct dram_cfg_param ddr_ddrphy_cfg[] = { {0x220024, 0x1ab}, {0x2003a, 0x0}, {0x20056, 0x3}, - {0x120056, 0xa}, - {0x220056, 0xa}, + {0x120056, 0x3}, + {0x220056, 0x3}, {0x1004d, 0xe00}, {0x1014d, 0xe00}, {0x1104d, 0xe00}, @@ -323,727 +325,726 @@ static struct dram_cfg_param ddr_ddrphy_cfg[] = {
/* ddr phy trained csr */ static struct dram_cfg_param ddr_ddrphy_trained_csr[] = { - { 0x200b2, 0x0 }, - { 0x1200b2, 0x0 }, - { 0x2200b2, 0x0 }, - { 0x200cb, 0x0 }, - { 0x10043, 0x0 }, - { 0x110043, 0x0 }, - { 0x210043, 0x0 }, - { 0x10143, 0x0 }, - { 0x110143, 0x0 }, - { 0x210143, 0x0 }, - { 0x11043, 0x0 }, - { 0x111043, 0x0 }, - { 0x211043, 0x0 }, - { 0x11143, 0x0 }, - { 0x111143, 0x0 }, - { 0x211143, 0x0 }, - { 0x12043, 0x0 }, - { 0x112043, 0x0 }, - { 0x212043, 0x0 }, - { 0x12143, 0x0 }, - { 0x112143, 0x0 }, - { 0x212143, 0x0 }, - { 0x13043, 0x0 }, - { 0x113043, 0x0 }, - { 0x213043, 0x0 }, - { 0x13143, 0x0 }, - { 0x113143, 0x0 }, - { 0x213143, 0x0 }, - { 0x80, 0x0 }, - { 0x100080, 0x0 }, - { 0x200080, 0x0 }, - { 0x1080, 0x0 }, - { 0x101080, 0x0 }, - { 0x201080, 0x0 }, - { 0x2080, 0x0 }, - { 0x102080, 0x0 }, - { 0x202080, 0x0 }, - { 0x3080, 0x0 }, - { 0x103080, 0x0 }, - { 0x203080, 0x0 }, - { 0x4080, 0x0 }, - { 0x104080, 0x0 }, - { 0x204080, 0x0 }, - { 0x5080, 0x0 }, - { 0x105080, 0x0 }, - { 0x205080, 0x0 }, - { 0x6080, 0x0 }, - { 0x106080, 0x0 }, - { 0x206080, 0x0 }, - { 0x7080, 0x0 }, - { 0x107080, 0x0 }, - { 0x207080, 0x0 }, - { 0x8080, 0x0 }, - { 0x108080, 0x0 }, - { 0x208080, 0x0 }, - { 0x9080, 0x0 }, - { 0x109080, 0x0 }, - { 0x209080, 0x0 }, - { 0x10080, 0x0 }, - { 0x110080, 0x0 }, - { 0x210080, 0x0 }, - { 0x10180, 0x0 }, - { 0x110180, 0x0 }, - { 0x210180, 0x0 }, - { 0x11080, 0x0 }, - { 0x111080, 0x0 }, - { 0x211080, 0x0 }, - { 0x11180, 0x0 }, - { 0x111180, 0x0 }, - { 0x211180, 0x0 }, - { 0x12080, 0x0 }, - { 0x112080, 0x0 }, - { 0x212080, 0x0 }, - { 0x12180, 0x0 }, - { 0x112180, 0x0 }, - { 0x212180, 0x0 }, - { 0x13080, 0x0 }, - { 0x113080, 0x0 }, - { 0x213080, 0x0 }, - { 0x13180, 0x0 }, - { 0x113180, 0x0 }, - { 0x213180, 0x0 }, - { 0x10081, 0x0 }, - { 0x110081, 0x0 }, - { 0x210081, 0x0 }, - { 0x10181, 0x0 }, - { 0x110181, 0x0 }, - { 0x210181, 0x0 }, - { 0x11081, 0x0 }, - { 0x111081, 0x0 }, - { 0x211081, 0x0 }, - { 0x11181, 0x0 }, - { 0x111181, 0x0 }, - { 0x211181, 0x0 }, - { 0x12081, 0x0 }, - { 0x112081, 0x0 }, - { 0x212081, 0x0 }, - { 0x12181, 0x0 }, - { 0x112181, 0x0 }, - { 0x212181, 0x0 }, - { 0x13081, 0x0 }, - { 0x113081, 0x0 }, - { 0x213081, 0x0 }, - { 0x13181, 0x0 }, - { 0x113181, 0x0 }, - { 0x213181, 0x0 }, - { 0x100d0, 0x0 }, - { 0x1100d0, 0x0 }, - { 0x2100d0, 0x0 }, - { 0x101d0, 0x0 }, - { 0x1101d0, 0x0 }, - { 0x2101d0, 0x0 }, - { 0x110d0, 0x0 }, - { 0x1110d0, 0x0 }, - { 0x2110d0, 0x0 }, - { 0x111d0, 0x0 }, - { 0x1111d0, 0x0 }, - { 0x2111d0, 0x0 }, - { 0x120d0, 0x0 }, - { 0x1120d0, 0x0 }, - { 0x2120d0, 0x0 }, - { 0x121d0, 0x0 }, - { 0x1121d0, 0x0 }, - { 0x2121d0, 0x0 }, - { 0x130d0, 0x0 }, - { 0x1130d0, 0x0 }, - { 0x2130d0, 0x0 }, - { 0x131d0, 0x0 }, - { 0x1131d0, 0x0 }, - { 0x2131d0, 0x0 }, - { 0x100d1, 0x0 }, - { 0x1100d1, 0x0 }, - { 0x2100d1, 0x0 }, - { 0x101d1, 0x0 }, - { 0x1101d1, 0x0 }, - { 0x2101d1, 0x0 }, - { 0x110d1, 0x0 }, - { 0x1110d1, 0x0 }, - { 0x2110d1, 0x0 }, - { 0x111d1, 0x0 }, - { 0x1111d1, 0x0 }, - { 0x2111d1, 0x0 }, - { 0x120d1, 0x0 }, - { 0x1120d1, 0x0 }, - { 0x2120d1, 0x0 }, - { 0x121d1, 0x0 }, - { 0x1121d1, 0x0 }, - { 0x2121d1, 0x0 }, - { 0x130d1, 0x0 }, - { 0x1130d1, 0x0 }, - { 0x2130d1, 0x0 }, - { 0x131d1, 0x0 }, - { 0x1131d1, 0x0 }, - { 0x2131d1, 0x0 }, - { 0x10068, 0x0 }, - { 0x10168, 0x0 }, - { 0x10268, 0x0 }, - { 0x10368, 0x0 }, - { 0x10468, 0x0 }, - { 0x10568, 0x0 }, - { 0x10668, 0x0 }, - { 0x10768, 0x0 }, - { 0x10868, 0x0 }, - { 0x11068, 0x0 }, - { 0x11168, 0x0 }, - { 0x11268, 0x0 }, - { 0x11368, 0x0 }, - { 0x11468, 0x0 }, - { 0x11568, 0x0 }, - { 0x11668, 0x0 }, - { 0x11768, 0x0 }, - { 0x11868, 0x0 }, - { 0x12068, 0x0 }, - { 0x12168, 0x0 }, - { 0x12268, 0x0 }, - { 0x12368, 0x0 }, - { 0x12468, 0x0 }, - { 0x12568, 0x0 }, - { 0x12668, 0x0 }, - { 0x12768, 0x0 }, - { 0x12868, 0x0 }, - { 0x13068, 0x0 }, - { 0x13168, 0x0 }, - { 0x13268, 0x0 }, - { 0x13368, 0x0 }, - { 0x13468, 0x0 }, - { 0x13568, 0x0 }, - { 0x13668, 0x0 }, - { 0x13768, 0x0 }, - { 0x13868, 0x0 }, - { 0x10069, 0x0 }, - { 0x10169, 0x0 }, - { 0x10269, 0x0 }, - { 0x10369, 0x0 }, - { 0x10469, 0x0 }, - { 0x10569, 0x0 }, - { 0x10669, 0x0 }, - { 0x10769, 0x0 }, - { 0x10869, 0x0 }, - { 0x11069, 0x0 }, - { 0x11169, 0x0 }, - { 0x11269, 0x0 }, - { 0x11369, 0x0 }, - { 0x11469, 0x0 }, - { 0x11569, 0x0 }, - { 0x11669, 0x0 }, - { 0x11769, 0x0 }, - { 0x11869, 0x0 }, - { 0x12069, 0x0 }, - { 0x12169, 0x0 }, - { 0x12269, 0x0 }, - { 0x12369, 0x0 }, - { 0x12469, 0x0 }, - { 0x12569, 0x0 }, - { 0x12669, 0x0 }, - { 0x12769, 0x0 }, - { 0x12869, 0x0 }, - { 0x13069, 0x0 }, - { 0x13169, 0x0 }, - { 0x13269, 0x0 }, - { 0x13369, 0x0 }, - { 0x13469, 0x0 }, - { 0x13569, 0x0 }, - { 0x13669, 0x0 }, - { 0x13769, 0x0 }, - { 0x13869, 0x0 }, - { 0x1008c, 0x0 }, - { 0x11008c, 0x0 }, - { 0x21008c, 0x0 }, - { 0x1018c, 0x0 }, - { 0x11018c, 0x0 }, - { 0x21018c, 0x0 }, - { 0x1108c, 0x0 }, - { 0x11108c, 0x0 }, - { 0x21108c, 0x0 }, - { 0x1118c, 0x0 }, - { 0x11118c, 0x0 }, - { 0x21118c, 0x0 }, - { 0x1208c, 0x0 }, - { 0x11208c, 0x0 }, - { 0x21208c, 0x0 }, - { 0x1218c, 0x0 }, - { 0x11218c, 0x0 }, - { 0x21218c, 0x0 }, - { 0x1308c, 0x0 }, - { 0x11308c, 0x0 }, - { 0x21308c, 0x0 }, - { 0x1318c, 0x0 }, - { 0x11318c, 0x0 }, - { 0x21318c, 0x0 }, - { 0x1008d, 0x0 }, - { 0x11008d, 0x0 }, - { 0x21008d, 0x0 }, - { 0x1018d, 0x0 }, - { 0x11018d, 0x0 }, - { 0x21018d, 0x0 }, - { 0x1108d, 0x0 }, - { 0x11108d, 0x0 }, - { 0x21108d, 0x0 }, - { 0x1118d, 0x0 }, - { 0x11118d, 0x0 }, - { 0x21118d, 0x0 }, - { 0x1208d, 0x0 }, - { 0x11208d, 0x0 }, - { 0x21208d, 0x0 }, - { 0x1218d, 0x0 }, - { 0x11218d, 0x0 }, - { 0x21218d, 0x0 }, - { 0x1308d, 0x0 }, - { 0x11308d, 0x0 }, - { 0x21308d, 0x0 }, - { 0x1318d, 0x0 }, - { 0x11318d, 0x0 }, - { 0x21318d, 0x0 }, - { 0x100c0, 0x0 }, - { 0x1100c0, 0x0 }, - { 0x2100c0, 0x0 }, - { 0x101c0, 0x0 }, - { 0x1101c0, 0x0 }, - { 0x2101c0, 0x0 }, - { 0x102c0, 0x0 }, - { 0x1102c0, 0x0 }, - { 0x2102c0, 0x0 }, - { 0x103c0, 0x0 }, - { 0x1103c0, 0x0 }, - { 0x2103c0, 0x0 }, - { 0x104c0, 0x0 }, - { 0x1104c0, 0x0 }, - { 0x2104c0, 0x0 }, - { 0x105c0, 0x0 }, - { 0x1105c0, 0x0 }, - { 0x2105c0, 0x0 }, - { 0x106c0, 0x0 }, - { 0x1106c0, 0x0 }, - { 0x2106c0, 0x0 }, - { 0x107c0, 0x0 }, - { 0x1107c0, 0x0 }, - { 0x2107c0, 0x0 }, - { 0x108c0, 0x0 }, - { 0x1108c0, 0x0 }, - { 0x2108c0, 0x0 }, - { 0x110c0, 0x0 }, - { 0x1110c0, 0x0 }, - { 0x2110c0, 0x0 }, - { 0x111c0, 0x0 }, - { 0x1111c0, 0x0 }, - { 0x2111c0, 0x0 }, - { 0x112c0, 0x0 }, - { 0x1112c0, 0x0 }, - { 0x2112c0, 0x0 }, - { 0x113c0, 0x0 }, - { 0x1113c0, 0x0 }, - { 0x2113c0, 0x0 }, - { 0x114c0, 0x0 }, - { 0x1114c0, 0x0 }, - { 0x2114c0, 0x0 }, - { 0x115c0, 0x0 }, - { 0x1115c0, 0x0 }, - { 0x2115c0, 0x0 }, - { 0x116c0, 0x0 }, - { 0x1116c0, 0x0 }, - { 0x2116c0, 0x0 }, - { 0x117c0, 0x0 }, - { 0x1117c0, 0x0 }, - { 0x2117c0, 0x0 }, - { 0x118c0, 0x0 }, - { 0x1118c0, 0x0 }, - { 0x2118c0, 0x0 }, - { 0x120c0, 0x0 }, - { 0x1120c0, 0x0 }, - { 0x2120c0, 0x0 }, - { 0x121c0, 0x0 }, - { 0x1121c0, 0x0 }, - { 0x2121c0, 0x0 }, - { 0x122c0, 0x0 }, - { 0x1122c0, 0x0 }, - { 0x2122c0, 0x0 }, - { 0x123c0, 0x0 }, - { 0x1123c0, 0x0 }, - { 0x2123c0, 0x0 }, - { 0x124c0, 0x0 }, - { 0x1124c0, 0x0 }, - { 0x2124c0, 0x0 }, - { 0x125c0, 0x0 }, - { 0x1125c0, 0x0 }, - { 0x2125c0, 0x0 }, - { 0x126c0, 0x0 }, - { 0x1126c0, 0x0 }, - { 0x2126c0, 0x0 }, - { 0x127c0, 0x0 }, - { 0x1127c0, 0x0 }, - { 0x2127c0, 0x0 }, - { 0x128c0, 0x0 }, - { 0x1128c0, 0x0 }, - { 0x2128c0, 0x0 }, - { 0x130c0, 0x0 }, - { 0x1130c0, 0x0 }, - { 0x2130c0, 0x0 }, - { 0x131c0, 0x0 }, - { 0x1131c0, 0x0 }, - { 0x2131c0, 0x0 }, - { 0x132c0, 0x0 }, - { 0x1132c0, 0x0 }, - { 0x2132c0, 0x0 }, - { 0x133c0, 0x0 }, - { 0x1133c0, 0x0 }, - { 0x2133c0, 0x0 }, - { 0x134c0, 0x0 }, - { 0x1134c0, 0x0 }, - { 0x2134c0, 0x0 }, - { 0x135c0, 0x0 }, - { 0x1135c0, 0x0 }, - { 0x2135c0, 0x0 }, - { 0x136c0, 0x0 }, - { 0x1136c0, 0x0 }, - { 0x2136c0, 0x0 }, - { 0x137c0, 0x0 }, - { 0x1137c0, 0x0 }, - { 0x2137c0, 0x0 }, - { 0x138c0, 0x0 }, - { 0x1138c0, 0x0 }, - { 0x2138c0, 0x0 }, - { 0x100c1, 0x0 }, - { 0x1100c1, 0x0 }, - { 0x2100c1, 0x0 }, - { 0x101c1, 0x0 }, - { 0x1101c1, 0x0 }, - { 0x2101c1, 0x0 }, - { 0x102c1, 0x0 }, - { 0x1102c1, 0x0 }, - { 0x2102c1, 0x0 }, - { 0x103c1, 0x0 }, - { 0x1103c1, 0x0 }, - { 0x2103c1, 0x0 }, - { 0x104c1, 0x0 }, - { 0x1104c1, 0x0 }, - { 0x2104c1, 0x0 }, - { 0x105c1, 0x0 }, - { 0x1105c1, 0x0 }, - { 0x2105c1, 0x0 }, - { 0x106c1, 0x0 }, - { 0x1106c1, 0x0 }, - { 0x2106c1, 0x0 }, - { 0x107c1, 0x0 }, - { 0x1107c1, 0x0 }, - { 0x2107c1, 0x0 }, - { 0x108c1, 0x0 }, - { 0x1108c1, 0x0 }, - { 0x2108c1, 0x0 }, - { 0x110c1, 0x0 }, - { 0x1110c1, 0x0 }, - { 0x2110c1, 0x0 }, - { 0x111c1, 0x0 }, - { 0x1111c1, 0x0 }, - { 0x2111c1, 0x0 }, - { 0x112c1, 0x0 }, - { 0x1112c1, 0x0 }, - { 0x2112c1, 0x0 }, - { 0x113c1, 0x0 }, - { 0x1113c1, 0x0 }, - { 0x2113c1, 0x0 }, - { 0x114c1, 0x0 }, - { 0x1114c1, 0x0 }, - { 0x2114c1, 0x0 }, - { 0x115c1, 0x0 }, - { 0x1115c1, 0x0 }, - { 0x2115c1, 0x0 }, - { 0x116c1, 0x0 }, - { 0x1116c1, 0x0 }, - { 0x2116c1, 0x0 }, - { 0x117c1, 0x0 }, - { 0x1117c1, 0x0 }, - { 0x2117c1, 0x0 }, - { 0x118c1, 0x0 }, - { 0x1118c1, 0x0 }, - { 0x2118c1, 0x0 }, - { 0x120c1, 0x0 }, - { 0x1120c1, 0x0 }, - { 0x2120c1, 0x0 }, - { 0x121c1, 0x0 }, - { 0x1121c1, 0x0 }, - { 0x2121c1, 0x0 }, - { 0x122c1, 0x0 }, - { 0x1122c1, 0x0 }, - { 0x2122c1, 0x0 }, - { 0x123c1, 0x0 }, - { 0x1123c1, 0x0 }, - { 0x2123c1, 0x0 }, - { 0x124c1, 0x0 }, - { 0x1124c1, 0x0 }, - { 0x2124c1, 0x0 }, - { 0x125c1, 0x0 }, - { 0x1125c1, 0x0 }, - { 0x2125c1, 0x0 }, - { 0x126c1, 0x0 }, - { 0x1126c1, 0x0 }, - { 0x2126c1, 0x0 }, - { 0x127c1, 0x0 }, - { 0x1127c1, 0x0 }, - { 0x2127c1, 0x0 }, - { 0x128c1, 0x0 }, - { 0x1128c1, 0x0 }, - { 0x2128c1, 0x0 }, - { 0x130c1, 0x0 }, - { 0x1130c1, 0x0 }, - { 0x2130c1, 0x0 }, - { 0x131c1, 0x0 }, - { 0x1131c1, 0x0 }, - { 0x2131c1, 0x0 }, - { 0x132c1, 0x0 }, - { 0x1132c1, 0x0 }, - { 0x2132c1, 0x0 }, - { 0x133c1, 0x0 }, - { 0x1133c1, 0x0 }, - { 0x2133c1, 0x0 }, - { 0x134c1, 0x0 }, - { 0x1134c1, 0x0 }, - { 0x2134c1, 0x0 }, - { 0x135c1, 0x0 }, - { 0x1135c1, 0x0 }, - { 0x2135c1, 0x0 }, - { 0x136c1, 0x0 }, - { 0x1136c1, 0x0 }, - { 0x2136c1, 0x0 }, - { 0x137c1, 0x0 }, - { 0x1137c1, 0x0 }, - { 0x2137c1, 0x0 }, - { 0x138c1, 0x0 }, - { 0x1138c1, 0x0 }, - { 0x2138c1, 0x0 }, - { 0x10020, 0x0 }, - { 0x110020, 0x0 }, - { 0x210020, 0x0 }, - { 0x11020, 0x0 }, - { 0x111020, 0x0 }, - { 0x211020, 0x0 }, - { 0x12020, 0x0 }, - { 0x112020, 0x0 }, - { 0x212020, 0x0 }, - { 0x13020, 0x0 }, - { 0x113020, 0x0 }, - { 0x213020, 0x0 }, - { 0x20072, 0x0 }, - { 0x20073, 0x0 }, - { 0x20074, 0x0 }, - { 0x100aa, 0x0 }, - { 0x110aa, 0x0 }, - { 0x120aa, 0x0 }, - { 0x130aa, 0x0 }, - { 0x20010, 0x0 }, - { 0x120010, 0x0 }, - { 0x220010, 0x0 }, - { 0x20011, 0x0 }, - { 0x120011, 0x0 }, - { 0x220011, 0x0 }, - { 0x100ae, 0x0 }, - { 0x1100ae, 0x0 }, - { 0x2100ae, 0x0 }, - { 0x100af, 0x0 }, - { 0x1100af, 0x0 }, - { 0x2100af, 0x0 }, - { 0x110ae, 0x0 }, - { 0x1110ae, 0x0 }, - { 0x2110ae, 0x0 }, - { 0x110af, 0x0 }, - { 0x1110af, 0x0 }, - { 0x2110af, 0x0 }, - { 0x120ae, 0x0 }, - { 0x1120ae, 0x0 }, - { 0x2120ae, 0x0 }, - { 0x120af, 0x0 }, - { 0x1120af, 0x0 }, - { 0x2120af, 0x0 }, - { 0x130ae, 0x0 }, - { 0x1130ae, 0x0 }, - { 0x2130ae, 0x0 }, - { 0x130af, 0x0 }, - { 0x1130af, 0x0 }, - { 0x2130af, 0x0 }, - { 0x20020, 0x0 }, - { 0x120020, 0x0 }, - { 0x220020, 0x0 }, - { 0x100a0, 0x0 }, - { 0x100a1, 0x0 }, - { 0x100a2, 0x0 }, - { 0x100a3, 0x0 }, - { 0x100a4, 0x0 }, - { 0x100a5, 0x0 }, - { 0x100a6, 0x0 }, - { 0x100a7, 0x0 }, - { 0x110a0, 0x0 }, - { 0x110a1, 0x0 }, - { 0x110a2, 0x0 }, - { 0x110a3, 0x0 }, - { 0x110a4, 0x0 }, - { 0x110a5, 0x0 }, - { 0x110a6, 0x0 }, - { 0x110a7, 0x0 }, - { 0x120a0, 0x0 }, - { 0x120a1, 0x0 }, - { 0x120a2, 0x0 }, - { 0x120a3, 0x0 }, - { 0x120a4, 0x0 }, - { 0x120a5, 0x0 }, - { 0x120a6, 0x0 }, - { 0x120a7, 0x0 }, - { 0x130a0, 0x0 }, - { 0x130a1, 0x0 }, - { 0x130a2, 0x0 }, - { 0x130a3, 0x0 }, - { 0x130a4, 0x0 }, - { 0x130a5, 0x0 }, - { 0x130a6, 0x0 }, - { 0x130a7, 0x0 }, - { 0x2007c, 0x0 }, - { 0x12007c, 0x0 }, - { 0x22007c, 0x0 }, - { 0x2007d, 0x0 }, - { 0x12007d, 0x0 }, - { 0x22007d, 0x0 }, - { 0x400fd, 0x0 }, - { 0x400c0, 0x0 }, - { 0x90201, 0x0 }, - { 0x190201, 0x0 }, - { 0x290201, 0x0 }, - { 0x90202, 0x0 }, - { 0x190202, 0x0 }, - { 0x290202, 0x0 }, - { 0x90203, 0x0 }, - { 0x190203, 0x0 }, - { 0x290203, 0x0 }, - { 0x90204, 0x0 }, - { 0x190204, 0x0 }, - { 0x290204, 0x0 }, - { 0x90205, 0x0 }, - { 0x190205, 0x0 }, - { 0x290205, 0x0 }, - { 0x90206, 0x0 }, - { 0x190206, 0x0 }, - { 0x290206, 0x0 }, - { 0x90207, 0x0 }, - { 0x190207, 0x0 }, - { 0x290207, 0x0 }, - { 0x90208, 0x0 }, - { 0x190208, 0x0 }, - { 0x290208, 0x0 }, - { 0x10062, 0x0 }, - { 0x10162, 0x0 }, - { 0x10262, 0x0 }, - { 0x10362, 0x0 }, - { 0x10462, 0x0 }, - { 0x10562, 0x0 }, - { 0x10662, 0x0 }, - { 0x10762, 0x0 }, - { 0x10862, 0x0 }, - { 0x11062, 0x0 }, - { 0x11162, 0x0 }, - { 0x11262, 0x0 }, - { 0x11362, 0x0 }, - { 0x11462, 0x0 }, - { 0x11562, 0x0 }, - { 0x11662, 0x0 }, - { 0x11762, 0x0 }, - { 0x11862, 0x0 }, - { 0x12062, 0x0 }, - { 0x12162, 0x0 }, - { 0x12262, 0x0 }, - { 0x12362, 0x0 }, - { 0x12462, 0x0 }, - { 0x12562, 0x0 }, - { 0x12662, 0x0 }, - { 0x12762, 0x0 }, - { 0x12862, 0x0 }, - { 0x13062, 0x0 }, - { 0x13162, 0x0 }, - { 0x13262, 0x0 }, - { 0x13362, 0x0 }, - { 0x13462, 0x0 }, - { 0x13562, 0x0 }, - { 0x13662, 0x0 }, - { 0x13762, 0x0 }, - { 0x13862, 0x0 }, - { 0x20077, 0x0 }, - { 0x10001, 0x0 }, - { 0x11001, 0x0 }, - { 0x12001, 0x0 }, - { 0x13001, 0x0 }, - { 0x10040, 0x0 }, - { 0x10140, 0x0 }, - { 0x10240, 0x0 }, - { 0x10340, 0x0 }, - { 0x10440, 0x0 }, - { 0x10540, 0x0 }, - { 0x10640, 0x0 }, - { 0x10740, 0x0 }, - { 0x10840, 0x0 }, - { 0x10030, 0x0 }, - { 0x10130, 0x0 }, - { 0x10230, 0x0 }, - { 0x10330, 0x0 }, - { 0x10430, 0x0 }, - { 0x10530, 0x0 }, - { 0x10630, 0x0 }, - { 0x10730, 0x0 }, - { 0x10830, 0x0 }, - { 0x11040, 0x0 }, - { 0x11140, 0x0 }, - { 0x11240, 0x0 }, - { 0x11340, 0x0 }, - { 0x11440, 0x0 }, - { 0x11540, 0x0 }, - { 0x11640, 0x0 }, - { 0x11740, 0x0 }, - { 0x11840, 0x0 }, - { 0x11030, 0x0 }, - { 0x11130, 0x0 }, - { 0x11230, 0x0 }, - { 0x11330, 0x0 }, - { 0x11430, 0x0 }, - { 0x11530, 0x0 }, - { 0x11630, 0x0 }, - { 0x11730, 0x0 }, - { 0x11830, 0x0 }, - { 0x12040, 0x0 }, - { 0x12140, 0x0 }, - { 0x12240, 0x0 }, - { 0x12340, 0x0 }, - { 0x12440, 0x0 }, - { 0x12540, 0x0 }, - { 0x12640, 0x0 }, - { 0x12740, 0x0 }, - { 0x12840, 0x0 }, - { 0x12030, 0x0 }, - { 0x12130, 0x0 }, - { 0x12230, 0x0 }, - { 0x12330, 0x0 }, - { 0x12430, 0x0 }, - { 0x12530, 0x0 }, - { 0x12630, 0x0 }, - { 0x12730, 0x0 }, - { 0x12830, 0x0 }, - { 0x13040, 0x0 }, - { 0x13140, 0x0 }, - { 0x13240, 0x0 }, - { 0x13340, 0x0 }, - { 0x13440, 0x0 }, - { 0x13540, 0x0 }, - { 0x13640, 0x0 }, - { 0x13740, 0x0 }, - { 0x13840, 0x0 }, - { 0x13030, 0x0 }, - { 0x13130, 0x0 }, - { 0x13230, 0x0 }, - { 0x13330, 0x0 }, - { 0x13430, 0x0 }, - { 0x13530, 0x0 }, - { 0x13630, 0x0 }, - { 0x13730, 0x0 }, - { 0x13830, 0x0 }, + {0x200b2, 0x0}, + {0x1200b2, 0x0}, + {0x2200b2, 0x0}, + {0x200cb, 0x0}, + {0x10043, 0x0}, + {0x110043, 0x0}, + {0x210043, 0x0}, + {0x10143, 0x0}, + {0x110143, 0x0}, + {0x210143, 0x0}, + {0x11043, 0x0}, + {0x111043, 0x0}, + {0x211043, 0x0}, + {0x11143, 0x0}, + {0x111143, 0x0}, + {0x211143, 0x0}, + {0x12043, 0x0}, + {0x112043, 0x0}, + {0x212043, 0x0}, + {0x12143, 0x0}, + {0x112143, 0x0}, + {0x212143, 0x0}, + {0x13043, 0x0}, + {0x113043, 0x0}, + {0x213043, 0x0}, + {0x13143, 0x0}, + {0x113143, 0x0}, + {0x213143, 0x0}, + {0x80, 0x0}, + {0x100080, 0x0}, + {0x200080, 0x0}, + {0x1080, 0x0}, + {0x101080, 0x0}, + {0x201080, 0x0}, + {0x2080, 0x0}, + {0x102080, 0x0}, + {0x202080, 0x0}, + {0x3080, 0x0}, + {0x103080, 0x0}, + {0x203080, 0x0}, + {0x4080, 0x0}, + {0x104080, 0x0}, + {0x204080, 0x0}, + {0x5080, 0x0}, + {0x105080, 0x0}, + {0x205080, 0x0}, + {0x6080, 0x0}, + {0x106080, 0x0}, + {0x206080, 0x0}, + {0x7080, 0x0}, + {0x107080, 0x0}, + {0x207080, 0x0}, + {0x8080, 0x0}, + {0x108080, 0x0}, + {0x208080, 0x0}, + {0x9080, 0x0}, + {0x109080, 0x0}, + {0x209080, 0x0}, + {0x10080, 0x0}, + {0x110080, 0x0}, + {0x210080, 0x0}, + {0x10180, 0x0}, + {0x110180, 0x0}, + {0x210180, 0x0}, + {0x11080, 0x0}, + {0x111080, 0x0}, + {0x211080, 0x0}, + {0x11180, 0x0}, + {0x111180, 0x0}, + {0x211180, 0x0}, + {0x12080, 0x0}, + {0x112080, 0x0}, + {0x212080, 0x0}, + {0x12180, 0x0}, + {0x112180, 0x0}, + {0x212180, 0x0}, + {0x13080, 0x0}, + {0x113080, 0x0}, + {0x213080, 0x0}, + {0x13180, 0x0}, + {0x113180, 0x0}, + {0x213180, 0x0}, + {0x10081, 0x0}, + {0x110081, 0x0}, + {0x210081, 0x0}, + {0x10181, 0x0}, + {0x110181, 0x0}, + {0x210181, 0x0}, + {0x11081, 0x0}, + {0x111081, 0x0}, + {0x211081, 0x0}, + {0x11181, 0x0}, + {0x111181, 0x0}, + {0x211181, 0x0}, + {0x12081, 0x0}, + {0x112081, 0x0}, + {0x212081, 0x0}, + {0x12181, 0x0}, + {0x112181, 0x0}, + {0x212181, 0x0}, + {0x13081, 0x0}, + {0x113081, 0x0}, + {0x213081, 0x0}, + {0x13181, 0x0}, + {0x113181, 0x0}, + {0x213181, 0x0}, + {0x100d0, 0x0}, + {0x1100d0, 0x0}, + {0x2100d0, 0x0}, + {0x101d0, 0x0}, + {0x1101d0, 0x0}, + {0x2101d0, 0x0}, + {0x110d0, 0x0}, + {0x1110d0, 0x0}, + {0x2110d0, 0x0}, + {0x111d0, 0x0}, + {0x1111d0, 0x0}, + {0x2111d0, 0x0}, + {0x120d0, 0x0}, + {0x1120d0, 0x0}, + {0x2120d0, 0x0}, + {0x121d0, 0x0}, + {0x1121d0, 0x0}, + {0x2121d0, 0x0}, + {0x130d0, 0x0}, + {0x1130d0, 0x0}, + {0x2130d0, 0x0}, + {0x131d0, 0x0}, + {0x1131d0, 0x0}, + {0x2131d0, 0x0}, + {0x100d1, 0x0}, + {0x1100d1, 0x0}, + {0x2100d1, 0x0}, + {0x101d1, 0x0}, + {0x1101d1, 0x0}, + {0x2101d1, 0x0}, + {0x110d1, 0x0}, + {0x1110d1, 0x0}, + {0x2110d1, 0x0}, + {0x111d1, 0x0}, + {0x1111d1, 0x0}, + {0x2111d1, 0x0}, + {0x120d1, 0x0}, + {0x1120d1, 0x0}, + {0x2120d1, 0x0}, + {0x121d1, 0x0}, + {0x1121d1, 0x0}, + {0x2121d1, 0x0}, + {0x130d1, 0x0}, + {0x1130d1, 0x0}, + {0x2130d1, 0x0}, + {0x131d1, 0x0}, + {0x1131d1, 0x0}, + {0x2131d1, 0x0}, + {0x10068, 0x0}, + {0x10168, 0x0}, + {0x10268, 0x0}, + {0x10368, 0x0}, + {0x10468, 0x0}, + {0x10568, 0x0}, + {0x10668, 0x0}, + {0x10768, 0x0}, + {0x10868, 0x0}, + {0x11068, 0x0}, + {0x11168, 0x0}, + {0x11268, 0x0}, + {0x11368, 0x0}, + {0x11468, 0x0}, + {0x11568, 0x0}, + {0x11668, 0x0}, + {0x11768, 0x0}, + {0x11868, 0x0}, + {0x12068, 0x0}, + {0x12168, 0x0}, + {0x12268, 0x0}, + {0x12368, 0x0}, + {0x12468, 0x0}, + {0x12568, 0x0}, + {0x12668, 0x0}, + {0x12768, 0x0}, + {0x12868, 0x0}, + {0x13068, 0x0}, + {0x13168, 0x0}, + {0x13268, 0x0}, + {0x13368, 0x0}, + {0x13468, 0x0}, + {0x13568, 0x0}, + {0x13668, 0x0}, + {0x13768, 0x0}, + {0x13868, 0x0}, + {0x10069, 0x0}, + {0x10169, 0x0}, + {0x10269, 0x0}, + {0x10369, 0x0}, + {0x10469, 0x0}, + {0x10569, 0x0}, + {0x10669, 0x0}, + {0x10769, 0x0}, + {0x10869, 0x0}, + {0x11069, 0x0}, + {0x11169, 0x0}, + {0x11269, 0x0}, + {0x11369, 0x0}, + {0x11469, 0x0}, + {0x11569, 0x0}, + {0x11669, 0x0}, + {0x11769, 0x0}, + {0x11869, 0x0}, + {0x12069, 0x0}, + {0x12169, 0x0}, + {0x12269, 0x0}, + {0x12369, 0x0}, + {0x12469, 0x0}, + {0x12569, 0x0}, + {0x12669, 0x0}, + {0x12769, 0x0}, + {0x12869, 0x0}, + {0x13069, 0x0}, + {0x13169, 0x0}, + {0x13269, 0x0}, + {0x13369, 0x0}, + {0x13469, 0x0}, + {0x13569, 0x0}, + {0x13669, 0x0}, + {0x13769, 0x0}, + {0x13869, 0x0}, + {0x1008c, 0x0}, + {0x11008c, 0x0}, + {0x21008c, 0x0}, + {0x1018c, 0x0}, + {0x11018c, 0x0}, + {0x21018c, 0x0}, + {0x1108c, 0x0}, + {0x11108c, 0x0}, + {0x21108c, 0x0}, + {0x1118c, 0x0}, + {0x11118c, 0x0}, + {0x21118c, 0x0}, + {0x1208c, 0x0}, + {0x11208c, 0x0}, + {0x21208c, 0x0}, + {0x1218c, 0x0}, + {0x11218c, 0x0}, + {0x21218c, 0x0}, + {0x1308c, 0x0}, + {0x11308c, 0x0}, + {0x21308c, 0x0}, + {0x1318c, 0x0}, + {0x11318c, 0x0}, + {0x21318c, 0x0}, + {0x1008d, 0x0}, + {0x11008d, 0x0}, + {0x21008d, 0x0}, + {0x1018d, 0x0}, + {0x11018d, 0x0}, + {0x21018d, 0x0}, + {0x1108d, 0x0}, + {0x11108d, 0x0}, + {0x21108d, 0x0}, + {0x1118d, 0x0}, + {0x11118d, 0x0}, + {0x21118d, 0x0}, + {0x1208d, 0x0}, + {0x11208d, 0x0}, + {0x21208d, 0x0}, + {0x1218d, 0x0}, + {0x11218d, 0x0}, + {0x21218d, 0x0}, + {0x1308d, 0x0}, + {0x11308d, 0x0}, + {0x21308d, 0x0}, + {0x1318d, 0x0}, + {0x11318d, 0x0}, + {0x21318d, 0x0}, + {0x100c0, 0x0}, + {0x1100c0, 0x0}, + {0x2100c0, 0x0}, + {0x101c0, 0x0}, + {0x1101c0, 0x0}, + {0x2101c0, 0x0}, + {0x102c0, 0x0}, + {0x1102c0, 0x0}, + {0x2102c0, 0x0}, + {0x103c0, 0x0}, + {0x1103c0, 0x0}, + {0x2103c0, 0x0}, + {0x104c0, 0x0}, + {0x1104c0, 0x0}, + {0x2104c0, 0x0}, + {0x105c0, 0x0}, + {0x1105c0, 0x0}, + {0x2105c0, 0x0}, + {0x106c0, 0x0}, + {0x1106c0, 0x0}, + {0x2106c0, 0x0}, + {0x107c0, 0x0}, + {0x1107c0, 0x0}, + {0x2107c0, 0x0}, + {0x108c0, 0x0}, + {0x1108c0, 0x0}, + {0x2108c0, 0x0}, + {0x110c0, 0x0}, + {0x1110c0, 0x0}, + {0x2110c0, 0x0}, + {0x111c0, 0x0}, + {0x1111c0, 0x0}, + {0x2111c0, 0x0}, + {0x112c0, 0x0}, + {0x1112c0, 0x0}, + {0x2112c0, 0x0}, + {0x113c0, 0x0}, + {0x1113c0, 0x0}, + {0x2113c0, 0x0}, + {0x114c0, 0x0}, + {0x1114c0, 0x0}, + {0x2114c0, 0x0}, + {0x115c0, 0x0}, + {0x1115c0, 0x0}, + {0x2115c0, 0x0}, + {0x116c0, 0x0}, + {0x1116c0, 0x0}, + {0x2116c0, 0x0}, + {0x117c0, 0x0}, + {0x1117c0, 0x0}, + {0x2117c0, 0x0}, + {0x118c0, 0x0}, + {0x1118c0, 0x0}, + {0x2118c0, 0x0}, + {0x120c0, 0x0}, + {0x1120c0, 0x0}, + {0x2120c0, 0x0}, + {0x121c0, 0x0}, + {0x1121c0, 0x0}, + {0x2121c0, 0x0}, + {0x122c0, 0x0}, + {0x1122c0, 0x0}, + {0x2122c0, 0x0}, + {0x123c0, 0x0}, + {0x1123c0, 0x0}, + {0x2123c0, 0x0}, + {0x124c0, 0x0}, + {0x1124c0, 0x0}, + {0x2124c0, 0x0}, + {0x125c0, 0x0}, + {0x1125c0, 0x0}, + {0x2125c0, 0x0}, + {0x126c0, 0x0}, + {0x1126c0, 0x0}, + {0x2126c0, 0x0}, + {0x127c0, 0x0}, + {0x1127c0, 0x0}, + {0x2127c0, 0x0}, + {0x128c0, 0x0}, + {0x1128c0, 0x0}, + {0x2128c0, 0x0}, + {0x130c0, 0x0}, + {0x1130c0, 0x0}, + {0x2130c0, 0x0}, + {0x131c0, 0x0}, + {0x1131c0, 0x0}, + {0x2131c0, 0x0}, + {0x132c0, 0x0}, + {0x1132c0, 0x0}, + {0x2132c0, 0x0}, + {0x133c0, 0x0}, + {0x1133c0, 0x0}, + {0x2133c0, 0x0}, + {0x134c0, 0x0}, + {0x1134c0, 0x0}, + {0x2134c0, 0x0}, + {0x135c0, 0x0}, + {0x1135c0, 0x0}, + {0x2135c0, 0x0}, + {0x136c0, 0x0}, + {0x1136c0, 0x0}, + {0x2136c0, 0x0}, + {0x137c0, 0x0}, + {0x1137c0, 0x0}, + {0x2137c0, 0x0}, + {0x138c0, 0x0}, + {0x1138c0, 0x0}, + {0x2138c0, 0x0}, + {0x100c1, 0x0}, + {0x1100c1, 0x0}, + {0x2100c1, 0x0}, + {0x101c1, 0x0}, + {0x1101c1, 0x0}, + {0x2101c1, 0x0}, + {0x102c1, 0x0}, + {0x1102c1, 0x0}, + {0x2102c1, 0x0}, + {0x103c1, 0x0}, + {0x1103c1, 0x0}, + {0x2103c1, 0x0}, + {0x104c1, 0x0}, + {0x1104c1, 0x0}, + {0x2104c1, 0x0}, + {0x105c1, 0x0}, + {0x1105c1, 0x0}, + {0x2105c1, 0x0}, + {0x106c1, 0x0}, + {0x1106c1, 0x0}, + {0x2106c1, 0x0}, + {0x107c1, 0x0}, + {0x1107c1, 0x0}, + {0x2107c1, 0x0}, + {0x108c1, 0x0}, + {0x1108c1, 0x0}, + {0x2108c1, 0x0}, + {0x110c1, 0x0}, + {0x1110c1, 0x0}, + {0x2110c1, 0x0}, + {0x111c1, 0x0}, + {0x1111c1, 0x0}, + {0x2111c1, 0x0}, + {0x112c1, 0x0}, + {0x1112c1, 0x0}, + {0x2112c1, 0x0}, + {0x113c1, 0x0}, + {0x1113c1, 0x0}, + {0x2113c1, 0x0}, + {0x114c1, 0x0}, + {0x1114c1, 0x0}, + {0x2114c1, 0x0}, + {0x115c1, 0x0}, + {0x1115c1, 0x0}, + {0x2115c1, 0x0}, + {0x116c1, 0x0}, + {0x1116c1, 0x0}, + {0x2116c1, 0x0}, + {0x117c1, 0x0}, + {0x1117c1, 0x0}, + {0x2117c1, 0x0}, + {0x118c1, 0x0}, + {0x1118c1, 0x0}, + {0x2118c1, 0x0}, + {0x120c1, 0x0}, + {0x1120c1, 0x0}, + {0x2120c1, 0x0}, + {0x121c1, 0x0}, + {0x1121c1, 0x0}, + {0x2121c1, 0x0}, + {0x122c1, 0x0}, + {0x1122c1, 0x0}, + {0x2122c1, 0x0}, + {0x123c1, 0x0}, + {0x1123c1, 0x0}, + {0x2123c1, 0x0}, + {0x124c1, 0x0}, + {0x1124c1, 0x0}, + {0x2124c1, 0x0}, + {0x125c1, 0x0}, + {0x1125c1, 0x0}, + {0x2125c1, 0x0}, + {0x126c1, 0x0}, + {0x1126c1, 0x0}, + {0x2126c1, 0x0}, + {0x127c1, 0x0}, + {0x1127c1, 0x0}, + {0x2127c1, 0x0}, + {0x128c1, 0x0}, + {0x1128c1, 0x0}, + {0x2128c1, 0x0}, + {0x130c1, 0x0}, + {0x1130c1, 0x0}, + {0x2130c1, 0x0}, + {0x131c1, 0x0}, + {0x1131c1, 0x0}, + {0x2131c1, 0x0}, + {0x132c1, 0x0}, + {0x1132c1, 0x0}, + {0x2132c1, 0x0}, + {0x133c1, 0x0}, + {0x1133c1, 0x0}, + {0x2133c1, 0x0}, + {0x134c1, 0x0}, + {0x1134c1, 0x0}, + {0x2134c1, 0x0}, + {0x135c1, 0x0}, + {0x1135c1, 0x0}, + {0x2135c1, 0x0}, + {0x136c1, 0x0}, + {0x1136c1, 0x0}, + {0x2136c1, 0x0}, + {0x137c1, 0x0}, + {0x1137c1, 0x0}, + {0x2137c1, 0x0}, + {0x138c1, 0x0}, + {0x1138c1, 0x0}, + {0x2138c1, 0x0}, + {0x10020, 0x0}, + {0x110020, 0x0}, + {0x210020, 0x0}, + {0x11020, 0x0}, + {0x111020, 0x0}, + {0x211020, 0x0}, + {0x12020, 0x0}, + {0x112020, 0x0}, + {0x212020, 0x0}, + {0x13020, 0x0}, + {0x113020, 0x0}, + {0x213020, 0x0}, + {0x20072, 0x0}, + {0x20073, 0x0}, + {0x20074, 0x0}, + {0x100aa, 0x0}, + {0x110aa, 0x0}, + {0x120aa, 0x0}, + {0x130aa, 0x0}, + {0x20010, 0x0}, + {0x120010, 0x0}, + {0x220010, 0x0}, + {0x20011, 0x0}, + {0x120011, 0x0}, + {0x220011, 0x0}, + {0x100ae, 0x0}, + {0x1100ae, 0x0}, + {0x2100ae, 0x0}, + {0x100af, 0x0}, + {0x1100af, 0x0}, + {0x2100af, 0x0}, + {0x110ae, 0x0}, + {0x1110ae, 0x0}, + {0x2110ae, 0x0}, + {0x110af, 0x0}, + {0x1110af, 0x0}, + {0x2110af, 0x0}, + {0x120ae, 0x0}, + {0x1120ae, 0x0}, + {0x2120ae, 0x0}, + {0x120af, 0x0}, + {0x1120af, 0x0}, + {0x2120af, 0x0}, + {0x130ae, 0x0}, + {0x1130ae, 0x0}, + {0x2130ae, 0x0}, + {0x130af, 0x0}, + {0x1130af, 0x0}, + {0x2130af, 0x0}, + {0x20020, 0x0}, + {0x120020, 0x0}, + {0x220020, 0x0}, + {0x100a0, 0x0}, + {0x100a1, 0x0}, + {0x100a2, 0x0}, + {0x100a3, 0x0}, + {0x100a4, 0x0}, + {0x100a5, 0x0}, + {0x100a6, 0x0}, + {0x100a7, 0x0}, + {0x110a0, 0x0}, + {0x110a1, 0x0}, + {0x110a2, 0x0}, + {0x110a3, 0x0}, + {0x110a4, 0x0}, + {0x110a5, 0x0}, + {0x110a6, 0x0}, + {0x110a7, 0x0}, + {0x120a0, 0x0}, + {0x120a1, 0x0}, + {0x120a2, 0x0}, + {0x120a3, 0x0}, + {0x120a4, 0x0}, + {0x120a5, 0x0}, + {0x120a6, 0x0}, + {0x120a7, 0x0}, + {0x130a0, 0x0}, + {0x130a1, 0x0}, + {0x130a2, 0x0}, + {0x130a3, 0x0}, + {0x130a4, 0x0}, + {0x130a5, 0x0}, + {0x130a6, 0x0}, + {0x130a7, 0x0}, + {0x2007c, 0x0}, + {0x12007c, 0x0}, + {0x22007c, 0x0}, + {0x2007d, 0x0}, + {0x12007d, 0x0}, + {0x22007d, 0x0}, + {0x400fd, 0x0}, + {0x400c0, 0x0}, + {0x90201, 0x0}, + {0x190201, 0x0}, + {0x290201, 0x0}, + {0x90202, 0x0}, + {0x190202, 0x0}, + {0x290202, 0x0}, + {0x90203, 0x0}, + {0x190203, 0x0}, + {0x290203, 0x0}, + {0x90204, 0x0}, + {0x190204, 0x0}, + {0x290204, 0x0}, + {0x90205, 0x0}, + {0x190205, 0x0}, + {0x290205, 0x0}, + {0x90206, 0x0}, + {0x190206, 0x0}, + {0x290206, 0x0}, + {0x90207, 0x0}, + {0x190207, 0x0}, + {0x290207, 0x0}, + {0x90208, 0x0}, + {0x190208, 0x0}, + {0x290208, 0x0}, + {0x10062, 0x0}, + {0x10162, 0x0}, + {0x10262, 0x0}, + {0x10362, 0x0}, + {0x10462, 0x0}, + {0x10562, 0x0}, + {0x10662, 0x0}, + {0x10762, 0x0}, + {0x10862, 0x0}, + {0x11062, 0x0}, + {0x11162, 0x0}, + {0x11262, 0x0}, + {0x11362, 0x0}, + {0x11462, 0x0}, + {0x11562, 0x0}, + {0x11662, 0x0}, + {0x11762, 0x0}, + {0x11862, 0x0}, + {0x12062, 0x0}, + {0x12162, 0x0}, + {0x12262, 0x0}, + {0x12362, 0x0}, + {0x12462, 0x0}, + {0x12562, 0x0}, + {0x12662, 0x0}, + {0x12762, 0x0}, + {0x12862, 0x0}, + {0x13062, 0x0}, + {0x13162, 0x0}, + {0x13262, 0x0}, + {0x13362, 0x0}, + {0x13462, 0x0}, + {0x13562, 0x0}, + {0x13662, 0x0}, + {0x13762, 0x0}, + {0x13862, 0x0}, + {0x20077, 0x0}, + {0x10001, 0x0}, + {0x11001, 0x0}, + {0x12001, 0x0}, + {0x13001, 0x0}, + {0x10040, 0x0}, + {0x10140, 0x0}, + {0x10240, 0x0}, + {0x10340, 0x0}, + {0x10440, 0x0}, + {0x10540, 0x0}, + {0x10640, 0x0}, + {0x10740, 0x0}, + {0x10840, 0x0}, + {0x10030, 0x0}, + {0x10130, 0x0}, + {0x10230, 0x0}, + {0x10330, 0x0}, + {0x10430, 0x0}, + {0x10530, 0x0}, + {0x10630, 0x0}, + {0x10730, 0x0}, + {0x10830, 0x0}, + {0x11040, 0x0}, + {0x11140, 0x0}, + {0x11240, 0x0}, + {0x11340, 0x0}, + {0x11440, 0x0}, + {0x11540, 0x0}, + {0x11640, 0x0}, + {0x11740, 0x0}, + {0x11840, 0x0}, + {0x11030, 0x0}, + {0x11130, 0x0}, + {0x11230, 0x0}, + {0x11330, 0x0}, + {0x11430, 0x0}, + {0x11530, 0x0}, + {0x11630, 0x0}, + {0x11730, 0x0}, + {0x11830, 0x0}, + {0x12040, 0x0}, + {0x12140, 0x0}, + {0x12240, 0x0}, + {0x12340, 0x0}, + {0x12440, 0x0}, + {0x12540, 0x0}, + {0x12640, 0x0}, + {0x12740, 0x0}, + {0x12840, 0x0}, + {0x12030, 0x0}, + {0x12130, 0x0}, + {0x12230, 0x0}, + {0x12330, 0x0}, + {0x12430, 0x0}, + {0x12530, 0x0}, + {0x12630, 0x0}, + {0x12730, 0x0}, + {0x12830, 0x0}, + {0x13040, 0x0}, + {0x13140, 0x0}, + {0x13240, 0x0}, + {0x13340, 0x0}, + {0x13440, 0x0}, + {0x13540, 0x0}, + {0x13640, 0x0}, + {0x13740, 0x0}, + {0x13840, 0x0}, + {0x13030, 0x0}, + {0x13130, 0x0}, + {0x13230, 0x0}, + {0x13330, 0x0}, + {0x13430, 0x0}, + {0x13530, 0x0}, + {0x13630, 0x0}, + {0x13730, 0x0}, + {0x13830, 0x0}, }; - /* P0 message block paremeter for training firmware */ struct dram_cfg_param ddr_fsp0_cfg[] = { {0xd0000, 0x0}, @@ -1054,7 +1055,6 @@ struct dram_cfg_param ddr_fsp0_cfg[] = { {0x54008, 0x131f}, {0x54009, 0xc8}, {0x5400b, 0x2}, - {0x5400d, 0x100}, {0x54012, 0x110}, {0x54019, 0x2dd4}, {0x5401a, 0x31}, @@ -1094,7 +1094,6 @@ static struct dram_cfg_param ddr_fsp1_cfg[] = { {0x54008, 0x121f}, {0x54009, 0xc8}, {0x5400b, 0x2}, - {0x5400d, 0x100}, {0x54012, 0x110}, {0x54019, 0x84}, {0x5401a, 0x31}, @@ -1134,7 +1133,6 @@ static struct dram_cfg_param ddr_fsp2_cfg[] = { {0x54008, 0x121f}, {0x54009, 0xc8}, {0x5400b, 0x2}, - {0x5400d, 0x100}, {0x54012, 0x110}, {0x54019, 0x84}, {0x5401a, 0x31}, @@ -1200,7 +1198,7 @@ static struct dram_cfg_param ddr_fsp0_2d_cfg[] = { {0x5403b, 0x4d}, {0x5403c, 0x4d}, {0x5403d, 0x1600}, - { 0xd0000, 0x1 }, + {0xd0000, 0x1}, };
/* DRAM PHY init engine image */ @@ -1693,15 +1691,15 @@ static struct dram_cfg_param ddr_phy_pie[] = { {0x400d6, 0x20a}, {0x400d7, 0x20b}, {0x2003a, 0x2}, - {0x2000b, 0x5d}, + {0x2000b, 0x34b}, {0x2000c, 0xbb}, {0x2000d, 0x753}, {0x2000e, 0x2c}, - {0x12000b, 0xc}, + {0x12000b, 0x70}, {0x12000c, 0x19}, {0x12000d, 0xfa}, {0x12000e, 0x10}, - {0x22000b, 0x3}, + {0x22000b, 0x1c}, {0x22000c, 0x6}, {0x22000d, 0x3e}, {0x22000e, 0x10}, @@ -1842,5 +1840,5 @@ struct dram_timing_info dram_timing = { .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), .ddrphy_pie = ddr_phy_pie, .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), - .fsp_table = { 3000, 400, 100, }, + .fsp_table = { 3000, 400, 100,}, };
Cem Tenruh
