[PULL] u-boot-sh/next network cleanup part 1
This is part 1 of big network cleanup / DM conversion. The dc2114x/rtl8139/pcnet/tulip PCI adapter drivers received checkpatch cleanups in preparation for DM conversion. The smc911x is converted to DM completely. The dwc_eth_qos cache fixes are applied.
I hope this is a one-off thing where I am picking my own network patches (sigh :-( ) and Joe comes back soon.
The following changes since commit 78021b63373de32335bd204471d6cb7c7e18bc52:
Merge tag 'efi-2020-07-rc2' of https://gitlab.denx.de/u-boot/custodians/u-boot-efi (2020-04-30 15:11:06 -0400)
git://git.denx.de/u-boot-sh.git next
for you to fetch changes up to 8148693b988fb36463dbc12cef4b7947acae9846:
net: smc911x: Add DM support (2020-05-01 15:37:48 +0200)
---------------------------------------------------------------- Marek Vasut (48): net: Fix warning when including netdev.h on DM systems net: pcnet: Remove CONFIG_PCNET_79C97x net: tulip: Remove CONFIG_TULIP_* net: pcnet: Replace mips-specific accessors net: pcnet: Switch to PCI memory access net: dc2114x: Clean up init code net: dc2114x: Clean up dc21x4x_send() net: dc2114x: Clean up dc21x4x_recv() net: dc2114x: Clean up dc21x4x_halt() net: dc2114x: Clean up send_setup_frame() net: dc2114x: Clean up SROM operations net: dc2114x: Clean up remaining driver code net: dc2114x: Clean up DE4X5 macros net: dc2114x: Clean up INL/OUTL functions net: dc2114x: Reorganize driver net: dc2114x: Switch DEBUG_SROM{,2} to debug_cond() net: dwc_eth_qos: Fully rewrite RX descriptor field 3 net: dwc_eth_qos: Correctly wrap around TX descriptor tail pointer net: dwc_eth_qos: Flush the RX descriptors on init net: dwc_eth_qos: Invalidate RX descriptor before reading net: dwc_eth_qos: Invalidate RX packet DMA buffer net: dwc_eth_qos: Prevent DMA from writing updated RX DMA descriptor net: rtl8139: Register macro cleanup net: rtl8139: Rework eeprom_delay() macro net: rtl8139: Minor cleanup of read_eeprom() net: rtl8139: Consistently use rtl8139_rx_config net: rtl8139: Minor cleanup of set_rx_mode() net: rtl8139: Minor cleanup of rtl_reset() net: rtl8139: Minor cleanup of rtl_transmit() net: rtl8139: Minor cleanup of rtl_poll() net: rtl8139: Minor cleanup of rtl_disable() net: rtl8139: Factor out hardware reset net: rtl8139: Finish cleanup net: rtl8139: Move functions around net: rtl8139: Fill in SPDX tag net: smc911x: Remove pkt_data_{push,pull} net: smc911x: Replace malloc()+memset() with calloc() net: smc911x: Rename smc911x_rx() to smc911x_recv() net: smc911x: Invert the logic in smc911x_miiphy_{read,write}() net: smc911x: Fix potential memleak() in init fail path net: smc911x: Pull MII registration into separate function net: smc911x: Inline all functions from header file net: smc911x: Drop weak alias from 32bit accessors net: smc911x: Convert IO accessors to {read,write}{w,l}() net: smc911x: Pass around driver private data net: smc911x: Clean up the status handling in smc911x_recv() net: smc911x: Split non-DM specific bits from common code net: smc911x: Add DM support
README | 2 - drivers/net/Kconfig | 2 + drivers/net/dc2114x.c | 965 +++++++++++++++++++++++++++++++++++++++++++----------------------------------------------------- drivers/net/dwc_eth_qos.c | 18 +- drivers/net/pcnet.c | 18 +- drivers/net/rtl8139.c | 742 +++++++++++++++++++++++++++++++++++++++----------------------------------- drivers/net/smc911x.c | 560 ++++++++++++++++++++++++++++++++++++++++++++------------ drivers/net/smc911x.h | 157 ---------------- examples/standalone/Makefile | 5 +- examples/standalone/smc911x_eeprom.c | 150 +++++++++++++++ include/configs/malta.h | 1 - include/netdev.h | 1 + scripts/config_whitelist.txt | 5 - 13 files changed, 1447 insertions(+), 1179 deletions(-)
Don't forget to pick [PATCH] net: pcnet: fix I/O primitives for memory access
