[U-Boot] [UBOOT PATCH v2] net: zynq_gem: convert to use livetree
This patch updates the zynq gem driver to support livetree.
Signed-off-by: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com Signed-off-by: Vipul Kumar vipul.kumar@xilinx.com --- Changes for v2: - Note that this patch is based on below two series. https://patchwork.ozlabs.org/cover/936370/ and https://patchwork.ozlabs.org/cover/936380/ --- drivers/net/zynq_gem.c | 30 ++++++++++++++---------------- 1 file changed, 14 insertions(+), 16 deletions(-)
diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c index 0f56cda..68d1c2f 100644 --- a/drivers/net/zynq_gem.c +++ b/drivers/net/zynq_gem.c @@ -178,7 +178,7 @@ struct zynq_gem_priv { struct zynq_gem_regs *iobase; phy_interface_t interface; struct phy_device *phydev; - int phy_of_handle; + ofnode phy_of_node; struct mii_dev *bus; struct clk clk; u32 max_speed; @@ -348,9 +348,7 @@ static int zynq_phy_init(struct udevice *dev) }
priv->phydev->advertising = priv->phydev->supported; - - if (priv->phy_of_handle > 0) - priv->phydev->node = offset_to_ofnode(priv->phy_of_handle); + priv->phydev->node = priv->phy_of_node;
return phy_config(priv->phydev); } @@ -693,21 +691,23 @@ static int zynq_gem_ofdata_to_platdata(struct udevice *dev) { struct eth_pdata *pdata = dev_get_platdata(dev); struct zynq_gem_priv *priv = dev_get_priv(dev); - int node = dev_of_offset(dev); + struct ofnode_phandle_args phandle_args; const char *phy_mode;
- pdata->iobase = (phys_addr_t)devfdt_get_addr(dev); + pdata->iobase = (phys_addr_t)dev_read_addr(dev); priv->iobase = (struct zynq_gem_regs *)pdata->iobase; /* Hardcode for now */ priv->phyaddr = -1;
- priv->phy_of_handle = fdtdec_lookup_phandle(gd->fdt_blob, node, - "phy-handle"); - if (priv->phy_of_handle > 0) - priv->phyaddr = fdtdec_get_int(gd->fdt_blob, - priv->phy_of_handle, "reg", -1); + if (dev_read_phandle_with_args(dev, "phy-handle", NULL, 0, 0, + &phandle_args)) { + debug("phy-handle does not exist %s\n", dev->name); + return -ENOENT; + }
- phy_mode = fdt_getprop(gd->fdt_blob, node, "phy-mode", NULL); + priv->phyaddr = ofnode_read_u32_default(phandle_args.node, "reg", -1); + priv->phy_of_node = phandle_args.node; + phy_mode = dev_read_prop(dev, "phy-mode", NULL); if (phy_mode) pdata->phy_interface = phy_get_interface_by_name(phy_mode); if (pdata->phy_interface == -1) { @@ -716,10 +716,8 @@ static int zynq_gem_ofdata_to_platdata(struct udevice *dev) } priv->interface = pdata->phy_interface;
- priv->max_speed = fdtdec_get_uint(gd->fdt_blob, priv->phy_of_handle, - "max-speed", SPEED_1000); - priv->int_pcs = fdtdec_get_bool(gd->fdt_blob, node, - "is-internal-pcspma"); + priv->max_speed = dev_read_u32_default(dev, "max-speed", SPEED_1000); + priv->int_pcs = dev_read_bool(dev, "is-internal-pcspma");
printf("ZYNQ GEM: %lx, phyaddr %x, interface %s\n", (ulong)priv->iobase, priv->phyaddr, phy_string_for_interface(priv->interface));
Hi Joe/Michal,
Can you please take it up if it is fine.
Thanks, Siva
-----Original Message----- From: Siva Durga Prasad Paladugu [mailto:siva.durga.paladugu@xilinx.com] Sent: Monday, July 16, 2018 6:26 PM To: u-boot@lists.denx.de Cc: Michal Simek michals@xilinx.com; joe.hershberger@ni.com; grygorii.strashko@ti.com; Siva Durga Prasad Paladugu sivadur@xilinx.com; Vipul Kumar vipulk@xilinx.com Subject: [UBOOT PATCH v2] net: zynq_gem: convert to use livetree
Changes for v2:
- ofnode phy_of_node; struct mii_dev *bus; struct clk clk; u32 max_speed;
phy_of_handle);
- struct ofnode_phandle_args phandle_args; const char *phy_mode;
- pdata->iobase = (phys_addr_t)dev_read_addr(dev); priv->iobase = (struct zynq_gem_regs *)pdata->iobase; /* Hardcode for now */ priv->phyaddr = -1;
"phy-handle");
- if (dev_read_phandle_with_args(dev, "phy-handle", NULL, 0, 0,
&phandle_args)) {
return -ENOENT;
- priv->phyaddr = ofnode_read_u32_default(phandle_args.node,
"reg", -1);
- priv->phy_of_node = phandle_args.node;
- phy_mode = dev_read_prop(dev, "phy-mode", NULL); if (phy_mode) pdata->phy_interface =
phy_of_handle,
- priv->max_speed = dev_read_u32_default(dev, "max-speed",
SPEED_1000);
iobase,
-- 2.7.4
On Tue, Jul 24, 2018 at 3:58 AM, Michal Simek michal.simek@xilinx.com wrote:
On 23.7.2018 07:48, Siva Durga Prasad Paladugu wrote:
Hi Joe/Michal,
joe: Can you please take it via your tree? There are some patches before this.
Sure. The second series that you depend on has build issues, so this will be backed up behind that.
Cheers, -Joe
Hi Joe/Michal,
ok. We will wait then.
Thanks, Michal
On Mon, Jul 16, 2018 at 7:55 AM, Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com wrote:
Hi Siva,
https://patchwork.ozlabs.org/patch/944372/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
Joe Hershberger
Michal Simek
