linksys wrt1900acs v2 boot problem
Hi, I have a problem with my linksys wrt1900acs. My main question is this a hardware problem or software problem? Is it possible to address? I have started researching and have tried with "kwboot" under Windows VM - Ubuntu 20 - Linux but I have a problem with usb serial connection. I have tried several things but I understand that it isn't possible to start USB to Serial on a Windows VM. I will expect your response. Thank you in advance.
All the best Dilyan
I see the following Log from U-Boot with PuTTy under Windows 10: BootROM - 1.73 Booting from NAND flash
General initialization - Version: 1.0.0 Detected Device ID 6820 High speed PHY - Version: 2.0
Init RD NAS topology Serdes Lane 3 is USB3 Serdes Lane 4 is SGMII board SerDes lanes topology details: | Lane # | Speed | Type | -------------------------------- | 0 | 06 | SATA0 | | 1 | 05 | PCIe0 | | 2 | 06 | SATA1 | | 3 | 05 | USB3 HOST1 | | 4 | 05 | PCIe1 | | 5 | 00 | SGMII2 | -------------------------------- :** Link is Gen1, check the EP capability PCIe, Idx 0: Link upgraded to Gen2 based on client cpabilities :** Link is Gen1, check the EP capability PCIe, Idx 1: remains Gen1 High speed PHY - Ended Successfully DDR3 Training Sequence - Ver TIP-1.26.0 mvSysEnvGetTopologyUpdateInfo: TWSI Read failed WL Supp: IF 0 busId 1 Failed ! WL Supp: IF 0 failed ddr3TipDynamicWriteLevelingSupp failure ******** DRAM initialization Failed (res 0x1) ******** DDR3 run algorithm - FAILED 0x1 DDR3 Training Sequence - FAILED
********** DRAM initialization failed! ********
Hello Dilyan!
This looks like DDR3 training SW issue problem. Marek worked on in and tried to address issue. He should know more details in this area.
You need to use kwboot natively. It was heavily tested on Linux and I think it should work also on BSD systems. Windows systems are not really supported and kwboot will not work on them.
All the best Dilyan
Dilyan
Could you please try to update U-Boot to the new version? If the issue is still there? Because DDR3 marvell driver was updated and it is possible that also your issue is fixed now too...
Hi all,
On Fri, Jan 6, 2023 at 9:35 AM Pali Rohár pali@kernel.org wrote:
Hello Dilyan!
All the best Dilyan
Dilyan
I can confirm that on the Synology DS116 board (also Armada 385, 1GB DDR3). The last tests I ran on this board were built with u-boot-2022.07 and did not see any problem with DDR3 training.
All the best, Tony
Dilyan Lazarov
Pali Rohár
Tony Dinh
