[PATCH] xilinx: zynqmp: Add support for saving sha3 key to different address
By default 48B sha3 hash value is written to srcaddr which is not the best solution in case of that you want to use data for other operations. That's why add key_addr optional parameters which enables to write 48B sha3 hash value to specified address.
Signed-off-by: Michal Simek michal.simek@xilinx.com Tested-by: Ashok Reddy Soma ashok.reddy.soma@xilinx.com ---
Based on https://lists.denx.de/pipermail/u-boot/2020-October/429294.html series. --- board/xilinx/zynqmp/cmds.c | 25 ++++++++++++++++++------- 1 file changed, 18 insertions(+), 7 deletions(-)
diff --git a/board/xilinx/zynqmp/cmds.c b/board/xilinx/zynqmp/cmds.c index caddb64b820e..8430a23eb32c 100644 --- a/board/xilinx/zynqmp/cmds.c +++ b/board/xilinx/zynqmp/cmds.c @@ -285,11 +285,11 @@ static int do_zynqmp_rsa(cmd_tbl_t *cmdtp, int flag, int argc, static int do_zynqmp_sha3(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - u64 srcaddr; + u64 srcaddr, hashaddr; u32 srclen, ret_payload[PAYLOAD_ARG_CNT]; int ret;
- if (argc != cmdtp->maxargs) + if (argc > cmdtp->maxargs || argc < (cmdtp->maxargs - 1)) return CMD_RET_USAGE;
if (zynqmp_firmware_version() <= PMUFW_V1_0) { @@ -302,6 +302,15 @@ static int do_zynqmp_sha3(cmd_tbl_t *cmdtp, int flag, srcaddr = simple_strtoul(argv[2], NULL, 16); srclen = simple_strtoul(argv[3], NULL, 16);
+ if (argc == 5) { + hashaddr = simple_strtoul(argv[4], NULL, 16); + flush_dcache_range(hashaddr, + hashaddr + roundup(ZYNQMP_SHA3_SIZE, + ARCH_DMA_MINALIGN)); + } else { + hashaddr = srcaddr; + } + /* Check srcaddr or srclen != 0 */ if (!srcaddr || !srclen) { puts("ERR: srcaddr & srclen should not be 0\n"); @@ -328,9 +337,10 @@ static int do_zynqmp_sha3(cmd_tbl_t *cmdtp, int flag, return CMD_RET_FAILURE; }
- ret = xilinx_pm_request(PM_SECURE_SHA, upper_32_bits((ulong)srcaddr), - lower_32_bits((ulong)srcaddr), ZYNQMP_SHA3_SIZE, - ZYNQMP_SHA3_FINAL, ret_payload); + ret = xilinx_pm_request(PM_SECURE_SHA, upper_32_bits((ulong)hashaddr), + lower_32_bits((ulong)hashaddr), + ZYNQMP_SHA3_SIZE, ZYNQMP_SHA3_FINAL, + ret_payload); if (ret || ret_payload[1]) { printf("Failed: SHA FINAL status:0x%x, errcode:0x%x\n", ret, ret_payload[1]); @@ -347,7 +357,7 @@ static struct cmd_tbl cmd_zynqmp_sub[] = { U_BOOT_CMD_MKENT(mmio_write, 5, 0, do_zynqmp_mmio_write, "", ""), U_BOOT_CMD_MKENT(aes, 9, 0, do_zynqmp_aes, "", ""), U_BOOT_CMD_MKENT(rsa, 7, 0, do_zynqmp_rsa, "", ""), - U_BOOT_CMD_MKENT(sha3, 4, 0, do_zynqmp_sha3, "", ""), + U_BOOT_CMD_MKENT(sha3, 5, 0, do_zynqmp_sha3, "", ""), #ifdef CONFIG_DEFINE_TCM_OCM_MMAP U_BOOT_CMD_MKENT(tcminit, 3, 0, do_zynqmp_tcm_init, "", ""), #endif @@ -415,9 +425,10 @@ static char zynqmp_help_text[] = " exp : private key exponent for RSA decryption(4096 bits)\n" " public key exponent for RSA encryption(32 bits)\n" " rsaop : 0 for RSA Decryption, 1 for RSA Encryption\n" - "zynqmp sha3 srcaddr srclen\n" + "zynqmp sha3 srcaddr srclen [key_addr]\n" " Generates sha3 hash value for data blob at srcaddr and puts\n" " 48 bytes hash value into srcaddr\n" + " Optional key_addr can be specified for saving sha3 hash value\n" " Note: srcaddr/srclen should not be 0\n" ; #endif
Michal Simek
