[PATCH v2 04/14] board: freescale: ls1046afrwy: Update I2C mux config
Updates the board configuration to enable use of the PCA9547 I2C mux.
Signed-off-by: Stephen Carlson stcarlso@linux.microsoft.com --- board/freescale/ls1046afrwy/ls1046afrwy.c | 27 +------------------ configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046afrwy_tfa_defconfig | 1 + 3 files changed, 3 insertions(+), 26 deletions(-)
diff --git a/board/freescale/ls1046afrwy/ls1046afrwy.c b/board/freescale/ls1046afrwy/ls1046afrwy.c index f1709dcd1c..f1c08a13f7 100644 --- a/board/freescale/ls1046afrwy/ls1046afrwy.c +++ b/board/freescale/ls1046afrwy/ls1046afrwy.c @@ -22,6 +22,7 @@ #include <fsl_esdhc.h> #include <fsl_sec.h> #include <fsl_dspi.h> +#include "../common/i2c_mux.h"
#define LS1046A_PORSR1_REG 0x1EE0000 #define BOOT_SRC_SD 0x20000000 @@ -38,32 +39,6 @@
DECLARE_GLOBAL_DATA_PTR;
-int select_i2c_ch_pca9547(u8 ch, int bus_num) -{ - int ret; - -#if CONFIG_IS_ENABLED(DM_I2C) - struct udevice *dev; - - ret = i2c_get_chip_for_busnum(bus_num, I2C_MUX_PCA_ADDR_PRI, - 1, &dev); - if (ret) { - printf("%s: Cannot find udev for a bus %d\n", __func__, - bus_num); - return ret; - } - ret = dm_i2c_write(dev, 0, &ch, 1); -#else - ret = i2c_write(I2C_MUX_PCA_ADDR_PRI, 0, 1, &ch, 1); -#endif - if (ret) { - puts("PCA: failed to select proper channel\n"); - return ret; - } - - return 0; -} - static inline void demux_select_usb2(void) { u32 val; diff --git a/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig b/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig index 33308aa0e3..4fb54f161a 100644 --- a/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig @@ -61,3 +61,4 @@ CONFIG_USB_ETHER_ASIX88179=y CONFIG_USB_ETHER_RTL8152=y CONFIG_RSA=y CONFIG_NXP_ESBC=y +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1046afrwy_tfa_defconfig b/configs/ls1046afrwy_tfa_defconfig index ea62d7fa7e..6861d22193 100644 --- a/configs/ls1046afrwy_tfa_defconfig +++ b/configs/ls1046afrwy_tfa_defconfig @@ -68,3 +68,4 @@ CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y CONFIG_USB_ETHER_RTL8152=y +CONFIG_FSL_USE_PCA9547_MUX=y
Stephen Carlson
