[U-Boot] [PATCH] arm: fix a double-definition error of _start symbol
The symbol "_start" is defined twice in arch/arm/lib/vectors.S: around line 48 and line 54.
If CONFIG_SYS_DV_NOR_BOOT_CFG is defined (as on calimain board), build fails:
arch/arm/lib/vectors.S: Assembler messages: arch/arm/lib/vectors.S:54: Error: symbol `_start' is already defined make[1]: *** [arch/arm/lib/vectors.o] Error 1 make: *** [arch/arm/lib] Error 2
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Albert ARIBAUD albert.u.boot@aribaud.net --- arch/arm/lib/vectors.S | 2 -- 1 file changed, 2 deletions(-)
diff --git a/arch/arm/lib/vectors.S b/arch/arm/lib/vectors.S index fad00da..493f337 100644 --- a/arch/arm/lib/vectors.S +++ b/arch/arm/lib/vectors.S @@ -45,8 +45,6 @@ ************************************************************************* */
-_start: - #ifdef CONFIG_SYS_DV_NOR_BOOT_CFG .word CONFIG_SYS_DV_NOR_BOOT_CFG #endif
Hi Masahiro,
On Tue, 27 May 2014 11:16:29 +0900, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
Apart from the shame of having written this double definition myself and missed it entirely, I am surprised because this error (obviously) does not occur on my setup. Which toolchain are you using?
Anyway:
-_start:
Applied to u-boot-arm/master, thanks!
Amicalement,
Hi Albert,
It is not because of the toolchain difference.
You should understand the problem I mentioned in the other mail.
In your tree, CONFIG_SYS_DV_NOR_BOOT_CFG is never defined in arch/arm/lib/vectors.S
So, arch/arm/lib/vectors.S in your source tree in always like this:
_start: _start: ldr pc, _reset ldr pc, _undefined_instruction ldr pc, _software_interrupt ldr pc, _prefetch_abort ldr pc, _data_abort ldr pc, _not_used ldr pc, _irq ldr pc, _fiq
It is true that "_start" symbol appears twice, but both are pointing to the same address.
That's why you never see the error message. (I mean, this problem is hidden behind another problem.)
You should fix the first problem. http://patchwork.ozlabs.org/patch/352484/
And then, the code should be like follows where CONFIG_SYS_DV_NOR_BOOT_CFG is defined.
_start: .word CONFIG_SYS_DV_NOR_BOOT_CFG _start: ldr pc, _reset ldr pc, _undefined_instruction ldr pc, _software_interrupt ldr pc, _prefetch_abort ldr pc, _data_abort ldr pc, _not_used ldr pc, _irq ldr pc, _fiq
In this case, two "_start" symbols point the different address. You will see the error message like this:
No.
Please apply http://patchwork.ozlabs.org/patch/352484/ http://patchwork.ozlabs.org/patch/352672/
in this order to keep the commit-description sane.
Best Regards Masahiro Yamada
Hi Masahiro,
On Mon, 09 Jun 2014 18:44:08 +0900, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
Hi Albert,
Thanks for the clarification. However:
No.
See my comment on the first patch commit message.
Besides, the second patch is a fix of its own accord, regardless to the fact that it was hidden by another bug, so I'll keep it in as-is.
(incidentally, patches which do have ordering constraints should be posted as a series.)
Amicalement,
Albert ARIBAUD
Masahiro Yamada
