[U-Boot] [PATCH v2 0/2] Fix DE2 SimpleFB node creation and support LCD SimpleFB
This patchset fixes the DE2 SimpleFB node creation when HDMI is not ready, and adds support for LCD SimpleFB node creation on A64.
The first patch prevents a broken SimpleFB node to be created when HDMI is present but not probed, this is a fix and should to into 2017.11.
The second patch adds support for LCD SimpleFB node creation.
Icenowy Zheng (2): video: sunxi: de2: fix SimpleFB node creation when HDMI not initialized video: sunxi: de2: add support for LCD SimpleFB
drivers/video/sunxi/sunxi_de2.c | 25 ++++++++++++++++++++----- 1 file changed, 20 insertions(+), 5 deletions(-)
When HDMI is not initialized (e.g. no monitor is plugged), the current SimpleFB code will still create a broken SimpleFB node.
Detect whether HDMI is initialized when creating SimpleFB node.
Fixes: be5b96f0e411 ("sunxi: setup simplefb for Allwinner DE2") Signed-off-by: Icenowy Zheng icenowy@aosc.io --- drivers/video/sunxi/sunxi_de2.c | 16 +++++++++++----- 1 file changed, 11 insertions(+), 5 deletions(-)
diff --git a/drivers/video/sunxi/sunxi_de2.c b/drivers/video/sunxi/sunxi_de2.c index e8903400ec..6d6bb2e0c3 100644 --- a/drivers/video/sunxi/sunxi_de2.c +++ b/drivers/video/sunxi/sunxi_de2.c @@ -346,13 +346,19 @@ int sunxi_simplefb_setup(void *blob) "sunxi_dw_hdmi", &hdmi); if (ret) { debug("HDMI not present\n"); - return 0; + } else if (device_active(hdmi)) { + if (mux == 0) + pipeline = "mixer0-lcd0-hdmi"; + else + pipeline = "mixer1-lcd1-hdmi"; + } else { + debug("HDMI present but not probed\n"); }
- if (mux == 0) - pipeline = "mixer0-lcd0-hdmi"; - else - pipeline = "mixer1-lcd1-hdmi"; + if (!pipeline) { + debug("No active display present\n"); + return 0; + }
de2_priv = dev_get_uclass_priv(de2); de2_plat = dev_get_uclass_platdata(de2);
Reviewed-by: Jagan Teki jagan@openedev.com
thanks!
Acked-by: Maxime Ripard maxime.ripard@free-electrons.com
On Thu, Nov 2, 2017 at 5:54 PM, Maxime Ripard maxime.ripard@free-electrons.com wrote:
Applied to u-boot-sunxi/master
thanks!
Add support for setting up SimpleFB for LCD display output in DE2 SimpleFB setup code.
Signed-off-by: Icenowy Zheng icenowy@aosc.io --- Changes in v2: - Use lcd variable. - Extract the HDMI SimpleFB fix to a dedicated patch.
drivers/video/sunxi/sunxi_de2.c | 11 ++++++++++- 1 file changed, 10 insertions(+), 1 deletion(-)
diff --git a/drivers/video/sunxi/sunxi_de2.c b/drivers/video/sunxi/sunxi_de2.c index 6d6bb2e0c3..860187323c 100644 --- a/drivers/video/sunxi/sunxi_de2.c +++ b/drivers/video/sunxi/sunxi_de2.c @@ -319,7 +319,7 @@ U_BOOT_DEVICE(sunxi_de2) = { #if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_VIDEO_DT_SIMPLEFB) int sunxi_simplefb_setup(void *blob) { - struct udevice *de2, *hdmi; + struct udevice *de2, *hdmi, *lcd; struct video_priv *de2_priv; struct video_uc_platdata *de2_plat; int mux; @@ -355,6 +355,15 @@ int sunxi_simplefb_setup(void *blob) debug("HDMI present but not probed\n"); }
+ ret = uclass_find_device_by_name(UCLASS_DISPLAY, + "sunxi_lcd", &lcd); + if (ret) + debug("LCD not present\n"); + else if (device_active(lcd)) + pipeline = "mixer0-lcd0"; + else + debug("LCD present but not probed\n"); + if (!pipeline) { debug("No active display present\n"); return 0;
thanks!
Maxime
Icenowy Zheng
Jagan Teki
Maxime Ripard
