[U-Boot-Users] "smc91111_eeprom.c" build Error
Hi all,
When I got the current source code by git, I run into a build error. The following is the log message: ====================================================== bfin-uclinux-gcc -g -Os -ffixed-P5 -D__KERNEL__ -DTEXT_BASE=0x07FC0000 -I/home/aubrey/main-line-uboot/patch/work/include -fno-builtin -ffreestanding -nostdinc -isystem /home/aubrey/cvs/toolchain-uclinux/lib/gcc/bfin-uclinux/3.4.5/include -pipe -DCONFIG_BLACKFIN -D__blackfin__ -I/home/aubrey/main-line-uboot/patch/work -Wall -Wstrict-prototypes -c -o smc91111_eeprom.o smc91111_eeprom.c smc91111_eeprom.c: In function `smc91111_eeprom': smc91111_eeprom.c:222: error: missing terminating " character smc91111_eeprom.c:223:11: invalid suffix "x" on integer constant smc91111_eeprom.c:223: error: syntax error before "with" smc91111_eeprom.c:223:21: invalid suffix "x" on integer constant smc91111_eeprom.c:223: error: stray '' in program smc91111_eeprom.c:223: error: missing terminating " character smc91111_eeprom.c:232: error: case label not within a switch statement smc91111_eeprom.c:235: error: case label not within a switch statement smc91111_eeprom.c:238: error: case label not within a switch statement smc91111_eeprom.c:241: error: case label not within a switch statement smc91111_eeprom.c:244: error: `default' label not within a switch statement smc91111_eeprom.c: At top level: smc91111_eeprom.c:250: error: syntax error before "return" make[1]: *** [smc91111_eeprom.o] Error 1 make[1]: Leaving directory `/home/aubrey/main-line-uboot/patch/work/examples' make: *** [examples] Error 2 ========================================================
I found in the file "./example/smc9111_eeprom.c", if changed ------------ printf ("Writing MAC register bank %i, reg %02x with %04x\n", reg >> 4, reg & 0xE, value); ------------ to ------------ printf ("Writing MAC register bank %i, reg %02x with %04x\n", reg >> 4, reg & 0xE, value); ------------
The problem is gone away.
Is it a typo?
Regards, Aubrey
Aubrey
