[U-Boot] [PATCH] arm, at91: add spi dataflash support for the taurus board
Signed-off-by: Heiko Schocher hs@denx.de Cc: Andreas Bießmann andreas.devel@googlemail.com Cc: Bo Shen voice.shen@atmel.com --- board/siemens/taurus/taurus.c | 22 ++++++++++++++++++++++ include/configs/taurus.h | 11 +++++++++++ 2 files changed, 33 insertions(+)
diff --git a/board/siemens/taurus/taurus.c b/board/siemens/taurus/taurus.c index 673b302..98ce441 100644 --- a/board/siemens/taurus/taurus.c +++ b/board/siemens/taurus/taurus.c @@ -22,6 +22,8 @@ #include <asm/arch/gpio.h> #include <asm/arch/at91sam9_sdramc.h> #include <atmel_mci.h> +#include <asm/arch/at91_spi.h> +#include <spi.h>
#include <net.h> #include <netdev.h> @@ -127,6 +129,25 @@ int board_early_init_f(void) return 0; }
+int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return bus == 0 && cs == 0; +} + +void spi_cs_activate(struct spi_slave *slave) +{ + at91_set_gpio_value(TAURUS_SPI_CS_PIN, 0); +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + at91_set_gpio_value(TAURUS_SPI_CS_PIN, 1); +} + +void spi_init_f(void) +{ + /* everything done in board_init */ +} int board_init(void) { /* adress of boot parameters */ @@ -139,6 +160,7 @@ int board_init(void) #ifdef CONFIG_MACB taurus_macb_hw_init(); #endif + at91_spi0_hw_init(TAURUS_SPI_MASK);
return 0; } diff --git a/include/configs/taurus.h b/include/configs/taurus.h index aadf4cd..e30542d 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -127,6 +127,17 @@ #define CONFIG_USB_STORAGE #endif
+/* SPI EEPROM */ +#define CONFIG_SPI +#define CONFIG_CMD_SPI +#define CONFIG_CMD_SF +#define CONFIG_SPI_FLASH +#define CONFIG_ATMEL_SPI +#define CONFIG_SPI_FLASH_STMICRO +#define CONFIG_SYS_SPI_WRITE_TOUT (5 * CONFIG_SYS_HZ) +#define TAURUS_SPI_MASK (1 << 4) +#define TAURUS_SPI_CS_PIN AT91_PIN_PA3 + /* load address */ #define CONFIG_SYS_LOAD_ADDR 0x22000000
Please don't hold spi variant calls on board files, I guess most of the atmel boards does the same but try to add them on driver itself.
at91_spi0_hw_init(TAURUS_SPI_MASK); return 0;
Don't make this as a config option instead define it on driver file.
-- 1.8.3.1
thanks!
Hello Jagan,
Am 01.10.2014 16:30, schrieb Jagan Teki:
On 1 October 2014 10:56, Heiko Schocherhs@denx.de wrote:
Signed-off-by: Heiko Schocherhs@denx.de Cc: Andreas Bießmannandreas.devel@googlemail.com Cc: Bo Shenvoice.shen@atmel.com
diff --git a/board/siemens/taurus/taurus.c b/board/siemens/taurus/taurus.c index 673b302..98ce441 100644 --- a/board/siemens/taurus/taurus.c +++ b/board/siemens/taurus/taurus.c @@ -22,6 +22,8 @@ #include<asm/arch/gpio.h> #include<asm/arch/at91sam9_sdramc.h> #include<atmel_mci.h> +#include<asm/arch/at91_spi.h> +#include<spi.h>
#include<net.h> #include<netdev.h> @@ -127,6 +129,25 @@ int board_early_init_f(void) return 0; }
return bus == 0&& cs == 0;
Heh, good catch ... I did this like the
board/calao/tny_a9260/spi.c board/calao/sbc35_a9g20/spi.c
boards ... I greped for this function, and it turned out, I did not need it! So, I remove it in v2.... thanks!
Ah, I see, this is defined in more than 10 at91 board config files, and all with the same value ... Ok, I add in drivers/spi/atmel_spi.h
#if !defined(CONFIG_SYS_SPI_WRITE_TOUT) #define CONFIG_SYS_SPI_WRITE_TOUT (5 * CONFIG_SYS_HZ) #endif
and remove this define from the board files ...
+#define TAURUS_SPI_MASK (1<< 4) +#define TAURUS_SPI_CS_PIN AT91_PIN_PA3
- /* load address */ #define CONFIG_SYS_LOAD_ADDR 0x22000000
Thanks!
bye, Heiko
Heiko Schocher
Jagan Teki
