[U-Boot] [PATCH v1] Makefile: Skip symbolic links to files for cscope
cscope complains that it can't find files that appears to be symbolic links
cscope: cannot find file tools/binman/test/u_boot_binman_syms_bad.c cscope: cannot find file tools/version.h
`find -L` tests properties, but name, and cscope can't cope with symbolic links (a lot of bugs in upstream were simple closed as kinda invalid).
To work around the problem, exclude symbolic links from the cscope.files. Note, it's done in two pass to speed up the process (`-exec realpath ...` approach is not portable and introduces a 3x delay).
Signed-off-by: Andy Shevchenko andriy.shevchenko@linux.intel.com --- Makefile | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/Makefile b/Makefile index 54da5cd51c..968a70885b 100644 --- a/Makefile +++ b/Makefile @@ -1793,6 +1793,9 @@ etags: cscope: $(FIND) $(FINDFLAGS) $(TAG_SUBDIRS) -name '*.[chS]' -print > \ cscope.files + @find $(TAG_SUBDIRS) -name '*.[chS]' -type l -print | \ + grep -xvf - cscope.files > cscope.files.no-symlinks; \ + mv cscope.files.no-symlinks cscope.files cscope -b -q -k
SYSTEM_MAP = \
Andy Shevchenko
