Hello! I have U-Boot installed on the SD card of my Orange Pi. It works great, using SRVLOC to get the address of the server, DHCP to get an IP address, and TFTP to get the application files.
I also have a rack of 48 Orange Pi devices with the same U-Boot code in their SD cards. They all have a common power supply. When they boot, sometimes do_pxe() runs before net_ip is set. (There are many devices trying to get IP addresses.)
I have my own copy of the U-Boot code. Is there an environment variable that I can set, or a code change that I can make? For example:
static int do_pxe(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { struct cmd_tbl *cp;
if (net_ip.s_addr == 0) { // now what? } ...
Do you have any ideas? Thank you!
Jim Schaettle
You should possibly be able to call the DHCP init the same way it is done in cmd/net.c function netboot_common
size = net_loop(proto); if (size < 0) { bootstage_error(BOOTSTAGE_ID_NET_NETLOOP_OK); return CMD_RET_FAILURE; } bootstage_mark(BOOTSTAGE_ID_NET_NETLOOP_OK);
/* net_loop ok, update environment */ netboot_update_env();
net_loop I think will do DHCP init and then netboot_update_env will set the env vars such as the ip address
-----Original Message----- From: Jim Schaettle jim.schaettle@etcconnect.com Sent: Wednesday, August 17, 2022 9:18 AM To: u-boot@lists.denx.de Subject: DHCP and TFTP
Jim Schaettle
Hi Jim,
On Thu, 18 Aug 2022 at 06:54, Jim Schaettle jim.schaettle@etcconnect.com wrote:
argv[]) {
struct cmd_tbl *cp; if (net_ip.s_addr == 0) { // now what? } ...
Do you see an error on the console, such as a failure to obtain an IP address?
Greg Leonberg
Jim Schaettle
