[U-Boot] SD-Card boot from SPI SD-Card
I have a Coldfire MCF5235 Board and I want to boot the uclinux direct from the sd-card connected to the spi-bus. Is that possible ? What do I have to configure ? Any driver to write ?
Regards Wilfried
Hi Wilfried,
It's possible. Nevertheless, i don't know if the driver is already done. As far as i know all drivers developed doesn't make use of the SPI bus. Just in case, i wrote one for my board and it's working. It could be useful to you. if you want to add MMC drivers you must define CONFIG_MMC, CONFIG_CMD_FAT and CONFIG_DOS_PARTITION in your configuration file.
Regards, Ivan Llopard.
2009/10/20 news.gmane.org w.busalski@lancier-monitoring.de:
Regards Wilfried
Ivan Llopard
news.gmane.org
