[U-Boot] [PATCH v2 2/6] efi_loader: Fix memory map size check to avoid out-of-bounds access
Do not overwrite the specified size of the provided buffer without having checked it is sufficient.
If the buffer is to small, memory_map_size is updated to indicate the required size, and an error code is returned.
Signed-off-by: Stefan Brüns stefan.bruens@rwth-aachen.de --- lib/efi_loader/efi_memory.c | 8 +++++--- 1 file changed, 5 insertions(+), 3 deletions(-)
diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index ebe8e94..72a5870 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -342,6 +342,11 @@ efi_status_t efi_get_memory_map(unsigned long *memory_map_size,
map_size = map_entries * sizeof(struct efi_mem_desc);
+ if (*memory_map_size < map_size) { + *memory_map_size = map_size; + return EFI_BUFFER_TOO_SMALL; + } + *memory_map_size = map_size;
if (descriptor_size) @@ -350,9 +355,6 @@ efi_status_t efi_get_memory_map(unsigned long *memory_map_size, if (descriptor_version) *descriptor_version = EFI_MEMORY_DESCRIPTOR_VERSION;
- if (*memory_map_size < map_size) - return EFI_BUFFER_TOO_SMALL; - /* Copy list into array */ if (memory_map) { /* Return the list in ascending order */
- if (*memory_map_size < map_size) {
IIRC I had issues with that approach in the past with payloads that wanted to determine the descriptor size regardless of the error output. I liked your previous version better - it really just needed a description overhaul :)
Alex
Alexander Graf
Stefan Brüns
