[U-Boot] FIT Image with same kernel but different load/entry point
Is it possible to have one kernel entry in a FIT image with two different load/entry point.
I have 2 boards which share the same kernel but doesn't have the same entry/load point.
Thanks, Clement
Not sure if it does exactly what you need but the pine64 board supports multiple boards with different device trees for each board in the fit image.
Peter
Hi Peter,
Peter
No it's not why I need, I was looking to do something like this but without doubling the size :
kernel-bcm { description = "Kernel for Broadcom"; data = /incbin/("./zImage"); type = "kernel"; arch = "arm"; os = "linux"; compression = "none"; load = <0x61000000>; entry = <0x61000000>; hash-1 { algo = "sha1"; }; }; kernel-imx { description = "Kernel for FreeScale"; data = /incbin/("./zImage"); /* Same zImage */ type = "kernel"; arch = "arm"; os = "linux"; compression = "none"; load = <0x12000000>; /* Different load/entry point */ entry = <0x12000000>; hash-1 { algo = "sha1"; }; };
Clement
I think what you want is to use kernel_noload and then load/entry values are ignored and we use the kernel in-place.
Clément Péron
Peter Robinson
