[U-Boot] [PATCH] README: Clarify difference of CONFIG_WATCHDOG and CONFIG_HW_WATCHDOG
Now that we have the documentation, the code should be changed to reflect it ;)
Asd far as I can see, these are the places where HW_WATCHDOG is used instead of WATCHDOG:
arch/blackfin/cpu/blackfin/watchdog.c arch/m68k/cpu/mcf547x_8x/cpu.c
The relevant maintainers are on CC.
Signed-off-by: Detlev Zundel dzu@denx.de Cc: Mike Frysinger vapier@gentoo.org Cc: TsiChungLiew Tsi-Chung.Liew@freescale.com --- README | 17 ++++++++++++----- 1 files changed, 12 insertions(+), 5 deletions(-)
diff --git a/README b/README index cdbb9de..63f5647 100644 --- a/README +++ b/README @@ -1,5 +1,5 @@ # -# (C) Copyright 2000 - 2009 +# (C) Copyright 2000 - 2011 # Wolfgang Denk, DENX Software Engineering, wd@denx.de. # # See file CREDITS for list of people who contributed to this @@ -719,10 +719,17 @@ The following options need to be configured: - Watchdog: CONFIG_WATCHDOG If this variable is defined, it enables watchdog - support. There must be support in the platform specific - code for a watchdog. For the 8xx and 8260 CPUs, the - SIU Watchdog feature is enabled in the SYPCR - register. + support for the SoC. There must be support in the SoC + specific code for a watchdog. For the 8xx and 8260 + CPUs, the SIU Watchdog feature is enabled in the SYPCR + register. When supported for a specific SoC is + available, then no further board specific code should + be needed to use it. + + CONFIG_HW_WATCHDOG + When using a watchdog circuitry external to the used + SoC, then define this variable and provide board + specific code for the "hw_watchdog_reset" function.
- U-Boot Version: CONFIG_VERSION_VARIABLE
the trouble is that watchdog.h doesnt seem to match, nor does the name. "hardware" means to me "hardware" as in "the cpu hardware".
#ifdef CONFIG_HW_WATCHDOG ... #else /* * Maybe a software watchdog? */ ... #endif
i dont see how a watchdog in the SoC could be a "software" watchdog or a "non-hardware" watchdog.
the watchdog system is a legacy mess, so probably be easier to just gut the whole thing. -mike
Hi Mike,
Yes, I understand that the situation is not 100% ideal, but I do not share your pessimism. Currently we should straighten out the inconsistencies present in the code and then subsequently we can think about aligning it with what we agree on to be a good name for.
True, we should align the comments in here also - I'll se if I can come up with something sensible.
A agree that the naming is not ideal, but this isn't a good enough argument for removing it. Apart from that, this feature is used in many commercial systems...
Cheers Detlev
it isnt pessimism ... it's a fact that the documentation does not match the source, nor is the source clear.
i didnt mean remove it and not provide equivalent functionality. there should be a single CONFIG_WATCHDOG and every different watchdog driver should have its own CONFIG_WATCHDOG_FOO define. -mike
Dear Detlev Zundel,
Applied, thanks.
Detlev Zundel
Mike Frysinger
