[U-Boot] [PATCH v2] Tegra114: SPL: Set SCLK source to CLK_M before PLLP init.
Based on the Tegra114 TRM, SCLK (system clock) can run up to 275MHz. At POR, the default SCLK source is set to PLLP_OUT0. In function clock_early_init(), PLLP_OUT0 will be set to 480MHz which is beyond the SCLK's upper limit.
The fix is to set SCLK source to CLK_M before initializing PLLP. Tested on A02 dalmore board.
Signed-off-by: Jimmy Zhang jimmzhang@nvidia.com Signed-off-by: Tom Warren twarren@nvidia.com --- v2: - Move/clarify comments and commit msg as per StephenW - Don't remove various unrelated clock enable/reset calls
arch/arm/cpu/arm720t/tegra-common/spl.c | 12 ++++++++++++ arch/arm/cpu/arm720t/tegra114/cpu.c | 20 ++++++++++++++++++-- arch/arm/cpu/tegra114-common/clock.c | 13 +++++++++++++ arch/arm/include/asm/arch-tegra/clk_rst.h | 7 +++++++ 4 files changed, 50 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/arm720t/tegra-common/spl.c b/arch/arm/cpu/arm720t/tegra-common/spl.c index 5171a8f..49a0544 100644 --- a/arch/arm/cpu/arm720t/tegra-common/spl.c +++ b/arch/arm/cpu/arm720t/tegra-common/spl.c @@ -17,6 +17,10 @@ #include <asm/arch/spl.h> #include "cpu.h"
+__weak void set_avp_clock_to_clkm(void) +{ +} + void spl_board_init(void) { struct pmux_tri_ctlr *pmt = (struct pmux_tri_ctlr *)NV_PA_APB_MISC_BASE; @@ -24,6 +28,14 @@ void spl_board_init(void) /* enable JTAG */ writel(0xC0, &pmt->pmt_cfg_ctl);
+ /* + * On poweron, AVP's clock source (also called system clock, or SCLK) + * is set to PLLP_OUT0 with a frequency of 1MHz. Before initializing + * PLLP, we need to move the SCLK source to CLK_M temporarily, and then + * switch it to PLLP_OUT4 (204MHz) at a later time. + */ + set_avp_clock_to_clkm(); + board_init_uart_f();
/* Initialize periph GPIOs */ diff --git a/arch/arm/cpu/arm720t/tegra114/cpu.c b/arch/arm/cpu/arm720t/tegra114/cpu.c index 51ecff7..8f7bce4 100644 --- a/arch/arm/cpu/arm720t/tegra114/cpu.c +++ b/arch/arm/cpu/arm720t/tegra114/cpu.c @@ -127,8 +127,8 @@ void t114_init_clocks(void) clrbits_le32(&flow->cluster_control, 1);
/* - * Switch system clock to PLLP_OUT4 (108 MHz), AVP will now run - * at 108 MHz. This is glitch free as only the source is changed, no + * Switch system clock to PLLP_OUT4 (204 MHz), AVP will now run + * at 204 MHz. This is glitch free as only the source is changed, no * special precaution needed. */ val = (SCLK_SOURCE_PLLP_OUT4 << SCLK_SWAKEUP_FIQ_SOURCE_SHIFT) | @@ -322,3 +322,19 @@ void start_cpu(u32 reset_vector) /* If the CPU(s) don't already have power, power 'em up */ powerup_cpus(); } + +/* Use CLK_M (crystal freq) as AVP/COP (SCLK) clock source */ +void set_avp_clock_to_clkm(void) +{ + struct clk_rst_ctlr *clkrst = + (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; + u32 val; + + val = (SCLK_SOURCE_CLKM << SCLK_SWAKEUP_FIQ_SOURCE_SHIFT) | + (SCLK_SOURCE_CLKM << SCLK_SWAKEUP_IRQ_SOURCE_SHIFT) | + (SCLK_SOURCE_CLKM << SCLK_SWAKEUP_RUN_SOURCE_SHIFT) | + (SCLK_SOURCE_CLKM << SCLK_SWAKEUP_IDLE_SOURCE_SHIFT) | + (SCLK_SYS_STATE_RUN << SCLK_SYS_STATE_SHIFT); + writel(val, &clkrst->crc_sclk_brst_pol); + udelay(3); +} diff --git a/arch/arm/cpu/tegra114-common/clock.c b/arch/arm/cpu/tegra114-common/clock.c index 5c4305a..e9a1a80 100644 --- a/arch/arm/cpu/tegra114-common/clock.c +++ b/arch/arm/cpu/tegra114-common/clock.c @@ -609,6 +609,7 @@ void clock_early_init(void) { struct clk_rst_ctlr *clkrst = (struct clk_rst_ctlr *)NV_PA_CLK_RST_BASE; + u32 reg;
/* * PLLP output frequency set to 408Mhz @@ -653,6 +654,18 @@ void clock_early_init(void) /* PLLD_MISC: Set CLKENABLE, CPCON 12, LFCON 1 */ writel(0x40000C10, &clkrst->crc_pll[CLOCK_ID_DISPLAY].pll_misc); udelay(2); + + /* Set PLLP_OUT3 and 4 freqs to 102MHz and 204MHz */ + /* Assert RSTN before enable */ + reg = PLLP_OUT4_RSTN_EN | PLLP_OUT3_RSTN_EN; + writel(reg, &clkrst->crc_pll[CLOCK_ID_PERIPH].pll_out[1]); + + /* set divisor and reenable */ + reg = (IN_408_OUT_204_DIVISOR << PLLP_OUT4_RATIO) + | PLLP_OUT4_OVR | PLLP_OUT4_CLKEN | PLLP_OUT4_RSTN_DIS + | (IN_408_OUT_102_DIVISOR << PLLP_OUT3_RATIO) + | PLLP_OUT3_OVR | PLLP_OUT3_CLKEN | PLLP_OUT3_RSTN_DIS; + writel(reg, &clkrst->crc_pll[CLOCK_ID_PERIPH].pll_out[1]); }
void arch_timer_init(void) diff --git a/arch/arm/include/asm/arch-tegra/clk_rst.h b/arch/arm/include/asm/arch-tegra/clk_rst.h index 074b3bc..a4c17e7 100644 --- a/arch/arm/include/asm/arch-tegra/clk_rst.h +++ b/arch/arm/include/asm/arch-tegra/clk_rst.h @@ -209,6 +209,13 @@ enum { IN_408_OUT_9_6_DIVISOR = 83, };
+#define PLLP_OUT3_RSTN_DIS (1 << 0) +#define PLLP_OUT3_RSTN_EN (0 << 0) +#define PLLP_OUT3_CLKEN (1 << 1) +#define PLLP_OUT4_RSTN_DIS (1 << 16) +#define PLLP_OUT4_RSTN_EN (0 << 16) +#define PLLP_OUT4_CLKEN (1 << 17) + /* CLK_RST_CONTROLLER_UTMIP_PLL_CFG1_0 */ #define PLLU_POWERDOWN (1 << 16) #define PLL_ENABLE_POWERDOWN (1 << 14)
Why do we need a weak symbol here? You always want to pick up the implementation in arch/arm/cpu/arm720t/tegra114/cpu.c, or it won't work...
Sorry for not noticing this earlier.
- /* Set PLLP_OUT3 and 4 freqs to 102MHz and 204MHz */
- /* Assert RSTN before enable */
- reg = PLLP_OUT4_RSTN_EN | PLLP_OUT3_RSTN_EN;
- writel(reg, &clkrst->crc_pll[CLOCK_ID_PERIPH].pll_out[1]);
- /* set divisor and reenable */
- reg = (IN_408_OUT_204_DIVISOR << PLLP_OUT4_RATIO)
Rather than calling set_avp_clock_to_clkm() from spl.c, wouldn't it make sense to call it from inside clock_early_init() where the PLL_P rate change actually happens? That would absolutely minimize the time the AVP spends running at a slow speed.
Also, shouldn't there be a matching set_avp_clock_to_pllpout4() or similar after PLL_P is fully configured, or the AVP will continue to run slowly for the rest of the time too. Admittedly it doesn't run a lot of code so the different isn't likely to be large, but just dumping it down to 12MHz forever seems like a bad idea.
Stephen Warren
Tom Warren
