[PATCH] fs/btrfs: handle data extents, which crosss stripe boundaries, correctly
[BUG] Since btrfs supports single device RAID0 at mkfs time after btrfs-progs v5.14, if we create a single device raid0 btrfs, and created a file crossing stripe boundary:
# mkfs.btrfs -m dup -d raid0 test.img # mount test.img mnt # xfs_io -f -c "pwrite 0 128K" mnt/file # umount mnt
Since btrfs is using 64K as stripe length, above 128K data write is definitely going to cross at least one stripe boundary.
Then u-boot would fail to read above 128K file:
=> host bind 0 /home/adam/test.img => ls host 0 < > 131072 Fri Dec 30 00:18:25 2022 file => load host 0 0 file BTRFS: An error occurred while reading file file Failed to load 'file'
[CAUSE] Unlike tree blocks read, data extent reads doesn't consider cases in which one data extent can cross stripe boundary.
In read_data_extent(), we just call btrfs_map_block() once and read the first mapped range.
And if the first mapped range is smaller than the desired range, it would return error.
But since even single device btrfs can utilize RAID0 profiles, the first mapped range can only be at most 64K for RAID0 profiles, and cause false error.
[FIX] Just like read_whole_eb(), we should call btrfs_map_block() in a loop until we read all data.
Since we're here, also add extra error messages for the following cases:
- btrfs_map_block() failure We already have the error message for it.
- Missing device This should not happen, as we only support single device for now.
- __btrfs_devread() failure
With this bug fixed, btrfs driver of u-boot can properly read the above 128K file, and have the correct content:
=> host bind 0 /home/adam/test.img => ls host 0 < > 131072 Fri Dec 30 00:18:25 2022 file => load host 0 0 file 131072 bytes read in 0 ms => md5sum 0 0x20000 md5 for 00000000 ... 0001ffff ==> d48858312a922db7eb86377f638dbc9f ^^^ Above md5sum also matches.
Reported-by: Sam Winchenbach swichenbach@tethers.com Signed-off-by: Qu Wenruo wqu@suse.com --- fs/btrfs/disk-io.c | 49 +++++++++++++++++++++++++--------------------- 1 file changed, 27 insertions(+), 22 deletions(-)
diff --git a/fs/btrfs/disk-io.c b/fs/btrfs/disk-io.c index 3f0d9f1c113b..7eaa7e949604 100644 --- a/fs/btrfs/disk-io.c +++ b/fs/btrfs/disk-io.c @@ -541,34 +541,39 @@ struct extent_buffer* read_tree_block(struct btrfs_fs_info *fs_info, u64 bytenr, int read_extent_data(struct btrfs_fs_info *fs_info, char *data, u64 logical, u64 *len, int mirror) { - u64 offset = 0; + u64 orig_len = *len; + u64 cur = logical; struct btrfs_multi_bio *multi = NULL; struct btrfs_device *device; int ret = 0; - u64 max_len = *len;
- ret = btrfs_map_block(fs_info, READ, logical, len, &multi, mirror, - NULL); - if (ret) { - fprintf(stderr, "Couldn't map the block %llu\n", - logical + offset); - goto err; - } - device = multi->stripes[0].dev; + while (cur < logical + orig_len) { + u64 cur_len = logical + orig_len - cur;
- if (*len > max_len) - *len = max_len; - if (!device->desc || !device->part) { - ret = -EIO; - goto err; - } - - ret = __btrfs_devread(device->desc, device->part, data, *len, - multi->stripes[0].physical); - if (ret != *len) - ret = -EIO; - else + ret = btrfs_map_block(fs_info, READ, cur, &cur_len, &multi, + mirror, NULL); + if (ret) { + error("Couldn't map the block %llu", cur); + goto err; + } + device = multi->stripes[0].dev; + if (!device->desc || !device->part) { + error("devid %llu is missing", device->devid); + ret = -EIO; + goto err; + } + ret = __btrfs_devread(device->desc, device->part, + data + (cur - logical), cur_len, + multi->stripes[0].physical); + if (ret != cur_len) { + error("read failed on devid %llu physical %llu", + device->devid, multi->stripes[0].physical); + ret = -EIO; + goto err; + } + cur += cur_len; ret = 0; + } err: kfree(multi); return ret;
This breaks btrfs on the HiFive Unmatched.
=> pci enum PCIE-0: Link up (Gen1-x8, Bus0) => nvme scan => load nvme 0:2 0x8c000000 /boot/dtb/sifive/hifive-unmatched-a00.dtb [hangs]
The length returned by btrfs_map_block is clearly bogus:
read_extent_data: cur=615817216, orig_len=16384, cur_len=16384 read_extent_data: btrfs_map_block: cur_len=479944704; ret=0 read_extent_data: ret=0 read_extent_data: cur=615833600, orig_len=4096, cur_len=4096 read_extent_data: btrfs_map_block: cur_len=479928320; ret=0
When I print ce->size in __btrfs_map_block, it is almost always 1073741824, which looks bogus.
On Feb 13 2023, Qu Wenruo wrote:
Can you provide the image of that filesystem?
How do I do that?
Andreas Schwab
Qu Wenruo
Qu Wenruo
