[U-Boot] socfpga qspi issues on SoCKit devkit
The QSPI NOR interface on the Altera Cyclone V SoCKit devkit (Rev B) appears to be broken in the current release. I've tracked it down to working in the v2016.07 release, but broken in the the v2016.09 release. With the help of git bisect, I tracked down the commit that breaks the QSPI to the following:
commit dac3bf20fb2c9b03476be0d73db620f62ab3cee1 Author: Vignesh R vigneshr@ti.com Date: Wed Jul 6 10:20:55 2016 +0530
spi: cadence_qspi_apb: Support 32 bit AHB address
AHB address can be as long as 32 bit, hence remove the CQSPI_REG_INDIRECTRDSTARTADDR mask. Since AHB address is passed from DT and read as u32 value, it anyway does not make sense to mask upper bits.
Signed-off-by: Vignesh R vigneshr@ti.com Tested-by: Marek Vasut marex@denx.de Acked-by: Marek Vasut marex@denx.de Reviewed-by: Jagan Teki jteki@openedev.com
When I try and read anything from the QSPI on the dac3bf20fb2c9b03476be0d73db620f62ab3cee1 commit I get a "data abort" and the CPU resets. Example output below is from a clean build of U-Boot configured with socfpga_sockit_defconfig:
=> sf probe SF: Detected N25Q1024 with page size 256 Bytes, erase size 64 KiB, total 128 MiB => sf read 0x2000000 0x50000 0x5000 device 0 offset 0x50000, size 0x5000 data abort pc : [<3ff7a9bc>] lr : [<3ff98359>] reloc pc : [<010249fc>] lr : [<01042399>] sp : 3bf4fde8 ip : 3ff7a371 fp : 00000002 r10: 00000000 r9 : 3bf54ee8 r8 : 3bf55530 r7 : 0000270d r6 : 02000000 r5 : 00005000 r4 : 3bf55530 r3 : 00000004 r2 : 00000000 r1 : 02000000 r0 : ffa00000 Flags: nZCv IRQs off FIQs off Mode SVC_32 Resetting CPU ...
When I run the same commands with the previous commit in the git log (fdf02a36c52cb96717b64113775c4251ecd49596) I get the following output:
=> sf probe SF: Detected N25Q1024 with page size 256 Bytes, erase size 64 KiB, total 128 MiB => sf read 0x2000000 0x50000 0x5000 device 0 offset 0x50000, size 0x5000 SF: 20480 bytes @ 0x50000 Read: OK =>
I've done some investigation, and previously the ahbbase was masked so the value 0xFFA0_0000 results in 0x0 when writing the CQSPI_REG_INDIRECTTRIGGER register. I assume the above commit works on some boards, but it appears to break the socfpga arch.
Is there someone that could help investigate or confirm this?
Thanks, Jason
+ Marek
spi: cadence_qspi_apb: Support 32 bit AHB address AHB address can be as long as 32 bit, hence remove the CQSPI_REG_INDIRECTRDSTARTADDR mask. Since AHB address is passed from DT and read as u32 value, it anyway does not make sense to mask upper bits. Signed-off-by: Vignesh R <vigneshr@ti.com> Tested-by: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Jagan Teki <jteki@openedev.com>
I am looking at cyclone5_handbook.pdf [1] and it says indaddrtrig field is 32 bit wide. So, I wonder why masking is needed. If you specify ahbbase as 0xFFA0_0000 in DT(reg property) then the expectation is 0xFFA0_0000 gets written to indaddrtrig reg. It looks like the trigger address is 0x0 and not 0xFFA0_0000, therefore you may have to update reg property in DT to reflect the same.
[1]https://www.altera.com/en_US/pdfs/literature/hb/cyclone-v/cyclone5_handbook....
On 02/20/2017 05:25 AM, Vignesh R wrote:
- Marek
Thanks, +CC Dinh and Ley
- Marek
[1]https://www.altera.com/en_US/pdfs/literature/hb/cyclone-v/cyclone5_ handbook.pdf
I agree, according to the handbook the indaddrtrig register is 32-bits wide, but writing the value 0xFFA0_0000 to indaddrtrig causes the above data abort. It looks like a similar issue has been discussed before: http://lists.denx.de/pipermail/u-boot/2015-August/224649.html
In that proposed patch, it looks like the address to use for the indaddrtrig reg was being separated from the ahbbase and the Altera SoC needed a value of 0x0000_0000. I'm not very familiar with the Cadence device on the Altera SoC, but it looks like it needs a different value than the ahbbase written to the indaddrtrig reg.
I noticed the Cadence QSPI driver in the Linux tree has a separate trigger_address that is loaded from the DT, and the socfpga.dtsi sets the trigger_address to 0x0000_0000.
On 02/20/2017 05:53 PM, Rush, Jason A. wrote:
- Marek
So let's just adopt the Linux bindings and get this fixed. Can you send a patch ? Thanks
btw where did this 0xffa0_0000 come from, Dinh ?
- Marek
[1]https://www.altera.com/en_US/pdfs/literature/hb/cyclone-v/cyclone 5_ handbook.pdf
I'll work on a patch.
Jason
On 02/21/2017 08:02 AM, Rush, Jason A. wrote:
- Marek
0Xffa00000 is the starting address for the QSPI module's data portion.
Dinh
Dinh Nguyen
Rush, Jason A.
Vignesh R
