Re: [U-Boot] U-boot nand bug, read.part should fail
[ I started this conversation off-list before I joined the list. ]
The idea is to add .part as a valid command suffix to nand read/write so it would match nand erase.part. The code to implement it makes "nand read.part" act identically to "nand read".
On Feb 7, 2013, at 4:59 PM, Scott Wood scottwood@freescale.com wrote:
In fact, I think erase should be modified to deprecate erase.part and make erase work like read does now.
Erase used to work like read does. I deliberately changed it so that typos (e.g. "nand erase $partition $fliesize") don't end up erasing your entire partition or chip.
Ah, then maybe we should add .part to nand read for consistency? I'm ok either way.
That would get messy because it would be orthogonal to other suffixes. Reading too much is not as harmful as
Nothing would change other than do_nand() would treat "nand read" and "nand read.part" identically.
erasing too much. Writing too much can be bad, though. Perhaps we should just eliminate the ability to do reads/writes without explicit size (it already has problems with the size needing adjustment due to bad blocks).
I liked that I didn't have to specify the size. Converting from numbers to partition names led me to find the bug in the "nand read" code. Using partition names makes it much easier to work with u-boot since I don't have to count 0s every time I type an address or size.
I'm ok either way.
The only reason to add .part/.chip is if the unsuffixed versions no longer operate on entire partitions/chips.
It's fine until you get a bad block in the partition, and you end up accessing the first block of the next partition (or getting "Attempt to read/write outside the flash area" if it's the last partition).
Of course, fixing partition/chip accesses to account for this when determining size would be even better. :-)
-Scott
Something like this?
diff --git a/common/cmd_nand.c b/common/cmd_nand.c --- a/common/cmd_nand.c +++ b/common/cmd_nand.c @@ -621,60 +621,78 @@ int do_nand(cmd_tbl_t * cmdtp, int flag,
nand = &nand_info[dev];
s = strchr(cmd, '.');
if (s && !strcmp(s, ".raw")) { raw = 1;
if (arg_off(argv[3], &dev, &off, &size)) return 1;
if (argc > 4 && !str2long(argv[4], &pagecount)) { printf("'%s' is not a number\n", argv[4]); return 1; }
if (pagecount * nand->writesize > size) { puts("Size exceeds partition or device limit\n"); return -1; }
rwsize = pagecount * (nand->writesize + nand->oobsize); } else { if (arg_off_size(argc - 3, argv + 3, &dev, &off, &size) != 0) return 1;
rwsize = size; }
+ /* If no size was given, it has been calculated for us as + * the remainder of the chip or partition from offset. Adjust + * down for bad blocks, if necessary. + */ + if (argc < 4) { + nand_info_t *nand = &nand_info[dev]; + int maxsize = rwsize; + int offset = off; + for (; offset < maxsize; offset += nand->erasesize) + if (nand_block_isbad(nand, offset)) + rwsize -= nand->erasesize; + + if (rwsize != maxsize) + printf("\nsize adjusted to %d (%d bad blocks)\n", + rwsize, + (maxsize - rwsize) / nand->erasesize); + } + if (!s || !strcmp(s, ".jffs2") || !strcmp(s, ".e") || !strcmp(s, ".i") || !strcmp(s, ".part")) { if (read) ret = nand_read_skip_bad(nand, off, &rwsize, (u_char *)addr); else ret = nand_write_skip_bad(nand, off, &rwsize, (u_char *)addr, 0); #ifdef CONFIG_CMD_NAND_TRIMFFS } else if (!strcmp(s, ".trimffs")) { if (read) { printf("Unknown nand command suffix '%s'\n", s); return 1; } ret = nand_write_skip_bad(nand, off, &rwsize, (u_char *)addr, WITH_DROP_FFS); #endif #ifdef CONFIG_CMD_NAND_YAFFS } else if (!strcmp(s, ".yaffs")) { if (read) { printf("Unknown nand command suffix '%s'.\n", s); return 1; } ret = nand_write_skip_bad(nand, off, &rwsize, (u_char *)addr, WITH_INLINE_OOB); #endif } else if (!strcmp(s, ".oob")) { /* out-of-band data */
Eh, I shouldn't post code that quickly… Try this:
diff --git a/common/cmd_nand.c b/common/cmd_nand.c --- a/common/cmd_nand.c +++ b/common/cmd_nand.c @@ -621,60 +621,80 @@ int do_nand(cmd_tbl_t * cmdtp, int flag,
rwsize = size; }
+ /* If no size was given, it has been calculated for us as + * the remainder of the chip or partition from offset. Adjust + * down for bad blocks, if necessary. + */ + if (argc < 5) { + nand_info_t *nand = &nand_info[dev]; + int size = rwsize; + int maxoffset = off + rwsize; + int offset = off; + int badblocks = 0; + for (offset = off; offset < maxoffset; offset += nand->erasesize) + if (nand_block_isbad(nand, offset)) + badblocks++; + if (badblocks) { + rwsize -= badblocks * nand->erasesize; + printf("size adjusted to 0x%llx (%d bad blocks)\n", + (unsigned long long)rwsize, badblocks); + } + } + if (!s || !strcmp(s, ".jffs2") || !strcmp(s, ".e") || !strcmp(s, ".i") || !strcmp(s, ".part")) { if (read) ret = nand_read_skip_bad(nand, off, &rwsize, (u_char *)addr); else ret = nand_write_skip_bad(nand, off, &rwsize, (u_char *)addr, 0); #ifdef CONFIG_CMD_NAND_TRIMFFS } else if (!strcmp(s, ".trimffs")) { if (read) { printf("Unknown nand command suffix '%s'\n", s); return 1; } ret = nand_write_skip_bad(nand, off, &rwsize, (u_char *)addr, WITH_DROP_FFS); #endif #ifdef CONFIG_CMD_NAND_YAFFS } else if (!strcmp(s, ".yaffs")) { if (read) { printf("Unknown nand command suffix '%s'.\n", s); return 1; } ret = nand_write_skip_bad(nand, off, &rwsize, (u_char *)addr, WITH_INLINE_OOB); #endif } else if (!strcmp(s, ".oob")) { /* out-of-band data */
nand = &nand_info[dev]; s = strchr(cmd, '.'); if (s && !strcmp(s, ".raw")) { raw = 1; if (arg_off(argv[3], &dev, &off, &size)) return 1; if (argc > 4 && !str2long(argv[4], &pagecount))
rwsize = size; }
us as
offset. Adjust
This should go inside the "not raw" path of the previous "if" statement.
Please use tabs to indent.
if (argc < 5) {
We already have "nand" in this context.
int size = rwsize;
We already have "size" -- and you don't even seem to use it.
int offset = off;
Offsets do not fit in "int". Use loff_t.
int badblocks = 0;
badblocks++;
Braces around multi-line "if" bodies (even if a single statement).
Please leave a blank line after the variable declaration block.
Maybe move this to its own function (having both "offset" and "off" is unpleasant, plus this function is way too big already).
We need this adjustment to be made to erase.part/chip as well.
-Scott
On Feb 8, 2013, at 6:34 PM, Scott Wood scottwood@freescale.com wrote:
On 02/08/2013 10:44:30 AM, Harvey Chapman wrote: This should go inside the "not raw" path of the previous "if" statement. Please use tabs to indent. We already have "nand" in this context. We already have "size" -- and you don't even seem to use it. Offsets do not fit in "int". Use loff_t. Braces around multi-line "if" bodies (even if a single statement). Please leave a blank line after the variable declaration block. Maybe move this to its own function (having both "offset" and "off" is unpleasant, plus this function is way too big already). We need this adjustment to be made to erase.part/chip as well.
Thanks for the feedback. This was just a proof of concept. I'll make the changes and submit the patch more formally.
Harvey Chapman
Scott Wood
